The laptop is freezing after few minutes, when switched to “nvidia” through optimus. The freeze seems to be random. Also, it detects two screens
after the switch. Why is that?
$ inxi -Fazy
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=360406bd-4b88-4225-9ed6-83c55baae3e2 rw apparmor=1
security=apparmor resume=UUID=7fcf84c8-a451-458d-b68b-b28222217236
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Portable System: Dell product: Dell System XPS L502X v: N/A
serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter>
Mobo: Dell model: 0MY6GN v: A00 serial: <filter> UEFI [Legacy]: Dell v: A12
date: 09/07/2012
ID-1: BAT0 charge: 39.0 Wh condition: 81.6/93.2 Wh (88%) volts: 12.1/11.1
model: SANYO Dell type: Li-ion serial: <filter> status: Charging
Info: Dual Core model: Intel Core i5-2450M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19967
Speed: 798 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 799
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0126
Device-2: NVIDIA GF108M [GeForce GT 540M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:0df4
Device-3: Quanta Laptop_Integrated_Webcam_2HDM type: USB driver: uvcvideo
bus ID: 1-1.4:3 chip ID: 0408:2fb1
Display: x11 server: X.Org 1.20.10 driver: modesetting display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0bea
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:008a
vendor: Dell driver: r8169 v: kernel port: 2000 bus ID: 06:00.0
chip ID: 10ec:8168
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 540.76 GiB (58.1%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0002 scheme: MBR
ID-1: / raw size: 922.71 GiB size: 907.23 GiB (98.32%)
used: 540.76 GiB (59.6%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 72.0 C mobo: 51.0 C
Fan Speeds (RPM): cpu: 2807
Processes: 191 Uptime: 8h 11m Memory: 7.67 GiB used: 2.11 GiB (27.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1508 lib: 366
Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
One of the log from /var/log/optimus-manager/switch/:
[13] INFO: # Xorg pre-start hook
[13] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'nvidia', 'current_mode': 'intel'}
[13] INFO: Requested mode is: nvidia
[13] INFO: Checking for GDM display servers
[284] INFO: Available modules: ['nouveau', 'bbswitch', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[285] INFO: Unloading modules ['nouveau'] (if loaded)
[291] INFO: Loading module bbswitch
[298] INFO: Setting GPU power to ON via bbswitch
[882] INFO: Loading module nvidia
[1056] INFO: Loading module nvidia_drm
[1600] INFO: Loaded extra Intel Xorg options (0 lines)
[1602] INFO: Loaded extra Intel Xorg options (0 lines)
[1603] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[1603] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20201216T120132', 'requested_mode': 'nvidia'}
[1604] INFO: Xorg pre-start hook completed successfully.
[7] INFO: # Xorg post-start hook
[7] INFO: Running xrandr commands
[153] INFO: Running /etc/optimus-manager/xsetup-nvidia.sh
[241] INFO: Writing state {'type': 'done', 'switch_id': '20201216T120132', 'current_mode': 'nvidia'}
[242] INFO: Xorg post-start hook completed successfully.
/var/log/Xorg.0.log.old:
[ 359.107]
X.Org X Server 1.20.10
[ 359.107] Build Operating System: Linux Manjaro Linux
[ 359.107] Current Operating System: Linux xps 5.9.11-3-MANJARO #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020 x86_64
[ 359.107] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=360406bd-4b88-4225-9ed6-83c55baae3e2 rw apparmor=1 security=apparmor resume=UUID=7fcf84c8-a451-458d-b68b-b28222217236 udev.log_priority=3
[ 359.107] Build Date: 03 December 2020 08:59:12AM
[ 359.107]
[ 359.107] Current version of pixman: 0.40.0
[ 359.107] Before reporting problems, check http://wiki.x.org
[ 359.107] Markers: (--) probed, (**) from config file, (==) default setting,
[ 359.107] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 16 13:16:18 2020
[ 359.107] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 359.107] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 359.107] (==) ServerLayout "layout"
[ 359.107] (**) |-->Screen "nvidia" (0)
[ 359.107] (**) | |-->Monitor "<default monitor>"
[ 359.108] (**) | |-->Device "nvidia"
[ 359.108] (**) | |-->GPUDevice "intel"
[ 359.108] (==) No monitor specified for screen "nvidia".
[ 359.108] (**) |-->Inactive Device "intel"
[ 359.108] (==) Automatically adding devices
[ 359.108] (==) Automatically enabling devices
[ 359.108] (==) Automatically adding GPU devices
[ 359.108] (==) Automatically binding GPU devices
[ 359.108] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 359.108] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 359.108] Entry deleted from font path.
[ 359.108] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 359.108] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 359.108] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 359.108] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 359.108] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 359.108] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 359.108] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 359.108] (==) FontPath set to:
[ 359.108] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 359.108] (II) The server relies on udev to provide the list of input devices.
