I’m really sorry for stressing you on this… I’m not so good with the shell/bash stuff.
You are supposed to do that inside the /mnt directory, as I explained above…
Okay, given that /dev/sda1 is already mounted, just do this… ![]()
cd /mnt
sudo du -ch . | sort -h
What about:
sudo du /mnt -chd1 | sort -h
as /mnt is already mounted ![]()
[manjaro mnt]# sudo du -ch . | sort -h
4.0K ./flashdrive
8.0K .
8.0K total
[manjaro mnt]# sudo du /mnt -chd1 | sort -h
4.0K /mnt/flashdrive
8.0K /mnt
8.0K total
Let’s try this again… ![]()
cd / && sudo du -chd1 /mnt | sort -h
I think it will be nice to send you all the command in my terminal so far.
~ sudo su - ✔
[manjaro ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda1]
--> mount: [/mnt]
mount: /mnt: /dev/sda1 already mounted on /mnt.
dmesg(1) may have more information after failed mount system call.
[manjaro /]# sudo du / -chd1 --exclude={/dev,/proc,/sys,/run/user}|sort -h
^C
[manjaro /]# sudo du / -chd1 --exclude={/dev,/proc,/sys,/run/user} | sort -h
^C
[manjaro /]# cd /mnt
[manjaro mnt]# sudo du / -chd1 --exclude={/dev,/proc,/sys,/run/user} | sort -h
^C
4.0K ./flashdrive
8.0K .
8.0K total
8.0K /mnt
8.0K total
[manjaro mnt]# ^C
[manjaro mnt]# cd / && sudo du -chd1 /mnt | sort -h
8.0K /mnt
8.0K total
[manjaro /]#
All these are from the terminal on the live USB drive
Whatever you mounted to /mnt, it is not the filesystem, you wanted to look into.
Interrupting a command with ^C
may prevent it from giving you any usefull results.
I did this because i wanted to run another command and since the initial command didn’t return anything
What is the output of… ![]()
lsblk
… and… ![]()
mount | grep sd
[manjaro mnt]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 93M 1 loop
loop1 7:1 0 867.5M 1 loop
loop2 7:2 0 1.9G 1 loop
loop3 7:3 0 921.4M 1 loop
sda 8:0 0 298.1G 0 disk
`-sda1 8:1 0 298.1G 0 part /
sdb 8:16 1 14.6G 0 disk
|-sdb1 8:17 1 3.8G 0 part
`-sdb2 8:18 1 4M 0 part
sr0 11:0 1 1024M 0 rom
[manjaro mnt]# mount | grep sd
/dev/sda1 on / type ext4 (rw,relatime)
That doesn’t make any sense. It means you are in a chroot environment.
Okay, now do this… ![]()
sudo du -chd1 / | sort -h
[manjaro mnt]# sudo du -chd1 / | sort -h
du: cannot access '/proc/3709/task/3709/fd/4': No such file or directory
du: cannot access '/proc/3709/task/3709/fdinfo/4': No such file or directory
du: cannot access '/proc/3709/fd/3': No such file or directory
du: cannot access '/proc/3709/fdinfo/3': No such file or directory
Try this then… ![]()
sudo du -chd1 / --exclude={/dev,/proc,/sys,/run} | sort -h
It doesn’t return anything
You need to wait until it does ![]()
Okay. Thought it’s gonna be a fast stuff.
Is this a LUKS-encrypted drive, by the way? ![]()
It is gona count every single byte on your volume !
This may take some time ![]()
