[amougsu@amougsu-x540sa ~]$ journalctl -b-1 -p5 --no-pager
sie 28 09:31:23 amougsu-x540sa kernel: Linux version 5.19.1-3-MANJARO (builduser@fv-az196-43) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1 SMP PREEMPT_DYNAMIC Sat Aug 13 06:34:52 UTC 2022
sie 28 09:31:23 amougsu-x540sa kernel: ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/32 (20220331/tbfadt-564)
sie 28 09:31:23 amougsu-x540sa kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=d646ca08-27aa-4c41-9b31-e521778d53d7 rw quiet resume=UUID=0d6c80ce-a3ea-4b7f-9449-e598b38d3431 udev.log_priority=3
sie 28 09:31:23 amougsu-x540sa kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64", will be passed to user space.
sie 28 09:31:23 amougsu-x540sa kernel: random: crng init done
sie 28 09:31:23 amougsu-x540sa kernel: audit: type=2000 audit(1661671877.016:1): state=initialized audit_enabled=0 res=1
sie 28 09:31:23 amougsu-x540sa kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
sie 28 09:31:23 amougsu-x540sa kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
sie 28 09:31:23 amougsu-x540sa kernel: cherryview-pinctrl INT33FF:01: interrupt on unmapped interrupt line 2
sie 28 09:31:23 amougsu-x540sa kernel: SCSI subsystem initialized
sie 28 09:31:23 amougsu-x540sa kernel: VFS: Disk quotas dquot_6.6.0
sie 28 09:31:23 amougsu-x540sa kernel: Initialise system trusted keyrings
sie 28 09:31:23 amougsu-x540sa kernel: Key type blacklist registered
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Platform Keyring initialized
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Machine keyring initialized
sie 28 09:31:23 amougsu-x540sa kernel: Key type asymmetric registered
sie 28 09:31:23 amougsu-x540sa kernel: Asymmetric key parser 'x509' registered
sie 28 09:31:23 amougsu-x540sa kernel: Loading compiled-in X.509 certificates
sie 28 09:31:23 amougsu-x540sa kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a79eaf520fee2b4b1cc63b196c2a681703b07612'
sie 28 09:31:23 amougsu-x540sa kernel: Key type ._fscrypt registered
sie 28 09:31:23 amougsu-x540sa kernel: Key type .fscrypt registered
sie 28 09:31:23 amougsu-x540sa kernel: Key type fscrypt-provisioning registered
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
sie 28 09:31:23 amougsu-x540sa kernel: integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
sie 28 09:31:23 amougsu-x540sa kernel: scsi 0:0:0:0: Direct-Access ATA PLEXTOR PX-128S2 1.01 PQ: 0 ANSI: 5
sie 28 09:31:23 amougsu-x540sa kernel: sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
sie 28 09:31:23 amougsu-x540sa kernel: sd 0:0:0:0: [sda] Write Protect is off
sie 28 09:31:23 amougsu-x540sa kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sie 28 09:31:23 amougsu-x540sa kernel: scsi 1:0:0:0: CD-ROM Slimtype DVD A DA8A6SH GAA2 PQ: 0 ANSI: 5
sie 28 09:31:23 amougsu-x540sa kernel: sd 0:0:0:0: [sda] Attached SCSI disk
sie 28 09:31:23 amougsu-x540sa kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
sie 28 09:31:23 amougsu-x540sa kernel: usb: port power management may be unreliable
sie 28 09:31:23 amougsu-x540sa kernel: audit: type=1130 audit(1661671883.473:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:23 amougsu-x540sa kernel: audit: type=1130 audit(1661671883.493:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:23 amougsu-x540sa kernel: audit: type=1130 audit(1661671883.573:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:23 amougsu-x540sa kernel: audit: type=1130 audit(1661671883.623:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:23 amougsu-x540sa kernel: gpio gpiochip4: (INT0002 Virtual GPIO): not an immutable chip, please consider fixing it!
