Hello, I recently install the Cinnamon edition of Manjaro, and later decided that I wanted to try Gnome so that I could benefit from using Wayland. I removed all the cinnamon related packages and installed the gnome meta-package including gdm and removed lightdm.
All seems to work really well so far except for when my laptop goes to sleep after 15 minutes of inactivity. When I wake it up, the gdm login screen appears but the laptop goes right back to sleep 15 seconds later. After waking up a second time, it stays awake.
This does not happen if i put the laptop in sleep mode manually by clicking the button from the menu.
I would appreciate if someone could help me diagnose the issue. I’m wondering if some configurations or packages relating to power management were left after switching DE’s.
inxi --filter --verbosity=8 --color=0
Kernel: 6.19.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
root=UUID=3df17036-c015-4d54-9309-6649f5120e99 rw quiet
cryptdevice=UUID=067f7b06-115e-44d7-85b3-88ba4dfd6cd5:luks-067f7b06-115e-44d7-85b3-88ba4dfd6cd5
root=/dev/mapper/luks-067f7b06-115e-44d7-85b3-88ba4dfd6cd5 apparmor=1
security=apparmor acpi_backlight=native
Desktop: GNOME v: 49.4 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506NF_FA506NF
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FA506NF v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: FA506NF.308 date: 01/08/2025
ID-1: BAT1 charge: 40.6 Wh (100%) condition: 40.6/48 Wh (84.5%) volts: 12.53
min: 11.68 model: ASUS A32-K55 type: Li-ion serial: N/A charging:
status: full control: start: N/A end: 90% cycles: N/A
System RAM: total: 24 GiB available: 22.79 GiB used: 5.96 GiB (26.2%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: spec: 5600 MT/s actual: 4800 MT/s volts:
note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M425R1GB4PB0-CWMOD serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: 4800 Series serial: <filter>
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404108
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3243 min/max: 416/4605 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3243 2: 3243 3: 3243
4: 3243 5: 3243 6: 3243 7: 3243 8: 3243 9: 3243 10: 3243 11: 3243 12: 3243
bogomips: 79045
xsaves xtopology
affected
Device-1: NVIDIA GA107 [GeForce RTX 2050] vendor: ASUSTeK driver: nvidia
v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none empty: DP-9,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, DP-8, Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 37.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 2b7e:b888
Display: wayland server: Xwayland v: 24.1.9 compositor: gnome-shell
driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt
LLVM 21.1.6 DRM 3.64 6.19.2-1-MANJARO) device-ID: 1002:1681
memory: 500 MiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA GA107 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.19.2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Foxconn
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: virbr2 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0489:e123
Report: rfkill ID: hci0 rfk-id: 39 state: up address: see --recommends
Device-1: luks-af41582c-41d3-4dce-b6da-af09c94d6607 maj-min: 253:1
type: LUKS dm: dm-1 size: 1.94 TiB
Components:
p-1: nvme1n1p1 maj-min: 259:1 size: 1.94 TiB
Device-2: luks-067f7b06-115e-44d7-85b3-88ba4dfd6cd5 maj-min: 253:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:5 size: 476.64 GiB
Local Storage: total: 7.74 TiB used: 1.58 TiB (20.4%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital model: WD PC
SN5000S SDEQNSJ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 34230100 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO NH
size: 7.28 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM51.3 temp: 27.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 65.8 GiB (14.1%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-067f7b06-115e-44d7-85b3-88ba4dfd6cd5 label: N/A
uuid: 3df17036-c015-4d54-9309-6649f5120e99
used: 688 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4 label: N/A
uuid: 02B1-2FC0
ID-3: /home raw-size: 1.94 TiB size: 1.91 TiB (98.38%)
used: 1.51 TiB (79.5%) fs: ext4 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-af41582c-41d3-4dce-b6da-af09c94d6607 label: Home
uuid: 3e092f30-b24a-40a8-a635-ed33182f33bf
ID-1: swap-1 type: file size: 16 GiB used: 1.27 GiB (7.9%) priority: -1
file: /swapfile
ID-1: /dev/nvme1n1p3 maj-min: 259:2 size: 5.34 TiB fs: <superuser required>
label: N/A uuid: N/A
Device-1: 1-4:2 info: Sonix USB2.0 HD UVC WebCam type: video driver: N/A
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 2b7e:b888 class-ID: 0e02 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-1:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-3:3 info: Foxconn / Hon Hai Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0489:e123 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-7: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 43.5 C mobo: 32.0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): cpu: 3200
Packages: 1583 pm: pacman pkgs: 1547 libs: 423 tools: pamac,yay pm: flatpak
pkgs: 36
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
2: https://manjaro.kurdy.org/stable/$repo/$arch
3: https://mirror.easyname.at/manjaro/stable/$repo/$arch
4: https://mirrors.manjaro.org/repo/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
8: https://mirrors2.manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 485
1: cpu: 100% command: ps pid: 1157321 mem: 4.15 MiB (0.0%)
2: cpu: 6.4% command: firefox pid: 1132722 mem: 729.4 MiB (3.1%)
3: cpu: 4.5% command: firefox pid: 1133393 mem: 340.2 MiB (1.4%)
4: cpu: 3.2% command: gnome-shell pid: 29897 mem: 470.0 MiB (2.0%)
5: cpu: 2.1% command: gnome-text-editor pid: 1150686 mem: 167.9 MiB (0.7%)
Memory top: 5 of 485
1: mem: 729.4 MiB (3.1%) command: firefox pid: 1132722 cpu: 6.4%
2: mem: 470.0 MiB (2.0%) command: gnome-shell pid: 29897 cpu: 3.2%
3: mem: 340.2 MiB (1.4%) command: firefox pid: 1133393 cpu: 4.5%
4: mem: 318.6 MiB (1.3%) command: firefox pid: 1133400 cpu: 0.4%
5: mem: 313.9 MiB (1.3%) command: exe pid: 668110 cpu: 0.4%
Processes: 485 Power: uptime: 3d 2h 57m states: freeze,mem,disk
suspend: s2idle wakeups: 34 fails: 4 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 9.05 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: kgx
inxi: 3.3.40
