Here you go:
cat /sys/power/mem_sleep
[s2idle]
journalctl --boot 0 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
shows nothing. But I haven’t put my laptop to sleep today. I’ll reboot (software updates just hit) and be back…
I rebooted, put the laptop to sleep (using the action button), closed and opened the lid and ran the command again:
oct 03 19:40:58 machine systemd[1]: Starting System Suspend...
oct 03 19:40:58 machine wpa_supplicant[768]: p2p-dev-wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
oct 03 19:40:58 machine wpa_supplicant[768]: nl80211: deinit ifname=p2p-dev-wlp3s0 disabled_11b_rates=0
oct 03 19:40:58 machine systemd-sleep[2475]: Successfully froze unit 'user.slice'.
oct 03 19:40:58 machine systemd-sleep[2475]: Performing sleep operation 'suspend'...
oct 03 19:40:58 machine kernel: PM: suspend entry (s2idle)
oct 03 19:41:06 machine kernel: Filesystems sync: 0.035 seconds
oct 03 19:41:06 machine kernel: Freezing user space processes
oct 03 19:41:06 machine kernel: Freezing user space processes completed (elapsed 0.032 seconds)
oct 03 19:41:06 machine kernel: OOM killer disabled.
oct 03 19:41:06 machine kernel: Freezing remaining freezable tasks
oct 03 19:41:06 machine kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
oct 03 19:41:06 machine kernel: printk: Suspending console(s) (use no_console_suspend to debug)
oct 03 19:41:06 machine kernel: fxpm, fxgmac_suspend callin
oct 03 19:41:06 machine kernel: fxpm,_fxgmac_shutdown, callin
oct 03 19:41:06 machine kernel: fxgmac_net_powerdown callin here.
oct 03 19:41:06 machine kernel: fxgmac_net_powerdown continue with down process.
oct 03 19:41:06 machine kernel: fxgmac_free_irqs, MSIx irq_tx clear done, ch=0
oct 03 19:41:06 machine kernel: fxgmac_free_irqs, MSIx rx irq clear done, total=4
oct 03 19:41:06 machine kernel: napi_disable, msix ch0 napi disabled done,del=1
oct 03 19:41:06 machine kernel: napi_disable, msix ch1 napi disabled done,del=1
oct 03 19:41:06 machine kernel: napi_disable, msix ch2 napi disabled done,del=1
oct 03 19:41:06 machine kernel: napi_disable, msix ch3 napi disabled done,del=1
oct 03 19:41:06 machine kernel: fxgmac_config_powerdown, phy and mac status update
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x0000a00c
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x00000000
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x0000a00d
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x0000a00e
oct 03 19:41:06 machine kernel: config_wol callout
oct 03 19:41:06 machine kernel: fxgmac_update_aoe_ipv4addr, Get net device binary IP ok, 0xca01a8c0
oct 03 19:41:06 machine kernel: fxgmac_update_aoe_ipv4addr, update arp ipaddr reg from 0x00000000 to 0xca01a8c0
oct 03 19:41:06 machine kernel: fxgmac_get_netdev_ip6addr FXGMAC_NS_IFA_GLOBAL_UNICAST is set, 2
oct 03 19:41:06 machine kernel: fxgmac_get_netdev_ip6addr get ipv6 addr failed, use default.
oct 03 19:41:06 machine kernel: fxgmac_update_ns_offload_ipv6addr, get net device ipv6 addr with err and ignore NS offload.
oct 03 19:41:06 machine kernel: fxgmac_get_netdev_ip6addr FXGMAC_NS_IFA_LOCAL_LINK is set, 1
oct 03 19:41:06 machine kernel: fxgmac_config_powerdown callout, reg=0x0000800f
oct 03 19:41:06 machine kernel: fxgmac_net_powerdown callout, powerstate=1.
oct 03 19:41:06 machine kernel: fxpm,_fxgmac_shutdown, save pci state done.
oct 03 19:41:06 machine kernel: fxpm,_fxgmac_shutdown callout, enable wake=1.
oct 03 19:41:06 machine kernel: fxpm, fxgmac_suspend callout to sleep
oct 03 19:41:06 machine kernel: pcieport 0000:00:08.3: quirk: disabling D3cold for suspend
oct 03 19:41:06 machine kernel: ACPI: EC: interrupt blocked
oct 03 19:41:06 machine kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.ACDC.RTAC], AE_NOT_FOUND (20230628/psargs-330)
oct 03 19:41:06 machine kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
oct 03 19:41:06 machine kernel: ACPI: EC: interrupt unblocked
oct 03 19:41:06 machine kernel: fxpm, fxgmac_resume callin
oct 03 19:41:06 machine kernel: fxgmac_net_powerup callin
oct 03 19:41:06 machine kernel: fxgmac start callin here.
oct 03 19:41:06 machine kernel: CHIP_RESET 0x80000001
oct 03 19:41:06 machine kernel: [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: SMU is resuming...
