adrxd
19 July 2022 13:03
1
Hello guys,
I’ve a problem with laptop monitor it is detected but it’s only showing black screen however external monitor works just fine.
As from I can see from the commands below the laptop monitor is connected.
Specs:
Laptop resolution:
13.5" 3000 x 2000
Intel Pentium J3710 1.60 GHz
RAM:
4 GB DDR3L
128 GB
Kernel version: Linux 5.15.55-1-MANJARO #1 SMP PREEMPT Fri Jul 15 09:45:39 UTC 2022 x86_64 GNU/Linux
Edid decode from /sys/class/drm/card0-eDP-1/edid is below.
edid-decode (hex):
00 ff ff ff ff ff ff 00 34 a9 a2 96 00 11 21 44
ff 19 01 04 a5 1d 13 78 03 ee 91 a3 54 4c 99 26
0f 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 80 a2 b8 68 b1 d0 40 70 08 08
88 00 1d be 10 00 00 1e 00 00 00 fd 00 2e 3c 5e
7c 2a 01 0a 20 20 20 20 20 20 00 00 00 fc 00 56
56 58 31 34 50 30 34 38 4d 30 30 0a 00 00 00 10
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 68
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: MEI
Model: 38562
Serial Number: 1143017728
Model year: 2015
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 8
DisplayPort interface
Maximum image size: 29 cm x 19 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4
First detailed timing includes the native pixel format and preferred refresh rate
Display is continuous frequency
Color Characteristics:
Red : 0.6396, 0.3300
Green: 0.2998, 0.5996
Blue : 0.1503, 0.0595
White: 0.3125, 0.3291
Established Timings I & II: none
Standard Timings: none
Detailed Timing Descriptors:
DTD 1: 3000x2000 59.985234 Hz 3:2 123.810 kHz 416.000000 MHz (285 mm x 190 mm)
Hfront 8 Hsync 8 Hback 344 Hpol P
Vfront 8 Vsync 8 Vback 48 Vpol P
Display Range Limits:
Monitor ranges (Bare Limits): 46-60 Hz V, 94-124 kHz H, max dotclock 420 MHz
Display Product Name: 'VVX14P048M00'
Dummy Descriptor:
Checksum: 0x68
Here is the output inxi -Fxz
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Console: pty pts/2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Plaisio s SA product: Flynote Xi v: N/A
serial: <superuser required>
Mobo: NA model: NA serial: <superuser required> UEFI: American Megatrends
v: E.S142C.E0_25.D4.047.rom date: 07/28/2021
ID-1: BAT0 charge: 38.0 Wh (100.0%) condition: 38.0/38.0 Wh (100.0%)
volts: 7.6 min: N/A model: Broadwell Battery status: full
Info: quad core model: Intel Pentium J3710 bits: 64 type: MCP arch: Airmont
rev: 4 cache: L1: 224 KiB L2: 2 MiB
Speed (MHz): avg: 684 high: 1197 min/max: 480/2640 cores: 1: 579 2: 1197
3: 480 4: 480 bogomips: 12805
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
driver: i915 v: kernel arch: Gen8 bus-ID: 00:02.0
Device-2: Syntek HD WebCam type: USB driver: uvcvideo bus-ID: 1-2.1:5
Display: x11 server: X.org v: 1.21.1.4 driver: X: loaded: modesetting
gpu: i915 tty: 80x24 resolution: 1: 1920x1200 2: 3000x2000
Message: GL data unavailable in console. Try -G --display
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 1-1:2
Device-2: MosArt USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: yes
Message: No PCI device data found.
IF-ID-1: wlp0s20u5i2 state: up mac: <filter>
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 1-5:4
Local Storage: total: 115.25 GiB used: 8.61 GiB (7.5%)
ID-1: /dev/mmcblk0 model: SCA128 size: 115.25 GiB
ID-1: / size: 48.19 GiB used: 8.61 GiB (17.9%) fs: ext4 dev: /dev/mmcblk0p4
ID-2: /boot/efi size: 115.2 MiB used: 298 KiB (0.3%) fs: vfat
dev: /dev/mmcblk0p1
ID-1: swap-1 type: partition size: 8.6 GiB used: 0 KiB (0.0%)
dev: /dev/mmcblk0p2
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 178 Uptime: 7m Memory: 3.74 GiB used: 1.04 GiB (27.8%)
Init: systemd Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1174
Shell: Bash v: 5.1.16 inxi: 3.3.19
Here is the output from xrandr.
Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
3200x1800 59.94
2880x1620 59.96 59.97
2560x1600 59.99 59.97
2560x1440 59.96 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 59.95*+
1920x1080 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1600x1200 60.00
1280x1024 75.02 60.02
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x576i 50.00
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
Any solution?
pressing win+p and playing with those settings may help
adrxd
19 July 2022 22:10
3
Already tried that. It’s not working. Seems like the laptop monitor is only detected when it’s connected to external monitor. When you reboot the grub bootloader is loading and when it comes to graphical interface black screen goes on.