[ 359.108] (II) Module ABI versions:
[ 359.108] X.Org ANSI C Emulation: 0.4
[ 359.108] X.Org Video Driver: 24.1
[ 359.108] X.Org XInput driver : 24.1
[ 359.108] X.Org Server Extension : 10.0
[ 359.108] (++) using VT number 7
[ 359.108] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 359.110] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 359.118] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 359.128] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 359.128] (**) OutputClass "nvidia" setting /dev/dri/card1 as PrimaryGPU
[ 359.129] (--) PCI: (0@0:2:0) 8086:0126:1028:050e rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 359.129] (--) PCI:*(1@0:0:0) 10de:0df4:1028:050e rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 359.130] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 359.130] (II) LoadModule: "glx"
[ 359.152] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 359.912] (II) Module glx: vendor="NVIDIA Corporation"
[ 359.912] compiled for 4.0.2, module version = 1.0.0
[ 359.912] Module class: X.Org Server Extension
[ 359.919] (II) NVIDIA GLX Module 390.132 Fri Nov 1 04:00:46 PDT 2019
[ 359.932] (II) LoadModule: "nvidia"
[ 359.932] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 360.016] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 360.017] compiled for 4.0.2, module version = 1.0.0
[ 360.017] Module class: X.Org Video Driver
[ 360.024] (II) LoadModule: "modesetting"
[ 360.024] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 360.026] (II) Module modesetting: vendor="X.Org Foundation"
[ 360.026] compiled for 1.20.10, module version = 1.20.10
[ 360.026] Module class: X.Org Video Driver
[ 360.026] ABI class: X.Org Video Driver, version 24.1
[ 360.031] (II) NVIDIA dlloader X Driver 390.132 Fri Nov 1 03:36:28 PDT 2019
[ 360.032] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 360.032] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 360.046] (II) Loading sub module "fb"
[ 360.046] (II) LoadModule: "fb"
[ 360.047] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 360.048] (II) Module fb: vendor="X.Org Foundation"
[ 360.048] compiled for 1.20.10, module version = 1.0.0
[ 360.048] ABI class: X.Org ANSI C Emulation, version 0.4
[ 360.048] (II) Loading sub module "wfb"
[ 360.048] (II) LoadModule: "wfb"
[ 360.048] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 360.063] (II) Module wfb: vendor="X.Org Foundation"
[ 360.063] compiled for 1.20.10, module version = 1.0.0
[ 360.063] ABI class: X.Org ANSI C Emulation, version 0.4
[ 360.063] (II) Loading sub module "ramdac"
[ 360.063] (II) LoadModule: "ramdac"
[ 360.063] (II) Module "ramdac" already built-in
[ 360.096] (II) modeset(G0): using drv /dev/dri/card0
[ 360.096] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 360.096] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 360.096] (==) NVIDIA(0): RGB weight 888
[ 360.096] (==) NVIDIA(0): Default visual is TrueColor
[ 360.096] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 360.096] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 360.096] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 360.096] (**) NVIDIA(0): Option "Coolbits" "28"
[ 360.097] (**) NVIDIA(0): Enabling 2D acceleration
[ 360.134] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 360.134] (--) NVIDIA(0): CRT-0 (boot)
[ 360.134] (--) NVIDIA(0): DFP-0
[ 360.136] (II) NVIDIA(0): NVIDIA GPU GeForce GT 540M (GF108) at PCI:1:0:0 (GPU-0)
[ 360.136] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 360.136] (--) NVIDIA(0): VideoBIOS: 70.08.44.00.11
[ 360.136] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 360.138] (--) NVIDIA(GPU-0): CRT-0: connected
[ 360.138] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 360.138] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 360.138] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 360.138] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 360.142] (==) NVIDIA(0):
[ 360.142] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 360.142] (==) NVIDIA(0): will be used as the requested mode.
[ 360.142] (II) NVIDIA(0): Validated MetaModes:
[ 360.142] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
[ 360.142] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 360.150] (WW) NVIDIA(0): CRT-0 does not have an EDID, or its EDID does not contain a
[ 360.150] (WW) NVIDIA(0): maximum image size; cannot compute DPI from CRT-0's EDID.
