Laptop ASUS ZenBook 14 UM431DA overheats…
Hello, linuxoids or owners of this laptop.
At some point I started noticing that this laptop was overheating for random reasons. Started looking into it.
Here is the output of the screenfetch command
██████████████████ ████████ alimektor@aspiration
██████████████████ ████████ OS: Manjaro 21.0 Ornara
██████████████████ ████████ Kernel: x86_64 Linux 5.9.16-1-MANJARO
██████████████████ ████████ Uptime: 26m
████████ ████████ Packages: 1666
████████ ████████ ████████ Shell: bash
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: KDE 5.80.0 / Plasma 5.21.3
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ GTK Theme: Breeze [GTK2/3]
████████ ████████ ████████ Icon Theme: candy-icons
████████ ████████ ████████ Disk: 50G / 178G (30%)
████████ ████████ ████████ CPU: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx @ 8x 2.1GHz
████████ ████████ ████████ GPU: AMD Radeon(TM) Vega 8 Graphics (RAVEN, DRM 3.39.0, 5.9.16-1-MANJARO, LLVM 11.1.0)
RAM: 3580MiB / 5941MiB
The output of the sensors command:
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +33.0°C
BATT-acpi-0
Adapter: ACPI interface
in0: 7.85 V
curr1: 1.48 A
k10temp-pci-00c3
Adapter: PCI adapter
Vcore: 950.00 mV
Vsoc: 1.09 V
Tctl: +47.4°C
Tdie: +47.4°C
Icore: 19.00 A
Isoc: 7.25 A
acpitz-acpi-0
temp1: +44.0°C
amdgpu-pci-0300
vddgfx: N/A
vddnb: N/A
edge: +47.0°C
asus-isa-0000
Adapter: ISA adapter
cpu_fan: 0 RPM
nvme-pci-0200
Composite: +35.9°C (low = -0.1°C, high = +80.8°C)
(crit = +81.8°C)
Sensor 1: +35.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +37.9°C (low = -273.1°C, high = +65261.8°C)
I noticed that the sensor on the processor shows that it is not spinning. no overheating in Windows. What could this be related to?
asus-isa-0000
cpu_fan: 0 RPM