sie 28 09:31:24 amougsu-x540sa kernel: elan_i2c i2c-ELAN1000:00: supply vcc not found, using dummy regulator
sie 28 09:31:24 amougsu-x540sa kernel: audit: type=1130 audit(1661671884.226:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-8A47\x2d383D comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:24 amougsu-x540sa kernel: audit: type=1130 audit(1661671884.763:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:24 amougsu-x540sa kernel: audit: type=1127 audit(1661671884.843:8): pid=344 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
sie 28 09:31:24 amougsu-x540sa kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
sie 28 09:31:24 amougsu-x540sa kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
sie 28 09:31:24 amougsu-x540sa kernel: audit: type=1130 audit(1661671884.873:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:24 amougsu-x540sa kernel: audit: type=1130 audit(1661671884.980:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:25 amougsu-x540sa kernel: audit: type=1334 audit(1661671885.036:11): prog-id=12 op=LOAD
sie 28 09:31:25 amougsu-x540sa polkitd[359]: Loading rules from directory /etc/polkit-1/rules.d
sie 28 09:31:25 amougsu-x540sa polkitd[359]: Loading rules from directory /usr/share/polkit-1/rules.d
sie 28 09:31:25 amougsu-x540sa polkitd[359]: Finished loading, compiling and executing 5 rules
sie 28 09:31:25 amougsu-x540sa polkitd[359]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
sie 28 09:31:27 amougsu-x540sa kernel: Creating 1 MTD partitions on "intel-spi":
sie 28 09:31:27 amougsu-x540sa kernel: 0x000000000000-0x000000800000 : "BIOS"
sie 28 09:31:27 amougsu-x540sa wpa_supplicant[612]: Successfully initialized wpa_supplicant
sie 28 09:31:28 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: WPS-CANCEL
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: SME: Trying to authenticate with b0:6e:bf:9e:22:c0 (SSID='ASUS' freq=2472 MHz)
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: Trying to associate with b0:6e:bf:9e:22:c0 (SSID='ASUS' freq=2472 MHz)
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: Associated with b0:6e:bf:9e:22:c0
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=FR
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: WPA: Key negotiation completed with b0:6e:bf:9e:22:c0 [PTK=CCMP GTK=CCMP]
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to b0:6e:bf:9e:22:c0 completed [id=0 id_str=]
sie 28 09:31:29 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-56 noise=-95 txrate=13000
sie 28 09:31:29 amougsu-x540sa kernel: kauditd_printk_skb: 21 callbacks suppressed
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1103 audit(1661671889.496:33): pid=638 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1130 audit(1661671889.550:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:29 amougsu-x540sa systemd[643]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1101 audit(1661671889.576:35): pid=643 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1103 audit(1661671889.576:36): pid=643 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1006 audit(1661671889.576:37): pid=643 uid=0 old-auid=4294967295 auid=968 tty=(none) old-ses=4294967295 ses=1 res=1
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1300 audit(1661671889.576:37): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fff7f627470 a2=3 a3=7fff7f627185 items=0 ppid=1 pid=643 auid=968 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1327 audit(1661671889.576:37): proctitle="(systemd)"
sie 28 09:31:29 amougsu-x540sa kernel: audit: type=1105 audit(1661671889.580:38): pid=643 uid=0 auid=968 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:30 amougsu-x540sa kernel: audit: type=1130 audit(1661671889.996:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:30 amougsu-x540sa kernel: audit: type=1105 audit(1661671890.020:40): pid=638 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:31:35 amougsu-x540sa kernel: audit: type=1131 audit(1661671895.546:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:55 amougsu-x540sa kernel: audit: type=1131 audit(1661671915.426:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:31:55 amougsu-x540sa kernel: audit: type=1334 audit(1661671915.533:43): prog-id=0 op=UNLOAD
sie 28 09:31:55 amougsu-x540sa kernel: audit: type=1334 audit(1661671915.533:44): prog-id=0 op=UNLOAD
sie 28 09:31:55 amougsu-x540sa kernel: audit: type=1334 audit(1661671915.533:45): prog-id=0 op=UNLOAD
sie 28 09:32:01 amougsu-x540sa lightdm[688]: gkr-pam: unable to locate daemon control file
