Hello @Manjaro-Communiy!
After I manged to elude the CUPS-hell thanks to your support,
I want to tackle the second big old issue with my Notebook.
When connecting one of its video ports (1 HDMI and 1 VGA) to a powered Monitor 1-1½ years ago, it would use that flawlessly (like its predecessors).
At home I used one of the monitors also connected to the desktop with matching ports, selecting its input either by the HDMI switch or digital/analog mode, and a portable monitor with HDMI while traveling.
Since around turn of the year I realized that the external screen goes black when connected to the laptop per VGA - but the HDMI connection (which I prefer anyway) still worked - until sometime late spring/early summer when it decided to turn black when switching the HDMI input, too.
Each time when it lost a functionality it was after a bundled update but I doubt that there’s a causal connection.
What are the usual suspects and how can I get info from the system to narrow down the actual cause and repair it?
(Cables have been exchanged multiply and tested positive for working from the desktop.)
And here's the typically required generic system's info:
Kernel: 6.18.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
root=UUID=ab46277f-9387-4ba4-a78d-c5d85119857d rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: GNOME v: 50.5 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
base: Arch Linux
Type: Laptop System: FUJITSU product: CELSIUS H780 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB5D v: 757383-01R9500225 serial: <filter>
part-nu: SK00 uuid: a41a3b37-7475-e911-8b14-a06610a7488b Firmware: UEFI
vendor: FUJITSU // Insyde v: Version 1.22 date: 11/16/2023
ID-1: BAT1 charge: 81.5 Wh (96.5%) condition: 84.5/96.5 Wh (87.6%)
volts: 16.42 min: 14.4 model: PAC CP722160-01 type: Li-ion serial: <filter>
charging: status: not charging cycles: 21
System RAM: total: 32 GiB available: 30.99 GiB used: 8.41 GiB (27.1%)
igpu: 64 MiB
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: curr: 1.2 min: 1.35 max: 1.35 width (bits): data: 64
total: 64 manufacturer: SK Hynix part-no: HMA82GS6AFR8N-UH
serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Message: No PCI Slot data found.
Info: model: Intel Core i7-8750H socket: BGA1440 bits: 64 type: MT MCP
arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave volts: 0.8 V ext-clock: 100 MHz cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 52799
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Fujitsu
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P600 Mobile] vendor: Fujitsu driver: N/A
alternate: nouveau, nova_core, nvidia_drm, nvidia non-free: 550-580.xx+
status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1cbc class-ID: 0300
Device-3: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b3b4
Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0630 built: 2016 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.365 green: x: 0.349 y: 0.580
blue: x: 0.161 y: 0.141 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e9b memory: 30.27 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo,xprop
Device-1: Intel 300/C240 Series Family HD Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Fujitsu
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.18.55-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.9 status: n/a (root, process) with:
Device-1: Intel 300/C240 Series Family CNVi Wi-Fi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-LM vendor: Fujitsu driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwp0s20f0u4i12 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 476.94 GiB used: 185.19 GiB (38.8%)
model: MZVLB512HAJQ-00007 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7302Q temp: 23.9 C scheme: GPT
ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 32.42 GiB (71.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
label: sme_5.ManjaroGNM uuid: ab46277f-9387-4ba4-a78d-c5d85119857d
ID-2: /boot/efi raw-size: 477 MiB size: 476 MiB (99.80%)
used: 456 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SME_5_EFI uuid: 407C-EF8F
ID-3: /home raw-size: 9.31 GiB size: 9.07 GiB (97.38%)
used: 5.98 GiB (65.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: sme_5.MG_home
uuid: 81135bcb-ea8f-40df-a191-f9f889f914e7
ID-4: /mnt/bkp raw-size: 176.59 GiB size: 172.76 GiB (97.83%)
used: 121.84 GiB (70.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: sme_5.MG_backup
uuid: c36ae656-eb75-4218-8828-26090d9b1dec
ID-5: /mnt/data raw-size: 149.01 GiB size: 145.61 GiB (97.72%)
used: 24.96 GiB (17.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: sme_5.data
uuid: fae9353f-dda4-4b69-9f6e-5179fa11200c
ID-1: swap-1 type: partition size: 39.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: sme_5.swap
uuid: 136dda25-3200-4c4d-8cd7-dce0de17bdd8
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 46.57 GiB fs: ext4
label: sme_5.ManjaroKDE uuid: 25f5f5ad-49fe-495c-861f-513c2bb77042
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 9.31 GiB fs: ext4
label: sme_5.MK_home uuid: 2f771f65-7d0a-4dc7-9b37-decd655d959f
Device-1: 1-2:2 info: Areson Corp Elecom MR-K013 Multicard Reader
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 25a7:fa61 class-ID: 0301
Device-2: 1-4:3 info: Sierra Wireless EM7455 type: communication,CDC-data
driver: cdc_mbim interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1199:9075 class-ID: 0a00
serial: <filter>
Device-3: 1-7:4 info: Chicony FJ Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b3b4 class-ID: 0e02 serial: <filter>
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 34.0 C pch: 35.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1588 libs: 414 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0
1: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
2: https://mirror.rabisu.com/mirrors/manjaro/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
6: https://mirror.23m.com/manjaro/stable/$repo/$arch
7: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
8: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
9: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
10: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
11: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
12: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
13: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
14: https://mirror.informatik.tu-freiberg.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 387
1: cpu: 400% command: ps pid: 48988 mem: 3.79 MiB (0.0%)
2: cpu: 31.2% command: fprintd pid: 48964 mem: 14.0 MiB (0.0%)
3: cpu: 4.3% command: firefox pid: 48928 mem: 88.0 MiB (0.2%)
4: cpu: 3.8% command: gnome-terminal-server pid: 48404
mem: 73.1 MiB (0.2%)
5: cpu: 1.8% command: zsh pid: 48674 mem: 10.7 MiB (0.0%)
Memory top: 5 of 387
1: mem: 1322.7 MiB (4.1%) command: thunderbird pid: 28887 cpu: 0.1%
2: mem: 1240.8 MiB (3.9%) command: firefox pid: 39143 cpu: 0.4%
3: mem: 895.5 MiB (2.8%) command: firefox pid: 40147 cpu: 0.0%
4: mem: 837.8 MiB (2.6%) command: firefox pid: 40207 cpu: 0.0%
5: mem: 557.3 MiB (1.7%) command: firefox pid: 40255 cpu: 0.0%
Processes: 387 Power: uptime: 18h 45m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.32 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: gcc: 16.2.1 Shell: Sudo (sudo) v: 1.9.17p2 default: Bash
v: 5.3.20 running-in: gnome-terminal inxi: 3.3.41
Mod edit:- When enclosing content in [details] … [/details] – all content must be enclosed, including the ``` before and after the content itself – Fixed for you. ![]()
