Hello,
I’m using Manjaro on a rather new Laptop (XMG Fusion - Mid 2022), and I’m experiencing some strange problems: when I’m using the laptop in AC mode, everything (including suspend) works fine. However, when I’m using the laptop in battery mode, it’s not possible to enter suspend or hibernate. When I try to suspend, the session is locked, and the screen turns off for a moment, but then it turns back on with a black screen and a flashing white underscore in the top left corner of the screen (looks a bit like a command prompt). At this point, I can only perform a hard restart to get it working again.
Another problem, which might be related, is that I can’t run some applications (e.g. Steam) while I’m on battery mode. When I try to start them, the laptop gets kind of stuck. I can still use any already running applications, but I can’t start new applications, and also the internet connection is lost. Also, if this happens, I can’t restart the laptop, except for a hard restart.
As both of these problems occur only on battery mode, I think the real problem might be related to the power management of my laptop. I’m running the latest Bios, and I already reset the Bios to the defaults.
I also tried re-installing Manjaro, but the problems also occur on the new installation.
Here is my system information:
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=a107ecb3-7db4-41bf-a728-0553e9b31d0b rw rootflags=subvol=@ quiet
cryptdevice=UUID=ed368491-e71b-4fa2-bd8c-f9e79576c8f2:luks-ed368491-e71b-4fa2-bd8c-f9e79576c8f2
root=/dev/mapper/luks-ed368491-e71b-4fa2-bd8c-f9e79576c8f2
udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SchenkerGmbH product: XMG FUSION 15 (XFU15M22)
v: M38721-403 serial: <superuser required> Chassis: type: 10 v: 2.0
Mobo: Intel model: LAPKC71F v: M22222-402 serial: <superuser required>
UEFI: Intel v: KCTGL357.0042.2022.0727.1604 date: 07/27/2022
ID-1: BAT0 charge: 71.8 Wh (80.0%) condition: 89.7/93.5 Wh (95.9%)
volts: 12.3 min: 11.4 model: standard type: Li-ion serial: <filter>
status: not charging
RAM: total: 30.94 GiB used: 4.77 GiB (15.4%)
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1829 high: 2300 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 812 7: 2300 8: 2300 9: 1133 10: 1127 11: 2300 12: 2300
13: 981 14: 2300 15: 1064 16: 1157 bogomips: 73744
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Intel
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 3-13:4
chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
s-diag: 1245mm (49.01")
Monitor-1: DP-1-0 pos: primary,right res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: eDP-1 pos: left res: 2560x1440 hz: 165 dpi: 189
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Intel
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 2e:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp46s0 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-14:5
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-ed368491-e71b-4fa2-bd8c-f9e79576c8f2 maj-min: 254:0
type: LUKS dm: dm-0 size: 499.41 GiB
Components:
p-1: nvme0n1p6 maj-min: 259:6 size: 499.42 GiB
Local Storage: total: 931.51 GiB used: 439.66 GiB (47.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 499.41 GiB size: 499.41 GiB (100.00%)
used: 439.52 GiB (88.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ed368491-e71b-4fa2-bd8c-f9e79576c8f2 label: N/A
uuid: a107ecb3-7db4-41bf-a728-0553e9b31d0b
ID-2: /boot raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 144.9 MiB (48.4%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: F002-39DF
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: F018-8726
ID-4: /home raw-size: 499.41 GiB size: 499.41 GiB (100.00%)
ID-5: /var/cache raw-size: 499.41 GiB size: 499.41 GiB (100.00%)
ID-6: /var/log raw-size: 499.41 GiB size: 499.41 GiB (100.00%)
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: EEC5-91F0
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 429.7 GiB fs: bitlocker
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 746 MiB fs: ntfs label: N/A
uuid: ECAABCDEAABCA70C
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 832 MiB fs: ntfs label: Recovery
uuid: B266C43966C3FC5B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-1:12 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 3-1:2 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Hub-5: 3-7:21 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-7.2:22 info: Cherry GmbH Wireless Device
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 046a:c114 class-ID: 0300
Device-2: 3-7.3:23 info: Cherry GmbH Keyboard type: Keyboard,HID
driver: cherry,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 046a:0023 class-ID: 0300
Device-3: 3-11:3 info: Integrated Express ITE Device(8291)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:6006 class-ID: 0300
Device-4: 3-13:4 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b71a
Device-5: 3-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 338 Uptime: 3h 54m wakeups: 393 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1628 libs: 431 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.25
And here’s the output of journalctl --boot=-1 --priority=3 --catalog --no-pager :
Feb 17 08:21:16 ManjaroFusion kernel: usbhid 3-11:1.0: couldn't find an input interrupt endpoint
Feb 17 08:21:17 ManjaroFusion kernel:
Feb 17 08:21:18 ManjaroFusion bluetoothd[950]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 17 08:21:18 ManjaroFusion bluetoothd[950]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 17 08:21:18 ManjaroFusion bluetoothd[950]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 17 08:21:18 ManjaroFusion sddm[1003]: Failed to read display number from pipe
Feb 17 08:21:19 ManjaroFusion kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Feb 17 08:21:23 ManjaroFusion systemd[1316]: Failed to start Update XDG user dir configuration.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 27 and the job result is failed.