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1100 audit(1661671921.110:46): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="amougsu" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1101 audit(1661671921.113:47): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="amougsu" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1106 audit(1661671921.250:48): pid=638 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1104 audit(1661671921.250:49): pid=638 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1103 audit(1661671921.266:50): pid=688 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="amougsu" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1006 audit(1661671921.266:51): pid=688 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1300 audit(1661671921.266:51): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffef167f9b0 a2=4 a3=7ffef167f6c4 items=0 ppid=382 pid=688 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" key=(null)
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1327 audit(1661671921.266:51): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1130 audit(1661671921.316:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:01 amougsu-x540sa kernel: audit: type=1101 audit(1661671921.336:53): pid=702 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="amougsu" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:01 amougsu-x540sa systemd[702]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[amougsu] ruser=[<unknown>] rhost=[<unknown>]
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: Configuration file /home/amougsu/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa wpa_supplicant[612]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=-95 txrate=72200
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: Configuration file /home/amougsu/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
sie 28 09:32:01 amougsu-x540sa systemd-xdg-autostart-generator[707]: /home/amougsu/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
sie 28 09:32:04 amougsu-x540sa pulseaudio[781]: stat('/etc/pulse/default.pa.d'): No such file or directory
sie 28 09:32:05 amougsu-x540sa tumblerd[856]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
sie 28 09:32:05 amougsu-x540sa zeitgeist-fts[908]: Empty index detected. Doing full rebuild
sie 28 09:32:05 amougsu-x540sa udisksd[911]: udisks daemon version 2.9.4 starting
sie 28 09:32:05 amougsu-x540sa zeitgeist-datah[906]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
sie 28 09:32:06 amougsu-x540sa udisksd[911]: Acquired the name org.freedesktop.UDisks2 on the system message bus
sie 28 09:32:06 amougsu-x540sa kernel: kauditd_printk_skb: 11 callbacks suppressed
sie 28 09:32:06 amougsu-x540sa kernel: audit: type=1334 audit(1661671926.636:63): prog-id=19 op=LOAD
sie 28 09:32:06 amougsu-x540sa kernel: audit: type=1334 audit(1661671926.636:64): prog-id=20 op=LOAD
sie 28 09:32:06 amougsu-x540sa polkitd[359]: Registered Authentication Agent for unix-session:2 (system bus name :1.39 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.utf8)
sie 28 09:32:06 amougsu-x540sa kernel: audit: type=1130 audit(1661671926.886:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:07 amougsu-x540sa kernel: audit: type=1105 audit(1661671927.210:66): pid=1026 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
sie 28 09:32:07 amougsu-x540sa pkexec[1026]: amougsu: Executing command [USER=root] [TTY=unknown] [CWD=/home/amougsu] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
sie 28 09:32:08 amougsu-x540sa kernel: audit: type=1130 audit(1661671928.400:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:11 amougsu-x540sa systemd[644]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
sie 28 09:32:11 amougsu-x540sa kernel: audit: type=1131 audit(1661671931.390:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:11 amougsu-x540sa kernel: audit: type=1131 audit(1661671931.416:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sie 28 09:32:28 amougsu-x540sa pulseaudio[781]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
sie 28 09:32:28 amougsu-x540sa dbus-daemon[358]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
sie 28 09:32:38 amougsu-x540sa kernel: audit: type=1131 audit(1661671958.446:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[amougsu@amougsu-x540sa ~]$ sudo dmesg -l err,warn,emerg,alert
[sudo] password for amougsu:
[ 0.011546] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/32 (20220331/tbfadt-564)
[ 0.181074] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.347704] cherryview-pinctrl INT33FF:01: interrupt on unmapped interrupt line 2
[ 3.099508] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 4.126966] usb: port power management may be unreliable
[ 6.810654] gpio gpiochip4: (INT0002 Virtual GPIO): not an immutable chip, please consider fixing it!
[ 6.976833] elan_i2c i2c-ELAN1000:00: supply vcc not found, using dummy regulator
[ 12.278289] kauditd_printk_skb: 21 callbacks suppressed
[ 22.570359] kauditd_printk_skb: 12 callbacks suppressed