[ 360.150] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 360.150] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 360.150] (==) modeset(G0): RGB weight 888
[ 360.150] (==) modeset(G0): Default visual is TrueColor
[ 360.150] (II) Loading sub module "glamoregl"
[ 360.150] (II) LoadModule: "glamoregl"
[ 360.151] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 360.154] (II) Module glamoregl: vendor="X.Org Foundation"
[ 360.154] compiled for 1.20.10, module version = 1.0.1
[ 360.154] ABI class: X.Org ANSI C Emulation, version 0.4
[ 360.233] (II) modeset(G0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 3000 (SNB GT2)
[ 360.233] (II) modeset(G0): glamor initialized
[ 360.233] (II) modeset(G0): Output LVDS-1-1 has no monitor section
[ 360.335] (II) modeset(G0): Output VGA-1-1 has no monitor section
[ 360.337] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 360.337] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 360.337] (II) modeset(G0): EDID for output LVDS-1-1
[ 360.337] (II) modeset(G0): Manufacturer: LGD Model: 33b Serial#: 0
[ 360.337] (II) modeset(G0): Year: 2011 Week: 0
[ 360.337] (II) modeset(G0): EDID Version: 1.3
[ 360.337] (II) modeset(G0): Digital Display Input
[ 360.337] (II) modeset(G0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 360.337] (II) modeset(G0): Gamma: 2.20
[ 360.337] (II) modeset(G0): No DPMS capabilities specified
[ 360.337] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 360.337] (II) modeset(G0): First detailed timing is preferred mode
[ 360.337] (II) modeset(G0): redX: 0.618 redY: 0.369 greenX: 0.355 greenY: 0.603
[ 360.337] (II) modeset(G0): blueX: 0.151 blueY: 0.103 whiteX: 0.313 whiteY: 0.329
[ 360.337] (II) modeset(G0): Manufacturer's mask: 0
[ 360.337] (II) modeset(G0): Supported detailed timing:
[ 360.337] (II) modeset(G0): clock: 70.0 MHz Image Size: 344 x 194 mm
[ 360.337] (II) modeset(G0): h_active: 1366 h_sync: 1402 h_sync_end 1450 h_blank_end 1492 h_border: 0
[ 360.337] (II) modeset(G0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 782 v_border: 0
[ 360.337] (II) modeset(G0): LG Display
[ 360.337] (II) modeset(G0): LP156WH4-TLP1
[ 360.337] (II) modeset(G0): EDID (in hex):
[ 360.337] (II) modeset(G0): 00ffffffffffff0030e43b0300000000
[ 360.337] (II) modeset(G0): 00150103802213780a61d59e5e5b9a26
[ 360.337] (II) modeset(G0): 1a505400000001010101010101010101
[ 360.337] (II) modeset(G0): 010101010101581b567e50000e302430
[ 360.337] (II) modeset(G0): 350058c2100000190000000000000000
[ 360.337] (II) modeset(G0): 00000000000000000000000000fe004c
[ 360.337] (II) modeset(G0): 4720446973706c61790a2020000000fe
[ 360.337] (II) modeset(G0): 004c503135365748342d544c50310080
[ 360.338] (II) modeset(G0): Printing probed modes for output LVDS-1-1
[ 360.338] (II) modeset(G0): Modeline "1366x768"x60.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz eP)
[ 360.338] (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 360.338] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 360.338] (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 360.338] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 360.338] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 360.338] (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 360.338] (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 360.338] (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 360.338] (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 360.338] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 360.338] (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 360.338] (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 360.338] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 360.338] (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 360.338] (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 360.338] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 360.338] (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 360.338] (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 360.338] (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 360.442] (II) modeset(G0): EDID for output VGA-1-1
[ 360.444] (II) modeset(G0): EDID for output HDMI-1-1
[ 360.444] (II) modeset(G0): EDID for output DP-1-1
[ 360.444] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 360.444] (==) modeset(G0): DPI set to (96, 96)
[ 360.444] (II) Loading sub module "fb"
[ 360.444] (II) LoadModule: "fb"
[ 360.444] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 360.444] (II) Module fb: vendor="X.Org Foundation"
[ 360.444] compiled for 1.20.10, module version = 1.0.0
[ 360.444] ABI class: X.Org ANSI C Emulation, version 0.4
[ 360.444] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 360.444] (II) NVIDIA: access.
[ 360.553] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 360.553] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 360.553] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 360.553] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 360.553] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 360.553] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 360.553] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 360.553] (II) NVIDIA(0): Config Options in the README.
[ 360.594] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[ 360.619] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 360.619] (==) NVIDIA(0): Backing store enabled
[ 360.619] (==) NVIDIA(0): Silken mouse disabled
[ 360.620] (==) NVIDIA(0): DPMS enabled
[ 360.620] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 360.620] (II) Loading sub module "dri2"
[ 360.620] (II) LoadModule: "dri2"
[ 360.620] (II) Module "dri2" already built-in
[ 360.620] (II) NVIDIA(0): [DRI2] Setup complete
[ 360.620] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 360.630] (==) modeset(G0): Backing store enabled
[ 360.630] (==) modeset(G0): Silken mouse disabled
[ 360.664] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 360.664] (==) modeset(G0): DPMS enabled
[ 360.664] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 360.664] (II) modeset(G0): [DRI2] Setup complete
[ 360.664] (II) modeset(G0): [DRI2] DRI driver: i965
[ 360.664] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 360.664] (II) Initializing extension Generic Event Extension
[ 360.664] (II) Initializing extension SHAPE
[ 360.665] (II) Initializing extension MIT-SHM
[ 360.665] (II) Initializing extension XInputExtension
[ 360.665] (II) Initializing extension XTEST
[ 360.665] (II) Initializing extension BIG-REQUESTS
[ 360.665] (II) Initializing extension SYNC
[ 360.665] (II) Initializing extension XKEYBOARD
[ 360.665] (II) Initializing extension XC-MISC
[ 360.666] (II) Initializing extension SECURITY
[ 360.666] (II) Initializing extension XFIXES
[ 360.666] (II) Initializing extension RENDER
[ 360.666] (II) Initializing extension RANDR
[ 360.666] (II) Initializing extension COMPOSITE
[ 360.666] (II) Initializing extension DAMAGE
[ 360.667] (II) Initializing extension MIT-SCREEN-SAVER
[ 360.667] (II) Initializing extension DOUBLE-BUFFER
[ 360.667] (II) Initializing extension RECORD
[ 360.667] (II) Initializing extension DPMS
[ 360.667] (II) Initializing extension Present
[ 360.667] (II) Initializing extension DRI3
[ 360.667] (II) Initializing extension X-Resource
[ 360.668] (II) Initializing extension XVideo
[ 360.668] (II) Initializing extension XVideo-MotionCompensation
[ 360.668] (II) Initializing extension XFree86-VidModeExtension
[ 360.668] (II) Initializing extension XFree86-DGA
[ 360.668] (II) Initializing extension XFree86-DRI
[ 360.668] (II) Initializing extension DRI2
[ 360.668] (II) Initializing extension GLX
[ 360.668] (II) Indirect GLX disabled.
