Hello everyone!
I know, I know the old issue with nvidia. My laptop had been working perfectly until yesterday I clicked auto install proprietary drivers in Settings. Then issue arose (battery draining much faster before, and getting too hot in sleep). I removed the drivers and set the working gpu with optimus-manager. The issues have not gone
optimus-manager --status
Optimus Manager (Client) version 1.4
Current GPU mode : integrated
GPU mode requested for next login : no change
GPU at startup : integrated
Temporary config path: no
System info:
Kernel: 6.2.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=00f27dfc-c891-4c33-a2a6-c2c0992b5aff rw quiet splash
resume=UUID=a43fbbbb8-b407-4asdc-9f29-sadf687da14 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: Victus by HP Laptop 16-d1xxx v: N/A
Mobo: HP model: 8A26 v: 34.55 serial: <superuser required> UEFI: AMI
v: F.07 date: 04/20/2022
ID-1: BAT0 charge: 17.2 Wh (27.4%) condition: 62.8/70.1 Wh (89.6%)
volts: 16.6 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 90
Info: model: 12th Gen Intel Core i5-12500H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x42A
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2579 high: 3100 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 986 3: 3100
4: 3100 5: 3100 6: 3100 7: 1138 8: 3100 9: 3100 10: 3100 11: 977 12: 969
13: 3100 14: 3100 15: 3100 16: 3100 bogomips: 99568
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0408:5477
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0aae built: 2021 res: 1920x1080
dpi: 137 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.2.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 13d3:3567
Local Storage: total: 238.47 GiB used: 74.86 GiB (31.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 221.35 GiB size: 216.82 GiB (97.95%)
used: 74.86 GiB (34.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.83 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 315 Uptime: 56m wakeups: 63564 Memory: available: 15.29 GiB
used: 2.72 GiB (17.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1425
pm: pacman pkgs: 1417 libs: 368 tools: pamac,yay pm: flatpak pkgs: 8
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
Kernel 6.2 is marked EOL and will no longer receive updates. Have you tried with 5.15 or 6.1 which are both LTS kernels? Kernel 6.3 would be a good alternative if you seek a non LTS kernel.
I have not tried with other kernel versions. One thing which is interesting is the fact that the laptop was working perfectly before that. Can we rollback to that situation ?
Hello,
Devalyus:
HP Laptop 16-d1xxx
This model is supposed to have an RTX 3050Ti, correct?
Well, the inxi output you provided shows no trace of it.
Devalyus:
That means it might be turned off from BIOS, or is something about that model that make it act funky, as others reported to have issues on the HP community support, like this one:
I have HP Victus 16-d1xxx laptop. My graphics card is NVIDIA GeForce RTX 3050Ti. When I use it daily or play games, it doesn't matter, the GPU turns itself off. This event happens randomly. Sometimes I play games for 5 hours and there is no...
or this one
And they are using Windows that is supposed to be supported better than Linux …
Devalyus:
6.2.16-2-MANJARO
As pointed out already, that kernel is EOL.
before that - what exactly?
You should fully update your system.