Strange. Maybe driver issue?
output from:
mhwd -l && mhwd -li
find /etc/X11/ -name "*.conf"
adrxd
20 July 2022 07:20
5
> 0000:00:02.0 (0300:8086:22b1) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
On the login screen it feels like I’m typing the password on laptop display and it accepts it but there is only black screen.
But when i the extend the monitors (Extend to right for ex.) my mouse is still locked only in external monitor.
go to system settings/compositor and uncheck enable on startup and uncheck allow apps to block…, click apply, reboot and see if it helped
adrxd
20 July 2022 07:31
7
Nope. It’s the same.
Whenever I reboot the laptop, in Display Configuration Laptop Screen, Enabled option is always unchecked.
When I check the option it’s still stays unchecked.
so enable the compositor back…
if you disconnect the external monitor, reboot is the laptop detected?
adrxd
20 July 2022 07:45
9
If I disconnect external monitor laptop monitor is only showing the grub bootloader, and when it reaches graphical interface it stops showing anything (goes to black screen).
I’ve ssh access as well.
This is the XORG log. Pay attention to eDP-1. It says eDP-1 connected but has no monitor section.
[ 9.262] (II) modeset(0): Output eDP-1 has no monitor section
[ 9.262] (II) modeset(0): Output DP-1 has no monitor section
[ 9.264] (II) modeset(0): Output HDMI-1 has no monitor section
[ 9.264] (II) modeset(0): Output DP-2 has no monitor section
[ 9.443] (II) modeset(0): Output HDMI-2 has no monitor section
[ 9.446] (II) modeset(0): EDID for output eDP-1
[ 9.446] (II) modeset(0): Manufacturer: MEI Model: 96a2 Serial#: 1143017728
[ 9.446] (II) modeset(0): Year: 2015 Week: 255
[ 9.446] (II) modeset(0): EDID Version: 1.4
[ 9.447] (II) modeset(0): Digital Display Input
[ 9.447] (II) modeset(0): 8 bits per channel
[ 9.447] (II) modeset(0): Digital interface is DisplayPort
[ 9.447] (II) modeset(0): Max Image Size [cm]: horiz.: 29 vert.: 19
[ 9.447] (II) modeset(0): Gamma: 2.20
[ 9.447] (II) modeset(0): No DPMS capabilities specified
[ 9.447] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 9.447] (II) modeset(0): First detailed timing is preferred mode
[ 9.447] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 9.447] (II) modeset(0): Display is continuous-frequency
[ 9.447] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 9.447] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[ 9.447] (II) modeset(0): Manufacturer's mask: 0
[ 9.447] (II) modeset(0): Supported detailed timing:
[ 9.447] (II) modeset(0): clock: 416.0 MHz Image Size: 290 x 190 mm
[ 9.447] (II) modeset(0): h_active: 3000 h_sync: 3008 h_sync_end 3016 h_blank_end 3360 h_border: 0
[ 9.447] (II) modeset(0): v_active: 2000 v_sync: 2008 v_sync_end 2016 v_blanking: 2064 v_border: 0
[ 9.447] (II) modeset(0): Ranges: V min: 46 V max: 60 Hz, H min: 94 H max: 124 kHz, PixClock max 425 MHz
[ 9.447] (II) modeset(0): Monitor name: VVX14P048M00
[ 9.447] (II) modeset(0): EDID (in hex):
[ 9.447] (II) modeset(0): 00ffffffffffff0034a9a29600112144
[ 9.447] (II) modeset(0): ff190104a51d137803ee91a3544c9926
[ 9.447] (II) modeset(0): 0f505400000001010101010101010101
[ 9.447] (II) modeset(0): 01010101010180a2b868b1d040700808
[ 9.447] (II) modeset(0): 88001dbe1000001e000000fd002e3c5e
[ 9.447] (II) modeset(0): 7c2a010a202020202020000000fc0056
[ 9.447] (II) modeset(0): 56583134503034384d30300a00000010
[ 9.447] (II) modeset(0): 00000000000000000000000000000068
[ 9.448] (II) modeset(0): Not using default mode "3200x1800" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "3840x2160" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "4096x2304" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "5120x2880" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "2560x1440" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "7680x4320" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Not using default mode "15360x8640" (bad mode clock/interlace/doublescan)
[ 9.448] (II) modeset(0): Printing probed modes for output eDP-1
[ 9.448] (II) modeset(0): Modeline "3200x1800"x59.9 373.00 3200 3248 3280 3360 1800 1803 1808 1852 +hsync -vsync (111.0 kHz d)
[ 9.448] (II) modeset(0): Modeline "2880x1620"x60.0 396.25 2880 3096 3408 3936 1620 1623 1628 1679 -hsync +vsync (100.7 kHz d)
[ 9.448] (II) modeset(0): Modeline "2880x1620"x60.0 303.75 2880 2928 2960 3040 1620 1623 1628 1666 +hsync -vsync (99.9 kHz d)
[ 9.448] (II) modeset(0): Modeline "2560x1600"x60.0 348.50 2560 2760 3032 3504 1600 1603 1609 1658 -hsync +vsync (99.5 kHz d)
[ 9.448] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 9.448] (II) modeset(0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz d)
[ 9.449] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz d)
[ 9.449] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 9.449] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 9.449] (II) modeset(0): Modeline "2048x1152"x60.0 406.50 2048 2220 2444 2840 1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[ 9.449] (II) modeset(0): Modeline "2048x1152"x60.