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: SMU is resumed successfully!
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 16 ok, ctrl=0x08100204, data=0x0000006a
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x00000052
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x0000231d
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x00000051
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x000004a9
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x00000057
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x0000264c
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x00002600
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x00001800
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 30 ok, ctrl=0x081e0204, data=0x00000027
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 31 ok, ctrl=0x081f0204, data=0x0000a812
oct 03 19:41:06 machine kernel: fxgmac_dismiss_all_int callin
oct 03 19:41:06 machine kernel: fxgmac hw init call in
oct 03 19:41:06 machine kernel: fxgmac_flush_tx_queues, reg=0x00000000897f8334, val=0x001f0009
oct 03 19:41:06 machine kernel: fxgmac_flush_tx_queues wait... reg=0x00000000897f8334, val=0x00000000
oct 03 19:41:06 machine kernel: enable_rss callout, rss ctrl reg=0x80001807
oct 03 19:41:06 machine kernel: yt6801 0000:02:00.0 enp2s0: 1 Tx hardware queues, 8192 byte fifo per queue
oct 03 19:41:06 machine kernel: yt6801 0000:02:00.0 enp2s0: 4 Rx hardware queues, 8192 byte fifo per queue
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 4 ok, ctrl=0x08040204, data=0x00001de1
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 0 ok, ctrl=0x08000204, data=0x00009140
oct 03 19:41:06 machine kernel: fxgmac enable rx checksum.
oct 03 19:41:06 machine kernel: fxgmac_update_vlan_hash_tabl done,hash tbl=00000000.
oct 03 19:41:06 machine kernel: fxgmac enable MAC rx vlan stripping.
oct 03 19:41:06 machine kernel: fxgmac_write_ephy_reg id 18 ok, ctrl=0x08120204, data=0x00000c00
oct 03 19:41:06 machine kernel: fxgmac hw init callout
oct 03 19:41:06 machine kernel: napi_enable, msix ch0 napi enabled done,add=1
oct 03 19:41:06 machine kernel: napi_enable, msix ch1 napi enabled done,add=1
oct 03 19:41:06 machine kernel: napi_enable, msix ch2 napi enabled done,add=1
oct 03 19:41:06 machine kernel: napi_enable, msix ch3 napi enabled done,add=1
oct 03 19:41:06 machine kernel: fxgmac_req_irqs, MSIx irq_tx request ok, ch=0, irq=74,enp2s0-ch0-Tx-0
oct 03 19:41:06 machine kernel: fxgmac_req_irqs, MSIx irq request ok, total=4,67~73
oct 03 19:41:06 machine kernel: fxgmac_net_powerup callout, powerstate=2.
oct 03 19:41:06 machine kernel: fxpm, fxgmac_resume callout
oct 03 19:41:06 machine kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
oct 03 19:41:06 machine kernel: amdgpu 0000:65:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
oct 03 19:41:06 machine kernel: [drm] ring gfx_32778.1.1 was added
oct 03 19:41:06 machine kernel: [drm] ring compute_32778.2.2 was added
oct 03 19:41:06 machine kernel: [drm] ring sdma_32778.3.3 was added
oct 03 19:41:06 machine kernel: [drm] ring gfx_32778.1.1 ib test pass
oct 03 19:41:06 machine kernel: [drm] ring compute_32778.2.2 ib test pass
oct 03 19:41:06 machine kernel: [drm] ring sdma_32778.3.3 ib test pass
oct 03 19:41:06 machine kernel: OOM killer enabled.
oct 03 19:41:06 machine kernel: Restarting tasks ... done.
oct 03 19:41:06 machine kernel: random: crng reseeded on system resumption
oct 03 19:41:06 machine wpa_supplicant[768]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
oct 03 19:41:06 machine systemd-sleep[2475]: System returned from sleep operation 'suspend'.
oct 03 19:41:06 machine systemd-sleep[2475]: Successfully thawed unit 'user.slice'.
oct 03 19:41:06 machine systemd[1]: systemd-suspend.service: Deactivated successfully.
oct 03 19:41:06 machine kernel: PM: suspend exit
oct 03 19:41:06 machine wpa_supplicant[768]: nl80211: deinit ifname=wlp3s0 disabled_11b_rates=0
oct 03 19:41:06 machine systemd[1]: Finished System Suspend.
And I also get the same results after running systemctl suspend
Is it a good sign? (I guess yes, it is…)
