Laptop freezing after resuming from Sleep
On my SO’s laptop almost every time the laptop enters sleep mode it freezes and she has to force shut down the laptop.
Journalctl log:
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6._PRW], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._DSM], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.DEV0._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.DEV0._RMV], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.PCIC], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DVID], AE_ALREADY_EXISTS (20240827/dsfield-637)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DDID], AE_ALREADY_EXISTS (20240827/dsfield-637)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.VGA._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.VGA._STA], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.HDAU._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC0._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.ACP._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.AZAL._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 19 09:26:46 CarolsIdeapad kernel: wmi_bus wmi_bus-PNP0C14:01: [Firmware Bug]: WQB1 data block query control method not found
Mai 19 09:26:46 CarolsIdeapad kernel: wmi_bus wmi_bus-PNP0C14:01: [Firmware Bug]: WQB2 data block query control method not found
Mai 19 09:26:46 CarolsIdeapad kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Mai 19 09:26:46 CarolsIdeapad systemd-journald[469]: File /var/log/journal/b0ed4cb2945b4fa9903a70a4cbbd3127/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 19 09:26:47 CarolsIdeapad dbus-broker-launch[675]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Mai 19 09:26:48 CarolsIdeapad ModemManager[732]: <wrn> [plugin-manager] task 0: port context already scheduled
Mai 19 09:26:48 CarolsIdeapad kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Mai 19 09:26:52 CarolsIdeapad systemd-resolved[487]: /etc/hosts:7: hostname "Carols_Ideapad" is not valid, ignoring.
Mai 19 09:26:52 CarolsIdeapad systemd-resolved[487]: /etc/hosts:7: line is missing any valid hostnames
Mai 19 09:26:52 CarolsIdeapad dbus-broker-launch[817]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mai 19 09:26:52 CarolsIdeapad dbus-broker-launch[817]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mai 19 09:26:52 CarolsIdeapad dbus-broker-launch[817]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mai 19 09:26:59 CarolsIdeapad sddm-greeter-qt6[813]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Mai 19 09:26:59 CarolsIdeapad systemd-journald[469]: File /var/log/journal/b0ed4cb2945b4fa9903a70a4cbbd3127/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 19 09:26:59 CarolsIdeapad dbus-broker-launch[914]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mai 19 09:26:59 CarolsIdeapad dbus-broker-launch[914]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mai 19 09:26:59 CarolsIdeapad dbus-broker-launch[914]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mai 19 09:27:00 CarolsIdeapad kernel: nvme nvme0: using unchecked data buffer
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Mai 19 09:27:00 CarolsIdeapad baloo_file[948]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.30'
Mai 19 09:27:00 CarolsIdeapad baloo_file[948]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.33'
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: Failed to create wl_display (No such file or directory)
Mai 19 09:27:00 CarolsIdeapad kconf_update[1212]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Mai 19 09:27:00 CarolsIdeapad kconf_update[1212]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Mai 19 09:27:00 CarolsIdeapad kconf_update[1212]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Mai 19 09:27:00 CarolsIdeapad kconf_update[1212]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Mai 19 09:27:00 CarolsIdeapad kconf_update[1212]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Mai 19 09:27:00 CarolsIdeapad bluetoothd[679]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 68:59:32:47:AF:1C: Protocol not available
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kf.bluezqt: PendingCall Error: "br-connection-profile-unavailable"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: kscreen.kded: PowerDevil SuspendSession action not available!
Mai 19 09:27:00 CarolsIdeapad plasmashell[1064]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
                                                 file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: Failed to find connector name for /dev/i2c-12, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    I2C_Bus_Info at: 0x62ef46055f90
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Flags:                   I2C_BUS_EXISTS | I2C_BUS_ACCESSIBLE | I2C_BUS_PROBED | I2C_BUS_X50_EDID | I2C_BUS_SYSFS_KNOWN_RELIABLE
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Bus /dev/i2c-12 found:   true
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Bus /dev/i2c-12 probed:  true
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    errno for open:          OK(0): success
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    drm_connector_found_by:  DRM_CONNECTOR_NOT_CHECKED (0)
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    last_checked_asleep:       false
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Display connectors reported by /sys:
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-HDMI-A-1
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    5
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 101
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       name:         (null)
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       enabled:      disabled
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       status:       disconnected
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       edid:         None
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-1
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    13
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 107
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-2
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    14
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 113
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-3
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    15
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 118
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-4
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    16
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 123
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-5
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    17
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 128
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-DP-6
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    18
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 133
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-eDP-1
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    4
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 93
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       enabled:      enabled
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       status:       connected
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:         +0          +4          +8          +c            0   4   8   c
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0000   00 ff ff ff ff ff ff 00 30 ae 59 91 00 00 00 00   ........0.Y.....
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0010   1c 21 01 04 a5 22 16 78 e3 ee 95 a3 54 4c 99 26   .!...".x....TL.&
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0020   0f 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01   .PT.............
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0030   01 01 01 01 01 01 42 3c 80 a0 70 b0 24 40 30 20   ......B<..p.$@0
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0040   a6 00 58 d7 10 00 00 18 00 00 00 fd 00 28 3c 4b   ..X..........(<K
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0050   4b 10 01 0a 20 20 20 20 20 20 00 00 00 fe 00 4c   K...      .....L
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0060   45 4e 4f 56 4f 0a 20 20 20 20 20 20 00 00 00 fe   ENOVO.      ....
