I found the data using:
sudo journalctl --since="2024-03-09 09:00:00" > journal_9.03.2024.log
Here is the hibernation process:
mar 09 18:59:03 Sirius16-Manjaro dbus-daemon[961]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.49' (uid=1000 pid=7247 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
mar 09 18:59:03 Sirius16-Manjaro org.kde.powerdevil.backlighthelper[1426187]: Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
mar 09 18:59:03 Sirius16-Manjaro dbus-daemon[961]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
mar 09 18:59:05 Sirius16-Manjaro plasmashell[7180]: error creating screencast "Nie można znaleźć id 0 okna"
mar 09 18:59:09 Sirius16-Manjaro systemd-logind[975]: The system will hibernate now!
mar 09 18:59:09 Sirius16-Manjaro ModemManager[1069]: <msg> [sleep-monitor-systemd] system is about to suspend
mar 09 18:59:09 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007149.8594] manager: sleep: sleep requested (sleeping: no enabled: yes)
mar 09 18:59:09 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007149.8595] device (enp5s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 09 18:59:09 Sirius16-Manjaro systemd-networkd[615]: enp5s0: Link DOWN
mar 09 18:59:09 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007149.8690] device (p2p-dev-wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 09 18:59:09 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007149.8693] manager: NetworkManager state is now ASLEEP
mar 09 18:59:09 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007149.8694] device (wlp6s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
mar 09 18:59:09 Sirius16-Manjaro kded6[7134]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
mar 09 18:59:09 Sirius16-Manjaro dbus-daemon[961]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=1055 comm="/usr/bin/NetworkManager --no-daemon")
mar 09 18:59:09 Sirius16-Manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 09 18:59:09 Sirius16-Manjaro dbus-daemon[961]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
mar 09 18:59:09 Sirius16-Manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
mar 09 18:59:09 Sirius16-Manjaro systemd-networkd[615]: wlp6s0: Lost carrier
mar 09 18:59:09 Sirius16-Manjaro systemd-timesyncd[729]: No network connectivity, watching for changes.
mar 09 18:59:09 Sirius16-Manjaro kernel: wlp6s0: deauthenticating from f8:64:b8:d7:36:aa by local choice (Reason: 3=DEAUTH_LEAVING)
mar 09 18:59:10 Sirius16-Manjaro wpa_supplicant[1059]: wlp6s0: CTRL-EVENT-DISCONNECTED bssid=f8:64:b8:d7:36:aa reason=3 locally_generated=1
mar 09 18:59:10 Sirius16-Manjaro wpa_supplicant[1059]: wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.0251] device (wlp6s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Withdrawing address record for fe80::13a8:5fa5:d4b8:e132 on wlp6s0.
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Leaving mDNS multicast group on interface wlp6s0.IPv6 with address fe80::13a8:5fa5:d4b8:e132.
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.0255] dhcp4 (wlp6s0): canceled DHCP transaction
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Interface wlp6s0.IPv6 no longer relevant for mDNS.
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.0255] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.0255] dhcp4 (wlp6s0): state changed no lease
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Interface wlp6s0.IPv4 no longer relevant for mDNS.
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Leaving mDNS multicast group on interface wlp6s0.IPv4 with address 192.168.1.108.
mar 09 18:59:10 Sirius16-Manjaro systemd-networkd[615]: wlp6s0: Link DOWN
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Withdrawing address record for 192.168.1.108 on wlp6s0.
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.0773] device (wlp6s0): set-hw-addr: set MAC address to BE:9C:4E:DC:31:1A (scanning)
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Joining mDNS multicast group on interface wlp6s0.IPv4 with address 192.168.1.108.
mar 09 18:59:10 Sirius16-Manjaro systemd-networkd[615]: wlp6s0: Link UP
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: New relevant interface wlp6s0.IPv4 for mDNS.
mar 09 18:59:10 Sirius16-Manjaro avahi-daemon[960]: Registering new address record for 192.168.1.108 on wlp6s0.IPv4.
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.1662] device (wlp6s0): supplicant interface state: completed -> disconnected
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.1666] device (wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 09 18:59:10 Sirius16-Manjaro NetworkManager[1055]: <info> [1710007150.3257] device (wlp6s0): set-hw-addr: reset MAC address to B0:DC:EF:2F:63:7C (unmanage)
mar 09 18:59:10 Sirius16-Manjaro wpa_supplicant[1059]: p2p-dev-wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
mar 09 18:59:10 Sirius16-Manjaro wpa_supplicant[1059]: nl80211: deinit ifname=p2p-dev-wlp6s0 disabled_11b_rates=0
mar 09 18:59:10 Sirius16-Manjaro systemd[1]: Starting TUXEDO Control Center Service (sleep/resume)...
mar 09 18:59:10 Sirius16-Manjaro systemd[1]: Stopping TUXEDO Control Center Service...
mar 09 18:59:10 Sirius16-Manjaro wpa_supplicant[1059]: nl80211: deinit ifname=wlp6s0 disabled_11b_rates=0
mar 09 18:59:10 Sirius16-Manjaro tccd[1427733]: Stopping daemon..
mar 09 18:59:11 Sirius16-Manjaro tccd[977]: SIGINT - Exiting
mar 09 18:59:11 Sirius16-Manjaro tccd[977]: DisplayBacklightWorker: Save display brightness 50% (128) on exit
mar 09 18:59:11 Sirius16-Manjaro tccd[1427733]: Daemon is stopped
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: tccd.service: Deactivated successfully.