sudo pacman-mirrors -f5 && sudo pacman -Syyu
then run
sudo mhwd-kernel -i linux61
or
sudo mhwd-kernel -i linux63
Actually I have specified in the issue above. Yesterday I clicked Auto install proprietary drivers in Settings(will never do again). After installing proprietary drivers laptop gets really hot in sleep mode and battery is draining much faster. Thanks I will try and get back
As for not showing discrete gpu, I disabled it in the config. Here it is new one:
root=UUID=99f27dfc-c891-4c87-a2a6-c2c0882b5aff rw quiet splash
resume=UUID=a01fbdb8-b407-4f5c-9f29-37240687da14 udev.log_priority=3
ID-1: BAT0 charge: 51.0 Wh (81.2%) condition: 62.8/70.1 Wh (89.6%)
volts: 17.2 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 91
System RAM: available: 15.29 GiB used: 2.16 GiB (14.1%)
microcode: 0x42A
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
Speed (MHz): avg: 2261 high: 3100 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 3100 3: 912 4: 825
5: 3100 6: 3100 7: 777 8: 3100 9: 3100 10: 3100 11: 3100 12: 909 13: 785
14: 3100 15: 3100 16: 972 bogomips: 99568
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Hewlett-Packard driver: N/A alternate: nouveau non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
direct-render: Yes
Local Storage: total: 238.47 GiB used: 67.58 GiB (28.3%)
fw-rev: HPS2 temp: 39.9 C scheme: GPT
used: 67.58 GiB (31.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 99f27dfc-c891-4c87-a2a6-c2c0882b5aff
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: E44B-722A
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: a01fbdb8-b407-4f5c-9f29-37240687da14
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 3-6:3 info: Quanta HP Wide Vision HD Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0408:5477 class-ID: fe01 serial: <filter>
Device-3: 3-7:4 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3567 class-ID: e001 serial: <filter>
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 362 Uptime: 4m wakeups: 25882 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1398 pm: pacman pkgs: 1390 libs: 363 tools: pamac,yay pm: flatpak
pkgs: 8 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
Right, so is using no driver, maybe because you are still using the EOL kernel so the nvidia modules for it are bonkers now, reason why you need to use a supported kernel.
It stuck in the booting after installing 6.1 @anon89812132
Sh:cant access tty; job control turned off
I tried to delete kernel 6.1 from emergency shell but it kept saying that the command not found. How can I remove it?
So that at least for now I can use my latop i had very serious task
That is just a notification by the shell that job control doesn’t work, that means that you can’t stop a program with Ctrl+C or Ctrl+Z
Did you actually updated the system before installing the new kernel? All the hooks and the mkinitcpio got generated, or you prematurely rebooted the system?
My suggestion is to manually boot by removing quick from kernel boot parameter and use nomodeset and also try linux63.
I think you are aiming for the most convoluted way to sort things out. To make sure things are ok, even if you have to boot in runlevel 3, and install the kernel from TTY, you can also manually reinstall the nvidia driver with:
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
Error: resume: hibernation device ‘/dev/mapper/luks-558055a3-long string here’ not found
Error: device ‘/dev/mapper/luks-long id here’ not found. Skipping fsck.
mount: /new_root: no filesystem type specified
You are now being dropped to an emergency shell.
Sh: can’t access tty:job control turned off
Sorry I am writing error message by hand
Yess fully updated the system before installing new kernel
Great, you also encrypted your system … Not my cup of tea, so maybe somebody else will pass around to give you some assistance.
Meanwhile here some hints related to that:
Solved.
In etc/default/grub the line GRUB_CMDLINE_LINUX_DEFAULT=… must contain the identifier as a device, not as a UUID. Even if that device has that UUID.
With the data from my OP:
I replaced
resume=/dev/disk/by-uuid/33333333-3333-3333-3333-333333333333
with
resume=/dev/mapper/crypt_sda2 and it works.
Probably (?) because the UUID of /dev/mapper/crypt_sda2 (from blkid) points to all btrfs subvolumes (in fstab), and even if /swap would be correctly identified, the physic…
You will need a Live Media Manjaro install and follow this to recover your system.
Difficulty: ★★☆☆☆
So you couldn’t wait until the update process had completed and you went for the reset/power button, didn’t you? And now you’re getting the message that you don’t have a kernel installed. Well, you’re not the only one — we’re seeing it happen all the time.
So, here’s how to fix it, you impatient n00b.
If you don’t happen to have a recent Manjaro installer USB/DVD/CD handy, direct your browser to this wonderful page , download t…
And make sure you also read this
I just did a fresh Virtualbox VM with 22.0.5 as base and updated to today’s stable update of 2023-04-11. The install used the automatic install mode with LUKS encryption using a normal password.
Boot process:
grub loads and ask for the password
after entering that it takes a short while
the cryptomount -u error happens: [PATCH v5 5/9] cryptodisk: Improve cryptomount -u error message
waiting or pressing any key continues the boot process
Now I’ve to see what changed and how to get that messa…