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: +0070   00 4c 45 4e 31 36 30 57 55 58 47 41 20 20 00 60   .LEN160WUXGA  .`
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:    Connector:    card1-Writeback-1
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       i2c_busno:    -1
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       connector_id: 142
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]:       status:       unknown
Mai 19 09:27:00 CarolsIdeapad plasmashell[1064]: Toolbox not loading, toolbox package is either invalid or disabled.
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.pulseaudio: No object for name "auto_null"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Mai 19 09:27:00 CarolsIdeapad kded6[1006]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_04_00.6.analog-stereo"
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mai 19 09:27:00 CarolsIdeapad org_kde_powerdevil[1142]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mai 19 09:27:01 CarolsIdeapad plasmashell[1064]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Mai 19 09:27:01 CarolsIdeapad kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Mai 19 09:27:10 CarolsIdeapad plasmashell[1064]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:87:9: QML ScrollView: Binding loop detected for property "implicitWidth":
                                                 file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:13
Mai 19 09:27:12 CarolsIdeapad plasmashell[1064]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:87:9: QML ScrollView: Binding loop detected for property "implicitWidth":
Mai 19 09:28:58 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 152 (BadDamage), sequence: 47898, resource id: 20975067, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Mai 19 09:28:58 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 3 (BadWindow), sequence: 47899, resource id: 48234560, major code: 129 (SHAPE), minor code: 6 (Input)
Mai 19 09:29:32 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 152 (BadDamage), sequence: 53430, resource id: 20975733, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Mai 19 09:29:32 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 3 (BadWindow), sequence: 53431, resource id: 48234562, major code: 129 (SHAPE), minor code: 6 (Input)
Mai 19 09:29:48 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 152 (BadDamage), sequence: 54802, resource id: 20975830, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Mai 19 09:29:48 CarolsIdeapad kwin_x11[1007]: kwin_core: XCB error: 3 (BadWindow), sequence: 54803, resource id: 48234564, major code: 129 (SHAPE), minor code: 6 (Input)
Mai 19 09:49:54 CarolsIdeapad kscreenlocker_greet[3679]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Mai 19 10:02:41 CarolsIdeapad kernel: queueing ieee80211 work while going to suspend
Mai 19 10:02:41 CarolsIdeapad kernel: ------------[ cut here ]------------
Mai 19 10:02:41 CarolsIdeapad kernel: WARNING: CPU: 10 PID: 4248 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:3077 dm_suspend+0x232/0x240 [amdgpu]
Mai 19 10:02:41 CarolsIdeapad kernel: Modules linked in: snd_seq_dummy rfcomm snd_hrtimer snd_seq snd_seq_device ccm cmac algif_hash algif_skcipher af_alg qrtr bnep vfat fat amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps mt7921e snd_soc_acpi_amd_match kvm_amd mt7921_common snd_hda_codec_conexant snd_amd_sdw_acpi snd_hda_codec_generic soundwire_amd mt792x_lib snd_hda_codec_hdmi soundwire_generic_allocation mt76_connac_lib kvm soundwire_bus mt76 snd_soc_sdca irqbypass snd_soc_core snd_hda_intel crct10dif_pclmul snd_intel_dspcfg snd_compress snd_intel_sdw_acpi crc32_pclmul ac97_bus mac80211 polyval_clmulni snd_pcm_dmaengine snd_hda_codec uvcvideo polyval_generic snd_rpl_pci_acp6x snd_acp_pci ghash_clmulni_intel videobuf2_vmalloc snd_hda_core snd_acp_legacy_common libarc4 sha512_ssse3 uvc videobuf2_memops snd_pci_acp6x snd_hwdep sha256_ssse3 spd5118 videobuf2_v4l2 sha1_ssse3
Mai 19 10:02:41 CarolsIdeapad kernel:  btusb snd_pcm sp5100_tco aesni_intel videobuf2_common cfg80211 btrtl snd_pci_acp5x snd_timer btintel snd_rn_pci_acp3x gf128mul ucsi_acpi crypto_simd snd_acp_config videodev i2c_piix4 btbcm snd typec_ucsi ideapad_laptop cryptd snd_soc_acpi hid_multitouch btmtk bluetooth mc rapl platform_profile wmi_bmof typec pcspkr sparse_keymap k10temp joydev ccp i2c_smbus soundcore snd_pci_acp3x mousedev rfkill roles i2c_hid_acpi i2c_hid amd_pmc 8250_dw mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables ext4 crc32c_generic mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec gpu_sched drm_suballoc_helper sdhci_pci serio_raw drm_panel_backlight_quirks sdhci_uhs2 atkbd drm_buddy libps2 vivaldi_fmap sdhci nvme drm_display_helper cqhci crc32c_intel nvme_core cec mmc_core i8042 video crc16 nvme_auth serio wmi
Mai 19 10:02:41 CarolsIdeapad kernel: CPU: 10 UID: 0 PID: 4248 Comm: kworker/u64:36 Not tainted 6.13.12-1-MANJARO #1 88c76e548aaedc3e054ac87569cedde1306db7af
Mai 19 10:02:41 CarolsIdeapad kernel: Hardware name: LENOVO 83DD/LNVNB161216, BIOS NGCN29WW 10/08/2024
Mai 19 10:02:41 CarolsIdeapad kernel: Workqueue: async async_run_entry_fn
Mai 19 10:02:41 CarolsIdeapad kernel: RIP: 0010:dm_suspend+0x232/0x240 [amdgpu]
Mai 19 10:02:41 CarolsIdeapad kernel: Code: 48 8b bd 08 31 04 00 e9 a0 fe ff ff 41 0f b6 84 24 a0 02 00 00 48 89 e6 4c 89 ef 4c 89 24 24 88 44 24 08 e8 b0 99 31 00 eb a6 <0f> 0b e9 15 fe ff ff e8 e2 e4 8a d7 66 90 90 90 90 90 90 90 90 90
Mai 19 10:02:41 CarolsIdeapad kernel: RSP: 0018:ffffbbc283c43cc0 EFLAGS: 00010282
Mai 19 10:02:41 CarolsIdeapad kernel: RAX: 0000000000000000 RBX: ffff9003d7ec55b8 RCX: 0000000000000000
Mai 19 10:02:41 CarolsIdeapad kernel: RDX: 00000000000000f0 RSI: 0000000000000000 RDI: ffff9003d7e80000
Mai 19 10:02:41 CarolsIdeapad kernel: RBP: ffff9003d7e80000 R08: ffff9003c04000f8 R09: ffffffff99452940
Mai 19 10:02:41 CarolsIdeapad kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffc0ee2ea0
Mai 19 10:02:41 CarolsIdeapad kernel: R13: 0000000000000001 R14: ffff9003d7ec3108 R15: ffff9003c22200c8
Mai 19 10:02:41 CarolsIdeapad kernel: FS:  0000000000000000(0000) GS:ffff90066ff00000(0000) knlGS:0000000000000000
Mai 19 10:02:41 CarolsIdeapad kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 19 10:02:41 CarolsIdeapad kernel: CR2: 0000000000000000 CR3: 00000002eda22000 CR4: 0000000000f50ef0
Mai 19 10:02:41 CarolsIdeapad kernel: PKRU: 55555554
Mai 19 10:02:41 CarolsIdeapad kernel: Call Trace:
Mai 19 10:02:41 CarolsIdeapad kernel:  <TASK>
Mai 19 10:02:41 CarolsIdeapad kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 19 10:02:41 CarolsIdeapad kernel:  ? hdp_v5_2_update_clock_gating+0x219/0x370 [amdgpu 2e78826c3bd11576b4cf6fbe04794fb5a005c725]
Mai 19 10:02:41 CarolsIdeapad kernel:  amdgpu_ip_block_suspend+0x24/0x40 [amdgpu 2e78826c3bd11576b4cf6fbe04794fb5a005c725]
Mai 19 10:02:41 CarolsIdeapad kernel:  amdgpu_device_ip_suspend_phase1+0x8f/0xb0 [amdgpu 2e78826c3bd11576b4cf6fbe04794fb5a005c725]
Mai 19 10:02:41 CarolsIdeapad kernel:  amdgpu_device_suspend+0x74/0x170 [amdgpu 2e78826c3bd11576b4cf6fbe04794fb5a005c725]
Mai 19 10:02:41 CarolsIdeapad kernel:  pci_pm_suspend+0x7c/0x170
Mai 19 10:02:41 CarolsIdeapad kernel:  ? __pfx_pci_pm_suspend+0x10/0x10
Mai 19 10:02:41 CarolsIdeapad kernel:  dpm_run_callback+0x48/0x150
Mai 19 10:02:41 CarolsIdeapad kernel:  device_suspend+0x141/0x520
Mai 19 10:02:41 CarolsIdeapad kernel:  ? try_to_wake_up+0x7d/0x700
Mai 19 10:02:41 CarolsIdeapad kernel:  async_suspend+0x1d/0x30
Mai 19 10:02:41 CarolsIdeapad kernel:  async_run_entry_fn+0x31/0x140
Mai 19 10:02:41 CarolsIdeapad kernel:  process_one_work+0x17b/0x330
Mai 19 10:02:41 CarolsIdeapad kernel:  worker_thread+0x2ce/0x3f0
Mai 19 10:02:41 CarolsIdeapad kernel:  ? __pfx_worker_thread+0x10/0x10
Mai 19 10:02:41 CarolsIdeapad kernel:  kthread+0xcf/0x100
Mai 19 10:02:41 CarolsIdeapad kernel:  ? __pfx_kthread+0x10/0x10
Mai 19 10:02:41 CarolsIdeapad kernel:  ret_from_fork+0x31/0x50
Mai 19 10:02:41 CarolsIdeapad kernel:  ret_from_fork_asm+0x1a/0x30
Mai 19 10:02:41 CarolsIdeapad kernel:  </TASK>
Mai 19 10:02:41 CarolsIdeapad kernel: ---[ end trace 0000000000000000 ]---
Mai 19 10:02:41 CarolsIdeapad kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.XHC3.RHUB], AE_NOT_FOUND (20240827/psargs-332)
Mai 19 10:02:41 CarolsIdeapad kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
Mai 19 10:02:41 CarolsIdeapad rtkit-daemon[989]: The canary thread is apparently starving. Taking action.
Mai 19 10:02:41 CarolsIdeapad kdeconnectd[1298]: 2025-05-19T10:02:41 default: Error sending UDP packet: QAbstractSocket::NetworkError
Mai 19 10:02:41 CarolsIdeapad kdeconnectd[1298]: 2025-05-19T10:02:41 kdeconnect.core: Failed to open any MDNS client sockets
Mai 19 10:02:41 CarolsIdeapad kdeconnectd[1298]: 2025-05-19T10:02:41 kdeconnect.core: Failed to open any MDNS server sockets
Mai 19 10:02:44 CarolsIdeapad kdeconnectd[1298]: 2025-05-19T10:02:44 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Is the system fully up to date?
System information could help:
inxi -zv8
some things - perhaps important, perhaps not, perhaps not causal for this:
→ run a file system check by booting from USB - but this likely happens automatically on a clean reboot
Mai 19 09:26:52 CarolsIdeapad systemd-resolved[487]: /etc/hosts:7: hostname “Carols_Ideapad” is not valid, ignoring.
→ hostname is invalid (perhaps only lower case allowed? Or because the name CarolsIdeapad is different from Carols_Ideapad ? Or only lowercase allowed? Don’t know.)
→ related to the switch from KDE 5 to KDE 6 (?)
and the GPU driver is crashing
It’s not important, but I don’t know what “SO” means. :man_shrugging:
I do think it’s graphic drivers related that it does get stuck.
There are a few pending updates but this problem exists for a couple of weeks already and I already did a full system update/updated to a newer/older kernel etc.
inxi output:
  Kernel: 6.13.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=a4ba9c63-6828-4a27-84d8-4906ac5ec671 rw quiet splash
    resume=UUID=90ba761e-cb3a-4f3e-b080-b8aa619838d8 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Laptop System: LENOVO product: 83DD v: IdeaPad Slim 5 16AHP9
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 5 16AHP9
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    part-nu: LENOVO_MT_83DD_BU_idea_FM_IdeaPad Slim 5 16AHP9
    uuid: <superuser required> UEFI: LENOVO v: NGCN29WW date: 10/08/2024
  ID-1: BAT1 charge: 71.8 Wh (96.5%) condition: 74.4/76.0 Wh (97.9%)
    power: 0.8 W volts: 17.2 min: 15.1 model: SMP L23M4PK3 type: Unknown
    serial: <filter> status: not charging cycles: 30
  System RAM: total: 16 GiB available: 13.45 GiB used: 4.12 GiB (30.6%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Samsung
    part-no: K3KL8L80CM-MGCT serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA705206
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3730 min/max: 400/5100 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3730 2: 3730 3: 3730
    4: 3730 5: 3730 6: 3730 7: 3730 8: 3730 9: 3730 10: 3730 11: 3730 12: 3730
    13: 3730 14: 3730 15: 3730 16: 3730 bogomips: 121366
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
    bus-ID: 04:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 53.0 C
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04f2:b808
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: Lenovo 0x9159 built: 2023 res: 1920x1200 dpi: 142
    gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
    phoenix LLVM 19.1.7 DRM 3.61 6.13.12-1-MANJARO) device-ID: 1002:1900
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.0.4-arch1.1
    device-ID: 1002:1900 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.13.12-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-5:4 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 178.58 GiB (37.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: MTFDKCD512TGE-1BK1AABLA size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 1001V6LN temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 178.55 GiB (38.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: a4ba9c63-6828-4a27-84d8-4906ac5ec671
    used: 32.3 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 0398-FD8E
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 90ba761e-cb3a-4f3e-b080-b8aa619838d8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-2:2 info: CX 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3554:fc03 class-ID: 0301
  Device-2: 1-4:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:650a class-ID: ef00 serial: <filter>
  Device-3: 1-5:4 info: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek
    MT7922] type: bluetooth driver: btusb interfaces: 3 rev: 2.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b808 class-ID: fe01
    serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 77.9 C mobo: N/A gpu: amdgpu temp: 56.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1379 libs: 354 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://manjaro.ynh.ovh/stable/$repo/$arch
    4: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    5: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    8: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    10: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    11: https://mirror.23m.com/manjaro/stable/$repo/$arch
    12: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    13: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    15: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    16: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    17: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    18: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    19: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    20: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    21: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    22: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    23: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    24: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    25: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    26: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    27: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    28: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    29: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    30: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    31: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    32: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    33: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    35: http://manjaro.mirror.ac.za/stable/$repo/$arch
    36: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    37: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    39: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    40: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    41: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    42: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    43: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    44: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    45: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    46: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    47: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    48: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    49: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    51: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    52: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    53: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    54: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    55: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    56: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    57: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    58: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    59: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    60: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    61: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    62: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    63: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    65: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    66: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    68: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    69: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    70: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    71: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    72: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    73: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    74: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    75: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    76: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    77: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    79: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    81: http://manjaro.grena.ge/stable/$repo/$arch
