Hello,
I have issue with Lan network, adapter or network card turning of and on.
Tested on another device and no issue. Tested with another adapter, same issue.
Could someone help fix this?
inxi -Fayz
Summary
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=210207dd-6d70-408c-bfe8-6df47a03f89c rw iommu=soft quiet
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20UH002DMH v: ThinkPad T14s Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20UH002DMH serial: <filter> UEFI: LENOVO
v: R1CET58W(1.27 ) date: 10/20/2020
vendor: Lenovo driver: r8169 v: kernel port: 2400 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus ID: 03:00.0 chip ID: 8086:2723
Device-3: **Lenovo USB-C Hub type: USB driver: r8152 bus ID: 7-1.1:83**
chip ID: 17ef:7214 serial: <filter>
IF: enp6s0f4u1u1 state: down mac: <filter>
Journal Log
Summary
1/31/21 6:02 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:02 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:02 PM kernel audit: type=1131 audit(1612108940.107:348): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:03 PM kscreenlocker_greet Qt: Session management error: networkIdsList argument is NULL
1/31/21 6:27 PM NetworkManager <info> [1612110459.3292] device (enp6s0f4u1u1): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:27 PM NetworkManager <info> [1612110459.3493] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:27 PM NetworkManager <info> [1612110459.3494] dhcp4 (enp6s0f4u1u1): state changed bound -> done
1/31/21 6:27 PM NetworkManager <warn> [1612110459.3502] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:27 PM NetworkManager <info> [1612110459.3514] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:27 PM NetworkManager <info> [1612110459.3756] policy: set 'debeselis' (wlp3s0) as default for IPv4 routing and DNS
1/31/21 6:27 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:27 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:27 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:27 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:27 PM kernel audit: type=1130 audit(1612110459.392:351): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:27 PM NetworkManager <info> [1612110461.9612] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/49)
1/31/21 6:27 PM NetworkManager <info> [1612110462.6335] device (eth0): interface index 47 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:27 PM NetworkManager <info> [1612110462.6402] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:27 PM NetworkManager <info> [1612110465.4183] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:27 PM NetworkManager <info> [1612110465.4195] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110465.4207] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:27 PM NetworkManager <info> [1612110465.4213] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:27 PM NetworkManager <info> [1612110465.4215] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110465.4241] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110465.4252] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110465.4256] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:27 PM NetworkManager <info> [1612110469.1082] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:27 PM NetworkManager <info> [1612110469.1254] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:27 PM NetworkManager <info> [1612110469.1256] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:27 PM NetworkManager <warn> [1612110469.1261] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:27 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:27 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:27 PM kernel audit: type=1131 audit(1612110470.105:353): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:27 PM NetworkManager <info> [1612110471.7342] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/50)
1/31/21 6:27 PM NetworkManager <info> [1612110472.3826] device (eth0): interface index 48 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:27 PM NetworkManager <info> [1612110472.3911] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:27 PM NetworkManager <info> [1612110475.2427] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:27 PM NetworkManager <info> [1612110475.2447] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110475.2468] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:27 PM NetworkManager <info> [1612110475.2481] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:27 PM NetworkManager <info> [1612110475.2484] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110475.2516] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110475.2529] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:27 PM NetworkManager <info> [1612110475.2536] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:27 PM NetworkManager <info> [1612110479.0012] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:27 PM NetworkManager <info> [1612110479.0292] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:27 PM NetworkManager <info> [1612110479.0293] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:27 PM NetworkManager <warn> [1612110479.0296] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:28 PM NetworkManager <info> [1612110481.6401] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/51)
1/31/21 6:28 PM NetworkManager <info> [1612110482.2871] device (eth0): interface index 49 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:28 PM NetworkManager <info> [1612110482.2970] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:28 PM NetworkManager <info> [1612110485.1152] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:28 PM NetworkManager <info> [1612110485.1168] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110485.1187] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110485.1199] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110485.1204] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110485.1226] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110485.1238] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110485.1245] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:28 PM NetworkManager <info> [1612110488.9957] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:28 PM NetworkManager <info> [1612110489.0340] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:28 PM NetworkManager <info> [1612110489.0341] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:28 PM NetworkManager <warn> [1612110489.0346] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:28 PM NetworkManager <info> [1612110491.6411] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/52)