[ 360.668] (II) Initializing extension NV-GLX
[ 360.668] (II) Initializing extension NV-CONTROL
[ 360.669] (II) Initializing extension XINERAMA
[ 361.051] (II) modeset(G0): Damage tracking initialized
[ 361.345] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 361.345] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 361.345] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 361.345] (**) Power Button: Applying InputClass "system-keyboard"
[ 361.345] (II) LoadModule: "libinput"
[ 361.345] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 361.346] (II) Module libinput: vendor="X.Org Foundation"
[ 361.347] compiled for 1.20.8, module version = 0.30.0
[ 361.347] Module class: X.Org XInput Driver
[ 361.347] ABI class: X.Org XInput driver, version 24.1
[ 361.347] (II) Using input driver 'libinput' for 'Power Button'
[ 361.347] (**) Power Button: always reports core events
[ 361.347] (**) Option "Device" "/dev/input/event3"
[ 361.347] (**) Option "_source" "server/udev"
[ 361.348] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 361.348] (II) event3 - Power Button: device is a keyboard
[ 361.348] (II) event3 - Power Button: device removed
[ 361.373] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 361.373] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 361.373] (**) Option "xkb_model" "pc105"
[ 361.373] (**) Option "xkb_layout" "us"
[ 361.375] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 361.375] (II) event3 - Power Button: device is a keyboard
[ 361.376] (II) config/udev: Adding input device Video Bus (/dev/input/event19)
[ 361.376] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 361.376] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 361.376] (**) Video Bus: Applying InputClass "system-keyboard"
[ 361.376] (II) Using input driver 'libinput' for 'Video Bus'
[ 361.377] (**) Video Bus: always reports core events
[ 361.377] (**) Option "Device" "/dev/input/event19"
[ 361.377] (**) Option "_source" "server/udev"
[ 361.378] (II) event19 - Video Bus: is tagged by udev as: Keyboard
[ 361.378] (II) event19 - Video Bus: device is a keyboard
[ 361.379] (II) event19 - Video Bus: device removed
[ 361.439] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input20/event19"
[ 361.439] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 361.439] (**) Option "xkb_model" "pc105"
[ 361.439] (**) Option "xkb_layout" "us"
[ 361.443] (II) event19 - Video Bus: is tagged by udev as: Keyboard
[ 361.444] (II) event19 - Video Bus: device is a keyboard
[ 361.446] (II) config/udev: Adding input device Video Bus (/dev/input/event18)
[ 361.446] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 361.446] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 361.446] (**) Video Bus: Applying InputClass "system-keyboard"
[ 361.446] (II) Using input driver 'libinput' for 'Video Bus'
[ 361.446] (**) Video Bus: always reports core events
[ 361.446] (**) Option "Device" "/dev/input/event18"
[ 361.446] (**) Option "_source" "server/udev"
[ 361.450] (II) event18 - Video Bus: is tagged by udev as: Keyboard
[ 361.450] (II) event18 - Video Bus: device is a keyboard
[ 361.450] (II) event18 - Video Bus: device removed
[ 361.519] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/LNXVIDEO:00/input/input19/event18"
[ 361.519] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 361.519] (**) Option "xkb_model" "pc105"
[ 361.519] (**) Option "xkb_layout" "us"
[ 361.524] (II) event18 - Video Bus: is tagged by udev as: Keyboard
[ 361.525] (II) event18 - Video Bus: device is a keyboard
[ 361.527] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 361.527] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 361.527] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 361.527] (**) Power Button: Applying InputClass "system-keyboard"
[ 361.527] (II) Using input driver 'libinput' for 'Power Button'
[ 361.527] (**) Power Button: always reports core events
[ 361.527] (**) Option "Device" "/dev/input/event0"
[ 361.527] (**) Option "_source" "server/udev"
[ 361.530] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 361.530] (II) event0 - Power Button: device is a keyboard
[ 361.531] (II) event0 - Power Button: device removed
[ 361.558] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 361.558] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 361.559] (**) Option "xkb_model" "pc105"
[ 361.559] (**) Option "xkb_layout" "us"
[ 361.562] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 361.563] (II) event0 - Power Button: device is a keyboard
[ 361.565] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 361.565] (II) No input driver specified, ignoring this device.
