I tried to put my laptop to sleep, and on resuming from sleep I got a black screen.
The system totally hangs, with switching ttys unusable and REISUB not responsive. The only way to reset the system is hard-poweroff by holding power button for a few seconds.
What is interesting is that if I close the lid and immediately reopen it in a few seconds, It seems fine and normally resumes from sleep. Any sleep time more than 1 minute will render the system dead.
Kernel message suggests that some amdgpu job timed out during resume, causing a GPU reset which I think fails shortly after.
Interestingly, adding amd_iommu=fullflush to boot parameter once fixed the problem(But broken again now). During a normal sleep procedure the amdgpu error is not present, so I think it causes the system to hang.
journalctl --system --boot=-1:
12ζ 25 12:27:31 catalysa-81yn systemd-logind[530]: Lid closed.
12ζ 25 12:27:31 catalysa-81yn NetworkManager[510]: <info> [1608870451.9062] manager: sleep: sleep requested (sleeping: no enabled: yes)
12ζ 25 12:27:31 catalysa-81yn ModemManager[563]: <info> [sleep-monitor] system is about to suspend
12ζ 25 12:27:31 catalysa-81yn NetworkManager[510]: <info> [1608870451.9064] device (98:F6:21:C9:08:19): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
12ζ 25 12:27:31 catalysa-81yn NetworkManager[510]: <info> [1608870451.9076] manager: NetworkManager state is now ASLEEP
12ζ 25 12:27:32 catalysa-81yn systemd[1]: Reached target Sleep.
12ζ 25 12:27:32 catalysa-81yn systemd[1]: Starting Suspend; Hibernate if not used for a period of time...
12ζ 25 12:27:33 catalysa-81yn systemd-sleep[1966]: Suspending system...
12ζ 25 12:27:33 catalysa-81yn kernel: PM: suspend entry (s2idle)
12ζ 25 12:27:33 catalysa-81yn kernel: Filesystems sync: 0.003 seconds
12ζ 25 12:27:42 catalysa-81yn kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
12ζ 25 12:27:42 catalysa-81yn kernel: OOM killer disabled.
12ζ 25 12:27:42 catalysa-81yn kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
12ζ 25 12:27:42 catalysa-81yn kernel: printk: Suspending console(s) (use no_console_suspend to debug)
12ζ 25 12:27:42 catalysa-81yn kernel: [drm] free PSP TMR buffer
12ζ 25 12:27:42 catalysa-81yn kernel: ACPI: EC: interrupt blocked
12ζ 25 12:27:42 catalysa-81yn kernel: ACPI: EC: interrupt unblocked
12ζ 25 12:27:42 catalysa-81yn kernel: ------------[ cut here ]------------
12ζ 25 12:27:42 catalysa-81yn kernel: WARNING: CPU: 1 PID: 1966 at kernel/irq/chip.c:210 irq_startup+0xe1/0xf0
12ζ 25 12:27:42 catalysa-81yn kernel: Modules linked in: rfcomm fuse cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel bluetooth ecdh_generic usbhid uvcvideo ecc videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc squashfs joydev mousedev hid_multitouch hid_generic snd_acp3x_pdm_dma snd_acp3x_rn snd_soc_dmic snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine wmi_bmof loop vmnet(OE) amdgpu snd_hda_codec_realtek rtw88_8822ce edac_mce_amd snd_hda_codec_generic rtw88_8822c kvm_amd nls_iso8859_1 ledtrig_audio nls_cp437 snd_hda_codec_hdmi rtw88_pci vfat snd_hda_intel kvm fat rtw88_core snd_intel_dspcfg snd_hda_codec irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel mac80211 aesni_intel gpu_sched snd_hda_core i2c_algo_bit crypto_simd ttm snd_hwdep cryptd glue_helper snd_pcm rapl cfg80211 drm_kms_helper pcspkr input_leds tpm_crb snd_timer sp5100_tco cec snd ideapad_laptop k10temp i2c_piix4 sparse_keymap snd_rn_pci_acp3x rc_core snd_pci_acp3x tpm_tis ucsi_acpi