Feb 17 08:21:25 ManjaroFusion systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 456 and the job result is failed.
Feb 17 08:21:42 ManjaroFusion systemd-coredump[2581]: Process 2559 (kscreen_osd_ser) of user 1000 dumped core.
Stack trace of thread 2559:
#0 0x00007f8d7274253f _ZN7QWindow10setVisibleEb (libQt5Gui.so.5 + 0x14253f)
#1 0x00007f8d722bea71 n/a (libQt5Core.so.5 + 0x2bea71)
#2 0x00007f8d722bee14 _ZN7QObject9destroyedEPS_ (libQt5Core.so.5 + 0x2bee14)
#3 0x00007f8d722b537c _ZN7QObjectD2Ev (libQt5Core.so.5 + 0x2b537c)
#4 0x00007f8d73bb0e8a n/a (libKF5Screen.so.7 + 0x28e8a)
#5 0x0000564e594d2956 n/a (kscreen_osd_service + 0xa956)
#6 0x0000564e594d29e5 n/a (kscreen_osd_service + 0xa9e5)
#7 0x00007f8d722b1bb0 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b1bb0)
#8 0x00007f8d7228df48 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28df48)
#9 0x00007f8d7228ea53 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x28ea53)
#10 0x00007f8d722d4e88 n/a (libQt5Core.so.5 + 0x2d4e88)
#11 0x00007f8d70b1682b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
#12 0x00007f8d70b6dcc9 n/a (libglib-2.0.so.0 + 0xaccc9)
#13 0x00007f8d70b150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#14 0x00007f8d722d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#15 0x00007f8d722866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#16 0x00007f8d72291219 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x291219)
#17 0x0000564e594cd4db n/a (kscreen_osd_service + 0x54db)
#18 0x00007f8d7323c790 n/a (libc.so.6 + 0x23790)
#19 0x00007f8d7323c84a __libc_start_main (libc.so.6 + 0x2384a)
#20 0x0000564e594cd685 n/a (kscreen_osd_service + 0x5685)
Stack trace of thread 2561:
#0 0x00007f8d733139df __poll (libc.so.6 + 0xfa9df)
#1 0x00007f8d7399626b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007f8d73997d1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007f8d6d7b0252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007f8d720e432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007f8d7329ebb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007f8d73320d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2563:
#0 0x00007f8d7329b766 n/a (libc.so.6 + 0x82766)
#1 0x00007f8d7329df90 pthread_cond_wait (libc.so.6 + 0x84f90)
#2 0x00007f8d6570c49e n/a (iris_dri.so + 0x10c49e)
#3 0x00007f8d656bc86c n/a (iris_dri.so + 0xbc86c)
#4 0x00007f8d6570c3cc n/a (iris_dri.so + 0x10c3cc)
Stack trace of thread 2560:
#1 0x00007f8d70b6dc2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007f8d70b150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007f8d722d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007f8d722866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007f8d720e725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007f8d73b1ecba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f8d720e432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007f8d7329ebb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007f8d73320d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2562:
Stack trace of thread 2564:
Stack trace of thread 2565:
Stack trace of thread 2568:
Stack trace of thread 2571:
Stack trace of thread 2570:
Stack trace of thread 2572:
Stack trace of thread 2574:
Stack trace of thread 2566:
Stack trace of thread 2569:
Stack trace of thread 2573:
Stack trace of thread 2567:
░░ Subject: Speicherabbild für Prozess 2559 (kscreen_osd_ser) generiert
░░ Documentation: man:core(5)
░░ Prozess 2559 (kscreen_osd_ser) ist abgebrochen worden und
░░ ein Speicherabbild wurde generiert.