    82: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    83: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    84: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    85: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    86: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    87: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    88: https://mirrors2.manjaro.org/stable/$repo/$arch
    89: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    90: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    91: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    92: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    93: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    94: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    95: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    96: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    97: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    98: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    99: https://mirror.init7.net/manjaro/stable/$repo/$arch
    100: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    101: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    102: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    103: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    104: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    105: https://manjaro.kurdy.org/stable/$repo/$arch
    106: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    107: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    108: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    109: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    110: https://linorg.usp.br/manjaro/stable/$repo/$arch
    111: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    112: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    113: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    114: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    115: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 349
  1: cpu: 26.0% command: brave pid: 10121 mem: 484.5 MiB (3.5%)
  2: cpu: 12.9% command: pamac-daemon pid: 10097 mem: 95.8 MiB (0.6%)
  3: cpu: 3.2% command: brave pid: 1592 mem: 651.7 MiB (4.7%)
  4: cpu: 1.9% command: brave pid: 2135 mem: 526.5 MiB (3.8%)
  5: cpu: 1.7% command: brave pid: 1645 mem: 315.1 MiB (2.2%)
  Memory top: 5 of 349
  1: mem: 651.7 MiB (4.7%) command: brave pid: 1592 cpu: 3.2%
  2: mem: 526.5 MiB (3.8%) command: brave pid: 2135 cpu: 1.9%
  3: mem: 484.5 MiB (3.5%) command: brave pid: 10121 cpu: 26.0%
  4: mem: 420.2 MiB (3.0%) command: plasmashell pid: 1024 cpu: 0.1%
  5: mem: 366.2 MiB (2.6%) command: brave pid: 2113 cpu: 0.4%
  Processes: 349 Power: uptime: 1h 40m states: freeze,mem,disk suspend: s2idle
    image: 5.36 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.38
SO = Significant Other
Is there any particular reason why your significant other is running Plasma on x11? The laptop doesn’t have an Nvidia GPU (they seem to be the main/only cause of issues with Plasma on Wayland), and Plasma Wayland works very well with AMD GPUs.
You can switch to a Plasma Wayland session by selecting it at the bottom of the SDDM login screen.
If your SO uses autologin to skip entering the password, then the session type can be changed by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
Wayland had a couple of weird bugs like it flickers when hovering a folder with preview images and also occasionally got stuck on reboot (although a lot more rarely)
Maybe try switching back to Wayland with a different kernel (linux613 is EOL). As your SO’s laptop has an AMD CPU released within the past 2 years, it should have no issues running linux614, or even the linux615 release candidate. I have been running linux615 full-time on my AMD mini-PC for a month without any issues:
[2025-04-21T19:51:42+1000] [ALPM] installed linux615 (6.15.0rc2-1)
Plasma on X11 probably isn’t going to get any better. All the development work is being done on Plasma Wayland. As of the upcoming release of Plasma 6.4.0, kwin_x11 has been split from kwin_wayland. kwin_x11 is being maintained by volunteers, with no new features to be added - just security updates & back-ported bug fixes:
Future of KWin/X11
KWin/X11 will be still maintained for the foreseeable future. But that maintenance work will boil down to fixing build errors, adapting to new KDE Frameworks and Plasma APIs, and backporting window-related fixes from KWin/Wayland. There are no plans to drop KWin/X11 in the Plasma 6 lifecycle, although it’s highly possible that it will happen in Plasma 7.
KWin/X11 won’t receive new features anymore; until recently, it received new features that had been developed against KWin/Wayland passively (because both lived in the same repository). However, it might be actually a good thing because the X11 session doesn’t receive that much testing nowadays.
Still happens on wayland:
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6._PRW], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._DSM], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.DEV0._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.DEV0._RMV], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.PCIC], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DVID], AE_ALREADY_EXISTS (20240827/dsfield-637)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DDID], AE_ALREADY_EXISTS (20240827/dsfield-637)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.VGA._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.VGA._STA], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.HDAU._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC0._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.ACP._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:36 CarolsIdeapad kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.AZAL._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Mai 21 16:54:37 CarolsIdeapad kernel: wmi_bus wmi_bus-PNP0C14:01: [Firmware Bug]: WQB1 data block query control method not found
Mai 21 16:54:37 CarolsIdeapad kernel: wmi_bus wmi_bus-PNP0C14:01: [Firmware Bug]: WQB2 data block query control method not found
Mai 21 16:54:37 CarolsIdeapad kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Mai 21 16:54:37 CarolsIdeapad systemd-journald[460]: File /var/log/journal/b0ed4cb2945b4fa9903a70a4cbbd3127/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 21 16:54:37 CarolsIdeapad systemd-resolved[478]: Failed to add DNS server address 'fe80::ee3e:b3ff:fe92:13f0%wlp2s0', ignoring: No such device
Mai 21 16:54:38 CarolsIdeapad dbus-broker-launch[674]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Mai 21 16:54:39 CarolsIdeapad ModemManager[725]: <wrn> [plugin-manager] task 0: port context already scheduled
Mai 21 16:54:39 CarolsIdeapad kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Mai 21 16:54:42 CarolsIdeapad dbus-broker-launch[800]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mai 21 16:54:42 CarolsIdeapad dbus-broker-launch[800]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mai 21 16:54:42 CarolsIdeapad dbus-broker-launch[800]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mai 21 16:54:43 CarolsIdeapad systemd-resolved[478]: /etc/hosts:7: hostname "Carols_Ideapad" is not valid, ignoring.
Mai 21 16:54:43 CarolsIdeapad systemd-resolved[478]: /etc/hosts:7: line is missing any valid hostnames
Mai 21 16:54:51 CarolsIdeapad sddm-greeter-qt6[796]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Mai 21 16:54:51 CarolsIdeapad systemd-journald[460]: File /var/log/journal/b0ed4cb2945b4fa9903a70a4cbbd3127/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 21 16:54:51 CarolsIdeapad dbus-broker-launch[912]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mai 21 16:54:51 CarolsIdeapad dbus-broker-launch[912]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mai 21 16:54:51 CarolsIdeapad dbus-broker-launch[912]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mai 21 16:54:51 CarolsIdeapad kernel: nvme nvme0: using unchecked data buffer
Mai 21 16:54:51 CarolsIdeapad kwin_wayland[926]: kwin_xkbcommon: XKB: Multiple definitions of group 2 name in map 'thinkpad'; Using 'Portuguese (Brazil, IBM/Lenovo ThinkPad)', ignoring 'Portuguese (Brazil)'
Mai 21 16:54:52 CarolsIdeapad baloo_file[925]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.32'
Mai 21 16:54:52 CarolsIdeapad baloo_file[925]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.36'
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Mai 21 16:54:52 CarolsIdeapad kconf_update[1215]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Mai 21 16:54:52 CarolsIdeapad kconf_update[1215]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Mai 21 16:54:52 CarolsIdeapad kconf_update[1215]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Mai 21 16:54:52 CarolsIdeapad kconf_update[1215]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Mai 21 16:54:52 CarolsIdeapad kactivitymanagerd[1213]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
Mai 21 16:54:52 CarolsIdeapad kded6[1095]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Mai 21 16:54:52 CarolsIdeapad plasmashell[1172]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Mai 21 16:54:52 CarolsIdeapad plasmashell[1172]: Toolbox not loading, toolbox package is either invalid or disabled.
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: Failed to find connector name for /dev/i2c-12, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    I2C_Bus_Info at: 0x57475f97db40
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Flags:                   I2C_BUS_EXISTS | I2C_BUS_ACCESSIBLE | I2C_BUS_PROBED | I2C_BUS_X50_EDID | I2C_BUS_SYSFS_KNOWN_RELIABLE
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Bus /dev/i2c-12 found:   true
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Bus /dev/i2c-12 probed:  true
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    errno for open:          OK(0): success
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    drm_connector_found_by:  DRM_CONNECTOR_NOT_CHECKED (0)
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    last_checked_asleep:       false
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Display connectors reported by /sys:
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-HDMI-A-1
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    5
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 101
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       name:         (null)
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       enabled:      disabled
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       status:       disconnected
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       edid:         None
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-1
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    13
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 107
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-2
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    14
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 113
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-3
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    15
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 118
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-4
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    16
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 123
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-5
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    17
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 128
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-DP-6
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    18
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 133
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-eDP-1
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    4
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 93
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       enabled:      enabled
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       status:       connected
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:         +0          +4          +8          +c            0   4   8   c
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0000   00 ff ff ff ff ff ff 00 30 ae 59 91 00 00 00 00   ........0.Y.....
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0010   1c 21 01 04 a5 22 16 78 e3 ee 95 a3 54 4c 99 26   .!...".x....TL.&
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0020   0f 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01   .PT.............
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0030   01 01 01 01 01 01 42 3c 80 a0 70 b0 24 40 30 20   ......B<..p.$@0
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0040   a6 00 58 d7 10 00 00 18 00 00 00 fd 00 28 3c 4b   ..X..........(<K
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0050   4b 10 01 0a 20 20 20 20 20 20 00 00 00 fe 00 4c   K...      .....L
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0060   45 4e 4f 56 4f 0a 20 20 20 20 20 20 00 00 00 fe   ENOVO.      ....
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: +0070   00 4c 45 4e 31 36 30 57 55 58 47 41 20 20 00 60   .LEN160WUXGA  .`
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:    Connector:    card1-Writeback-1
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       i2c_busno:    -1
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       connector_id: 142
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]:       status:       unknown
Mai 21 16:54:52 CarolsIdeapad org_kde_powerdevil[1219]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mai 21 16:54:53 CarolsIdeapad org_kde_powerdevil[1219]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mai 21 16:54:53 CarolsIdeapad org_kde_powerdevil[1219]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mai 21 16:54:53 CarolsIdeapad kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Mai 21 16:54:53 CarolsIdeapad plasmashell[1172]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Mai 21 16:54:56 CarolsIdeapad kwalletd6[1667]: g_dbus_proxy_get_object_path: assertion 'G_IS_DBUS_PROXY (proxy)' failed
Mai 21 16:54:57 CarolsIdeapad kwin_wayland[926]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Mai 21 16:54:59 CarolsIdeapad kwin_wayland[926]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Mai 21 16:55:20 CarolsIdeapad xdg-desktop-portal-kde[1220]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 21 16:55:28 CarolsIdeapad kioworker[2541]: qt.gui.imageio.jpeg: Not a JPEG file: starts with 0x89 0x50
Mai 21 16:55:54 CarolsIdeapad kactivitymanagerd[1213]: org.kde.kactivities.plugin.recentlyused-eventspy: could not parse "/home/carol/.local/share/recently-used.xbel" error was  "Opening and ending tag mismatch."