12ζ 25 12:27:42 catalysa-81yn kernel: syscopyarea typec_ucsi rfkill tpm_tis_core sysfillrect sysimgblt ccp fb_sys_fops libarc4 soundcore typec wmi evdev battery ac tpm mac_hid rng_core pinctrl_amd i2c_hid hid acpi_cpufreq vmmon(OE) vmw_vmci uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) drm msr sg crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 sdhci_pci cqhci crc32c_intel xhci_pci sdhci xhci_hcd mmc_core i8042 serio
12ζ 25 12:27:42 catalysa-81yn kernel: CPU: 1 PID: 1966 Comm: systemd-sleep Tainted: G OE 5.9.11-3-MANJARO #1
12ζ 25 12:27:42 catalysa-81yn kernel: Hardware name: LENOVO 81YN/LNVNB161216, BIOS DTCN22WW(V1.08) 07/07/2020
12ζ 25 12:27:42 catalysa-81yn kernel: RIP: 0010:irq_startup+0xe1/0xf0
12ζ 25 12:27:42 catalysa-81yn kernel: Code: f6 4c 89 e7 e8 e0 41 00 00 85 c0 75 21 4c 89 e7 31 d2 4c 89 ee e8 cf c3 ff ff 48 89 ef e8 b7 fe ff ff 41 89 c4 e9 51 ff ff ff <0f> 0b eb b6 0f 0b eb b2 0f 1f 80 00 00 00 00 0f 1f 44 00 00 55 48
12ζ 25 12:27:42 catalysa-81yn kernel: RSP: 0018:ffff92ce88677da0 EFLAGS: 00010002
12ζ 25 12:27:42 catalysa-81yn kernel: RAX: 0000000000000140 RBX: 0000000000000001 RCX: 0000000000000140
12ζ 25 12:27:42 catalysa-81yn kernel: RDX: 0000000000000004 RSI: ffffffff849756e0 RDI: ffff90033ca1b818
12ζ 25 12:27:42 catalysa-81yn kernel: RBP: ffff90033ca1b800 R08: 0000000000000000 R09: 0000000000000140
12ζ 25 12:27:42 catalysa-81yn kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001
12ζ 25 12:27:42 catalysa-81yn kernel: R13: ffff90033ca1b818 R14: ffff90033ca1b8e4 R15: 0000000000000000
12ζ 25 12:27:42 catalysa-81yn kernel: FS: 00007fd2dfa90200(0000) GS:ffff90033f440000(0000) knlGS:0000000000000000
12ζ 25 12:27:42 catalysa-81yn kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12ζ 25 12:27:42 catalysa-81yn kernel: CR2: 00007f25e265d310 CR3: 000000039e070000 CR4: 0000000000350ee0
12ζ 25 12:27:42 catalysa-81yn kernel: Call Trace:
12ζ 25 12:27:42 catalysa-81yn kernel: resume_irqs+0xb6/0xf0
12ζ 25 12:27:42 catalysa-81yn kernel: dpm_resume_noirq+0xf/0x20
12ζ 25 12:27:42 catalysa-81yn kernel: suspend_devices_and_enter+0x333/0x8a0
12ζ 25 12:27:42 catalysa-81yn kernel: pm_suspend.cold+0x329/0x374
12ζ 25 12:27:42 catalysa-81yn kernel: state_store+0x42/0x90
12ζ 25 12:27:42 catalysa-81yn kernel: kernfs_fop_write+0xce/0x1b0
12ζ 25 12:27:42 catalysa-81yn kernel: vfs_write+0xc7/0x210
12ζ 25 12:27:42 catalysa-81yn kernel: ksys_write+0x67/0xe0
12ζ 25 12:27:42 catalysa-81yn kernel: do_syscall_64+0x33/0x40
12ζ 25 12:27:42 catalysa-81yn kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
12ζ 25 12:27:42 catalysa-81yn kernel: RIP: 0033:0x7fd2e08a9f67
12ζ 25 12:27:42 catalysa-81yn kernel: Code: 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 51 c3 48 83 ec 28 48 89 54 24 18 48 89 74 24
12ζ 25 12:27:42 catalysa-81yn kernel: RSP: 002b:00007fff88a54e88 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
12ζ 25 12:27:42 catalysa-81yn kernel: RAX: ffffffffffffffda RBX: 0000000000000004 RCX: 00007fd2e08a9f67
12ζ 25 12:27:42 catalysa-81yn kernel: RDX: 0000000000000004 RSI: 00007fff88a54f70 RDI: 0000000000000005
12ζ 25 12:27:42 catalysa-81yn kernel: RBP: 00007fff88a54f70 R08: 00005584f7642570 R09: 00007fd2e09400c0
12ζ 25 12:27:42 catalysa-81yn kernel: R10: 00007fd2e093ffc0 R11: 0000000000000246 R12: 0000000000000004
12ζ 25 12:27:42 catalysa-81yn kernel: R13: 00005584f76413c0 R14: 0000000000000004 R15: 00007fd2e097c720
12ζ 25 12:27:42 catalysa-81yn kernel: ---[ end trace 73fc629cbe95bc78 ]---
12ζ 25 12:27:42 catalysa-81yn kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
12ζ 25 12:27:42 catalysa-81yn kernel: [drm] PSP is resuming...
