When bluetooth is enabled (via KDE plasma’s GUI), my laptop will immediately wake from hibernation (both systemctl hibernate
and systemctl suspend-then-hibernate
). But suspend works as expected.
I tried removing and reinstalling tlp
, but that didn’t help.
I also looked for options like “Wake on bluetooth”, “Wake on LAN” in the BIOS, but I didn’t find anything similar.
I found a similar topic from 2018, but it’s said to be outdated and already archived.
Output of inxi -Fxz
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ZenBook UX425EA_UX425EA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: UX425EA v: 1.0 serial: <filter> UEFI: American Megatrends LLC.
v: UX425EA.307 date: 05/25/2021
Battery: ID-1: BAT0 charge: 43.5 Wh (67.0%) condition: 64.9/67.1 Wh (96.7%) volts: 15.9
min: 15.9 model: ASUSTeK UX425 status: Discharging
CPU: Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38720
Speed: 469 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 469 2: 555 3: 553 4: 1168
5: 568 6: 558 7: 1006 8: 1081
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 0000:00:02.0
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-6:2
Display: x11 server: X.Org 1.20.13 driver: loaded: intel unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000 bus-ID: 0000:00:14.3
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
RAID: Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6
bus-ID: 0000:00:0e.0
Drives: Local Storage: total: 931.51 GiB used: 36.62 GiB (3.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB
temp: 39.9 C
Partition: ID-1: / size: 392.65 GiB used: 36.59 GiB (9.3%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 26.4 MiB (27.5%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
Info: Processes: 266 Uptime: 1m Memory: 15.33 GiB used: 1.37 GiB (8.9%) Init: systemd
Compilers: gcc: 11.1.0 Packages: 1394 Shell: Zsh v: 5.8 inxi: 3.3.06
Please let me know if any other information is needed. Thank you very much for your help!