[ 361.565] (II) This device may have been added with another device file.
[ 361.566] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 361.566] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 361.566] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 361.567] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 361.567] (II) Using input driver 'libinput' for 'Sleep Button'
[ 361.567] (**) Sleep Button: always reports core events
[ 361.567] (**) Option "Device" "/dev/input/event1"
[ 361.567] (**) Option "_source" "server/udev"
[ 361.568] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 361.568] (II) event1 - Sleep Button: device is a keyboard
[ 361.568] (II) event1 - Sleep Button: device removed
[ 361.576] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 361.576] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 361.576] (**) Option "xkb_model" "pc105"
[ 361.576] (**) Option "xkb_layout" "us"
[ 361.580] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 361.581] (II) event1 - Sleep Button: device is a keyboard
[ 361.581] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 361.581] (II) No input driver specified, ignoring this device.
[ 361.581] (II) This device may have been added with another device file.
[ 361.582] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 361.582] (II) No input driver specified, ignoring this device.
[ 361.582] (II) This device may have been added with another device file.
[ 361.582] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 361.583] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 361.583] (II) No input driver specified, ignoring this device.
[ 361.583] (II) This device may have been added with another device file.
[ 361.584] (II) config/udev: Adding input device Laptop_Integrated_Webcam_2HDM: (/dev/input/event25)
[ 361.584] (**) Laptop_Integrated_Webcam_2HDM: : Applying InputClass "evdev keyboard catchall"
[ 361.584] (**) Laptop_Integrated_Webcam_2HDM: : Applying InputClass "libinput keyboard catchall"
[ 361.584] (**) Laptop_Integrated_Webcam_2HDM: : Applying InputClass "system-keyboard"
[ 361.584] (II) Using input driver 'libinput' for 'Laptop_Integrated_Webcam_2HDM: '
[ 361.584] (**) Laptop_Integrated_Webcam_2HDM: : always reports core events
[ 361.584] (**) Option "Device" "/dev/input/event25"
[ 361.584] (**) Option "_source" "server/udev"
[ 361.585] (II) event25 - Laptop_Integrated_Webcam_2HDM: : is tagged by udev as: Keyboard
[ 361.585] (II) event25 - Laptop_Integrated_Webcam_2HDM: : device is a keyboard
[ 361.585] (II) event25 - Laptop_Integrated_Webcam_2HDM: : device removed
[ 361.639] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input26/event25"
[ 361.639] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_2HDM: " (type: KEYBOARD, id 11)
[ 361.639] (**) Option "xkb_model" "pc105"
[ 361.639] (**) Option "xkb_layout" "us"
[ 361.645] (II) event25 - Laptop_Integrated_Webcam_2HDM: : is tagged by udev as: Keyboard
[ 361.645] (II) event25 - Laptop_Integrated_Webcam_2HDM: : device is a keyboard
[ 361.647] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event20)
[ 361.647] (II) No input driver specified, ignoring this device.
[ 361.647] (II) This device may have been added with another device file.
[ 361.648] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event21)
[ 361.648] (II) No input driver specified, ignoring this device.
[ 361.648] (II) This device may have been added with another device file.
[ 361.650] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event22)
[ 361.650] (II) No input driver specified, ignoring this device.
[ 361.650] (II) This device may have been added with another device file.
[ 361.651] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event23)
[ 361.651] (II) No input driver specified, ignoring this device.
[ 361.651] (II) This device may have been added with another device file.
[ 361.653] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event24)
[ 361.653] (II) No input driver specified, ignoring this device.
[ 361.653] (II) This device may have been added with another device file.