12ζ 25 12:27:42 catalysa-81yn kernel: [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
12ζ 25 12:27:42 catalysa-81yn kernel: usb 3-4: reset full-speed USB device number 4 using xhci_hcd
12ζ 25 12:27:42 catalysa-81yn kernel: ideapad_laptop: Unknown event: 10
12ζ 25 12:27:42 catalysa-81yn kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
12ζ 25 12:27:42 catalysa-81yn kernel: amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
12ζ 25 12:27:42 catalysa-81yn kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
12ζ 25 12:27:42 catalysa-81yn kernel: [drm] kiq ring mec 2 pipe 1 q 0
12ζ 25 12:27:42 catalysa-81yn kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
12ζ 25 12:27:42 catalysa-81yn kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
12ζ 25 12:27:42 catalysa-81yn kernel: [drm:amdgpu_device_resume [amdgpu]] *ERROR* amdgpu_device_ip_resume failed (-110).
12ζ 25 12:27:42 catalysa-81yn kernel: PM: dpm_run_callback(): pci_pm_resume+0x0/0xe0 returns -110
12ζ 25 12:27:42 catalysa-81yn kernel: PM: Device 0000:04:00.0 failed to resume async: error -110
12ζ 25 12:27:42 catalysa-81yn kernel: WARNING: CPU: 1 PID: 1966 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc_link.c:2548 dc_link_set_backlight_level+0x8a/0xf0 [amdgpu]
12ζ 25 12:27:42 catalysa-81yn kernel: CPU: 1 PID: 1966 Comm: systemd-sleep Tainted: G W OE 5.9.11-3-MANJARO #1
12ζ 25 12:27:42 catalysa-81yn kernel: RIP: 0010:dc_link_set_backlight_level+0x8a/0xf0 [amdgpu]
12ζ 25 12:27:42 catalysa-81yn kernel: Code: 70 03 00 00 31 c0 48 8d 96 c0 01 00 00 48 8b 0a 48 85 c9 74 06 48 3b 59 08 74 20 83 c0 01 48 81 c2 d8 04 00 00 83 f8 06 75 e3 <0f> 0b 45 31 e4 5b 44 89 e0 5d 41 5c 41 5d 41 5e c3 48 98 48 69 c0
12ζ 25 12:27:42 catalysa-81yn kernel: RSP: 0018:ffff92ce88677ce8 EFLAGS: 00010246
12ζ 25 12:27:42 catalysa-81yn kernel: RAX: 0000000000000006 RBX: ffff90033b33cc00 RCX: 0000000000000000
12ζ 25 12:27:42 catalysa-81yn kernel: RDX: ffff900310bc1ed0 RSI: ffff900310bc0000 RDI: 0000000000000000
12ζ 25 12:27:42 catalysa-81yn kernel: RBP: ffff900320770000 R08: 00000000000000f2 R09: ffff90033f46c4f0
12ζ 25 12:27:42 catalysa-81yn kernel: R10: 00000000000002c9 R11: 0000000000000000 R12: 000000000000f201
12ζ 25 12:27:42 catalysa-81yn kernel: R13: 0000000000000000 R14: 000000000000f2f2 R15: 0000000000000010
12ζ 25 12:27:42 catalysa-81yn kernel: amdgpu_dm_backlight_update_status+0xb4/0xc0 [amdgpu]
12ζ 25 12:27:42 catalysa-81yn kernel: backlight_resume+0x6a/0x80
12ζ 25 12:27:42 catalysa-81yn kernel: ? backlight_suspend+0x80/0x80
12ζ 25 12:27:42 catalysa-81yn kernel: dpm_run_callback+0x4f/0x180
12ζ 25 12:27:42 catalysa-81yn kernel: device_resume+0xa7/0x200
12ζ 25 12:27:42 catalysa-81yn kernel: dpm_resume+0xc9/0x2f0
12ζ 25 12:27:42 catalysa-81yn kernel: dpm_resume_end+0xd/0x20
12ζ 25 12:27:42 catalysa-81yn kernel: suspend_devices_and_enter+0x1a8/0x8a0
12ζ 25 12:27:42 catalysa-81yn kernel: ---[ end trace 73fc629cbe95bc79 ]---
12ζ 25 12:27:42 catalysa-81yn kernel: OOM killer enabled.
