I am running Manjaro kernel 5.15.28-1 (KDE Plasma) on an Asus netbook and am having an issue where the computer reboots when coming out of sleep/suspend. I have the Energy Saving setting ‘Suspend session’ set to ‘sleep’ after 10 minutes when on battery., but turned the ‘Suspend’ option off entirely for when the computer is on AC power, since I was having the same issue. I’ve posted more information in the logs below. Any ideas how I can fix this, or the best way to continue troubleshooting the issue? Thanks.
inxi
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=fcc76dc4-db96-464e-a903-66b48f0c33dd rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: UX305CA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX305CA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX305CA.201 date: 09/11/2015
ID-1: BAT0 charge: 29.1 Wh (76.6%) condition: 38.0/45.0 Wh (84.5%)
volts: 11.4 min: 11.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 284
RAM: total: 7.67 GiB used: 4.78 GiB (62.3%)
RAM Report:
Info: model: Intel Core m3-6Y30 bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1818 high: 1933 min/max: 400/2200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1606 2: 1933 3: 1857
4: 1879 bogomips: 12007
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 515 vendor: ASUSTeK driver: i915 v: kernel
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:191e
class-ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b56b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x272d built: 2015 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 515 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-9:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 238.47 GiB used: 70.6 GiB (29.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: M600 MTFDDAV256MBF
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MA01 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 70.6 GiB (30.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fcc76dc4-db96-464e-a903-66b48f0c33dd
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: AC78-0D1B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Chicony USB2.0 HD UVC WebCam type: Video
Device-2: 1-9:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C pch: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 259 Uptime: 32m wakeups: 34354 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1469
pacman: 1457 lib: 379 flatpak: 5 snap: 7 Shell: Zsh v: 5.8.1
running-in: konsole inxi: 3.3.14
journalctl -t systemd-sleep
-- Boot ea047cbf5565475d8b41f3607e9b03e6 --
Mar 28 16:03:22 asusMNJ systemd-sleep[29526]: Entering sleep state 'suspend'...
Mar 28 16:04:02 asusMNJ systemd-sleep[29526]: Failed to put system to sleep. System resumed again: Device or resource busy
Mar 28 16:14:03 asusMNJ systemd-sleep[29654]: Entering sleep state 'suspend'...
journalctl -e -x
Mar 28 16:24:53 asusMNJ akonadi_davgroupware_resource[1096]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Mar 28 16:24:53 asusMNJ kded5[730]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Mar 28 16:24:53 asusMNJ kdeconnectd[791]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: SME: Trying to authenticate with xx:xx:xx:xx:xx:xx (SSID='MGMTnet' freq=5200 MHz)
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: authenticate with xx:xx:xx:xx:xx:xx
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.3919] device (wlp1s0): supplicant interface state: disconnected -> authenticating
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.3920] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> authenticating
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: send auth to xx:xx:xx:xx:xx:xx (try 1/3)
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: Trying to associate with xx:xx:xx:xx:xx:xx (SSID='MGMTnet' freq=5200 MHz)
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.3958] device (wlp1s0): supplicant interface state: authenticating -> associating
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.3959] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: authenticated
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: associate with xx:xx:xx:xx:xx:xx (try 1/3)
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: RX AssocResp from xx:xx:xx:xx:xx:xx (capab=0x1511 status=0 aid=2)
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: Associated with xx:xx:xx:xx:xx:xx
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 28 16:24:53 asusMNJ kernel: wlp1s0: associated
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4111] device (wlp1s0): supplicant interface state: associating -> associated
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4112] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4205] device (wlp1s0): supplicant interface state: associated -> 4way_handshake
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4205] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> 4way_handshake
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: WPA: Key negotiation completed with xx:xx:xx:xx:xx:xx [PTK=CCMP GTK=CCMP]
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to xx:xx:xx:xx:xx:xx completed [id=0 id_str=]
Mar 28 16:24:53 asusMNJ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=6000
Mar 28 16:24:53 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-47 noise=9999 txrate=6000
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4632] device (wlp1s0): supplicant interface state: 4way_handshake -> completed
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4632] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "MGMTnet"
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4633] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake -> completed
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4635] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4646] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::28f8:5c2f:4238:4a80.
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: New relevant interface wlp1s0.IPv6 for mDNS.
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: Registering new address record for fe80::28f8:5c2f:4238:4a80 on wlp1s0.*.
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.4801] dhcp4 (wlp1s0): state changed new lease, address=10.66.10.55
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 10.66.10.55.
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: New relevant interface wlp1s0.IPv4 for mDNS.
Mar 28 16:24:53 asusMNJ avahi-daemon[456]: Registering new address record for 10.66.10.55 on wlp1s0.IPv4.
Mar 28 16:24:53 asusMNJ mullvad-daemon[493]: [mullvad_rpc::availability][DEBUG] Resuming API requests due to coming online
Mar 28 16:24:53 asusMNJ audit: BPF prog-id=27 op=LOAD
Mar 28 16:24:53 asusMNJ audit[479]: SYSCALL arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffcec31f950 a2=80 a3=7ffcec31f950 items=0 ppid=1 pid=479 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mar 28 16:24:53 asusMNJ audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5055] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 28 16:24:53 asusMNJ kernel: audit: type=1334 audit(1648499093.496:134): prog-id=27 op=LOAD
Mar 28 16:24:53 asusMNJ kernel: audit: type=1300 audit(1648499093.496:134): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffcec31f950 a2=80 a3=7ffcec31f950 items=0 ppid=1 pid=479 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mar 28 16:24:53 asusMNJ kernel: audit: type=1327 audit(1648499093.496:134): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 28 16:24:53 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=67 TOS=0x00 PREC=0x00 TTL=63 ID=51815 DF PROTO=TCP SPT=80 DPT=56980 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5163] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5172] device (wlp1s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5181] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5197] manager: NetworkManager state is now CONNECTED_SITE
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5205] policy: set 'MGMTnet' (wlp1s0) as default for IPv4 routing and DNS
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5291] device (wlp1s0): Activation: successful, device activated.
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5299] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 28 16:24:53 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=2000 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5596] audit: op="statistics" interface="wlp1s0" ifindex=2 args="2000" pid=790 uid=1000 result="success"
Mar 28 16:24:53 asusMNJ NetworkManager[479]: <info> [1648499093.5692] audit: op="statistics" interface="wlp1s0" ifindex=2 args="500" pid=1094 uid=1000 result="success"
Mar 28 16:24:53 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:24:58 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14921, resource id: 54526175, major code: 15 (QueryTree), minor code: 0
Mar 28 16:25:00 asusMNJ appimagelauncherd[672]: Directories to watch disappeared, unintegrating AppImages formerly found in there
Mar 28 16:25:01 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:24:40 2022" - "Mon. Mar. 28 16:25:01 2022"
Mar 28 16:25:02 asusMNJ systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ Defined-By: systemd
░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Mar 28 16:25:02 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:02 asusMNJ kernel: kauditd_printk_skb: 2 callbacks suppressed
Mar 28 16:25:02 asusMNJ kernel: audit: type=1131 audit(1648499102.986:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:05 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-background: GetAppState called: no parameters
Mar 28 16:25:07 asusMNJ systemd[1]: systemd-timedated.service: Deactivated successfully.
░░ The unit systemd-timedated.service has successfully entered the 'dead' state.
Mar 28 16:25:07 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:07 asusMNJ kernel: audit: type=1131 audit(1648499107.429:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:07 asusMNJ audit: BPF prog-id=0 op=UNLOAD
Mar 28 16:25:07 asusMNJ kernel: audit: type=1334 audit(1648499107.466:139): prog-id=0 op=UNLOAD
Mar 28 16:25:07 asusMNJ kernel: audit: type=1334 audit(1648499107.466:140): prog-id=0 op=UNLOAD
Mar 28 16:25:07 asusMNJ kernel: audit: type=1334 audit(1648499107.466:141): prog-id=0 op=UNLOAD
Mar 28 16:25:07 asusMNJ systemd[1]: systemd-hostnamed.service: Deactivated successfully.
░░ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Mar 28 16:25:07 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:07 asusMNJ kernel: audit: type=1131 audit(1648499107.976:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:08 asusMNJ audit: BPF prog-id=0 op=UNLOAD
Mar 28 16:25:08 asusMNJ kernel: audit: type=1334 audit(1648499108.103:143): prog-id=0 op=UNLOAD
Mar 28 16:25:08 asusMNJ kernel: audit: type=1334 audit(1648499108.103:144): prog-id=0 op=UNLOAD
Mar 28 16:25:08 asusMNJ kernel: audit: type=1334 audit(1648499108.103:145): prog-id=0 op=UNLOAD
Mar 28 16:25:12 asusMNJ systemd[1]: systemd-localed.service: Deactivated successfully.
░░ The unit systemd-localed.service has successfully entered the 'dead' state.
Mar 28 16:25:12 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:12 asusMNJ kernel: audit: type=1131 audit(1648499112.346:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:12 asusMNJ audit: BPF prog-id=0 op=UNLOAD
Mar 28 16:25:12 asusMNJ kernel: audit: type=1334 audit(1648499112.426:147): prog-id=0 op=UNLOAD
Mar 28 16:25:12 asusMNJ kernel: audit: type=1334 audit(1648499112.426:148): prog-id=0 op=UNLOAD
Mar 28 16:25:12 asusMNJ kernel: audit: type=1334 audit(1648499112.426:149): prog-id=0 op=UNLOAD
Mar 28 16:25:17 asusMNJ systemd[650]: Started Firefox - Web Browser.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 309.
Mar 28 16:25:17 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16461, resource id: 54526225, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:25:17 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16477, resource id: 54526226, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:25:17 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: Read called with parameters:
Mar 28 16:25:17 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: group: "org.freedesktop.appearance"
Mar 28 16:25:17 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: key: "color-scheme"
Mar 28 16:25:19 asusMNJ rtkit-daemon[817]: Supervising 6 threads of 3 processes of 1 users.
Mar 28 16:25:19 asusMNJ rtkit-daemon[817]: Successfully made thread 1496 of process 1364 owned by '1000' RT at priority 10.
Mar 28 16:25:19 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:25:19 asusMNJ NetworkManager[479]: <info> [1648499119.5103] audit: op="statistics" interface="wlp1s0" ifindex=2 args="0" pid=790 uid=1000 result="success"
Mar 28 16:25:19 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=0 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:19 asusMNJ kernel: audit: type=1111 audit(1648499119.506:150): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=0 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:19 asusMNJ NetworkManager[479]: <info> [1648499119.5236] audit: op="statistics" interface="wlp1s0" ifindex=2 args="500" pid=1094 uid=1000 result="success"
Mar 28 16:25:19 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:19 asusMNJ kernel: audit: type=1111 audit(1648499119.519:151): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:25:20 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:25:21 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:25:22 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:25:23 asusMNJ plasmashell[790]: trying to show an empty dialog
Mar 28 16:25:25 asusMNJ plasmashell[790]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
Mar 28 16:25:25 asusMNJ plasmashell[790]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
Mar 28 16:25:26 asusMNJ plasmashell[790]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mar 28 16:25:26 asusMNJ wpa_supplicant[582]: wlp1s0: Reject scan trigger since one is already pending
Mar 28 16:25:26 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Activating via systemd: service name='org.kde.runners.baloo' unit='plasma-baloorunner.service' requested by ':1.34' (uid=1000 pid=790 comm="/usr/bin/plasmashell")
Mar 28 16:25:26 asusMNJ systemd[650]: Starting KRunner provider for baloo file indexer...
░░ Subject: A start job for unit UNIT has begun execution
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 313.
Mar 28 16:25:27 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Successfully activated service 'org.kde.runners.baloo'
Mar 28 16:25:27 asusMNJ systemd[650]: Started KRunner provider for baloo file indexer.
Mar 28 16:25:28 asusMNJ systemd[650]: Started TigerVNC Viewer - Remote Desktop Viewer.
░░ The job identifier is 332.
Mar 28 16:25:28 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26178, resource id: 54526290, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:25:31 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28620, resource id: 111149059, major code: 15 (QueryTree), minor code: 0
Mar 28 16:25:31 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28948, resource id: 14683113, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:25:31 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28949, resource id: 14683113, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:25:35 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-background: GetAppState called: no parameters
Mar 28 16:25:45 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Activating service name='org.kde.LogoutPrompt' requested by ':1.13' (uid=1000 pid=760 comm="/usr/bin/ksmserver")
Mar 28 16:25:45 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Successfully activated service 'org.kde.LogoutPrompt'
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:258: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:463: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:659: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:913: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1049: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1251: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1453: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1631: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1739: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:1980: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:46 asusMNJ ksmserver-logout-greeter[1933]: qt.svg: <input>:303:2223: Could not add child element to parent element because the types are incorrect.
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39954, resource id: 113246232, major code: 19 (DeleteProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39962, resource id: 113246232, major code: 19 (DeleteProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39963, resource id: 113246232, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39964, resource id: 113246232, major code: 19 (DeleteProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39965, resource id: 113246232, major code: 19 (DeleteProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39966, resource id: 113246232, major code: 19 (DeleteProperty), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39967, resource id: 113246232, major code: 7 (ReparentWindow), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39968, resource id: 113246232, major code: 6 (ChangeSaveSet), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39969, resource id: 113246232, major code: 2 (ChangeWindowAttributes), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39970, resource id: 113246232, major code: 10 (UnmapWindow), minor code: 0
Mar 28 16:25:49 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39994, resource id: 113246254, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:26:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:25:02 2022" - "Mon. Mar. 28 16:26:00 2022"
Mar 28 16:26:02 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=390 TOS=0x00 PREC=0x00 TTL=63 ID=17344 DF PROTO=TCP SPT=80 DPT=56984 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:26:10 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=128 TOS=0x00 PREC=0x00 TTL=63 ID=39191 DF PROTO=TCP SPT=80 DPT=56986 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:26:39 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=67 TOS=0x00 PREC=0x00 TTL=63 ID=51816 DF PROTO=TCP SPT=80 DPT=56980 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:27:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:26:01 2022" - "Mon. Mar. 28 16:27:00 2022"
Mar 28 16:27:02 asusMNJ dbus-daemon[458]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.36' (uid=1000 pid=784 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Mar 28 16:27:02 asusMNJ dbus-daemon[458]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Mar 28 16:27:12 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=400000
Mar 28 16:27:18 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:27:43 asusMNJ kcmshell5[2127]: kf.coreaddons: "Could not load plugin from kcm_kwindecoration: The shared library was not found."
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: kf.kirigami: Units.devicePixelRatio is deprecated (since 5.86): This returns 1 when using Qt HiDPI scaling.
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: kf.coreaddons: "Could not load plugin from kcm_kwinrules: The shared library was not found."
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: Invalid window uuid.
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/RulesList.qml:64:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: kf.coreaddons: Expected JSON property "X-KWin-Border-Activate" to be a single string. but it is a bool
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: kf.coreaddons: KPluginFactory could not load the plugin "/usr/lib/qt/plugins/org.kde.kdecoration2/oxygendecoration.so"
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: kf.coreaddons: KPluginFactory could not load the plugin "/usr/lib/qt/plugins/org.kde.kdecoration2/breezedecoration.so"
Mar 28 16:27:44 asusMNJ kcmshell5[2127]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Mar 28 16:27:45 asusMNJ kcmshell5[2127]: qt.svg: link #g1000 is undefined!
Mar 28 16:27:48 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55426, resource id: 113246266, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:27:55 asusMNJ kwin_rules_dialog[2148]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:27:55 asusMNJ kwin_rules_dialog[2148]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:27:55 asusMNJ kwin_rules_dialog[2148]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/RulesList.qml:64:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
Mar 28 16:27:56 asusMNJ kwin_rules_dialog[2148]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:261:9: QML ActionToolBar: Binding loop detected for property "atBottom"
Mar 28 16:27:56 asusMNJ kwin_rules_dialog[2148]: Retrieved properties for window QUuid("{1cea11a7-6d5a-4770-bb09-83b263cf1263}")
Mar 28 16:27:56 asusMNJ kwin_rules_dialog[2148]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/RulesEditor.qml:69:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
Mar 28 16:28:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:27:01 2022" - "Mon. Mar. 28 16:28:00 2022"
Mar 28 16:28:03 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2019, resource id: 113246263, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:28:05 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=390 TOS=0x00 PREC=0x00 TTL=63 ID=17345 DF PROTO=TCP SPT=80 DPT=56984 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:28:13 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=128 TOS=0x00 PREC=0x00 TTL=63 ID=39192 DF PROTO=TCP SPT=80 DPT=56986 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:28:14 asusMNJ kwin_rules_dialog[2164]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:28:14 asusMNJ kwin_rules_dialog[2164]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:28:14 asusMNJ kwin_rules_dialog[2164]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/RulesList.qml:64:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
Mar 28 16:28:15 asusMNJ kwin_rules_dialog[2164]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:261:9: QML ActionToolBar: Binding loop detected for property "atBottom"
Mar 28 16:28:15 asusMNJ kwin_rules_dialog[2164]: Retrieved properties for window QUuid("{1cea11a7-6d5a-4770-bb09-83b263cf1263}")
Mar 28 16:28:15 asusMNJ kwin_rules_dialog[2164]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/RulesEditor.qml:69:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
Mar 28 16:28:19 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15144, resource id: 113246259, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:28:42 asusMNJ kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx SRC=10.66.0.10 DST=10.66.10.55 LEN=67 TOS=0x00 PREC=0x00 TTL=63 ID=51817 DF PROTO=TCP SPT=80 DPT=56980 WINDOW=84 RES=0x00 ACK PSH URGP=0
Mar 28 16:29:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:28:01 2022" - "Mon. Mar. 28 16:29:00 2022"
Mar 28 16:29:23 asusMNJ mullvad-daemon[493]: [mullvad_daemon::version_check][DEBUG] Writing version check cache to /var/cache/mullvad-vpn/version-info.json
Mar 28 16:29:23 asusMNJ mullvad-daemon[493]: [mullvad_daemon::management_interface][DEBUG] Broadcasting new app version info
Mar 28 16:29:37 asusMNJ dbus-daemon[458]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.13' (uid=0 pid=461 comm="/usr/lib/snapd/snapd")
Mar 28 16:29:37 asusMNJ audit: BPF prog-id=28 op=LOAD
Mar 28 16:29:37 asusMNJ audit: BPF prog-id=29 op=LOAD
Mar 28 16:29:37 asusMNJ audit: BPF prog-id=30 op=LOAD
Mar 28 16:29:37 asusMNJ kernel: audit: type=1334 audit(1648499377.436:152): prog-id=28 op=LOAD
Mar 28 16:29:37 asusMNJ kernel: audit: type=1334 audit(1648499377.436:153): prog-id=29 op=LOAD
Mar 28 16:29:37 asusMNJ kernel: audit: type=1334 audit(1648499377.436:154): prog-id=30 op=LOAD
Mar 28 16:29:37 asusMNJ systemd[1]: Starting Time & Date Service...
░░ Subject: A start job for unit systemd-timedated.service has begun execution
░░ A start job for unit systemd-timedated.service has begun execution.
░░ The job identifier is 1662.
Mar 28 16:29:37 asusMNJ dbus-daemon[458]: [system] Successfully activated service 'org.freedesktop.timedate1'
Mar 28 16:29:37 asusMNJ systemd[1]: Started Time & Date Service.
░░ Subject: A start job for unit systemd-timedated.service has finished successfully
░░ A start job for unit systemd-timedated.service has finished successfully.
Mar 28 16:29:37 asusMNJ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:29:37 asusMNJ kernel: audit: type=1130 audit(1648499377.563:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:29:37 asusMNJ akonadi_davgroupware_resource[1096]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:29:37 asusMNJ akonadi_davgroupware_resource[1093]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:29:38 asusMNJ dbus-daemon[458]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.36' (uid=1000 pid=784 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Mar 28 16:29:38 asusMNJ dbus-daemon[458]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Mar 28 16:29:48 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:29:51 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:29:53 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:29:56 asusMNJ systemd[650]: Started Joplin.
░░ The job identifier is 542.
Mar 28 16:29:57 asusMNJ systemd[650]: Reloading.
Mar 28 16:29:57 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:29:59 asusMNJ systemd[650]: Started Konsole - Terminal.
░░ The job identifier is 564.
Mar 28 16:30:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:29:01 2022" - "Mon. Mar. 28 16:30:00 2022"
Mar 28 16:30:00 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15915, resource id: 14704142, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:30:00 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 15916, resource id: 14704142, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:30:01 asusMNJ polkitd[459]: Registered Authentication Agent for unix-process:2637:34489 (system bus name :1.98 [flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:30:01 asusMNJ polkitd[459]: Unregistered Authentication Agent for unix-process:2637:34489 (system bus name :1.98, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:30:02 asusMNJ konsole[2536]: Unsupported return type 65 QPixmap in method "grab"
Mar 28 16:30:02 asusMNJ konsole[2536]: Invalid return type in method "addAction"
Mar 28 16:30:02 asusMNJ konsole[2536]: Skipped method "setDefaultShortcuts" : Pointers are not supported: QAction*
Mar 28 16:30:03 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:30:07 asusMNJ systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 28 16:30:07 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:30:07 asusMNJ kernel: audit: type=1131 audit(1648499407.596:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:30:07 asusMNJ audit: BPF prog-id=0 op=UNLOAD
Mar 28 16:30:07 asusMNJ kernel: audit: type=1334 audit(1648499407.609:157): prog-id=0 op=UNLOAD
Mar 28 16:30:07 asusMNJ kernel: audit: type=1334 audit(1648499407.609:158): prog-id=0 op=UNLOAD
Mar 28 16:30:07 asusMNJ kernel: audit: type=1334 audit(1648499407.609:159): prog-id=0 op=UNLOAD
Mar 28 16:30:09 asusMNJ kded5[730]: Registering ":1.93/org/ayatana/NotificationItem/Joplin1" to system tray
Mar 28 16:30:18 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:30:39 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:30:59 asusMNJ systemd[650]: Started System Settings - System Settings.
░░ The job identifier is 568.
Mar 28 16:30:59 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6412, resource id: 54526351, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:31:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:30:01 2022" - "Mon. Mar. 28 16:31:00 2022"
Mar 28 16:31:00 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:31:01 asusMNJ systemsettings5[3097]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:31:01 asusMNJ systemsettings5[3097]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
Mar 28 16:31:01 asusMNJ systemsettings5[3097]: QFSFileEngine::open: No file name specified
Mar 28 16:31:01 asusMNJ systemsettings5[3097]: kf.coreaddons.desktopparser: Error: Failed to open ""
Mar 28 16:31:01 asusMNJ systemsettings5[3097]: QFileDevice::seek: IODevice is not open
Mar 28 16:31:03 asusMNJ systemsettings5[3097]: qml: The item SubCategoryPage_QMLTYPE_109(0x5594b13828d0) is already in the PageRow
Mar 28 16:31:08 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:31:09 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:31:21 asusMNJ kwin_x11[733]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Mar 28 16:31:21 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30455, resource id: 14713614, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:31:21 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30456, resource id: 14713614, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:31:21 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30459, resource id: 14713614, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:31:21 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30460, resource id: 14713614, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:31:25 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33780, resource id: 14713636, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:31:25 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 33781, resource id: 14713636, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:31:25 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33784, resource id: 14713636, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:31:25 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 33785, resource id: 14713636, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:32:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:31:01 2022" - "Mon. Mar. 28 16:32:00 2022"
Mar 28 16:32:49 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:32:50 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:32:51 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:33:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:32:01 2022" - "Mon. Mar. 28 16:33:00 2022"
Mar 28 16:33:59 asusMNJ systemsettings5[3097]: qml: The item SubCategoryPage_QMLTYPE_109(0x5594b13828d0) is already in the PageRow
Mar 28 16:33:59 asusMNJ dbus-daemon[458]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.102' (uid=1000 pid=3097 comm="/usr/bin/systemsettings5 kcm_powerdevilprofilescon") (using servicehelper)
Mar 28 16:33:59 asusMNJ dbus-daemon[458]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
Mar 28 16:33:59 asusMNJ systemsettings5[3097]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Mar 28 16:34:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:33:01 2022" - "Mon. Mar. 28 16:34:00 2022"
Mar 28 16:34:03 asusMNJ systemsettings5[3097]: qml: The item SubCategoryPage_QMLTYPE_109(0x5594b13828d0) is already in the PageRow
Mar 28 16:34:13 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:34:19 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:34:22 asusMNJ snapd[461]: devicemgr.go:1780: no NTP sync after 10m0s, trying auto-refresh anyway
Mar 28 16:34:51 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:35:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:34:01 2022" - "Mon. Mar. 28 16:35:00 2022"
Mar 28 16:35:27 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:36:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:35:01 2022" - "Mon. Mar. 28 16:36:00 2022"
Mar 28 16:37:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:36:01 2022" - "Mon. Mar. 28 16:37:00 2022"
Mar 28 16:37:19 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:38:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:37:01 2022" - "Mon. Mar. 28 16:38:00 2022"
Mar 28 16:38:15 asusMNJ wpa_supplicant[582]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=360000
Mar 28 16:39:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:38:01 2022" - "Mon. Mar. 28 16:39:00 2022"
Mar 28 16:39:18 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41462, resource id: 14730411, major code: 20 (GetProperty), minor code: 0
Mar 28 16:39:18 asusMNJ kwin_x11[733]: kwin_core: XCB error: 152 (BadDamage), sequence: 41593, resource id: 14770521, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Mar 28 16:39:19 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:39:19 asusMNJ systemd[1]: Starting Cleanup of Temporary Directories...
░░ Subject: A start job for unit systemd-tmpfiles-clean.service has begun execution
░░ A start job for unit systemd-tmpfiles-clean.service has begun execution.
░░ The job identifier is 1770.
Mar 28 16:39:20 asusMNJ systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
░░ The unit systemd-tmpfiles-clean.service has successfully entered the 'dead' state.
Mar 28 16:39:20 asusMNJ systemd[1]: Finished Cleanup of Temporary Directories.
░░ Subject: A start job for unit systemd-tmpfiles-clean.service has finished successfully
░░ A start job for unit systemd-tmpfiles-clean.service has finished successfully.
Mar 28 16:39:20 asusMNJ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:39:20 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:39:20 asusMNJ kernel: audit: type=1130 audit(1648499960.133:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:39:20 asusMNJ kernel: audit: type=1131 audit(1648499960.133:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:39:22 asusMNJ polkitd[459]: Registered Authentication Agent for unix-process:3699:90591 (system bus name :1.111 [flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:39:22 asusMNJ polkitd[459]: Unregistered Authentication Agent for unix-process:3699:90591 (system bus name :1.111, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:39:23 asusMNJ konsole[2536]: Unsupported return type 65 QPixmap in method "grab"
Mar 28 16:39:23 asusMNJ konsole[2536]: Invalid return type in method "addAction"
Mar 28 16:39:23 asusMNJ konsole[2536]: Skipped method "setDefaultShortcuts" : Pointers are not supported: QAction*
Mar 28 16:39:23 asusMNJ mullvad-daemon[493]: [mullvad_rpc::rest][DEBUG] Fetched new API addresses [193.138.218.78:443, 193.138.218.71:444, 185.65.134.66:444, 185.65.135.117:444, 217.138.254.130:444, 91.90.44.10:444], will fetch again in 24 hours
Mar 28 16:39:26 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50069, resource id: 14771551, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:39:26 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50070, resource id: 14771551, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:39:26 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50073, resource id: 14771551, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:39:26 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50074, resource id: 14771551, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:39:37 asusMNJ akonadi_davgroupware_resource[1093]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:39:37 asusMNJ akonadi_davgroupware_resource[1096]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:40:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:39:01 2022" - "Mon. Mar. 28 16:40:00 2022"
Mar 28 16:41:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:40:01 2022" - "Mon. Mar. 28 16:41:00 2022"
Mar 28 16:42:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:41:01 2022" - "Mon. Mar. 28 16:42:00 2022"
Mar 28 16:42:00 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:42:22 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:42:22 asusMNJ rtkit-daemon[817]: Successfully made thread 4033 of process 2494 owned by '1000' RT at priority 10.
Mar 28 16:42:22 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:43:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:42:01 2022" - "Mon. Mar. 28 16:43:00 2022"
Mar 28 16:43:26 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:43:33 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:43:37 asusMNJ systemsettings5[3097]: qml: The item SubCategoryPage_QMLTYPE_109(0x5594b13828d0) is already in the PageRow
Mar 28 16:43:52 asusMNJ rtkit-daemon[817]: Supervising 7 threads of 4 processes of 1 users.
Mar 28 16:43:52 asusMNJ rtkit-daemon[817]: Successfully made thread 4206 of process 3545 owned by '1000' RT at priority 10.
Mar 28 16:43:52 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:43:57 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:44:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:43:01 2022" - "Mon. Mar. 28 16:44:00 2022"
Mar 28 16:44:37 asusMNJ akonadi_davgroupware_resource[1093]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:44:37 asusMNJ akonadi_davgroupware_resource[1096]: org.kde.pim.davresource: Unable to fetch collections 300 "There was a problem with the request.\nInvalid username/password (401)."
Mar 28 16:44:44 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:44:52 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44650, resource id: 14789870, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:44:52 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44651, resource id: 14789870, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:44:52 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44654, resource id: 14789870, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:44:52 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44655, resource id: 14789870, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:44:55 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47966, resource id: 14810640, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:44:55 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 47967, resource id: 14810640, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:44:55 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47970, resource id: 14810640, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:44:55 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 47971, resource id: 14810640, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:45:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:44:01 2022" - "Mon. Mar. 28 16:45:00 2022"
Mar 28 16:45:11 asusMNJ kernel: perf: interrupt took too long (2520 > 2500), lowering kernel.perf_event_max_sample_rate to 79200
Mar 28 16:45:33 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23751, resource id: 14815404, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:45:33 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 23752, resource id: 14815404, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:45:33 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23755, resource id: 14815404, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:45:33 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 23756, resource id: 14815404, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:45:48 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38904, resource id: 132120579, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:45:48 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38908, resource id: 132120586, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:45:48 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38930, resource id: 132120593, major code: 18 (ChangeProperty), minor code: 0
Mar 28 16:46:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:45:01 2022" - "Mon. Mar. 28 16:46:00 2022"
Mar 28 16:46:03 asusMNJ wpa_supplicant[582]: wlp1s0: WPA: Group rekeying completed with xx:xx:xx:xx:xx:xx [GTK=CCMP]
Mar 28 16:47:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:46:01 2022" - "Mon. Mar. 28 16:47:00 2022"
Mar 28 16:48:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:47:01 2022" - "Mon. Mar. 28 16:48:00 2022"
Mar 28 16:49:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:48:01 2022" - "Mon. Mar. 28 16:49:00 2022"
Mar 28 16:49:21 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:49:41 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:50:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:49:01 2022" - "Mon. Mar. 28 16:50:00 2022"
Mar 28 16:51:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:50:01 2022" - "Mon. Mar. 28 16:51:00 2022"
Mar 28 16:51:30 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:51:31 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:51:33 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:51:46 asusMNJ kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22817, resource id: 14842246, major code: 20 (GetProperty), minor code: 0
Mar 28 16:51:55 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:52:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:51:01 2022" - "Mon. Mar. 28 16:52:00 2022"
Mar 28 16:52:15 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:52:21 asusMNJ audit[733]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=733 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=6 res=1
Mar 28 16:52:21 asusMNJ kernel: audit: type=1701 audit(1648500741.253:162): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=733 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=6 res=1
Mar 28 16:52:21 asusMNJ systemd[1]: Created slice Slice /system/systemd-coredump.
░░ Subject: A start job for unit system-systemd\x2dcoredump.slice has finished successfully
░░ A start job for unit system-systemd\x2dcoredump.slice has finished successfully.
░░ The job identifier is 1780.
Mar 28 16:52:21 asusMNJ audit: BPF prog-id=31 op=LOAD
Mar 28 16:52:21 asusMNJ audit: BPF prog-id=32 op=LOAD
Mar 28 16:52:21 asusMNJ audit: BPF prog-id=33 op=LOAD
Mar 28 16:52:21 asusMNJ kernel: audit: type=1334 audit(1648500741.310:163): prog-id=31 op=LOAD
Mar 28 16:52:21 asusMNJ kernel: audit: type=1334 audit(1648500741.310:164): prog-id=32 op=LOAD
Mar 28 16:52:21 asusMNJ kernel: audit: type=1334 audit(1648500741.310:165): prog-id=33 op=LOAD
Mar 28 16:52:21 asusMNJ systemd[1]: Started Process Core Dump (PID 4916/UID 0).
░░ Subject: A start job for unit systemd-coredump@0-4916-0.service has finished successfully
░░ A start job for unit systemd-coredump@0-4916-0.service has finished successfully.
░░ The job identifier is 1775.
Mar 28 16:52:21 asusMNJ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:21 asusMNJ kernel: audit: type=1130 audit(1648500741.320:166): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:21 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:52:21 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: Read called with parameters:
Mar 28 16:52:21 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: group: "org.freedesktop.appearance"
Mar 28 16:52:21 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: key: "color-scheme"
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:258: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:463: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:659: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:913: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1049: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1251: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1453: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1631: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1739: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:1980: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.svg: <input>:303:2223: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 180, resource id: 14680083, major code: 20 (GetProperty), minor code: 0
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 181, resource id: 14680083, major code: 20 (GetProperty), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28932, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28933, resource id: 54526479, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28934, resource id: 54526479, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28935, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28936, resource id: 54526481, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28937, resource id: 54526481, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28938, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28939, resource id: 54526483, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28940, resource id: 54526483, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28941, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28942, resource id: 54526485, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28943, resource id: 54526485, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28944, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28945, resource id: 54526487, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28946, resource id: 54526487, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28947, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28948, resource id: 54526489, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28949, resource id: 54526489, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28950, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28951, resource id: 54526491, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28952, resource id: 54526491, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 28953, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28954, resource id: 54526493, major code: 55 (CreateGC), minor code: 0
Mar 28 16:52:22 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28955, resource id: 54526493, major code: 72 (PutImage), minor code: 0
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Mar 28 16:52:22 asusMNJ kwin_x11[4915]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Mar 28 16:52:23 asusMNJ xembedsniproxy[785]: Container window visible, stack below
Mar 28 16:52:24 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Activating service name='org.kde.KSplash' requested by ':1.216' (uid=1000 pid=4915 comm="/usr/bin/kwin_x11 --crashes 1")
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2219, resource id: 14680102, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2220, resource id: 14680102, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2231, resource id: 14680106, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2232, resource id: 14680106, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2250, resource id: 14680113, major code: 3 (GetWindowAttributes), minor code: 0
Mar 28 16:52:24 asusMNJ kwin_x11[4915]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2251, resource id: 14680113, major code: 14 (GetGeometry), minor code: 0
Mar 28 16:52:24 asusMNJ xembedsniproxy[785]: Container window visible, stack below
Mar 28 16:52:24 asusMNJ systemd-coredump[4920]: Process 733 (kwin_x11) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 6318c4a6aee96a4b3563df9857aef147f8c4bc48
Module libqtquickcontrolsplugin.so with build-id 602d4f96352bb4126fbd41009591f773ad6c8c95
Module libqtquicktemplates2plugin.so with build-id 51f763481a27c954372e6a935303cc633a796670
Module libwindowplugin.so with build-id 8be5f7932daaab642612f157272bebeb266d2f77
Module libqmlplugin.so with build-id c88b327d36e5ab36b0471eac72bad9c82ac37ae6
Module libplasmaextracomponentsplugin.so with build-id 5a151973aaca2735e2125d30c188fc360a87db46
Module libplasmacomponentsplugin.so with build-id b6aa5034b254fc6988fabc80635ea9a705d87dc8
Module libOpenGL.so.0 with build-id f09885433fcfb48c54d308f1c8fbe2898b5e9ceb
Module libKF5PlasmaQuick.so.5 with build-id 6d18a7260e5196c2e17664fc42c092b8ec30b71d
Module libcorebindingsplugin.so with build-id 453f914fbd23550b278dfecc3ba4f8a562d31df6
Module libqquicklayoutsplugin.so with build-id 84ba981e12282aa5e52f992f3ab36f60e30707ba
Module libQt5QmlWorkerScript.so.5 with build-id 0ca03050412e259f2094b24c301e618d879a24db
Module libqtquick2plugin.so with build-id ba5197dd23318e740bc7a0a0ed75b04c10c0d1e1
Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
Module libwebpdemux.so.2 with build-id 7bc15ac239db643015e169a2c6cc822156eb999a
Module libwebpmux.so.3 with build-id 4232d5263a45719ba12f58ed7d8cae3a0fc887de
Module libqwebp.so with build-id dacb86849cf63601c096302bc5248957f26c1792
Module libqwbmp.so with build-id f364a39e41da7b352070f5b0d1a0330479eb0f3d
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libqtiff.so with build-id b37ad8ac140e0c9543378e4c326613a1311b2295
Module libqsvg.so with build-id 5a05e2dce49105d54df27dedbaf767fed536cf54
Module libQt5Pdf.so.5 with build-id 5fa88f5bcfd7be908f5c276fb1de7415c25e2e03
Module libqpdf.so with build-id cc8e7ffa26bacf0f941345ff9b248d5d3c510fd0
Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Module libqmng.so with build-id 9d7d2aea82b20085d0fe175021ffaba5f838f4f7
Module libqjpeg.so with build-id 8f3fd514e6a0e33f6c43a88045271ca1e38fe721
Module libjasper.so.4 with build-id 062fa02a47172a8bf53b976a67eea42a61f37f0f
Module libqjp2.so with build-id dc19aeb06d63cb2c80fb2a3cbeea2e117e073cdc
Module libqico.so with build-id c10d08a71544a009ff12fd922652abb0e14bbc31
Module libqicns.so with build-id 685f743bf4bce33832bb725d0fc7c93548c9e302
Module libqgif.so with build-id 39b4fe207c1219ed12d22aa7c37396fbe0466e75
Module kimg_xcf.so with build-id 9fe04ac38f3201b102daba6ea42992c0482418b6
Module kimg_tga.so with build-id 4f7050335d3b8060b6bf0456196619a52bf9adaf
Module kimg_rgb.so with build-id 5f374a4d7fe6e944829421290cf040b0e38b70f4
Module kimg_ras.so with build-id eea4e35523994af08b140c6ac89a569ebf004b47
Module kimg_psd.so with build-id c41234ece3110aef8bbed1ad0945fafe7772794c
Module kimg_pic.so with build-id 52c039cb43a2106a582f14950c1aa1b1cb0e2efa
Module kimg_pcx.so with build-id 97df76584d24ddb10b0b72010d22f3e2d24baac5
Module kimg_ora.so with build-id a1d56ef5b03e68fe0277ddd9119ef121da9ebd32
Module kimg_kra.so with build-id 8c5906db16a823046b8f63ef36ff5aba19d31910
Module libmvec.so.1 with build-id 760a099552c4783b979e942bf839c2bbc5ff603d
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libde265.so.0 with build-id 459cf009e847aef8f1589ad39b1573351b6a3b22
Module libheif.so.1 with build-id 64bccee060b5f2b512bc5ab529a4030b4f58ea8b
Module kimg_heif.so with build-id 6420c1c95ca5d7feea2299492fba7b0490262209
Module kimg_hdr.so with build-id 4a4e8d05cee899bc2d9564721798ac47b727bb2f
Module libIlmThread-3_1.so.30 with build-id 1d5714e7fdf53519be7a5cedbf91bcd1cbc2fb2e
Module libIex-3_1.so.30 with build-id 90c74db82d22b8d1ac7a77361fd579bd1c08af94
Module libImath-3_1.so.29 with build-id a6382ff94f639bb105265ceb819bdac92a7a9ae3
Module libOpenEXR-3_1.so.30 with build-id d1572feb4f222f541eec5e11a2ca5276da9317c5
Module kimg_exr.so with build-id 67dc9fd309dd2b0eb3c33324704f4398689e28fa
Module kimg_eps.so with build-id 7130f547d61a8afd51add157244c48d39fab25f7
Module libjpeg.so.8 with build-id 324d9d66f01707241e31af5cc104db3c9122f4c4
Module libyuv.so with build-id c7a5e1943921367b12460b618d38ce4afd1e6caf
Module libaom.so.3 with build-id 3c057fe8c5fa7033366274352148acb4dbb42728
Module libSvtAv1Enc.so.0 with build-id e9143f88be53d2aebfa4f9249295869f09e22be4
Module librav1e.so.0 with build-id 2e9e70e2433e4d2955a870f2de730172729fbe4f
Module libdav1d.so.5 with build-id 82862181dbe48302fde94240f68e17fb6f9a03c7
Module libavif.so.13 with build-id cdc4233bc1ff2e9b419e9bf8aaf8b5a94cf0bd87
Module kimg_avif.so with build-id f214c4eff8e24f5f2a74c5cd6f38cb0e5787b82e
Module kimg_ani.so with build-id 4640fe15903bfd14bc61549a4ab75aa50fcfc9e4
Module libKWinNightColorPlugin.so with build-id e28f6007f6d3e1d67391bc04666c30309ba369a0
Module colordintegration.so with build-id 0a73dde8a5bf750fe1bac0e22ff241807061734e
Module krunnerintegration.so with build-id 3d68a8266551e2b34142d365bc4614cfd8cab7e0
Module libxcb-res.so.0 with build-id b825f66a75478fd00eeb4c57ecb0ac7792e00f5e
Module KF5WindowSystemX11Plugin.so with build-id da35d5d7e94136066b54ff126970476a61a5b78a
Module breezedecoration.so with build-id ec151b94d2448846d597fee046ea258b5666ca73
Module libkwinxrenderutils.so.13 with build-id 5982344229547d2e47563cb608d8b1a7f76c5358
Module KWinX11Platform.so with build-id 87618ad2299e55e135ab859fd5a470826268e900
Module libKF5Style.so.5 with build-id 5ad99c439e6e1cfcdfbfc84bf53219cf44413f40
Module libbreezecommon5.so.5 with build-id 9d14f44ebecc5c4279925a6d0b41b98ebd61cb00
Module breeze.so with build-id ee5ea727e3220cd4130fd8232a078d00cb173134
Module libxml2.so.2 with build-id 34aa03d6fadb52a051964f0e50a977efaea9482e
Module libncursesw.so.6 with build-id 1f873ddb2c32ab39d0b7d8646d03680ffe99de7c
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libvulkan.so.1 with build-id e51d30864bc4e0d36087d09e4c30892f91fa594a
Module libdrm_nouveau.so.2 with build-id af8afb2331ac08c52132102ecbdc6076a8eb4c6f
Module libdrm_amdgpu.so.1 with build-id 8eb3977b830f3012d9ead7b4def5f4d2f38ec688
Module libelf.so.1 with build-id 4cf96cb4785e1ca233693ae17fa0d62971ee09c2
Module libdrm_radeon.so.1 with build-id 43e0aecc70c4ce905ba35c948e1c9a5d999b14c0
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-13.so with build-id 62bb83aeee3a955305312248a401be2cf62a0ea8
Module iris_dri.so with build-id c43e3cc6cde38c8c92a9612fcdb368153bc65720
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libxcb-present.so.0 with build-id 68f5465258750e2397b1333b3ffc01ee33caa4e1
Module libxcb-dri3.so.0 with build-id 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
Module libXxf86vm.so.1 with build-id 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
Module libxcb-dri2.so.0 with build-id 2dd6e65129a809dab828a1d26215a3f7a363fcc8
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libglapi.so.0 with build-id 7aa51925ea129481550b50f3ded60c755e169faa
Module libGLX_mesa.so.0 with build-id 5726e2258f9efa2ef8ffc94c1696ba9e38c4e6a7
Module libqxcb-glx-integration.so with build-id 69b495b75d80f7ca64f0d6e2de8ea5c98e4246df
Module libcomposeplatforminputcontextplugin.so with build-id 21084422e8f6910b5e50e5b059e60e221b20c049
Module libQt5QuickTemplates2.so.5 with build-id 541d260e92c4f4c55aac6277ceb86ada943ac126
Module libKF5Bookmarks.so.5 with build-id c4c0c3fa866da193d9de4d728e9bf06ebeeb70c4
Module libQt5QuickControls2.so.5 with build-id 1a09985eae02988320fa89f4e051a1ba6a1f713d
Module libKF5WaylandClient.so.5 with build-id 0d17b85b85fe9575fd95015540608a69b692e7e4
Module libKF5KIOFileWidgets.so.5 with build-id b9f3b9a9a328c81ebe1cfb01e878e51248f16a17
Module KDEPlasmaPlatformTheme.so with build-id acab59ba529b73a28decf1e8c86b4ab9bd0edba4
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libuuid.so.1 with build-id cc94de1b28210d2b06109bd76c198c80f518aad6
Module libxkbcommon-x11.so.0 with build-id c942fd85702bc7165a42bcb102660f9413376572
Module libICE.so.6 with build-id af53458a64fe1e62a4d95606f7b03c210b2b098c
Module libSM.so.6 with build-id ac7b055fd3f16b4f29373285ab04ed52eebb632d
Module libxcb-xinput.so.0 with build-id 6403174c48f05f40cf7c168beb86f2886b9f09c1
Module libxcb-xkb.so.1 with build-id fce20d2101f3e5439923e9283c489c2cad4420c3
Module libxcb-xinerama.so.0 with build-id b328103ce7502d94fd3a4e2e8773978a9aa84adc
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libQt5XcbQpa.so.5 with build-id 3998978703b0c5a780a304dfa94429f654dbc799
Module libqxcb.so with build-id 6efa06a18493fb9c622575524b46c406ccbf03cc
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libexpat.so.1 with build-id a05c64fe82308a309e7653685c94ce71735f8a1a
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libgnutls.so.30 with build-id 50f3a52ba3db67b822fd5888790238eb548b64aa
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libgobject-2.0.so.0 with build-id 1ab19051c262a2c995e86ea2b0af7e8ab70798f3
Module libgudev-1.0.so.0 with build-id a9f734ea9206d637d5aacfbd86298c91cdc1a33a
Module libxcb-util.so.1 with build-id 4188ebc629b472b560849c5792a69c1803c3d1a4
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libltdl.so.7 with build-id 04a5ffeff80ecdfcb5f7ff2d889b5a3ecfb88d7c
Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f160f
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libQt5WaylandClient.so.5 with build-id 1b81e08da393573f619fa8b8d3bb9ec534a0ebfa
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libKF5Completion.so.5 with build-id 4061ecfcd0f3d597b8ca460de54af8ac5e220f2c
Module libKF5Solid.so.5 with build-id 4c5798183ecb8a7e7cbf8381affaa8c60d0bc380
Module libKF5JobWidgets.so.5 with build-id 087796138878ebe41e4efb8478d554ff9628942f
Module libKF5KIOCore.so.5 with build-id 5e3a5ef5ec1076dcb63ed036f8a5de5ed922bbc6
Module libKF5ItemViews.so.5 with build-id 04ee67c91f84ee1337857f53a0898f98270d9f3f
Module libQt5PrintSupport.so.5 with build-id c54a6f029d10cb6c6e2b15e772fb7bdb1b0db658
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libwacom.so.9 with build-id 7e303135e132c1d883060092e9b4cc5971a94378
Module libevdev.so.2 with build-id b62ae69f839f1b6b06ef2c1df19f25ff09b0d824
Module libmtdev.so.1 with build-id 0cea2a842ae9a0ef02a08477076caab0e5ac5e42
Module libxcb-image.so.0 with build-id ee7f8577926fe7c1d6972036c2f8e6f727e43b1b
Module libxcb-render-util.so.0 with build-id c64fb28ea20a320a9754273d9ea3af85f6f74b17
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libKF5WaylandServer.so.5 with build-id a535b592e207de2af6cac17fb9635c71844f94cf
Module libKF5IdleTime.so.5 with build-id 11fae1d166ac6bbdfa567115cf14899d212a085b
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libglib-2.0.so.0 with build-id 0fcc81d3dfd68bddbf63423156549fc66939e8ca
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module libpcre2-16.so.0 with build-id 195fbccafbcff538ce13805ba687514fb614c5ed
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libsystemd.so.0 with build-id 05d0460efefd339d315812f9506aecc5a5d22200
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id ee57ebbf2c33ad97fd7ee7327cf63f419548e64e
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libKF5AuthCore.so.5 with build-id f2ecc84dedb1f77bec1cc90f831eaf8f12522a8f
Module libKF5Codecs.so.5 with build-id b57cd6f2c680dcd42a81513601d84a1ea8171ae6
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id 96411faea62997274e362f263e65082e601a787b
Module libQt5TextToSpeech.so.5 with build-id 0de0c55a9318b069483c964448f193318a5ec8c4
Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libQt5Network.so.5 with build-id beaa14cdda8e3dc16c9e7d1d1f9560dd24b4da13
Module libQt5QmlModels.so.5 with build-id 545f240ac067668ca3c15a541c9982ff745eb174
Module libEGL.so.1 with build-id 686c2e4036c01a3a72349ed0dd04f7c434af14ce
Module libKF5DBusAddons.so.5 with build-id 3ebe80cda0a1e460bca002aca38df063331e9694
Module libQt5Xml.so.5 with build-id c117dde732dd4946c4842e65b3beb75ad290cf82
Module libKF5GuiAddons.so.5 with build-id 9c7532d5df9aed6b24a8a6730d2175f89905ea24
Module libKF5Archive.so.5 with build-id 470e73d63e84a43c1afacfad57aea0a50be51ec9
Module libQt5Svg.so.5 with build-id f7022a2f8451f8b6317ed423207a2f17c647ec90
Module libKF5IconThemes.so.5 with build-id 1122bfe0392d0ccf526d6b842dd7c0b3f2829bf0
Module libKF5KIOGui.so.5 with build-id 201b46a9950c8d914d9b069a8dfc6c99ad313899
Module libKF5KIOWidgets.so.5 with build-id 2019564c393898c6816765f04356f34b7e3aed0a
Module libKF5XmlGui.so.5 with build-id 12580e8b5f4e0d7111990b7918fe2bff45a9e6a3
Module libKF5Declarative.so.5 with build-id 9a90c83421ebe40f709fa20e5ca0aff477e73391
Module libQt5Sql.so.5 with build-id 03b37a8f06cec32dfbcb264dc0a2ec2c9f15b0b4
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b37737b27696365f
Module libKF5WidgetsAddons.so.5 with build-id 9ca3a0bbe0a1e4781e34ccab8578aec08cbbce47
Module libKF5Package.so.5 with build-id 60da8bc349bf9cb644521a792d91a698d8d698ad
Module libKF5Activities.so.5 with build-id 578e8808437804fed6014966fd3f038ddbc923c1
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libinput.so.10 with build-id 1303998925dd344a6a55546c2f9ce6b936c97cb7
Module libudev.so.1 with build-id 7dc938362569112855b6086de066cd6a18d1b978
Module libxcb-xfixes.so.0 with build-id a6b197ace5b9b59f913f5969eb419a88d1194f47
Module libxcb-sync.so.1 with build-id dda14591103b01b1311906053bf1ca9e82ade35c
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-shape.so.0 with build-id f1b3376c4534fab0469feb1cd19f022ff98df533
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb-randr.so.0 with build-id b6c1c7d4b28863b55ade251813db7f246b7ffe8b
Module libxcb-keysyms.so.1 with build-id 333e5eb4075795f947c924a2085f17e2e2ae7147
Module libxcb-icccm.so.4 with build-id 73f1e12d76af383aa969a60279ed5ed922045f47
Module libxcb-glx.so.0 with build-id 8ad115382ad874165523dc5b4488c99d73bbc3c4
Module libxcb-damage.so.0 with build-id 14ba8de82d16adadd150a1d0ae3e8ac2119ccc8a
Module libxcb-cursor.so.0 with build-id 69d87b342ff51e520334e5fda3dd33bcf09c1483
Module libxcb-composite.so.0 with build-id 94fff40466ef37eb5973997211aa68f9beb81d15
Module libKScreenLocker.so.5 with build-id 02cb2ad476ac4f85aafa186bc06f0e8c2359c88e
Module libkdecorations2private.so.9 with build-id cf407f60d7497d6c578cb854de8a48e000f1073c
Module libkdecorations2.so.5 with build-id cfd9ab618f744bda8d01eb105ee4de150dfc1eec
Module libKF5GlobalAccelPrivate.so.5 with build-id f4ef4fb897a883590bd46069c3959cc477e29653
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libQt5X11Extras.so.5 with build-id 25320ee0d79d41ea309fc03b608da2d35d24e6b6
Module libKF5CoreAddons.so.5 with build-id bcc6ff26016e7ccece6bd8ad2855f479606d9794
Module libQt5Widgets.so.5 with build-id 232fbe097cdff1e68525af0f647a4fa0364a14de
Module libKF5WindowSystem.so.5 with build-id 0de1964b4947b65b4004c9c1774e96d8bf69c117
Module libQt5DBus.so.5 with build-id eaadac7eb0682c8accdb8431fb928470c0546840
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libQt5Core.so.5 with build-id f73371ea886ae2451065382ad41edd28617aa39e
Module libQt5Gui.so.5 with build-id 20965ca1f74bb86f1ddf8c9ba72cc14fe616787c
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libKF5I18n.so.5 with build-id 9b38367b44cd4fd7d6106a33def5d8c2e35f245d
Module libKF5ConfigCore.so.5 with build-id 2d612e09eb2dc97190d58a696e703fb9f1d1eb42
Module libKF5ConfigGui.so.5 with build-id fac1e547b0b7f1eeca4cd2efb3a2a118d6079366
Module libKF5ConfigWidgets.so.5 with build-id 4858db3aaddcc9a6e1e3eb2d2464312b661593f4
Module libKF5GlobalAccel.so.5 with build-id 3c88c07e9461982ed9dda649fb6a3add4129ce0a
Module libKF5Notifications.so.5 with build-id 9d89d1a7e900ac60bc23fd355be213734ef1a5d5
Module libQt5Qml.so.5 with build-id e9144441df428bab106b32860a6b1b6846ceb6e4
Module libQt5Quick.so.5 with build-id 5beb28a3ff98ec771c9a6f66a97e74f4fa083815
Module libKF5QuickAddons.so.5 with build-id 2e4337a935c6a6495a1508b64f13926783514c35
Module libkwinglutils.so.13 with build-id dd5b718187ef4a30cedd5dc721a0875cdf2cd396
Module libkwineffects.so.13 with build-id ccfd862981f1b9e6f092b04a3a4e71f564db4a8d
Module libKWaylandServer.so.5 with build-id fa1dbaad7bb6ed79481361a76a63e357c204d277
Module libKF5Service.so.5 with build-id 4d8713f27727a94a714483bf3d0450e8109bdf56
Module libKF5Plasma.so.5 with build-id 73096d201de503c303c9dafe64d5047282180d6e
Module libqaccessibilityclient-qt5.so.0 with build-id 3133e868d77f4c2c6ebd657793baeb6a4e824544
Module libKF5Crash.so.5 with build-id 2c00f96c474bc5d49601dda86ca649e5ce011acd
Module libkwin.so.5 with build-id ece775158bffd022c5125d60fe5975d35e62484d
Module kwin_x11 with build-id 224b184210290686044f38eaa9a7119f12228c92
Stack trace of thread 733:
#0 0x00007f17e149534c __pthread_kill_implementation (libc.so.6 + 0x8f34c)
#1 0x00007f17e14484b8 raise (libc.so.6 + 0x424b8)
#2 0x00007f17e3cb6384 _ZN6KCrash19defaultCrashHandlerEi (libKF5Crash.so.5 + 0x7384)
#3 0x00007f17e1448560 __restore_rt (libc.so.6 + 0x42560)
#4 0x00007f17e149534c __pthread_kill_implementation (libc.so.6 + 0x8f34c)
#5 0x00007f17e14484b8 raise (libc.so.6 + 0x424b8)
#6 0x00007f17e1432534 abort (libc.so.6 + 0x2c534)
#7 0x00007f17d994da89 n/a (iris_dri.so + 0x1b5a89)
#8 0x00007f17da5cfcc5 n/a (iris_dri.so + 0xe37cc5)
#9 0x00007f17d9b54849 n/a (iris_dri.so + 0x3bc849)
#10 0x00007f17e3eb3d48 n/a (libkwin.so.5 + 0x1f8d48)
#11 0x00007f17e2545f63 n/a (libQt5Core.so.5 + 0x2bdf63)
#12 0x00007f17e3e8b3a6 _ZN4KWin5Scene11paintScreenERK7QRegionS3_PS1_S4_PNS_10RenderLoopERK10QMatrix4x4 (libkwin.so.5 + 0x1d03a6)
#13 0x00007f17e3f512e7 _ZN4KWin11SceneOpenGL5paintEPNS_14AbstractOutputERK7QRegionRK5QListIPNS_8ToplevelEEPNS_10RenderLoopE (libkwin.so.5 + 0x2962e7)
#14 0x00007f17e3ded7f4 _ZN4KWin10Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x1327f4)
#15 0x00007f17e3dedd40 _ZN4KWin13X11Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x132d40)
#16 0x00007f17e2545f63 n/a (libQt5Core.so.5 + 0x2bdf63)
#17 0x00007f17e3dab7a7 _ZN4KWin10RenderLoop14frameRequestedEPS0_ (libkwin.so.5 + 0xf07a7)
#18 0x00007f17e3e7cbd8 _ZN4KWin17RenderLoopPrivate8dispatchEv (libkwin.so.5 + 0x1c1bd8)
#19 0x00007f17e2545f63 n/a (libQt5Core.so.5 + 0x2bdf63)
#20 0x00007f17e254819f _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2c019f)
#21 0x00007f17e2539266 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b1266)
#22 0x00007f17e1b441c6 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x1791c6)
#23 0x00007f17e25150aa _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28d0aa)
#24 0x00007f17e25608e5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d88e5)
#25 0x00007f17e2560d82 _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8d82)
#26 0x00007f17dc2acf83 n/a (libQt5XcbQpa.so.5 + 0x63f83)
#27 0x00007f17e250d39b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28539b)
#28 0x00007f17e2518ad7 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x290ad7)
#29 0x000056386e3afe8c n/a (kwin_x11 + 0x2fe8c)
#30 0x00007f17e1433310 __libc_start_call_main (libc.so.6 + 0x2d310)
#31 0x00007f17e14333c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#32 0x000056386e3b1225 n/a (kwin_x11 + 0x31225)
Stack trace of thread 743:
#0 0x00007f17e149015a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f17e1492960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x00007f17d997351c n/a (iris_dri.so + 0x1db51c)
#3 0x00007f17d996c56c n/a (iris_dri.so + 0x1d456c)
#4 0x00007f17e14935c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007f17e1518584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 744:
Stack trace of thread 746:
Stack trace of thread 748:
Stack trace of thread 741:
#0 0x00007f17e150c2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f17e2e2063b n/a (libxcb.so.1 + 0xc63b)
#2 0x00007f17e2e2237b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
#3 0x00007f17dc2aab12 n/a (libQt5XcbQpa.so.5 + 0x61b12)
#4 0x00007f17e236c8cc n/a (libQt5Core.so.5 + 0xe48cc)
#5 0x00007f17e14935c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f17e1518584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 745:
Stack trace of thread 777:
Stack trace of thread 778:
Stack trace of thread 779:
Stack trace of thread 796:
Stack trace of thread 3624:
Stack trace of thread 3625:
#2 0x00007f17e2373cfc _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebcfc)
#3 0x00007f17e35f6bef n/a (libQt5Quick.so.5 + 0x200bef)
Stack trace of thread 772:
#0 0x00007f17e150c3ae ppoll (libc.so.6 + 0x1063ae)