[ 361.654] (II) config/udev: Adding input device CHICONY USB Keyboard (/dev/input/event5)
[ 361.654] (**) CHICONY USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 361.654] (**) CHICONY USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 361.654] (**) CHICONY USB Keyboard: Applying InputClass "system-keyboard"
[ 361.654] (II) Using input driver 'libinput' for 'CHICONY USB Keyboard'
[ 361.654] (**) CHICONY USB Keyboard: always reports core events
[ 361.654] (**) Option "Device" "/dev/input/event5"
[ 361.654] (**) Option "_source" "server/udev"
[ 361.656] (II) event5 - CHICONY USB Keyboard: is tagged by udev as: Keyboard
[ 361.656] (II) event5 - CHICONY USB Keyboard: device is a keyboard
[ 361.656] (II) event5 - CHICONY USB Keyboard: device removed
[ 361.683] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.0/0003:04F2:0833.0001/input/input6/event5"
[ 361.684] (II) XINPUT: Adding extended input device "CHICONY USB Keyboard" (type: KEYBOARD, id 12)
[ 361.684] (**) Option "xkb_model" "pc105"
[ 361.684] (**) Option "xkb_layout" "us"
[ 361.690] (II) event5 - CHICONY USB Keyboard: is tagged by udev as: Keyboard
[ 361.690] (II) event5 - CHICONY USB Keyboard: device is a keyboard
[ 361.694] (II) config/udev: Adding input device CHICONY USB Keyboard System Control (/dev/input/event6)
[ 361.694] (**) CHICONY USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 361.694] (**) CHICONY USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 361.694] (**) CHICONY USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 361.694] (II) Using input driver 'libinput' for 'CHICONY USB Keyboard System Control'
[ 361.694] (**) CHICONY USB Keyboard System Control: always reports core events
[ 361.694] (**) Option "Device" "/dev/input/event6"
[ 361.694] (**) Option "_source" "server/udev"
[ 361.700] (II) event6 - CHICONY USB Keyboard System Control: is tagged by udev as: Keyboard
[ 361.701] (II) event6 - CHICONY USB Keyboard System Control: device is a keyboard
[ 361.701] (II) event6 - CHICONY USB Keyboard System Control: device removed
[ 361.732] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.1/0003:04F2:0833.0002/input/input7/event6"
[ 361.733] (II) XINPUT: Adding extended input device "CHICONY USB Keyboard System Control" (type: KEYBOARD, id 13)
[ 361.733] (**) Option "xkb_model" "pc105"
[ 361.733] (**) Option "xkb_layout" "us"
[ 361.739] (II) event6 - CHICONY USB Keyboard System Control: is tagged by udev as: Keyboard
[ 361.740] (II) event6 - CHICONY USB Keyboard System Control: device is a keyboard
[ 361.743] (II) config/udev: Adding input device CHICONY USB Keyboard Consumer Control (/dev/input/event7)
[ 361.743] (**) CHICONY USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 361.743] (**) CHICONY USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 361.743] (**) CHICONY USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 361.743] (II) Using input driver 'libinput' for 'CHICONY USB Keyboard Consumer Control'
[ 361.743] (**) CHICONY USB Keyboard Consumer Control: always reports core events
[ 361.743] (**) Option "Device" "/dev/input/event7"
[ 361.743] (**) Option "_source" "server/udev"
[ 361.749] (II) event7 - CHICONY USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 361.750] (II) event7 - CHICONY USB Keyboard Consumer Control: device is a keyboard
[ 361.750] (II) event7 - CHICONY USB Keyboard Consumer Control: device removed
[ 361.826] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.1/0003:04F2:0833.0002/input/input8/event7"
[ 361.826] (II) XINPUT: Adding extended input device "CHICONY USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 361.826] (**) Option "xkb_model" "pc105"
[ 361.826] (**) Option "xkb_layout" "us"
[ 361.832] (II) event7 - CHICONY USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 361.833] (II) event7 - CHICONY USB Keyboard Consumer Control: device is a keyboard
[ 361.836] (II) config/udev: Adding input device CHICONY USB Keyboard (/dev/input/event8)
[ 361.836] (**) CHICONY USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 361.836] (**) CHICONY USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 361.836] (**) CHICONY USB Keyboard: Applying InputClass "system-keyboard"
[ 361.836] (II) Using input driver 'libinput' for 'CHICONY USB Keyboard'
[ 361.837] (**) CHICONY USB Keyboard: always reports core events
[ 361.837] (**) Option "Device" "/dev/input/event8"
[ 361.837] (**) Option "_source" "server/udev"
[ 361.842] (II) event8 - CHICONY USB Keyboard: is tagged by udev as: Keyboard
[ 361.843] (II) event8 - CHICONY USB Keyboard: device is a keyboard
[ 361.843] (II) event8 - CHICONY USB Keyboard: device removed
[ 361.897] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1/3-1:1.1/0003:04F2:0833.0002/input/input9/event8"
[ 361.897] (II) XINPUT: Adding extended input device "CHICONY USB Keyboard" (type: KEYBOARD, id 15)
[ 361.897] (**) Option "xkb_model" "pc105"
[ 361.898] (**) Option "xkb_layout" "us"
[ 361.904] (II) event8 - CHICONY USB Keyboard: is tagged by udev as: Keyboard
[ 361.904] (II) event8 - CHICONY USB Keyboard: device is a keyboard
[ 361.908] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/event9)
[ 361.908] (**) MOSART Semi. 2.4G Wireless Mouse: Applying InputClass "evdev pointer catchall"
[ 361.908] (**) MOSART Semi. 2.4G Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 361.908] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Wireless Mouse'
[ 361.908] (**) MOSART Semi. 2.4G Wireless Mouse: always reports core events
[ 361.908] (**) Option "Device" "/dev/input/event9"
[ 361.908] (**) Option "_source" "server/udev"
[ 361.971] (II) event9 - MOSART Semi. 2.4G Wireless Mouse: is tagged by udev as: Mouse
[ 361.972] (II) event9 - MOSART Semi. 2.4G Wireless Mouse: device is a pointer
[ 361.972] (II) event9 - MOSART Semi. 2.4G Wireless Mouse: device removed
[ 362.026] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-2/3-2:1.0/0003:3938:1031.0003/input/input10/event9"
[ 362.026] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Wireless Mouse" (type: MOUSE, id 16)
[ 362.026] (**) Option "AccelerationScheme" "none"
[ 362.026] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) selected scheme none/0
[ 362.026] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) acceleration factor: 2.000
[ 362.026] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) acceleration threshold: 4
[ 362.084] (II) event9 - MOSART Semi. 2.4G Wireless Mouse: is tagged by udev as: Mouse
[ 362.084] (II) event9 - MOSART Semi. 2.4G Wireless Mouse: device is a pointer
[ 362.085] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/mouse0)
[ 362.085] (II) No input driver specified, ignoring this device.
