I do have an Laptop (ASUS N76vz) and an external Screen (BENQ 24).
I’ve worked a bit at my nvidia config. After rebooting the PC, the Laptop-Screen-Resolutions are way to low. The highest resolution I could choose is 950x540:
AND, the screens are always arranged above each other after reboot… even if I put the Laptop-Screen at the right side of the BENQ 24, and save that changes. On next boot, position of Laptop-Screen is again as shown in the image.
How can I fix that?
BTW: If I try to run nvidia-settings, I always got this message:
Ok, figured out, how to add an needed resolution to xorg:
If you can only choose lower resolutions in your KDE settings, you can add them like this:
xrandr
// Might output something like that:
Screen 0: minimum 8 x 8, current 2880 x 1080, maximum 32767 x 32767
LVDS1 connected 960x540+1920+0 (normal left inverted right x axis y axis) 380mm x 210mm
960x540 59.82*
864x486 60.00 59.92 59.57
640x480 59.94
VGA1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
1920x1080 60.00*+
1680x1050 59.95
1600x900 60.00
1280x1024 60.02
1280x800 59.81
1280x720 60.00
1024x768 60.00
800x600 60.32
640x480 59.94
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Our LVDS1 (Laptop-Screen) is missing higher resolutions. So we add the now:
