Olli
20 July 2022 12:41
41
okay please set your system now in this way that we configure and start wit the intel-parameter set to 1.
remember to update as exlained and do a reboot. before please post the output of
for p in /sys/class/drm/*/status; do con=${p%/status}; echo -n "${con#*/card?-}: "; cat $p; done
and the output of
ls /sys/class/backlight/
there is also the “intel-media-driver” package. install it if it’s not installed yet.
adrxd
20 July 2022 12:58
42
Olli:
Okay.
DP-1: disconnected
DP-2: disconnected
HDMI-A-1: connected
HDMI-A-2: disconnected
eDP-1: connected
intel_backlight
I’ve installed intel-media-driver package as well.
Olli
20 July 2022 13:02
43
okay next step, please make sur that you update your system to the newest avaiable. check that your update is up to date.
if you’re ready. this is helpful also to others to know that this one is the status we are dealing with
adrxd
20 July 2022 13:05
44
Here you go.
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0262f6df-2fea-4f21-88fe-529a32d7884a rw i915.modeset=1
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Plaisio s SA product: Flynote Xi v: N/A
serial: <superuser required>
Mobo: NA model: NA serial: <superuser required> UEFI: American Megatrends
v: E.S142C.E0_25.D4.047.rom date: 07/28/2021
ID-1: BAT0 charge: 38.0 Wh (100.0%) condition: 38.0/38.0 Wh (100.0%)
volts: 7.6 min: N/A model: Broadwell Battery type: Unknown serial: <filter>
status: full
RAM: total: 3.74 GiB used: 800.7 MiB (20.9%)
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: model: Intel Pentium J3710 bits: 64 type: MCP arch: Airmont
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 4
microcode: 0x411
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 649 high: 1159 min/max: 480/2640 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 480 2: 480 3: 1159
4: 480 bogomips: 12805
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
driver: i915 v: kernel arch: Gen8 process: Intel 14nm built: 2014-15
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1,DP-2,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:22b1 class-ID: 0300
Device-2: Sonix HD WebCam type: USB driver: uvcvideo bus-ID: 1-2.1:5
chip-ID: 174f:2411 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Dell U2415
serial: <filter> built: 2019 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 note: disabled model: Panasonic VVX14P048M00
serial: <filter> built: 2015 res: 1920x1200 dpi: 267 gamma: 1.2
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2 modes: N/A
OpenGL: renderer: Mesa Intel HD Graphics 405 (BSW) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 1-1:2 chip-ID: 062a:9539
class-ID: 0300
Device-2: MosArt USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.55 running: no
Message: No PCI device data found.
IF-ID-1: wlp0s20u5i2 state: up mac: <filter>
Device-1: Realtek 802.11n WLAN Adapter type: USB driver: btusb,rtl8xxxu
bus-ID: 1-5:4 chip-ID: 0bda:b720 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 115.25 GiB used: 6.15 GiB (5.3%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SCA128 size: 115.25 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-1: / raw-size: 49.26 GiB size: 48.19 GiB (97.82%) used: 6.15 GiB (12.8%)
fs: ext4 dev: /dev/mmcblk0p4 maj-min: 179:4 label: N/A
uuid: 0262f6df-2fea-4f21-88fe-529a32d7884a
ID-1: swap-1 type: partition size: 8.6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: 5ebba3e9-a9a7-4e0a-b366-22ecf70e06a2
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 117 MiB fs: vfat label: NO_LABEL
uuid: 1E74-E280
ID-2: /dev/mmcblk0p3 maj-min: 179:3 size: 57.27 GiB fs: ntfs label: N/A
uuid: CAD6BB85D6BB7075
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-1:2 info: MosArt USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 062a:9539 class-ID: 0300
Hub-2: 1-2:3 info: Hi-speed hub with single TT ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-2.1:5 info: Sonix HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2411
class-ID: 0e02
Device-2: 1-2.2:6 info: SIGMACHIP Usb Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 98mA chip-ID: 1c4f:0034 class-ID: 0301
Device-3: 1-5:4 info: Realtek 802.11n WLAN Adapter type: Bluetooth
driver: btusb,rtl8xxxu interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 149 Uptime: 6m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: N/A Packages: pacman: 611 lib: 161
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
Olli
20 July 2022 13:07
45
well as we can see there is a curious message
eDP-1 empty
please search also while i do the same. never saw that before
adrxd
20 July 2022 13:16
46
As I can see from other threads for example this one .
https://forums.linuxmint.com/viewtopic.php?t=376894
In that log eDP-1 is empty however his monitor is working so I think that might not be something to search for? However I can see that in my log
Monitor-2: eDP-1 note: disabled and in other guy’s log Monitor-2: eDP-1 mapped.
Olli
20 July 2022 13:25
47
GRUB_CMDLINE_LINUX_DEFAULT="i915.modeset=1 video=eDP-1:e udev.log_priority=3"
and again
sudo update-grub
sudo mkinitcpio -P
this should force to enable (video=…:e) it straight from the startup. any changes after reboot ?
adrxd
20 July 2022 13:31
48
No lucky. Still the same. Even in the log everything is the same.
Olli
20 July 2022 13:36
49
okay let’s try something else and check the behaviour with wayland instead.
install the “plasma-wayland-session” and reboot. at the login-screen check the left-bottom of the display. there you can choose wayland or x11. switch to wayland and see if there’s a change under wayland.
adrxd
20 July 2022 13:42
50
I’ve installed plasma-wayland-session but in KDE it seems buggy as @brahma said.
Whenever I select Wayland and login it goes black screen with one line in terminal and only keeps restarting to login screen.
Olli
20 July 2022 13:49
51
okay so turn back to x11. i’m running out of ideas, your monitor eDP1 is shutdown and i wonder why it is not activated.
are there any bios-settings that could interfere ?
adrxd
20 July 2022 14:02
52
Okay. A little progress. I’ve activate the monitor with the following link:
https://forums.linuxmint.com/viewtopic.php?f=59&t=343706&p=1978463&hilit=GWTN141+4#p1978463
I’ve created EDID bin from the local and move to edid/firmware and added to boot. AND STILL monitor is black. I cannot believe this.
Integrated Graphics
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0
gpu: i915 tty: 80x24
Monitor-1: HDMI-A-1 model: Dell U2415 serial: <filter> built: 2019
res: 1920x1200 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
Monitor-2: eDP-1 model: Linux FHD serial: <filter> built: 2012
res: 1920x1080 dpi: 98 gamma: 1.2 size: 500x281mm (19.69x11.06")
diag: 574mm (22.6") ratio: 16:9 modes: 1920x1080
Message: GL data unavailable in console. Try -G --display
Olli
20 July 2022 14:05
53
hey a step forward is a step closer to the finish-line. but in fact your system is really scary.
but again, do you have a bios you can enter and check and what is the actual setting of
cat /etc/default/grub | egrep -i "GRUB_CMDLINE_LINUX_DEFAULT="
adrxd
20 July 2022 14:10
54
I’ve played with couple of things in BIOS but no luck. I can change something if you want.
GRUB_CMDLINE_LINUX_DEFAULT="i915.modeset=1 video=eDP-1:e drm.edid_firmware=eDP-1:edid/1920x1080.bin udev.log_priority=3"
Olli
20 July 2022 14:14
55
just to check out, what happens if you set the parameter
i915.modeset=0
to zero. don’t forget to update grub and please try it now with i915.modeset=0
adrxd
20 July 2022 14:37
56
With i915.modeset=0 Laptop screen is printing booting messages and get stuck at Starting Hostname Service and not working sddm. So maybe modeset=0 is good mode but how to run the system?
Olli
20 July 2022 14:42
57
i think we’re getting closer. let me think a little bit. what happens if you boot to the point were it gets stuck and you change via ALT-F to a different text-console ? is there a text console that you can login ?
Olli
20 July 2022 14:44
59
okay so it’s just that sddm is stuck. you are on plasma, give me some minutes please.
Olli
20 July 2022 14:47
60
okay boot till you’re stuck, change to a console, login and try this from text-console
kquitapp5 plasmashell && kstart5 plasmashell > /dev/null 2>&1
then you have to change with ALT-F1 to the graphical console