12ζ 25 12:27:42 catalysa-81yn kernel: Restarting tasks ...
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000c lmp_ver=0a lmp_subver=8822
12ζ 25 12:27:42 catalysa-81yn kernel: done.
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: rom_version status=0 version=3
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cu_fw.bin
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cu_config.bin
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: cfg_sz 6, total sz 34338
12ζ 25 12:27:42 catalysa-81yn systemd-logind[530]: Lid opened.
12ζ 25 12:27:42 catalysa-81yn bluetoothd[1220]: Endpoint unregistered: sender=:1.94 path=/MediaEndpoint/A2DPSink/sbc
12ζ 25 12:27:42 catalysa-81yn systemd[1]: Starting Load/Save RF Kill Switch Status...
12ζ 25 12:27:42 catalysa-81yn bluetoothd[1220]: Endpoint unregistered: sender=:1.94 path=/MediaEndpoint/A2DPSource/sbc
12ζ 25 12:27:42 catalysa-81yn upowerd[1311]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-4
12ζ 25 12:27:42 catalysa-81yn systemd[1]: Stopped target Bluetooth.
12ζ 25 12:27:42 catalysa-81yn audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:42 catalysa-81yn systemd[1]: Started Load/Save RF Kill Switch Status.
12ζ 25 12:27:42 catalysa-81yn systemd[1]: Reached target Bluetooth.
12ζ 25 12:27:42 catalysa-81yn kernel: audit: type=1130 audit(1608870462.371:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:42 catalysa-81yn systemd-sleep[1966]: System resumed.
12ζ 25 12:27:42 catalysa-81yn kernel: PM: suspend exit
12ζ 25 12:27:42 catalysa-81yn kernel: Bluetooth: hci0: RTL: fw version 0x099a281a
12ζ 25 12:27:42 catalysa-81yn bluetoothd[1220]: Endpoint registered: sender=:1.94 path=/MediaEndpoint/A2DPSink/sbc
12ζ 25 12:27:42 catalysa-81yn bluetoothd[1220]: Endpoint registered: sender=:1.94 path=/MediaEndpoint/A2DPSource/sbc
12ζ 25 12:27:43 catalysa-81yn systemd[1]: systemd-suspend-then-hibernate.service: Succeeded.
12ζ 25 12:27:43 catalysa-81yn systemd[1]: Finished Suspend; Hibernate if not used for a period of time.
12ζ 25 12:27:43 catalysa-81yn audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend-then-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:43 catalysa-81yn kernel: audit: type=1130 audit(1608870463.048:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend-then-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:43 catalysa-81yn kernel: audit: type=1131 audit(1608870463.048:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend-then-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:43 catalysa-81yn audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend-then-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:43 catalysa-81yn systemd[1]: Stopped target Sleep.
12ζ 25 12:27:43 catalysa-81yn systemd[1]: Reached target Suspend; Hibernate if not used for a period of time.
12ζ 25 12:27:43 catalysa-81yn systemd[1]: Stopped target Suspend; Hibernate if not used for a period of time.
12ζ 25 12:27:43 catalysa-81yn systemd-logind[530]: Operation 'sleep' finished.
12ζ 25 12:27:43 catalysa-81yn ModemManager[563]: <info> [sleep-monitor] system is resuming
12ζ 25 12:27:43 catalysa-81yn NetworkManager[510]: <info> [1608870463.0598] manager: sleep: wake requested (sleeping: yes enabled: yes)
12ζ 25 12:27:43 catalysa-81yn NetworkManager[510]: <info> [1608870463.0601] manager: NetworkManager state is now DISCONNECTED
12ζ 25 12:27:47 catalysa-81yn systemd[1]: systemd-rfkill.service: Succeeded.
12ζ 25 12:27:47 catalysa-81yn audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:47 catalysa-81yn kernel: audit: type=1131 audit(1608870467.378:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12ζ 25 12:27:52 catalysa-81yn kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=1072, emitted seq=1074
12ζ 25 12:27:52 catalysa-81yn kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
12ζ 25 12:27:52 catalysa-81yn kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset begin!