░░ Üblicherweise ist dies ein Hinweis auf einen Programmfehler und sollte
░░ als Fehler dem jeweiligen Hersteller gemeldet werden.
Feb 17 08:21:43 ManjaroFusion bluetoothd[950]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Feb 17 08:21:44 ManjaroFusion kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1128
Feb 17 08:21:53 ManjaroFusion systemd-coredump[2639]: Process 2612 (kscreen_osd_ser) of user 1000 dumped core.
Stack trace of thread 2612:
#0 0x00007fd6f094253f _ZN7QWindow10setVisibleEb (libQt5Gui.so.5 + 0x14253f)
#1 0x00007fd6f04bea71 n/a (libQt5Core.so.5 + 0x2bea71)
#2 0x00007fd6f04bee14 _ZN7QObject9destroyedEPS_ (libQt5Core.so.5 + 0x2bee14)
#3 0x00007fd6f04b537c _ZN7QObjectD2Ev (libQt5Core.so.5 + 0x2b537c)
#4 0x00007fd6f1c03e8a n/a (libKF5Screen.so.7 + 0x28e8a)
#5 0x000055bf1e9cd956 n/a (kscreen_osd_service + 0xa956)
#6 0x000055bf1e9cd9e5 n/a (kscreen_osd_service + 0xa9e5)
#7 0x00007fd6f04b1bb0 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b1bb0)
#8 0x00007fd6f048df48 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28df48)
#9 0x00007fd6f048ea53 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x28ea53)
#10 0x00007fd6f04d4e88 n/a (libQt5Core.so.5 + 0x2d4e88)
#11 0x00007fd6eec6e82b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
#12 0x00007fd6eecc5cc9 n/a (libglib-2.0.so.0 + 0xaccc9)
#13 0x00007fd6eec6d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#14 0x00007fd6f04d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#15 0x00007fd6f04866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#16 0x00007fd6f0491219 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x291219)
#17 0x000055bf1e9c84db n/a (kscreen_osd_service + 0x54db)
#18 0x00007fd6f143c790 n/a (libc.so.6 + 0x23790)
#19 0x00007fd6f143c84a __libc_start_main (libc.so.6 + 0x2384a)
#20 0x000055bf1e9c8685 n/a (kscreen_osd_service + 0x5685)
Stack trace of thread 2614:
#0 0x00007fd6f15139df __poll (libc.so.6 + 0xfa9df)
#1 0x00007fd6f0e9f26b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007fd6f0ea0d1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007fd6eb827252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007fd6f02e432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007fd6f149ebb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007fd6f1520d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2616:
#0 0x00007fd6f149b766 n/a (libc.so.6 + 0x82766)
#1 0x00007fd6f149df90 pthread_cond_wait (libc.so.6 + 0x84f90)
#2 0x00007fd6e250c49e n/a (iris_dri.so + 0x10c49e)
#3 0x00007fd6e24bc86c n/a (iris_dri.so + 0xbc86c)
#4 0x00007fd6e250c3cc n/a (iris_dri.so + 0x10c3cc)
Stack trace of thread 2617:
Stack trace of thread 2615:
Stack trace of thread 2613:
#1 0x00007fd6eecc5c2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007fd6eec6d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007fd6f04d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007fd6f04866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007fd6f02e725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007fd6f1b71cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007fd6f02e432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007fd6f149ebb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007fd6f1520d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2620:
Stack trace of thread 2619:
Stack trace of thread 2618:
Stack trace of thread 2622:
Stack trace of thread 2624:
Stack trace of thread 2626:
Stack trace of thread 2623:
Stack trace of thread 2635:
#1 0x00007fd6f149e294 pthread_cond_timedwait (libc.so.6 + 0x85294)
#2 0x00007fd6f02eb754 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb754)
#3 0x00007fd6f02e82f7 n/a (libQt5Core.so.5 + 0xe82f7)
Stack trace of thread 2636:
Stack trace of thread 2637:
Stack trace of thread 2627:
Stack trace of thread 2625:
Stack trace of thread 2633:
Stack trace of thread 2621:
Stack trace of thread 2634:
░░ Subject: Speicherabbild für Prozess 2612 (kscreen_osd_ser) generiert
░░ Prozess 2612 (kscreen_osd_ser) ist abgebrochen worden und
Feb 17 08:21:59 ManjaroFusion kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1128
Feb 17 08:22:01 ManjaroFusion kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1128
Feb 17 08:22:15 ManjaroFusion kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1128
Feb 17 08:22:17 ManjaroFusion kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1128
Feb 17 08:22:56 ManjaroFusion systemd-coredump[3282]: Process 2647 (kscreen_osd_ser) of user 1000 dumped core.
