My laptop (ThinkPad X1 Carbon gen. 4) completely hangs at random times on the actual kernel (6.0.8 at the time) and on the latest LTS kernel 5.15. Also tried Linux Zen 6.0.8.1 from Arch repos with the same result.
How it looks: at some point the system stops accepting commands. At first the mouse looks like functional, I can minimize-maximize and move the windows, but their content is not displayed anymore, only artefacts, Application menu doesn’t work and applications couldn’t being runned. Yakuake(F12) is not called, switching to another session via Ctrl+Alt+F* does not work, Ctrl+Esc does not response. Once I catch hanging with active Konsole and it didn’t respond to commands. Even that hangs deeper after a while. The system completely stops responding to any command, even the hardware CapsLock indicator stops switching. The only thing left is a hard shutdown by holding down the power button.
It’s definitely not overheating - before and during the hanging fans weren’t working even halfway.
It’s definitely not a problem with fs - tried both btfs and (now) ext4.
It must not be a RAM problem, cuz I didn’t done any RAM (or CPU) consuming operations during the hanging, and the problem isn’t connected with load out. I can play games without any problems, but sometimes it may hang in browser with 3-5 tabs.
The fwupdate is done, the firmware for the bios is latest and dated 11.2022.
The same problem was on EndeavourOS, so this problem is not specific to the Manjaro.
Now I’m using the oldest available kernel (4.19.267-1) and it doesn’t have the problem. Only once I faced plasma crashed, but I don’t think that’s related to the described problem, although on fresh kernels the plasma didn’t crash.
Here is my current state of inxi -Fxz
Kernel: 4.19.265-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.26.3 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20FB004JUS v: ThinkPad X1 Carbon 4th
Mobo: LENOVO model: 20FB004JUS UEFI: LENOVO v: N1FET81W (1.55 ) date: 10/11/2022
ID-1: BAT0 charge: 46.9 Wh (100.0%) condition: 46.9/52.1 Wh (90.0%)
volts: 17.0 min: 15.2 model: SMP 00HW029 status: full
Info: dual core model: Intel Core i5-6300U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 733 high: 800 min/max: 400/3000 cores: 1: 620 2: 712
3: 800 4: 800 bogomips: 19968
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 bus-ID: 00:02.0
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:4
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound API: ALSA v: k4.19.265-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: 3.2.6-k
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up
Local Storage: total: 119.24 GiB used: 74.68 GiB (62.6%)
ID-1: /dev/nvme0n1 vendor: Silicon Power model: SPCC M.2 PCIe SSD
ID-1: / size: 107.86 GiB used: 74.56 GiB (69.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 9.4 MiB (3.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 105 MiB (1.2%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 54.0 C pch: 48.5 C mobo: N/A
Fan Speeds (RPM): cpu: 3522
Processes: 202 Uptime: 21h 5m Memory: 7.53 GiB used: 4.4 GiB (58.5%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1452 Shell: Zsh
v: 5.9 inxi: 3.3.23
