So installed Manjaro last week and just noticed that I don’t have a swap partition setup. So I did it by following a Manjaro wiki article on the same and it worked! I think…
$ swapon --show
NAME TYPE SIZE USED PRIO
/dev/nvme0n1p6 partition 9.8G 1.1G -2
But now when I click on hibernate my laptop screen goes black and when I try to wake it up by pressing a key on the keyboard it shows this weird static thing and just shuts off. However, when I power it back on all my stuff is still there!
I also followed some tutorial which told me to:
GRUB_CMDLINE_LINUX="resume=UUID={partition-UUID}"
in/etc/default/grub
- Adding
resume
to myHOOKS
in/etc/mkinitcpio.conf
. So it’sHOOKS="base udev resume autodetect modconf block keyboard keymap filesystems fsck"
now. - And then running
sudo mkinitcpio -P && sudo update-grub
Is there anyway to get it working properly?
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fafd7abd-d23a-4df3-afbb-a8f76cdf2c7f rw
resume=UUID=f49cbfea-93dd-42ec-a75a-3418f0929411 quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DA_X512DA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X512DA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X512DA.316 date: 02/02/2021
ID-1: BAT0 charge: 28.3 Wh (95.3%) condition: 29.7/37.1 Wh (79.9%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 764
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
RAM: total: 5.81 GiB used: 2.72 GiB (46.9%)
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 33551
Speed: 1221 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1221 2: 1219 3: 1221 4: 1221 5: 1282 6: 1395 7: 1399 8: 1395
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:5 chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.52-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.32 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 3-2.1:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 34.77 GiB (7.3%)
model: PC SN520 SDAPNUW-512G-1102 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20180000 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%)
used: 33.64 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: Manjaro uuid: fafd7abd-d23a-4df3-afbb-a8f76cdf2c7f
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 27.8 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 2E61-DF92
ID-1: swap-1 type: partition size: 9.77 GiB used: 1.11 GiB (11.3%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: Swap
uuid: f49cbfea-93dd-42ec-a75a-3418f0929411
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 221.93 GiB fs: ntfs label: Windows
uuid: C652638E52638253
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 850 MiB fs: ntfs label: RECOVERY
uuid: A40E56010E55CD44
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.1:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 3-2.2:5 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-3: 3-2.3:6 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0903 class-ID: 0000
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 66.2 C mobo: N/A gpu: amdgpu temp: 66.0 C
Fan Speeds (RPM): cpu: 3200
Processes: 251 Uptime: 1h 30m wakeups: 23 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1302
lib: 362 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