1/31/21 6:28 PM NetworkManager <info> [1612110492.2833] device (eth0): interface index 50 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:28 PM NetworkManager <info> [1612110492.2902] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:28 PM NetworkManager <info> [1612110495.0986] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:28 PM NetworkManager <info> [1612110495.1012] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110495.1030] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110495.1041] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110495.1044] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110495.1078] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110495.1089] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110495.1095] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:28 PM NetworkManager <info> [1612110498.7830] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:28 PM NetworkManager <info> [1612110498.8121] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:28 PM NetworkManager <info> [1612110498.8122] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:28 PM NetworkManager <warn> [1612110498.8127] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:28 PM NetworkManager <info> [1612110501.4638] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/53)
1/31/21 6:28 PM NetworkManager <info> [1612110502.1159] device (eth0): interface index 51 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:28 PM NetworkManager <info> [1612110502.1217] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:28 PM NetworkManager <info> [1612110505.2757] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:28 PM NetworkManager <info> [1612110505.2770] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110505.2789] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110505.2801] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:28 PM NetworkManager <info> [1612110505.2804] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110505.2837] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110505.2847] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110505.2851] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:28 PM NetworkManager <info> [1612110508.9388] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:28 PM NetworkManager <info> [1612110509.3373] dhcp4 (enp6s0f4u1u1): option dhcp_lease_time => '86400'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3374] dhcp4 (enp6s0f4u1u1): option domain_name_servers => '192.168.1.1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3374] dhcp4 (enp6s0f4u1u1): option expiry => '1612196909'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3374] dhcp4 (enp6s0f4u1u1): option host_name => 'vld'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3374] dhcp4 (enp6s0f4u1u1): option ip_address => '192.168.1.38'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option next_server => '192.168.1.1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option requested_broadcast_address => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option requested_domain_name => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option requested_domain_name_servers => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option requested_domain_search => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3375] dhcp4 (enp6s0f4u1u1): option requested_host_name => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_interface_mtu => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_ms_classless_static_routes => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_nis_domain => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_nis_servers => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_ntp_servers => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3376] dhcp4 (enp6s0f4u1u1): option requested_rfc3442_classless_static_routes => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_root_path => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_routers => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_static_routes => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_subnet_mask => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_time_offset => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option requested_wpad => '1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3377] dhcp4 (enp6s0f4u1u1): option routers => '192.168.1.1'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3378] dhcp4 (enp6s0f4u1u1): option subnet_mask => '255.255.255.0'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3378] dhcp4 (enp6s0f4u1u1): option wpad => '
1/31/21 6:28 PM NetworkManager <info> [1612110509.3378] dhcp4 (enp6s0f4u1u1): state changed unknown -> bound
1/31/21 6:28 PM NetworkManager <info> [1612110509.3399] device (enp6s0f4u1u1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:28 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:28 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:28 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3572] device (enp6s0f4u1u1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM NetworkManager <info> [1612110509.3576] device (enp6s0f4u1u1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
1/31/21 6:28 PM kernel audit: type=1130 audit(1612110509.352:372): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:28 PM NetworkManager <info> [1612110509.3608] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:28 PM NetworkManager <info> [1612110509.3804] device (enp6s0f4u1u1): Activation: successful, device activated.