Stack trace of thread 2647:
#0 0x00007f973f74253f _ZN7QWindow10setVisibleEb (libQt5Gui.so.5 + 0x14253f)
#1 0x00007f973f2bea71 n/a (libQt5Core.so.5 + 0x2bea71)
#2 0x00007f973f2bee14 _ZN7QObject9destroyedEPS_ (libQt5Core.so.5 + 0x2bee14)
#3 0x00007f973f2b537c _ZN7QObjectD2Ev (libQt5Core.so.5 + 0x2b537c)
#4 0x00007f9740b9fe8a n/a (libKF5Screen.so.7 + 0x28e8a)
#5 0x0000558092470956 n/a (kscreen_osd_service + 0xa956)
#6 0x00005580924709e5 n/a (kscreen_osd_service + 0xa9e5)
#7 0x00007f973f2bea71 n/a (libQt5Core.so.5 + 0x2bea71)
#8 0x00007f973f2c0fcf _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2c0fcf)
#9 0x00007f973f2b1b56 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b1b56)
#10 0x00007f973f28df48 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28df48)
#11 0x00007f973f2d84b3 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d84b3)
#12 0x00007f973f2d8aaa n/a (libQt5Core.so.5 + 0x2d8aaa)
#13 0x00007f973db1682b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
#14 0x00007f973db6dcc9 n/a (libglib-2.0.so.0 + 0xaccc9)
#15 0x00007f973db150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#16 0x00007f973f2d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#17 0x00007f973f2866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#18 0x00007f973f291219 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x291219)
#19 0x000055809246b4db n/a (kscreen_osd_service + 0x54db)
#20 0x00007f974023c790 n/a (libc.so.6 + 0x23790)
#21 0x00007f974023c84a __libc_start_main (libc.so.6 + 0x2384a)
#22 0x000055809246b685 n/a (kscreen_osd_service + 0x5685)
Stack trace of thread 2649:
#0 0x00007f97403139df __poll (libc.so.6 + 0xfa9df)
#1 0x00007f974098526b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007f9740986d1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007f973a7b0252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007f973f0e432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007f974029ebb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007f9740320d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2658:
#0 0x00007f974029b766 n/a (libc.so.6 + 0x82766)
#1 0x00007f974029df90 pthread_cond_wait (libc.so.6 + 0x84f90)
#2 0x00007f973250c49e n/a (iris_dri.so + 0x10c49e)
#3 0x00007f97324bc86c n/a (iris_dri.so + 0xbc86c)
#4 0x00007f973250c3cc n/a (iris_dri.so + 0x10c3cc)
Stack trace of thread 2654:
Stack trace of thread 2660:
Stack trace of thread 2661:
Stack trace of thread 2653:
Stack trace of thread 2659:
Stack trace of thread 2651:
Stack trace of thread 2655:
Stack trace of thread 2648:
#1 0x00007f973db6dc2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007f973db150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007f973f2d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007f973f2866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007f973f0e725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007f9740b0dcba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f973f0e432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007f974029ebb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007f9740320d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 2652:
Stack trace of thread 2657:
Stack trace of thread 2650:
Stack trace of thread 2656:
Stack trace of thread 2662:
░░ Subject: Speicherabbild für Prozess 2647 (kscreen_osd_ser) generiert
░░ Prozess 2647 (kscreen_osd_ser) ist abgebrochen worden und
Feb 17 09:09:07 ManjaroFusion kernel: Freezing of tasks failed after 20.008 seconds (6 tasks refusing to freeze, wq_busy=0):
I’m glad for any kind of help. If you need additional logs, please let me know.