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 9.449] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 9.449] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 9.449] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 9.449] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 9.449] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 9.449] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 9.449] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 9.449] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 9.449] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 9.449] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 9.449] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 9.449] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 9.449] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 9.449] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 9.450] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 9.450] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 9.450] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 9.450] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 9.450] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 9.450] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 9.450] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 9.450] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 9.450] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 9.450] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 9.451] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 9.451] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.451] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 9.451] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 9.451] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 9.451] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 9.451] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 9.451] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 9.451] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 9.451] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 9.451] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 9.451] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 9.451] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 9.451] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 9.451] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 9.451] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 9.451] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 9.451] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 9.451] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 9.451] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 9.451] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 9.451] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 9.451] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 9.452] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 9.452] (II) modeset(0): EDID for output DP-1
[ 9.453] (II) modeset(0): EDID for output HDMI-1
[ 9.453] (II) modeset(0): EDID for output DP-2
[ 9.633] (II) modeset(0): EDID for output HDMI-2
[ 9.633] (II) modeset(0): Output eDP-1 connected
[ 9.633] (II) modeset(0): Output DP-1 disconnected
[ 9.633] (II) modeset(0): Output HDMI-1 disconnected
[ 9.633] (II) modeset(0): Output DP-2 disconnected
[ 9.633] (II) modeset(0): Output HDMI-2 disconnected
[ 9.634] (II) modeset(0): Using exact sizes for initial modes
[ 9.634] (II) modeset(0): Output eDP-1 using initial mode 2560x1600 +0+0
[ 9.634] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.634] (==) modeset(0): DPI set to (96, 96)
[ 9.634] (II) Loading sub module "fb"
[ 9.634] (II) LoadModule: "fb"
[ 9.634] (II) Module "fb" already built-in
[ 9.778] (==) modeset(0): Backing store enabled
[ 9.778] (==) modeset(0): Silken mouse enabled
[ 9.782] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9.783] (==) modeset(0): DPMS enabled
[ 9.783] (II) modeset(0): [DRI2] Setup complete
[ 9.783] (II) modeset(0): [DRI2] DRI driver: crocus
[ 9.783] (II) modeset(0): [DRI2] VDPAU driver: va_gl
so the built int laptop monitor isnt working … did it worked in the live usb?
try different kernels, install the 5.10 and the 5.18, reboot and select the 5.10 in grub menu and test, do the same with the 5.18
adrxd
20 July 2022 08:06
11
No. It didn’t worked in the live usb as well.
I’ve tried with following versions of kernel 5.4, 5.10, 5.15, 5.18 & 5.19.
porvide logs:
journalctl -b0 -p4 --no-pager
adrxd
20 July 2022 08:11
13
ul 20 10:09:34 dcfn-flynote-xi plasmashell[565]: requesting unexisting screen 0
Jul 20 10:09:34 dcfn-flynote-xi plasmashell[565]: requesting unexisting screen 0
Jul 20 10:09:34 dcfn-flynote-xi plasmashell[565]: requesting unexisting screen 1
Here is full log.
nothing there except:
can you try under wayland, install this:
sudo pacman -S plasma-wayland-session
it will also install wayland dependencies, then reboot and select wayland in the login screen, then reboot again so that wayland is selected as default
adrxd
20 July 2022 10:41
15
I’ve installed plasma-wayland-session, whenever it enter wayland it keeps restarting to login graphical interface (sddm).
I’ve also reinstalled manjaro with basestrap and wayland as well but same result (keeps restarting back to sddm).
All this is displaying on external monitor and not laptop screen.
wayland is unstable on kde, but was hoping it would work with your system…
reinstalling was not needed since the issue happened also in the live usb…
are you dual booting with win? if yes is fastboot disabled?
you could try booting into live session of for example linux mint, and see if it happens there also
adrxd
20 July 2022 10:49
17
I’ve tried couple of different distros (mint is one of them) before opening the thread same thing happened there.
Fastboot is disabled. Laptop screen works just fine on Windows.
so its a linux and your hardware thing … maybe some setting in bios?
open this:
kate /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(i915)
save the file, and run:
sudo mkinitcpio -P
reboot
adrxd
20 July 2022 11:06
19
Okay now small progress.
Laptop monitor is detected and in “Monitor Settings” if you expend to the left mouse goes to left however it’s still stays black. Both “Laptop Screen” and “DELL Monitor” are enabled.
Detected resolutions are not correct for the laptop btw.
well that was it haha …
try disabling the compositor again at startup, then reboot