1/31/21 6:28 PM NetworkManager <info> [1612110509.4821] policy: set 'New 802-3-ethernet connection' (enp6s0f4u1u1) as default for IPv4 routing and DNS
1/31/21 6:28 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:28 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:28 PM kernel audit: type=1131 audit(1612110520.102:373): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM NetworkManager <info> [1612110671.7464] device (enp6s0f4u1u1): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:31 PM NetworkManager <info> [1612110671.7789] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:31 PM NetworkManager <info> [1612110671.7791] dhcp4 (enp6s0f4u1u1): state changed bound -> done
1/31/21 6:31 PM NetworkManager <warn> [1612110671.7796] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:31 PM NetworkManager <info> [1612110671.7804] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:31 PM NetworkManager <info> [1612110671.8053] policy: set 'debeselis' (wlp3s0) as default for IPv4 routing and DNS
1/31/21 6:31 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:31 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:31 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:31 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM kernel audit: type=1130 audit(1612110671.826:375): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM NetworkManager <info> [1612110674.3943] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/54)
1/31/21 6:31 PM NetworkManager <info> [1612110675.0530] device (eth0): interface index 52 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:31 PM NetworkManager <info> [1612110675.0607] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:31 PM NetworkManager <info> [1612110677.8051] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:31 PM NetworkManager <info> [1612110677.8067] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110677.8082] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110677.8090] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110677.8093] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110677.8124] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110677.8132] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110677.8136] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:31 PM NetworkManager <info> [1612110681.4901] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:31 PM NetworkManager <info> [1612110681.5292] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:31 PM NetworkManager <info> [1612110681.5293] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:31 PM NetworkManager <warn> [1612110681.5298] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:31 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:31 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM kernel audit: type=1131 audit(1612110682.106:376): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM NetworkManager <info> [1612110686.3947] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/55)
1/31/21 6:31 PM NetworkManager <info> [1612110687.0640] device (eth0): interface index 53 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:31 PM NetworkManager <info> [1612110687.0707] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:31 PM NetworkManager <info> [1612110689.8852] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:31 PM NetworkManager <info> [1612110689.8866] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110689.8882] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110689.8894] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110689.8897] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110689.8929] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110689.8942] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110689.8947] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:31 PM NetworkManager <info> [1612110693.5691] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:31 PM NetworkManager <info> [1612110693.6056] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:31 PM NetworkManager <info> [1612110693.6057] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:31 PM NetworkManager <warn> [1612110693.6065] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:31 PM NetworkManager <info> [1612110696.2016] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/56)
1/31/21 6:31 PM NetworkManager <info> [1612110696.8461] device (eth0): interface index 54 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:31 PM NetworkManager <info> [1612110696.8554] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:31 PM NetworkManager <info> [1612110699.7094] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:31 PM NetworkManager <info> [1612110699.7108] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110699.7124] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110699.7131] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:31 PM NetworkManager <info> [1612110699.7133] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110699.7155] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110699.7166] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110699.7171] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:31 PM NetworkManager <info> [1612110703.5325] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:31 PM NetworkManager <info> [1612110704.0917] dhcp4 (enp6s0f4u1u1): option dhcp_lease_time => '86400'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0918] dhcp4 (enp6s0f4u1u1): option domain_name_servers => '192.168.1.1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0918] dhcp4 (enp6s0f4u1u1): option expiry => '1612197104'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0918] dhcp4 (enp6s0f4u1u1): option host_name => 'vld'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0918] dhcp4 (enp6s0f4u1u1): option ip_address => '192.168.1.38'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0919] dhcp4 (enp6s0f4u1u1): option next_server => '192.168.1.1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0919] dhcp4 (enp6s0f4u1u1): option requested_broadcast_address => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0919] dhcp4 (enp6s0f4u1u1): option requested_domain_name => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0919] dhcp4 (enp6s0f4u1u1): option requested_domain_name_servers => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0919] dhcp4 (enp6s0f4u1u1): option requested_domain_search => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0920] dhcp4 (enp6s0f4u1u1): option requested_host_name => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0920] dhcp4 (enp6s0f4u1u1): option requested_interface_mtu => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_ms_classless_static_routes => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_nis_domain => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_nis_servers => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_ntp_servers => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_rfc3442_classless_static_routes => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0921] dhcp4 (enp6s0f4u1u1): option requested_root_path => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option requested_routers => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option requested_static_routes => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option requested_subnet_mask => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option requested_time_offset => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option requested_wpad => '1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0922] dhcp4 (enp6s0f4u1u1): option routers => '192.168.1.1'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0923] dhcp4 (enp6s0f4u1u1): option subnet_mask => '255.255.255.0'
1/31/21 6:31 PM NetworkManager <info> [1612110704.0923] dhcp4 (enp6s0f4u1u1): option wpad => '
1/31/21 6:31 PM NetworkManager <info> [1612110704.0923] dhcp4 (enp6s0f4u1u1): state changed unknown -> bound
1/31/21 6:31 PM NetworkManager <info> [1612110704.0944] device (enp6s0f4u1u1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM kernel audit: type=1130 audit(1612110704.100:377): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:31 PM NetworkManager <info> [1612110704.1059] device (enp6s0f4u1u1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110704.1061] device (enp6s0f4u1u1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
1/31/21 6:31 PM NetworkManager <info> [1612110704.1073] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:31 PM NetworkManager <info> [1612110704.1290] device (enp6s0f4u1u1): Activation: successful, device activated.