Mai 21 17:01:12 CarolsIdeapad kscreenlocker_greet[2925]: The Wayland connection broke. Did the Wayland compositor die?
Mai 21 17:58:24 CarolsIdeapad kernel: queueing ieee80211 work while going to suspend
Mai 21 17:58:24 CarolsIdeapad kernel: ------------[ cut here ]------------
Mai 21 17:58:24 CarolsIdeapad kernel: WARNING: CPU: 6 PID: 3727 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:3129 dm_suspend+0x246/0x260 [amdgpu]
Mai 21 17:58:24 CarolsIdeapad kernel: Modules linked in: rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device ccm cmac algif_hash algif_skcipher af_alg qrtr bnep vfat fat amd_atl intel_rapl_msr snd_sof_amd_acp70 intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_ctl_led snd_amd_sdw_acpi soundwire_amd kvm_amd snd_hda_codec_conexant soundwire_generic_allocation soundwire_bus snd_hda_codec_generic snd_soc_sdca snd_hda_codec_hdmi kvm snd_soc_core snd_hda_intel mt7921e irqbypass snd_compress snd_intel_dspcfg mt7921_common polyval_clmulni ac97_bus snd_intel_sdw_acpi snd_pcm_dmaengine polyval_generic mt792x_lib uvcvideo snd_rpl_pci_acp6x snd_hda_codec ghash_clmulni_intel mt76_connac_lib snd_acp_pci videobuf2_vmalloc snd_hda_core sha512_ssse3 snd_acp_legacy_common uvc mt76 sha256_ssse3 snd_hwdep videobuf2_memops snd_pci_acp6x videobuf2_v4l2 btusb sha1_ssse3 spd5118 snd_pcm videobuf2_common btrtl
Mai 21 17:58:24 CarolsIdeapad kernel:  aesni_intel snd_pci_acp5x sp5100_tco mac80211 hid_multitouch btintel snd_timer snd_rn_pci_acp3x crypto_simd ucsi_acpi videodev btbcm snd_acp_config snd cryptd ideapad_laptop typec_ucsi i2c_piix4 libarc4 snd_soc_acpi btmtk bluetooth rapl platform_profile mc cfg80211 pcspkr typec wmi_bmof sparse_keymap amdxdna k10temp snd_pci_acp3x mousedev i2c_smbus ccp joydev soundcore rfkill roles i2c_hid_acpi i2c_hid 8250_dw amd_pmc mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables hid_generic usbhid amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec sdhci_pci gpu_sched sdhci_uhs2 serio_raw drm_suballoc_helper atkbd sdhci drm_panel_backlight_quirks nvme libps2 drm_buddy cqhci vivaldi_fmap drm_display_helper nvme_core mmc_core i8042 video cec nvme_auth serio wmi
Mai 21 17:58:24 CarolsIdeapad kernel: CPU: 6 UID: 0 PID: 3727 Comm: kworker/u64:25 Not tainted 6.14.6-2-MANJARO #1 c44399280e56315b63f8490b2c72f1b5d553c73d
Mai 21 17:58:24 CarolsIdeapad kernel: Hardware name: LENOVO 83DD/LNVNB161216, BIOS NGCN29WW 10/08/2024
Mai 21 17:58:24 CarolsIdeapad kernel: Workqueue: async async_run_entry_fn
Mai 21 17:58:24 CarolsIdeapad kernel: RIP: 0010:dm_suspend+0x246/0x260 [amdgpu]
Mai 21 17:58:24 CarolsIdeapad kernel: Code: 48 8b bd 68 4a 04 00 e9 95 fe ff ff 41 0f b6 8c 24 a0 02 00 00 48 89 e6 4c 89 ef 4c 89 24 24 88 4c 24 08 e8 0c 4e 32 00 eb a2 <0f> 0b e9 fa fd ff ff e8 de aa 07 f5 66 66 2e 0f 1f 84 00 00 00 00
Mai 21 17:58:24 CarolsIdeapad kernel: RSP: 0018:ffffb5bc04a37cb8 EFLAGS: 00010282
Mai 21 17:58:24 CarolsIdeapad kernel: RAX: 0000000000000000 RBX: ffff8cc0de780078 RCX: ffffffffc11d0940
Mai 21 17:58:24 CarolsIdeapad kernel: RDX: 00000000000000f0 RSI: 0000000000000000 RDI: ffff8cc0de780000
Mai 21 17:58:24 CarolsIdeapad kernel: RBP: ffff8cc0de780000 R08: 0000000003c00020 R09: 0000000000000001
Mai 21 17:58:24 CarolsIdeapad kernel: R10: 00000000d3e01508 R11: 0000000000000000 R12: 0000000000000001
Mai 21 17:58:24 CarolsIdeapad kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8cc0ec75ae00
Mai 21 17:58:24 CarolsIdeapad kernel: FS:  0000000000000000(0000) GS:ffff8cc36fd00000(0000) knlGS:0000000000000000