12ζ 25 12:27:52 catalysa-81yn kernel: BUG: kernel NULL pointer dereference, address: 0000000000000028
12ζ 25 12:27:52 catalysa-81yn kernel: #PF: supervisor read access in kernel mode
12ζ 25 12:27:52 catalysa-81yn kernel: #PF: error_code(0x0000) - not-present page
12ζ 25 12:27:52 catalysa-81yn kernel: PGD 0 P4D 0
12ζ 25 12:27:52 catalysa-81yn kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
12ζ 25 12:27:52 catalysa-81yn kernel: CPU: 3 PID: 328 Comm: kworker/3:2 Tainted: G W OE 5.9.11-3-MANJARO #1
12ζ 25 12:27:52 catalysa-81yn kernel: Hardware name: LENOVO 81YN/LNVNB161216, BIOS DTCN22WW(V1.08) 07/07/2020
12ζ 25 12:27:52 catalysa-81yn kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
12ζ 25 12:27:52 catalysa-81yn kernel: RIP: 0010:kernel_queue_uninit+0xd/0xf0 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: Code: ee 48 89 c7 e8 a4 f9 ff ff 84 c0 0f 84 95 db 1d 00 4c 89 e0 5d 41 5c 41 5d c3 0f 1f 00 0f 1f 44 00 00 55 48 8b 47 10 48 89 fd <8b> 50 28 83 fa 02 74 78 83 fa 03 0f 84 b1 00 00 00 48 8b 7f 08 4c
12ζ 25 12:27:52 catalysa-81yn kernel: RSP: 0018:ffff92ce82017d50 EFLAGS: 00010246
12ζ 25 12:27:52 catalysa-81yn kernel: RAX: 0000000000000000 RBX: ffff90031f6b1000 RCX: 000000008080007d
12ζ 25 12:27:52 catalysa-81yn kernel: RDX: 000000008080007e RSI: 0000000000000001 RDI: ffff90032b33d080
12ζ 25 12:27:52 catalysa-81yn kernel: RBP: ffff90032b33d080 R08: 0000000000000001 R09: 0000000000000001
12ζ 25 12:27:52 catalysa-81yn kernel: R10: ffff90032b2fd080 R11: 0000000000000000 R12: ffff90031f6b10d0
12ζ 25 12:27:52 catalysa-81yn kernel: R13: ffff90032d960000 R14: ffff9003023f2000 R15: 0000000000000001
12ζ 25 12:27:52 catalysa-81yn kernel: FS: 0000000000000000(0000) GS:ffff90033f4c0000(0000) knlGS:0000000000000000
12ζ 25 12:27:52 catalysa-81yn kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12ζ 25 12:27:52 catalysa-81yn kernel: CR2: 0000000000000028 CR3: 00000001bf20e000 CR4: 0000000000350ee0
12ζ 25 12:27:52 catalysa-81yn kernel: Call Trace:
12ζ 25 12:27:52 catalysa-81yn kernel: stop_cpsch+0xa2/0xc0 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: kgd2kfd_suspend.part.0+0x2f/0x40 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: kgd2kfd_pre_reset+0x35/0x50 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: amdgpu_device_gpu_recover.cold+0x208/0xef0 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: amdgpu_job_timedout+0x121/0x140 [amdgpu]
12ζ 25 12:27:52 catalysa-81yn kernel: drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
12ζ 25 12:27:52 catalysa-81yn kernel: process_one_work+0x1da/0x3d0
12ζ 25 12:27:52 catalysa-81yn kernel: worker_thread+0x4d/0x3d0
12ζ 25 12:27:52 catalysa-81yn kernel: ? rescuer_thread+0x410/0x410
12ζ 25 12:27:52 catalysa-81yn kernel: kthread+0x142/0x160
12ζ 25 12:27:52 catalysa-81yn kernel: ? __kthread_bind_mask+0x60/0x60
12ζ 25 12:27:52 catalysa-81yn kernel: ret_from_fork+0x22/0x30
12ζ 25 12:27:52 catalysa-81yn kernel: Modules linked in: rfcomm fuse cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel bluetooth ecdh_generic usbhid uvcvideo ecc videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc squashfs joydev mousedev hid_multitouch hid_generic snd_acp3x_pdm_dma snd_acp3x_rn snd_soc_dmic snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine wmi_bmof loop vmnet(OE) amdgpu snd_hda_codec_realtek rtw88_8822ce edac_mce_amd snd_hda_codec_generic rtw88_8822c kvm_amd nls_iso8859_1 ledtrig_audio nls_cp437 snd_hda_codec_hdmi rtw88_pci vfat snd_hda_intel kvm fat rtw88_core snd_intel_dspcfg snd_hda_codec irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel mac80211 aesni_intel gpu_sched snd_hda_core i2c_algo_bit crypto_simd ttm snd_hwdep cryptd glue_helper snd_pcm rapl cfg80211 drm_kms_helper pcspkr input_leds tpm_crb snd_timer sp5100_tco cec snd ideapad_laptop k10temp i2c_piix4 sparse_keymap snd_rn_pci_acp3x rc_core snd_pci_acp3x tpm_tis ucsi_acpi