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: Stopped TUXEDO Control Center Service.
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: tccd.service: Consumed 46min 4.870s CPU time.
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: Finished TUXEDO Control Center Service (sleep/resume).
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: Reached target Sleep.
mar 09 18:59:11 Sirius16-Manjaro systemd[1]: Starting System Hibernate...
mar 09 18:59:11 Sirius16-Manjaro systemd-sleep[1428172]: Performing sleep operation 'hibernate'...
mar 09 18:59:11 Sirius16-Manjaro kernel: PM: hibernation: hibernation entry
And here is the boot from hibernation:
mar 09 23:27:16 Sirius16-Manjaro kernel: Filesystems sync: 0.005 seconds
mar 09 23:27:16 Sirius16-Manjaro kernel: Freezing user space processes
mar 09 23:27:16 Sirius16-Manjaro kernel: Freezing user space processes completed (elapsed 0.002 seconds)
mar 09 23:27:16 Sirius16-Manjaro kernel: OOM killer disabled.
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x000a0000-0x000fffff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x09a7f000-0x09ffffff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x0a200000-0x0a23bfff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x8b0e8000-0x8b163fff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x8dacf000-0x8dacffff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x8f5a6000-0x9adfefff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x9bff9000-0x9bffcfff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Marking nosave pages: [mem 0x9bfff000-0xffffffff]
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Basic memory bitmaps created
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Preallocating image memory
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Allocated 3142445 pages for snapshot
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Allocated 12569780 kbytes in 5.79 seconds (2170.94 MB/s)
mar 09 23:27:16 Sirius16-Manjaro kernel: Freezing remaining freezable tasks
mar 09 23:27:16 Sirius16-Manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.002 seconds)
mar 09 23:27:16 Sirius16-Manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: interrupt blocked
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: PM: Preparing to enter system sleep state S4
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: event blocked
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: EC stopped
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: PM: Saving platform NVS memory
mar 09 23:27:16 Sirius16-Manjaro kernel: Disabling non-boot CPUs ...
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 1 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 2 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 3 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 4 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 5 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 6 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 7 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 8 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: Spectre V2 : Update user space SMT mitigation: STIBP off
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 9 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 10 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 11 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 12 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 13 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 14 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: CPU 15 is now offline
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Creating image:
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Need to copy 3232459 pages
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Normal pages needed: 3232459 + 1024, available pages: 4951148
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: PM: Restoring platform NVS memory
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: EC started
mar 09 23:27:16 Sirius16-Manjaro kernel: AMD-Vi: Virtual APIC enabled
mar 09 23:27:16 Sirius16-Manjaro kernel: LVT offset 0 assigned for vector 0x400
mar 09 23:27:16 Sirius16-Manjaro kernel: Enabling non-boot CPUs ...
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C002: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU1 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C004: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU2 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C006: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU3 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C008: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU4 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00A: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU5 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00C: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU6 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00E: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU7 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C001: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU8 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C003: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU9 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C005: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU10 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C007: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU11 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C009: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU12 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00B: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU13 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00D: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU14 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: \_SB_.PLTF.C00F: Found 3 idle states
mar 09 23:27:16 Sirius16-Manjaro kernel: CPU15 is up
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: PM: Waking up from system sleep state S4
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: interrupt unblocked
mar 09 23:27:16 Sirius16-Manjaro kernel: ACPI: EC: event unblocked
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] PCIE GART of 512M enabled (table at 0x00000081FEB00000).
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb1: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb2: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb3: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] PSP is resuming...
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb4: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb7: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb8: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000F00000).
mar 09 23:27:16 Sirius16-Manjaro kernel: nvme 0000:04:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0015 address=0xe95ef000 flags=0x0000]
mar 09 23:27:16 Sirius16-Manjaro kernel: nvme nvme0: 15/0/0 default/read/poll queues
mar 09 23:27:16 Sirius16-Manjaro kernel: nvme nvme1: Shutdown timeout set to 8 seconds
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] reserve 0x4a00000 from 0x8010000000 for PSP TMR
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] reserve 0x1300000 from 0x81fc000000 for PSP TMR
mar 09 23:27:16 Sirius16-Manjaro kernel: nvme nvme1: 12/0/0 default/read/poll queues
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000035, smu fw if version = 0x00000040, smu fw program = 0, smu fw version = 0x00525800 (82.88.0)
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] DMUB hardware initialized: version=0x07002600
mar 09 23:27:16 Sirius16-Manjaro kernel: usb 3-1: reset high-speed USB device number 2 using xhci_hcd
mar 09 23:27:16 Sirius16-Manjaro kernel: usb 1-4: reset full-speed USB device number 3 using xhci_hcd
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: RAS: optional ras ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: RAP: optional rap ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: SMU is resuming...