Mai 21 17:58:24 CarolsIdeapad kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mai 21 17:58:24 CarolsIdeapad kernel: CR2: 0000000000000000 CR3: 000000010ea22000 CR4: 0000000000f50ef0
Mai 21 17:58:24 CarolsIdeapad kernel: PKRU: 55555554
Mai 21 17:58:24 CarolsIdeapad kernel: Call Trace:
Mai 21 17:58:24 CarolsIdeapad kernel:  <TASK>
Mai 21 17:58:24 CarolsIdeapad kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Mai 21 17:58:24 CarolsIdeapad kernel:  ? hdp_v5_2_update_clock_gating+0x219/0x370 [amdgpu 1d4beda2ba3b7e4e3dfdfe36f6578b6c7ea1a1b8]
Mai 21 17:58:24 CarolsIdeapad kernel:  amdgpu_ip_block_suspend+0x24/0x50 [amdgpu 1d4beda2ba3b7e4e3dfdfe36f6578b6c7ea1a1b8]
Mai 21 17:58:24 CarolsIdeapad kernel:  amdgpu_device_ip_suspend_phase1+0xaa/0xc0 [amdgpu 1d4beda2ba3b7e4e3dfdfe36f6578b6c7ea1a1b8]
Mai 21 17:58:24 CarolsIdeapad kernel:  amdgpu_device_suspend+0x76/0x160 [amdgpu 1d4beda2ba3b7e4e3dfdfe36f6578b6c7ea1a1b8]
Mai 21 17:58:24 CarolsIdeapad kernel:  pci_pm_suspend+0x7d/0x170
Mai 21 17:58:24 CarolsIdeapad kernel:  ? __pfx_pci_pm_suspend+0x10/0x10
Mai 21 17:58:24 CarolsIdeapad kernel:  dpm_run_callback+0x47/0x150
Mai 21 17:58:24 CarolsIdeapad kernel:  device_suspend+0x14d/0x540
Mai 21 17:58:24 CarolsIdeapad kernel:  async_suspend+0x21/0x30
Mai 21 17:58:24 CarolsIdeapad kernel:  async_run_entry_fn+0x33/0x140
Mai 21 17:58:24 CarolsIdeapad kernel:  process_one_work+0x17c/0x340
Mai 21 17:58:24 CarolsIdeapad kernel:  worker_thread+0x2d2/0x400
Mai 21 17:58:24 CarolsIdeapad kernel:  ? __pfx_worker_thread+0x10/0x10
Mai 21 17:58:24 CarolsIdeapad kernel:  kthread+0xec/0x230
Mai 21 17:58:24 CarolsIdeapad kernel:  ? __pfx_kthread+0x10/0x10
Mai 21 17:58:24 CarolsIdeapad kernel:  ret_from_fork+0x31/0x50
Mai 21 17:58:24 CarolsIdeapad kernel:  ret_from_fork_asm+0x1a/0x30
Mai 21 17:58:24 CarolsIdeapad kernel:  </TASK>
Mai 21 17:58:24 CarolsIdeapad kernel: ---[ end trace 0000000000000000 ]---
Mai 21 17:58:24 CarolsIdeapad kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.XHC3.RHUB], AE_NOT_FOUND (20240827/psargs-332)
Mai 21 17:58:24 CarolsIdeapad kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
Mai 21 17:58:24 CarolsIdeapad rtkit-daemon[968]: The canary thread is apparently starving. Taking action.
Mai 21 17:58:24 CarolsIdeapad kdeconnectd[1383]: 2025-05-21T17:58:24 default: Error sending UDP packet: QAbstractSocket::NetworkError
Mai 21 17:58:24 CarolsIdeapad kdeconnectd[1383]: 2025-05-21T17:58:24 kdeconnect.core: Failed to open any MDNS client sockets
Mai 21 17:58:24 CarolsIdeapad kdeconnectd[1383]: 2025-05-21T17:58:24 kdeconnect.core: Failed to open any MDNS server sockets
Mai 21 17:58:24 CarolsIdeapad org_kde_powerdevil[1219]: org.kde.powerdevil: [BacklightBrightness]: Failed to set screen brightness ""
Mai 21 17:58:28 CarolsIdeapad kdeconnectd[1383]: 2025-05-21T17:58:28 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Just going to through my two cents in here.
The error comes from BIOS. Beside the fact it actually says BIOS those AE… come from Advanced Error reporting from BIOS (from what I remember), so I am not sure this is solvable on Manjaro level.
Maybe you can check if there are any BIOS updates available?
Beside from that I had a similar problem long ago, couldn’t resume from sleep, or maybe hibernation. I tried to find a post about it, but maybe I never asked about it here, I want to remember it was GRUB related.
EDIT: Those errors seems to be common and mostly harmless and might not be related to your problem.
But maybe this can be something:
https://wiki.archlinux.org/title/Lenovo_IdeaPad_5_14are05#Suspend