#1 0x00007f17e2559fca _Z12qt_safe_pollP6pollfdmPK8timespec (libQt5Core.so.5 + 0x2d1fca)
#2 0x00007f17e2560bce _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8bce)
#3 0x00007f17e250d39b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28539b)
#4 0x00007f17e236fa56 _ZN7QThread4execEv (libQt5Core.so.5 + 0xe7a56)
#5 0x00007f17e32b3d00 n/a (libQt5Qml.so.5 + 0x2c6d00)
#6 0x00007f17e236c8cc n/a (libQt5Core.so.5 + 0xe48cc)
#7 0x00007f17e14935c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007f17e1518584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 780:
Stack trace of thread 781:
Stack trace of thread 800:
#5 0x00007f17e236c8cc n/a (libQt5Core.so.5 + 0xe48cc)
#6 0x00007f17e14935c2 start_thread (libc.so.6 + 0x8d5c2)
#7 0x00007f17e1518584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 749:
#5 0x00007f17e20f93a9 n/a (libQt5DBus.so.5 + 0x233a9)
░░ Subject: Process 733 (kwin_x11) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 733 (kwin_x11) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Mar 28 16:52:24 asusMNJ kernel: audit: type=1131 audit(1648500744.770:167): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:24 asusMNJ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4916-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:24 asusMNJ systemd[1]: systemd-coredump@0-4916-0.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit systemd-coredump@0-4916-0.service has successfully entered the 'dead' state.
Mar 28 16:52:24 asusMNJ systemd[1]: systemd-coredump@0-4916-0.service: Consumed 2.425s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit systemd-coredump@0-4916-0.service completed and consumed the indicated resources.
Mar 28 16:52:24 asusMNJ audit: BPF prog-id=0 op=UNLOAD
Mar 28 16:52:24 asusMNJ kernel: audit: type=1334 audit(1648500744.870:168): prog-id=0 op=UNLOAD
Mar 28 16:52:24 asusMNJ kernel: audit: type=1334 audit(1648500744.870:169): prog-id=0 op=UNLOAD
Mar 28 16:52:24 asusMNJ kernel: audit: type=1334 audit(1648500744.870:170): prog-id=0 op=UNLOAD
Mar 28 16:52:25 asusMNJ rtkit-daemon[817]: Supervising 8 threads of 5 processes of 1 users.
Mar 28 16:52:25 asusMNJ kwin_x11[4915]: kwin_core: XCB error: 10 (BadAccess), sequence: 2387, resource id: 1944, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Mar 28 16:52:25 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: Read called with parameters:
Mar 28 16:52:25 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: group: "org.freedesktop.appearance"
Mar 28 16:52:25 asusMNJ xdg-desktop-portal-kde[974]: xdp-kde-settings: key: "color-scheme"
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:258: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:463: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:659: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:913: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1049: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1251: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1453: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1631: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1739: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:1980: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:25 asusMNJ plasmashell[790]: qt.svg: <input>:303:2223: Could not add child element to parent element because the types are incorrect.
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30570, resource id: 54526483, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30571, resource id: 54526484, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30572, resource id: 54526485, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30573, resource id: 54526486, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30574, resource id: 54526487, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30575, resource id: 54526488, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30576, resource id: 54526489, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30577, resource id: 54526490, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30578, resource id: 54526491, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30579, resource id: 54526492, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30580, resource id: 54526493, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30581, resource id: 54526494, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30582, resource id: 54526479, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30583, resource id: 54526480, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 30584, resource id: 54526481, major code: 54 (FreePixmap), minor code: 0
Mar 28 16:52:26 asusMNJ plasmashell[790]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 30585, resource id: 54526482, major code: 60 (FreeGC), minor code: 0
Mar 28 16:52:35 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=2000 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:35 asusMNJ NetworkManager[479]: <info> [1648500755.6086] audit: op="statistics" interface="wlp1s0" ifindex=2 args="2000" pid=790 uid=1000 result="success"
Mar 28 16:52:35 asusMNJ kernel: audit: type=1111 audit(1648500755.603:171): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=2000 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:35 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:35 asusMNJ NetworkManager[479]: <info> [1648500755.6283] audit: op="statistics" interface="wlp1s0" ifindex=2 args="500" pid=1094 uid=1000 result="success"
Mar 28 16:52:35 asusMNJ kernel: audit: type=1111 audit(1648500755.623:172): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:35 asusMNJ plasmashell[790]: QQmlExpression: Expression file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:123:21 depends on non-NOTIFYable properties:
Mar 28 16:52:35 asusMNJ plasmashell[790]: QAction::priority
Mar 28 16:52:41 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:52:42 asusMNJ NetworkManager[479]: <info> [1648500762.4546] audit: op="statistics" interface="wlp1s0" ifindex=2 args="0" pid=790 uid=1000 result="success"
Mar 28 16:52:42 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=0 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:42 asusMNJ kernel: audit: type=1111 audit(1648500762.450:173): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=0 pid=790 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:42 asusMNJ audit[479]: USYS_CONFIG pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:42 asusMNJ NetworkManager[479]: <info> [1648500762.4718] audit: op="statistics" interface="wlp1s0" ifindex=2 args="500" pid=1094 uid=1000 result="success"
Mar 28 16:52:42 asusMNJ kernel: audit: type=1111 audit(1648500762.466:174): pid=479 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp1s0" ifindex=2 args=500 pid=1094 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 28 16:52:42 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:53:00 asusMNJ kalendarac[830]: Check: "Mon. Mar. 28 16:52:01 2022" - "Mon. Mar. 28 16:53:00 2022"
Mar 28 16:53:17 asusMNJ plasmashell[790]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Mar 28 16:53:21 asusMNJ polkitd[459]: Registered Authentication Agent for unix-process:5149:174496 (system bus name :1.128 [flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:53:21 asusMNJ polkitd[459]: Unregistered Authentication Agent for unix-process:5149:174496 (system bus name :1.128, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Mar 28 16:53:22 asusMNJ konsole[2536]: Unsupported return type 65 QPixmap in method "grab"
Mar 28 16:53:22 asusMNJ konsole[2536]: Invalid return type in method "addAction"
Mar 28 16:53:22 asusMNJ konsole[2536]: Skipped method "setDefaultShortcuts" : Pointers are not supported: QAction*
Mar 28 16:53:24 asusMNJ plasma_waitforname[4964]: org.kde.knotifications: WaitForName: Service was not registered within timeout
Mar 28 16:53:24 asusMNJ dbus-daemon[687]: [session uid=1000 pid=687] Activated service 'org.kde.KSplash' failed: Process org.kde.KSplash exited with status 1
Mar 28 16:53:37 asusMNJ plasmashell[790]: QQmlExpression: Expression file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:123:21 depends on non-NOTIFYable properties:
Mar 28 16:53:37 asusMNJ plasmashell[790]: QAction::priority