[ 362.085] (II) This device may have been added with another device file.
[ 362.085] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/event10)
[ 362.086] (II) No input driver specified, ignoring this device.
[ 362.086] (II) This device may have been added with another device file.
[ 362.086] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event12)
[ 362.086] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 362.086] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 362.086] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 362.086] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 362.086] (**) Dell WMI hotkeys: always reports core events
[ 362.086] (**) Option "Device" "/dev/input/event12"
[ 362.086] (**) Option "_source" "server/udev"
[ 362.087] (II) event12 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 362.088] (II) event12 - Dell WMI hotkeys: device is a keyboard
[ 362.088] (II) event12 - Dell WMI hotkeys: device removed
[ 362.146] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input14/event12"
[ 362.146] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 17)
[ 362.146] (**) Option "xkb_model" "pc105"
[ 362.146] (**) Option "xkb_layout" "us"
[ 362.150] (II) event12 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 362.150] (II) event12 - Dell WMI hotkeys: device is a keyboard
[ 362.150] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 362.150] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 362.150] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 362.150] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 362.150] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 362.151] (**) AT Translated Set 2 keyboard: always reports core events
[ 362.151] (**) Option "Device" "/dev/input/event4"
[ 362.151] (**) Option "_source" "server/udev"
[ 362.152] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 362.152] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 362.153] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 362.182] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 362.182] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[ 362.182] (**) Option "xkb_model" "pc105"
[ 362.182] (**) Option "xkb_layout" "us"
[ 362.187] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 362.187] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 362.191] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event17)
[ 362.191] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 362.191] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 362.191] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 362.191] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 362.191] (**) Option "Device" "/dev/input/event17"
[ 362.191] (**) Option "_source" "server/udev"
[ 362.192] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 362.193] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 362.193] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 362.267] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input13/event17"
[ 362.267] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 19)
[ 362.268] (**) Option "AccelerationScheme" "none"
[ 362.269] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 362.269] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 362.269] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 362.273] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 362.276] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 362.278] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 362.278] (II) No input driver specified, ignoring this device.
[ 362.279] (II) This device may have been added with another device file.
[ 362.280] (II) config/udev: Adding input device PC Speaker (/dev/input/event11)
[ 362.280] (II) No input driver specified, ignoring this device.
[ 362.280] (II) This device may have been added with another device file.
[ 362.385] (--) NVIDIA(GPU-0): CRT-0: connected
[ 362.385] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 362.385] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 362.385] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 362.385] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 374.647] (--) NVIDIA(GPU-0): CRT-0: connected
[ 374.647] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 374.648] (--) NVIDIA(GPU-0):
[ 374.648] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 374.648] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 374.648] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 374.665] (--) NVIDIA(GPU-0): CRT-0: connected
[ 374.665] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 374.665] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 374.665] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 374.665] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 374.825] (II) NVIDIA(0): Setting mode "NULL"
[ 375.177] (--) NVIDIA(GPU-0): CRT-0: connected
[ 375.177] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 375.177] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 375.177] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 375.177] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 375.179] (--) NVIDIA(GPU-0): CRT-0: connected
[ 375.179] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 375.179] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 375.179] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 375.179] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 375.827] (--) NVIDIA(GPU-0): CRT-0: connected
[ 375.835] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 375.836] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 375.836] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 375.836] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 375.838] (--) NVIDIA(GPU-0): CRT-0: connected
[ 375.838] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 375.838] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 375.838] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 375.838] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 378.508] (--) NVIDIA(GPU-0): CRT-0: connected
[ 378.508] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 378.508] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 378.508] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 378.508] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 378.511] (--) NVIDIA(GPU-0): CRT-0: connected
[ 378.511] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 378.511] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 378.511] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 378.511] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 383.088] (--) NVIDIA(GPU-0): CRT-0: connected
[ 383.088] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 383.088] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 383.088] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 383.088] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 383.090] (--) NVIDIA(GPU-0): CRT-0: connected
[ 383.090] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 383.090] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 383.090] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 383.090] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 396.310] (EE) event9 - MOSART Semi. 2.4G Wireless Mouse: client bug: event processing lagging behind by 29ms, your system is too slow
[ 398.137] (--) NVIDIA(GPU-0): CRT-0: connected
[ 398.137] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 398.137] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 398.137] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 398.137] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 398.139] (--) NVIDIA(GPU-0): CRT-0: connected
[ 398.139] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 398.139] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 398.139] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 398.139] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 423.110] (--) NVIDIA(GPU-0): CRT-0: connected
[ 423.110] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 423.110] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 423.110] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 423.110] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 423.115] (--) NVIDIA(GPU-0): CRT-0: connected
[ 423.116] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 423.116] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 423.116] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 423.116] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 5492.842] (EE) event9 - MOSART Semi. 2.4G Wireless Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
[ 5643.509] (EE) NVIDIA(0): The NVIDIA X driver has encountered an error; attempting to
[ 5643.509] (EE) NVIDIA(0): recover...
[ 5650.518] (EE) NVIDIA(GPU-0): Failed to initialize DMA.
[ 5654.526] (EE) NVIDIA(0): Failed to allocate push buffer
[ 5654.526] (EE) NVIDIA(0): Error recovery failed.
[ 5654.526] (EE) NVIDIA(0): *** Aborting ***
[ 5654.526] (EE)
Fatal server error:
[ 5654.526] (EE) Failed to recover from error!
[ 5654.526] (EE)
[ 5654.526] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 5654.526] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 5654.526] (EE)
$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev ff)
$ nano /usr/share/optimus-manager.conf
[optimus]
# This parameter defines the method used to power switch the Nvidia card. See the documentation
# for a complete description of what each value does. Possible values :
# - nouveau : load the nouveau module on the Nvidia card.
# - bbswitch : power off the card using the bbswitch module (requires the bbswitch dependency).
# - acpi_call : try various ACPI method calls to power the card on and off (requires the acpi_call dependency)
# - custom: use custom scripts at /etc/optimus-manager/nvidia-enable.sh and /etc/optimus-manager/nvidia-disable.sh
# - none : do not use an external module for power management. For some laptop models it's preferable to
# use this option in combination with pci_power_control (see below).
switching=none
# Enable PCI power management in Intel mode.
# This option is incompatible with acpi_call and bbswitch, so it will be ignored in those cases.
pci_power_control=no
# Remove the Nvidia card from the PCI bus.
# May prevent crashes caused by power switching.
# Ignored if switching=nouveau or switching=bbswitch.
pci_remove=no
# Reset the Nvidia card at the PCI level before reloading the nvidia module.
# Ensures the card is in a fresh state before reloading the nvidia module.
# May fix some switching issues. Possible values :
# - no : does not perform any reset
# - function_level : perform a light "function-level" reset
# - hot_reset : perform a "hot reset" of the PCI bridge. ATTENTION : this method messes with the hardware
# directly, please read the online documentation of optimus-manager before using it.
# Also, it will perform a PCI remove even if pci_remove=no.
pci_reset=no
# Automatically log out the current desktop session when switching GPUs.
# This feature is currently supported for the following DE/WM :
# KDE Plasma, GNOME, XFCE, LXDE, Deepin, i3, Openbox, AwesomeWM, bspwm
# If this option is disabled or you use a different desktop environment,
# GPU switching only becomes effective at the next graphical session login.
auto_logout=yes
# GPU mode to use at computer startup. Possible values: nvidia, intel, hybrid, auto
# "auto" is a special mode that auto-detects if the computer is running on battery
# and selects a proper GPU mode. See the other options below.
startup_mode=intel
# GPU mode to select when startup_mode=auto and the computer is running on battery.
# Possible values: nvidia, intel, hybrid
startup_auto_battery_mode=intel
# GPU mode to select when startup_mode=auto and the computer is running on external power.
startup_auto_extpower_mode=nvidia
[intel]
# Driver to use for the Intel GPU. Possible values : modesetting, intel
# To use the intel driver, you need to install the package "xf86-video-intel".
driver=modesetting
# Acceleration method (corresponds to AccelMethod in the Xorg configuration).
# Only applies to the intel driver.
# Possible values : sna, xna, uxa
# Leave blank for the default (no option specified)
accel=
# Enable TearFree option in the Xorg configuration.
# Possible values : yes, no
tearfree=
# DRI version. Possible values : 2, 3
DRI=3
# Whether or not to enable modesetting for the nouveau driver.
# Does not affect modesetting for the Intel GPU driver !
# This option only matters if you use nouveau as the switching backend.
modeset=yes
[nvidia]
# Whether or not to enable modesetting. Required for PRIME Synchronization (which prevents tearing).
modeset=yes
# Whether or not to enable the NVreg_UsePageAttributeTable option in the Nvidia driver.
# Recommended, can cause poor CPU performance otherwise.
PAT=yes
# DPI value. This will be set using the Xsetup script passed to your login manager.
# It will run the command
# xrandr --dpi <DPI>
# Leave blank for the default (the above command will not be run).
DPI=96
# If you're running an updated version of xorg-server (let's say to get PRIME Render offload enabled),
# the nvidia driver may not load because of an ABI version mismatch. Setting this flag to "yes"
# will allow the loading of the nvidia driver.
ignore_abi=no
# Set to yes if you want to use optimus-manager with external Nvidia GPUs (experimental)
allow_external_gpus=no
# Comma-separated list of Nvidia-specific options to apply.
# Available options :
# - overclocking : enable CoolBits in the Xorg configuration, which unlocks clocking options
# in the Nvidia control panel. Note: does not work in hybrid mode.
# - triple_buffer : enable triple buffering.
options=overclocking
