There is a solution there but I found an even easier solution. I even deleted the Manjaro partition which did not fix it. In EasyBCD you can Reset BCD configuration and re-create boot files and after a restart I was able to access the bios again. For those who might be stuck longer in the future ![]()
Yes, that’s true.
NeoSmart’s EasyBCD is one of several Windows applications that have similar capabilities. Unfortunately, EasyBCD is not applicable to Manjaro or Linux generally, as it requires a Windows environment to run.
We appreciate your interest in contributing, however in this instance your submission is declined.
Thank you.