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: SMU is resumed successfully!
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] DMUB hardware initialized: version=0x08003300
mar 09 23:27:16 Sirius16-Manjaro kernel: usb 1-3: reset full-speed USB device number 2 using xhci_hcd
mar 09 23:27:16 Sirius16-Manjaro kernel: atkbd serio0: Failed to enable keyboard on isa0060/serio0
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] kiq ring mec 3 pipe 1 q 0
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:69:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring gfx_32796.1.1 was added
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring compute_32796.2.2 was added
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring sdma_32796.3.3 was added
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring gfx_32796.1.1 ib test pass
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring compute_32796.2.2 ib test pass
mar 09 23:27:16 Sirius16-Manjaro kernel: [drm] ring sdma_32796.3.3 ib test pass
mar 09 23:27:16 Sirius16-Manjaro kernel: usb 1-5: reset full-speed USB device number 4 using xhci_hcd
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
mar 09 23:27:16 Sirius16-Manjaro kernel: amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb5: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: usb usb6: root hub lost power or was reset
mar 09 23:27:16 Sirius16-Manjaro kernel: iwlwifi 0000:06:00.0: WRT: Invalid buffer destination
mar 09 23:27:16 Sirius16-Manjaro kernel: iwlwifi 0000:06:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
mar 09 23:27:16 Sirius16-Manjaro kernel: iwlwifi 0000:06:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
mar 09 23:27:16 Sirius16-Manjaro kernel: iwlwifi 0000:06:00.0: WFPM_AUTH_KEY_0: 0x90
mar 09 23:27:16 Sirius16-Manjaro kernel: iwlwifi 0000:06:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: Basic memory bitmaps freed
mar 09 23:27:16 Sirius16-Manjaro kernel: OOM killer enabled.
mar 09 23:27:16 Sirius16-Manjaro kernel: Restarting tasks ... done.
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Device revision is 0
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Secure boot is enabled
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: OTP lock is enabled
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: API lock is enabled
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Debug lock is disabled
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: No support for _PRR ACPI method
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Boot Address: 0x100800
mar 09 23:27:16 Sirius16-Manjaro kernel: Bluetooth: hci0: Firmware Version: 60-48.23
mar 09 23:27:16 Sirius16-Manjaro kernel: PM: hibernation: hibernation exit
mar 09 23:27:16 Sirius16-Manjaro kwin_wayland[6034]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
mar 09 23:27:16 Sirius16-Manjaro systemd-sleep[1428172]: System returned from sleep operation 'hibernate'.
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/ldac
mar 09 23:27:16 Sirius16-Manjaro systemd[1]: Starting Load/Save RF Kill Switch Status...
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/aptx_hd
mar 09 23:27:16 Sirius16-Manjaro systemd[1]: Stopped target Bluetooth Support.
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_hd
mar 09 23:27:16 Sirius16-Manjaro systemd[4815]: Reached target Bluetooth.
mar 09 23:27:16 Sirius16-Manjaro systemd[1]: Started Load/Save RF Kill Switch Status.
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/aac
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aac
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/sbc
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/sbc
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/sbc_xq
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/sbc_xq
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_1
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_0
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/faststream
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/faststream_duplex
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/opus_05
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/opus_05
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/opus_05_duplex
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/opus_05_duplex
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Destroy Adv Monitor Manager
mar 09 23:27:16 Sirius16-Manjaro bluetoothd[1829]: Battery Provider Manager destroyed
mar 09 23:27:16 Sirius16-Manjaro dbus-daemon[961]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.36" (uid=1000 pid=6970 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.13" (uid=0 pid=1829 comm="/usr/lib/bluetooth/bluetoothd")
mar 09 23:27:16 Sirius16-Manjaro systemd[1]: systemd-hibernate.service: Deactivated successfully.
mar 09 23:27:17 Sirius16-Manjaro systemd[1]: Finished System Hibernate.
mar 09 23:27:17 Sirius16-Manjaro systemd[1]: systemd-hibernate.service: Consumed 6.841s CPU time.
mar 09 23:27:17 Sirius16-Manjaro systemd[1]: Reached target System Hibernation.
mar 09 23:27:17 Sirius16-Manjaro systemd[1]: Stopped target Sleep.
mar 09 23:27:17 Sirius16-Manjaro systemd-logind[975]: Operation 'hibernate' finished.
mar 09 23:27:17 Sirius16-Manjaro systemd[1]: Stopped target System Hibernation.
mar 09 23:27:17 Sirius16-Manjaro NetworkManager[1055]: <info> [1710023237.0247] manager: sleep: wake requested (sleeping: yes enabled: yes)
mar 09 23:27:17 Sirius16-Manjaro kernel: Generic FE-GE Realtek PHY r8169-0-500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-500:00, irq=MAC)
mar 09 23:27:17 Sirius16-Manjaro NetworkManager[1055]: <info> [1710023237.0251] device (enp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 09 23:27:17 Sirius16-Manjaro ModemManager[1069]: <msg> [sleep-monitor-systemd] system is resuming
