Hi, So I notice something has been eating up my hard disk space lately. But I didn’t pay attention to it. So yesterday it display that I have 0 space left. Then everything start freezing so I have to shut it down with the power button. This morning I try logging in then it frozes. It just get stucked there. I’ve tried to several times now… it’s still the same.
So I got into tty
Sudo pacman -Syyu
It returns
error: failed to synchronize all database ( invalid url for server)
sudo pacman -Scc
sudo pacman-mirrors -f5
sudo pacman -Syyu
I got an error after the last command
error: failed to synchronize all databases (invalid url for server)
you did the 3 commands i posted ?
please post
pacman-mirrors -G
and
use the three backticks / preformatted text and paste it inside this
I ran the second command but there is no way to get that pasted here
use
inxi --admin --verbosity=7 --filter --no-host --width > /tmp/inxioutput.txt
this will create a file inxioutput.txt in the temporary folder.
open /tmp/inxioutput.txt with an editor and from there you can copy the text to here. you don’t need to delet this txt-file because everything in /tmp is deleted with shutting down / rebooting your computer next time.
Timijah:
This is the normal behavior when the root filesystem is full.
Boot up from the live USB/DVD/CD, open up a terminal window and issue the following commands…
sudo su -
manjaro-chroot -a
paccache -rvk0
This will clean out your package cache and free up some disk space. After that you can try safely rebooting…
exit
systemctl reboot
Make sure you remove the live USB/DVD/CD in time, and see whether you can now log in.
Hi this is the output
Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b6384f6e-45c0-4829-94ff-86f993a1fb2a rw quiet
udev.log_priority=3
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E5530 non-vPro v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0VP63H v: A00 serial: <superuser required> BIOS: Dell
v: A18 date: 01/04/2017
ID-1: BAT0 charge: 35.5 Wh (100.0%) condition: 35.5/48.8 Wh (72.7%)
volts: 12.4 min: 11.1 model: Samsung SDI DELL 5CGM4A7 type: Li-ion
serial: <filter> status: full
RAM: total: 11.59 GiB used: 542.6 MiB (4.6%)
Info: model: Intel Core i3-2348M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1173 high: 2300 min/max: 800/2300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2300 2: 800 3: 797 4: 797
bogomips: 18349
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: DP-1, DP-2,
DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0116 class-ID: 0300
Device-2: Microdia Dell Integrated HD Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 0c45:643f class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: crocus gpu: i915 tty: 170x48
Monitor-1: LVDS-1 model: Seiko Epson 0x5441 built: 2011 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.1.26-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: 1: pipewire-pulse
status: off 2: wireplumber status: off 3: pipewire-alsa type: plugin
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF: wlp2s0 state: dormant mac: <filter>
Device-2: Broadcom NetXtreme BCM5761 Gigabit Ethernet PCIe vendor: Dell
driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A
bus-ID: 0c:00.0 chip-ID: 14e4:1681 class-ID: 0200
IF: enp12s0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 312.7 GiB used: 291.13 GiB (93.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST320LT007-9ZV142
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: DEM1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.61 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7700H rev: 1.V0
dev-links: cdrom
ID-1: / raw-size: 298.09 GiB size: 292.35 GiB (98.07%)
used: 278.17 GiB (95.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: b6384f6e-45c0-4829-94ff-86f993a1fb2a
ID-2: /mnt/flashdrive raw-size: 14.6 GiB size: 14.6 GiB (100.00%)
used: 12.96 GiB (88.7%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 361E95E81E95A183
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.5:4 info: Microdia Dell Integrated HD Webcam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 51.0 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 130 Uptime: 14m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1306 libs: 339 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash (login)
v: 5.1.16 running-in: tty 3 inxi: 3.3.26
Apologies for getting back to you late.
Olli
29 May 2023 16:23
13
all your drives are almost full loaded. drive 1 is at 95% , drive 2 is at 88%.
you don’t have any space left and you should solve this first.
as long as you’re running on empty with your free disk space you’ll run in trouble anyways. probably this might be the cause but nevertheless until you fixed it you’ll be in trouble.
How can I delete my files since I can’t login? Knowing the right files to delete from the terminal will be really hard
So I need to create a bootable Manjaro USB right
Well, most people keep one handy at all time, even if only for repairing your installed system. So yes, you have to create a live USB/DVD/CD, or have someone do it for you.
Thank you. I will do that.
There’s usually one or two causes of a full root partition. Either there’s too many Timehift snapshots, because it hasn’t been configured properly, or too many app tar files in paccache. Have a look first at at:
sudo du / -chd1 --exclude={/dev,/proc,/sys,/run/user}|sort -h
Apart from /usr which is should be the largest directory of several GBs, any other directories listed of a similar or larger size like /var , might need investigating. In that case look at:
du -ch /var/cache/pacman/pkg/*|sort -h
I would suggest if the total is more than 4 GB it needs pruning.
