Hi all,
I have just fresh install on my Dell. I have SimpleScreenRecorder installed, video is fine but for audio, all I get is loud static noise. Any input is appreciated. SimpleScreenRecorder works fine on my HP 470g3 laptop.
inxi -Fzxxxa
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9661aef0-376b-4553-b17b-dfa6338aaa82 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: A00 serial: <superuser required> UEFI: Dell
v: 1.15.0 date: 08/30/2021
ID-1: BAT0 charge: 11.6 Wh (19.4%) condition: 59.8/74.0 Wh (80.9%)
volts: 11.0 min: 11.4 model: SMP DELL 71JF453 type: Li-poly serial: <filter>
status: discharging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2558 high: 2800 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2800 2: 2800 3: 2800
4: 2800 5: 2800 6: 2800 7: 2800 8: 864 bogomips: 44817
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-03)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0300 temp: 34.0 C
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-12:5 chip-ID: 1bcf:28c1 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris,nouveau gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x63ed built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
vendor: Dell driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: d000 bus-ID: 02:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-4:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.93 TiB used: 11.51 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNK128GVN8 M.2 2280
128GB size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4101 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 1D scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB model: USB 3.0 Disk 3.0
size: 1.91 TiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 2.00 scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 11.51 GiB (9.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 38.0 C pch: 35.5 C mobo: 32.0 C sodimm: SODIMM C
gpu: nouveau temp: 34.0 C
Fan Speeds (RPM): cpu: 0
Processes: 249 Uptime: 3h 44m wakeups: 14925 Memory: 7.63 GiB
used: 2.86 GiB (37.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1087 libs: 342 tools: pamac Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.26
and
pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0fb9"
device.product.name = "GP107GL High Definition Audio Controller"
device.string = "1"
device.description = "GP107GL High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdf328000 irq 132"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a171"
device.product.name = "CM238 HD Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:analog-surround-21: Analog Surround 2.1 Output (priority 34068, available: unknown)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (priority 34133, available: unknown)
output:analog-surround-40: Analog Surround 4.0 Output (priority 33968, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 34033, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#4: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#5: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#6: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-headphone-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
also
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC3246 Analog [ALC3246 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
