Freues neues manjarouser,
Will für mein älteren Nachbar sein laptop einrichten ,
Manjaro cinammon community edition wurde instaliert , kommt mir vor das vivaldi browser etwas lagsamer seiten lädt , gibts vieleicht schnelleren browser und rentnerfreudlich hier Daten zum laptop
[user@user-satellitel350 ~]$ lsb_release -sirc
ManjaroLinux 23.1.1 Vulcan
[user@user-satellitel350 ~]$ inxi -v7azy
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=92c180e5-63f2-4ced-92fa-9f617c75ab19 rw quiet apparmor=1
security=apparmor resume=UUID=8d750683-cede-448f-a396-2f6258105a0f
udev.log_priority=3
Desktop: Cinnamon v: 6.0.2 tk: GTK v: 3.24.39 vt: 7 dm: LightDM v: 1.32.0
Type: Other-vm? System: TOSHIBA product: Satellite L350 v: PSLD0E-00H00YGR
serial: <superuser required>
Mobo: Intel model: N/A serial: <superuser required> BIOS: INSYDE v: 1.30
date: 03/19/2008
ID-1: BAT0 charge: 0% condition: N/A volts: N/A model: PA3533U-1BAS
type: Li-ion serial: <filter> status: not charging
System RAM: total: 2 GiB available: 1.92 GiB used: 1.42 GiB (73.9%)
Info: model: Intel Pentium Dual T2370 bits: 64 type: MCP arch: Core2 Merom
level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
stepping: 0xD (13) microcode: 0xA4
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 798 min/max: 800/1733 scaling: driver: acpi-cpufreq
governor: schedutil cores: 1: 798 2: 798 bogomips: 6918
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
pti rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Mobile GM965/GL960 Integrated Graphics vendor: Toshiba
driver: i915 v: kernel arch: Gen-4 process: Intel 65n built: 2006-07 ports:
active: LVDS-1 empty: SVIDEO-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:2a02
class-ID: 0300
Device-2: Chicony Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 04f2:b070
Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-size: <missing: xdpyinfo>
Monitor-1: LVDS-1 model: AU Optronics 0x6287 built: 2007 res: 1440x900
hz: 60 dpi: 100 gamma: 1.2 size: 367x229mm (14.45x9.02") diag: 433mm (17")
ratio: 16:10 modes: 1440x900
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel 965GM (CL)
device-ID: 8086:2a02 memory: 375 MiB unified: yes
Device-1: Intel 82801H HD Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Toshiba RTL8102E PCI-E driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-2: Realtek RTL8187B Wireless Adapter driver: rtl8187 type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-6:2 chip-ID: 0bda:8197
class-ID: 0000 serial: <filter>
IF: wlp0s29f7u6 state: up mac: <filter>
Local Storage: total: 298.09 GiB used: 11.61 GiB (3.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9320325AS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: MBR
Optical-1: /dev/sr0 vendor: MATSHITA model: DVD-RAM UJ-850S rev: 1.40
dev-links: cdrom
ID-1: / raw-size: 293.89 GiB size: 288.21 GiB (98.07%) used: 10.6 GiB (3.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 92c180e5-63f2-4ced-92fa-9f617c75ab19
ID-1: swap-1 type: partition size: 4.2 GiB used: 1.01 GiB (24.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 8d750683-cede-448f-a396-2f6258105a0f
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 4 rev: 2.0
Device-1: 6-2:2 info: Chicony Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 98mA chip-ID: 04f2:b070 class-ID: 0e02 serial: <filter>
Hub-7: 7-0:1 info: full speed or root hub ports: 6 rev: 2.0
Device-1: 7-6:2 info: Realtek RTL8187B Wireless Adapter type: Network
driver: rtl8187 interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:8197 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 184 Uptime: 17m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1117 libs: 322 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash
v: 5.2.21 running-in: gnome-terminal inxi: 3.3.31
[user@user-satellitel350 ~]$ LANG=C lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 36 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Vendor ID: GenuineIntel
Model name: Intel(R) Pentium(R) Dual CPU T2370 @ 1.73GHz
CPU family: 6
Model: 15
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Stepping: 13
CPU(s) scaling MHz: 100%
CPU max MHz: 1733,0000
CPU min MHz: 800,0000
BogoMIPS: 3459,32
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca
cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm
pbe syscall nx lm constant_tsc arch_perfmon pebs bts re
p_good nopl cpuid aperfmperf pni dtes64 monitor ds_cpl e
st tm2 ssse3 cx16 xtpr pdcm lahf_lm pti dtherm
Caches (sum of all):
L1d: 64 KiB (2 instances)
L1i: 64 KiB (2 instances)
L2: 1 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0,1
Gather data sampling: Not affected
Itlb multihit: KVM: Mitigation: VMX unsupported
L1tf: Mitigation; PTE Inversion
Mds: Vulnerable: Clear CPU buffers attempted, no microcode; S
MT disabled
Meltdown: Mitigation; PTI
Mmio stale data: Unknown: No mitigations
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Vulnerable
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer
Spectre v2: Mitigation; Retpolines, STIBP disabled, RSB filling, PBR
SB-eIBRS Not affected
Srbds: Not affected
Tsx async abort: Not affected
[user@user-satellitel350 ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
[user@user-satellitel350 ~]$ lsblk -fa
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
sda
├─sda1
│ ext4 1.0 92c180e5-63f2-4ced-92fa-9f617c75ab19 262,9G 4% /
└─sda2
swap 1 swap 8d750683-cede-448f-a396-2f6258105a0f [SWAP]
sr0
[user@user-satellitel350 ~]$ LANG=C sudo parted -l
[sudo] password for user:
Model: ATA ST9320325AS (scsi)
Disk /dev/sda: 320GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 316GB 316GB primary ext4 boot
2 316GB 320GB 4512MB primary linux-swap(v1) swap
[user@user-satellitel350 ~]$ free
gesamt benutzt frei gemns. Puffer/Cache verfügbar
Speicher: 2009404 1475048 123192 304316 872844 534356
Swap: 4406112 1091264 3314848
[user@user-satellitel350 ~]$ sudo du -ha /var /usr /opt | sort -hr | head -20
8,1G /usr
4,4G /usr/lib
2,6G /usr/share
2,0G /var
1,8G /var/cache/pacman/pkg
1,8G /var/cache
541M /usr/lib/firmware
497M /usr/share/locale
494M /usr/lib/libreoffice
473M /usr/lib32
472M /usr/bin
419M /usr/lib/python3.11
387M /usr/share/doc
369M /opt/vivaldi
369M /opt
343M /usr/lib/python3.11/site-packages
335M /usr/include
332M /usr/share/icons
250M /usr/lib/libreoffice/program