12ζ 25 12:27:52 catalysa-81yn kernel: syscopyarea typec_ucsi rfkill tpm_tis_core sysfillrect sysimgblt ccp fb_sys_fops libarc4 soundcore typec wmi evdev battery ac tpm mac_hid rng_core pinctrl_amd i2c_hid hid acpi_cpufreq vmmon(OE) vmw_vmci uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) drm msr sg crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 sdhci_pci cqhci crc32c_intel xhci_pci sdhci xhci_hcd mmc_core i8042 serio
12ζ 25 12:27:52 catalysa-81yn kernel: ---[ end trace 73fc629cbe95bc7a ]---
12ζ 25 12:27:56 catalysa-81yn kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x67 on isa0060/serio0).
12ζ 25 12:27:56 catalysa-81yn kernel: atkbd serio0: Use 'setkeycodes 67 <keycode>' to make it known.
12ζ 25 12:27:56 catalysa-81yn kernel: atkbd serio0: Unknown key released (translated set 2, code 0x67 on isa0060/serio0).
12ζ 25 12:27:59 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:02 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:04 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:08 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:10 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:11 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:16 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:23 catalysa-81yn kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x67 on isa0060/serio0).
12ζ 25 12:28:23 catalysa-81yn kernel: atkbd serio0: Use 'setkeycodes 67 <keycode>' to make it known.
12ζ 25 12:28:23 catalysa-81yn kernel: atkbd serio0: Unknown key released (translated set 2, code 0x67 on isa0060/serio0).
12ζ 25 12:28:24 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:39 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:41 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:28:42 catalysa-81yn systemd-logind[530]: Power key pressed.
12ζ 25 12:29:01 catalysa-81yn kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x67 on isa0060/serio0).
12ζ 25 12:29:01 catalysa-81yn kernel: atkbd serio0: Use 'setkeycodes 67 <keycode>' to make it known.
12ζ 25 12:29:01 catalysa-81yn kernel: atkbd serio0: Unknown key released (translated set 2, code 0x67 on isa0060/serio0).
Log begins on lid closure, with the amdgpu thing on line 151.
System info:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=84301e39-36c2-4423-b005-01cd15923255 rw apparmor=1
security=apparmor udev.log_priority=3 amd_iommu=fullflush iommu=soft
acpi_backlight=native resume=/dev/nvme0n1p5
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81YN v: Lenovo XiaoXinAir-14ARE 2020
serial: <filter> Chassis: type: 10 v: Lenovo XiaoXinAir-14ARE 2020
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769 WIN serial: <filter>
UEFI: LENOVO v: DTCN22WW(V1.08) date: 07/07/2020
ID-1: BAT1 charge: 17.9 Wh condition: 54.7/56.5 Wh (97%) volts: 11.2/11.6
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x39 0x43 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 17
Info: 6-Core model: AMD Ryzen 5 4600U with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 3072 KiB
bogomips: 50326
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
10: 1397 11: 1397 12: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 04:00.0
chip ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
chip ID: 04f2:b6c2 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 120 s-size: 406x228mm (16.0x9.0")
s-diag: 466mm (18.3")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 04:00.1
chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus ID: 03:00.0 chip ID: 10ec:c822
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 476.94 GiB used: 35.10 GiB (7.4%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA512TDV size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 3006P4LN scheme: GPT
ID-1: / raw size: 43.69 GiB size: 42.76 GiB (97.86%) used: 35.07 GiB (82.0%)
fs: ext4 dev: /dev/nvme0n1p6
ID-1: swap-1 type: partition size: 14.90 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5
System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 299 Uptime: 22m Memory: 15.01 GiB used: 2.15 GiB (14.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1259 lib: 340
flatpak: 0 Shell: Zsh v: 5.8 running in: yakuake inxi: 3.1.08
