I’ve suspected for a while that this laptop is using a lot of power in standby mode (suspend to ram). Usually I use standby only when charger is connected, otherwise I use hibernate (suspend to disk). Now, however, I but it into standby and placed it in a bag for a 30 minute travel. When I unbagged it I realized that it was hot. So I did a test: Fully charged, I unplugged to charger and placed the laptop in standby. Exactly 10 hours later I powered it on 37% of the battery was left. So it consumes 6.2% of the battery /hour in standby mode.
For comparison, if I turn off wlan, BT and put screen on lowest brightness, it consumes 3,52%/hour. And with wlan and BT on and screen at my usual working britgthness level, it consumes about 4.3%/hour. So battery drains way faster in standby than when powered on.
Is there anything that can be done to reduce power consumption in standby mode?
# tlp-stat --battery
--- TLP 1.3.1 --------------------------------------------
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi = inactive (laptop not supported)
+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer = Notebook
/sys/class/power_supply/BAT0/model_name = BAT
/sys/class/power_supply/BAT0/cycle_count = (not supported)
/sys/class/power_supply/BAT0/charge_full_design = 9600 [mAh]
/sys/class/power_supply/BAT0/charge_full = 9179 [mAh]
/sys/class/power_supply/BAT0/charge_now = 8298 [mAh]
/sys/class/power_supply/BAT0/current_now = 351 [mA]
/sys/class/power_supply/BAT0/status = Discharging
Charge = 90.4 [%]
Capacity = 95.6 [%]
# inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.11.22-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=b71e4128-01e3-4565-97ec-2fa0745987aa rw sysrq_always_enabled=1
apparmor=1 security=apparmor
resume=UUID=daf0114f-9ff9-4f2e-884d-24924538c92b udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: SCHENKER product: SCHENKER_VIA_14_SVI14E20 v: N/A
serial: N/A Chassis: Notebook type: 10 serial: N/A
Mobo: SCHENKER model: L140CU serial: N/A UEFI: INSYDE v: 1.07.08
date: 03/27/2020
ID-1: BAT0 charge: 64.8 Wh (91.7%) condition: 70.7/73.9 Wh (95.6%)
volts: 8.3 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: Discharging
RAM: total: 23.22 GiB used: 1.82 GiB (7.8%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 2667 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
part-no: M471A1G44AB0-CTD serial: N/A
Device-2: ChannelB-DIMM0 size: 16 GiB speed: 2667 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Crucial
part-no: CT16G4SFD8266.C16FD1 serial: <filter>
Info: Quad Core model: Intel Core i5-10210U socket: BGA1528 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE cache: L2: 6 MiB
bogomips: 33615
Speed: 1372 MHz min/max: 400/4200 MHz base/boost: 1485/8300 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1372 2: 1266 3: 1294 4: 1531
5: 1837 6: 1353 7: 2076 8: 2039
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-7:2 chip-ID: 04f2:b684 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.11.22-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 3000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF-ID-1: brfjt state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-2: brmen state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-3: brptp state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-4: dumfjt state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-5: dummen state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-6: dumptp state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Device-1: m type: zfs status: ONLINE level: linear size: 476 GiB
free: 145 GiB allocated: 331 GiB
Components: Online:
1: nvme1n1 maj-min: 259:8 size: 476.94 GiB
Device-2: z type: zfs status: ONLINE level: linear size: 780 GiB
free: 159 GiB allocated: 621 GiB
Components: Online:
1: nvme0n1p7 maj-min: 259:7 size: 781.65 GiB
Local Storage: total: raw: 1.38 TiB usable: 1.37 TiB used: 53.54 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 temp: 29.9 C
scheme: GPT
SMART: yes health: PASSED on: 88d 20h cycles: 662
read-units: 19,129,589 [9.79 TB] written-units: 13,433,202 [6.87 TB]
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Micron model: 2200 MTFDHBA512TCK
lanes: 4 rotation: SSD serial: <filter> rev: P1MU003 temp: 27.9 C
scheme: GPT
SMART: yes health: PASSED on: 19d 17h cycles: 966
read-units: 2,603 [1.33 GB] written-units: 95,234 [48.7 GB]
ID-1: / raw-size: 4.88 GiB size: 4.74 GiB (97.13%) used: 1.05 GiB (22.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: b71e4128-01e3-4565-97ec-2fa0745987aa
used: 284 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 6753-CC31
ID-3: /com/common raw-size: N/A size: 153.79 GiB used: 19.23 GiB (12.5%)
fs: zfs logical: z/common label: N/A uuid: N/A
ID-4: /home raw-size: 92.77 GiB size: 90.32 GiB (97.35%)
used: 16.81 GiB (18.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: b6c4a853-9def-48bf-9586-ec731ff3c88f
ID-5: /usr raw-size: 12.21 GiB size: 11.95 GiB (97.92%)
used: 9.57 GiB (80.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 64523363-5d2a-4e1a-825d-23fa623fa8cb
ID-6: /var raw-size: 15.29 GiB size: 14.99 GiB (98.05%)
used: 6.88 GiB (45.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4 label: N/A uuid: 8da49cc0-3304-4db8-894f-241e809ee825
Kernel: swappiness: 5 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 24.41 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: daf0114f-9ff9-4f2e-884d-24924538c92b
ID-1: /dev/nvme1n1p9 maj-min: 259:10 size: 8 MiB fs: N/A label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-7:2 info: Chicony Chicony USB2.0 Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 461 Uptime: 9m wakeups: 627 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1345 pacman: 1342 lib: 421 flatpak: 0
snap: 3 Shell: Bash (su) v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
