On doing sudo systemctl suspend the screen goes black then wakes up immediately.
dmesg
[ 404.821728] PM: suspend entry (s2idle)
[ 404.839580] Filesystems sync: 0.017 seconds
[ 404.841120] Freezing user space processes
[ 404.847067] Freezing user space processes completed (elapsed 0.005 seconds)
[ 404.847074] OOM killer disabled.
[ 404.847076] Freezing remaining freezable tasks
[ 404.848306] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 404.848309] printk: Suspending console(s) (use no_console_suspend to debug)
[ 404.880622] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 404.883904] atkbd serio0: Disabling IRQ1 wakeup source to avoid platform firmware bug
[ 406.135871] ACPI: EC: interrupt blocked
[ 406.294296] dell_wmi: Unknown key with type 0x0010 and code 0x0140 pressed
[ 406.294302] dell_wmi: Invalid length of WMI event
[ 406.299232] dell_wmi: Unknown key with type 0x0010 and code 0x0140 pressed
[ 406.299234] dell_wmi: Invalid length of WMI event
[ 407.103194] ACPI: EC: interrupt unblocked
[ 407.117251] dell_wmi: Unknown key with type 0x0010 and code 0x0130 pressed
[ 407.117254] dell_wmi: Invalid length of WMI event
[ 407.444883] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 407.444889] pci 0000:00:00.2: PCI INT A: no GSI
[ 407.446053] [drm] PCIE GART of 1024M enabled.
[ 407.446059] [drm] PTB located at 0x000000F417C00000
[ 407.446086] amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
[ 407.447625] amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
[ 407.448674] amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
[ 407.491184] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 407.491597] [drm] JPEG decode initialized successfully.
[ 407.491601] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 407.491604] amdgpu 0000:04:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
[ 407.491606] amdgpu 0000:04:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
[ 407.491608] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
[ 407.491610] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
[ 407.491612] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
[ 407.491613] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
[ 407.491615] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
[ 407.491616] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
[ 407.491618] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
[ 407.491619] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
[ 407.491621] amdgpu 0000:04:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
[ 407.491623] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
[ 407.491624] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
[ 407.491626] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
[ 407.491627] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
[ 407.491629] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
[ 407.605402] nvme nvme0: 16/0/0 default/read/poll queues
[ 407.755838] ata2: SATA link down (SStatus 0 SControl 300)
[ 407.757612] ata1: SATA link down (SStatus 0 SControl 300)
[ 407.962073] OOM killer enabled.
[ 407.962076] Restarting tasks ... done.
[ 407.963777] random: crng reseeded on system resumption
[ 407.965728] PM: suspend exit
inxi --full -xxx
Host: g15 Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Dell G15 5515 v: 1.9.0 serial:
Chassis: type: 10 v: 1.9.0 serial:
Mobo: Dell model: 0TGD6F v: A04 serial:
UEFI: Dell v: 1.9.0 date: 11/10/2022
ID-1: BAT1 charge: 33.5 Wh (63.1%) condition: 53.1/56.0 Wh (94.7%)
volts: 11.9 min: 11.4 model: Simplo 0x50,0x39,0x35,0x41,0x0B,0x0A,0x03
type: Li-ion serial: 000E status: not charging
Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB
L3: 16 MiB
Speed (MHz): avg: 1767 high: 2400 min/max: 400/4280 volts: 1.2 V
ext-clock: 100 MHz cores: 1: 2013 2: 400 3: 2400 4: 2398 5: 1959 6: 400
7: 2398 8: 2397 9: 2012 10: 400 11: 2290 12: 2138 bogomips: 79083
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 545.29.06 arch: Ampere pcie: speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Dell driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1 bus-ID: 04:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 47.0 C
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 0c45:6a09
class-ID: 0e02
Display: server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0a8a res: 1920x1080 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:1638
API: Vulkan v: 1.3.274 layers: 1 surfaces: xcb,xlib device: 0
type: discrete-gpu driver: nvidia device-ID: 10de:25a2 device: 1
type: integrated-gpu hw: amd driver: mesa radv device-ID: 1002:1638
Device-1: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
3: pipewire-alsa type: plugin
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlp3s0 state: up mac: 50:84:92:b3:25:9a
speed: 12 Mb/s lanes: 1 bus-ID: 1-3:4 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 942.7 GiB used: 8.91 GiB (0.9%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNS512G NVMe KIOXIA 512GB
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 22EPG2OFQXD3
fw-rev: 10410106 temp: 32.9 C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 tech: SSD
serial: 21374C451301 scheme: GPT
ID-1: / size: 9.75 GiB used: 8.91 GiB (91.4%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 1023 MiB used: 308 KiB (0.0%) fs: vfat
dev: /dev/sda3
System Temperatures: cpu: 58.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A
Processes: 328 Uptime: 4m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.1 GiB used: 2.62 GiB (17.4%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1126 Shell: Sudo (sudo) v: 1.9.15p4 default: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
sudo dmidecode | grep Wake-up
Wake-up Type: Power Switch
sort /proc/acpi/wakeup | grep -v disabled
Device S-state Status Sysfs node
GP17 S4 *enabled pci:0000:00:08.1
GPP0 S4 *enabled pci:0000:00:01.1
GPP1 S4 *enabled pci:0000:00:01.2
I disabled all wakeups but suspend still doesn’t work.