1/31/21 6:31 PM NetworkManager <info> [1612110704.2284] policy: set 'New 802-3-ethernet connection' (enp6s0f4u1u1) as default for IPv4 routing and DNS
1/31/21 6:31 PM kernel audit: type=1131 audit(1612110714.106:379): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:32 PM NetworkManager <info> [1612110770.1718] device (enp6s0f4u1u1): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:32 PM NetworkManager <info> [1612110770.2191] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:32 PM NetworkManager <info> [1612110770.2191] dhcp4 (enp6s0f4u1u1): state changed bound -> done
1/31/21 6:32 PM NetworkManager <warn> [1612110770.2197] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:32 PM NetworkManager <info> [1612110770.2204] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:32 PM NetworkManager <info> [1612110770.2439] policy: set 'debeselis' (wlp3s0) as default for IPv4 routing and DNS
1/31/21 6:32 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:32 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:32 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:32 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:32 PM kernel audit: type=1130 audit(1612110770.263:391): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:32 PM NetworkManager <info> [1612110772.8447] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/57)
1/31/21 6:32 PM NetworkManager <info> [1612110773.2765] device (eth0): interface index 55 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:32 PM NetworkManager <info> [1612110773.2830] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:32 PM NetworkManager <info> [1612110776.2865] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:32 PM NetworkManager <info> [1612110776.2882] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:32 PM NetworkManager <info> [1612110776.2900] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:32 PM NetworkManager <info> [1612110776.2910] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:32 PM NetworkManager <info> [1612110776.2913] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:32 PM NetworkManager <info> [1612110776.2947] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:32 PM NetworkManager <info> [1612110776.2956] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:32 PM NetworkManager <info> [1612110776.2962] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:32 PM NetworkManager <info> [1612110779.9781] device (enp6s0f4u1u1): state change: ip-config -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:33 PM NetworkManager <info> [1612110780.0057] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:33 PM NetworkManager <info> [1612110780.0058] dhcp4 (enp6s0f4u1u1): state changed unknown -> done
1/31/21 6:33 PM NetworkManager <warn> [1612110780.0063] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:33 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:33 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:33 PM kernel audit: type=1131 audit(1612110780.103:392): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:33 PM NetworkManager <info> [1612110782.6545] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/58)
1/31/21 6:33 PM NetworkManager <info> [1612110783.2865] device (eth0): interface index 56 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:33 PM NetworkManager <info> [1612110783.2984] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:33 PM NetworkManager <info> [1612110786.0944] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:33 PM NetworkManager <info> [1612110786.0963] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110786.0981] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:33 PM NetworkManager <info> [1612110786.0994] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:33 PM NetworkManager <info> [1612110786.0997] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110786.1020] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110786.1032] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110786.1039] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:33 PM NetworkManager <info> [1612110789.8058] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:33 PM NetworkManager <info> [1612110790.2442] dhcp4 (enp6s0f4u1u1): option dhcp_lease_time => '86400'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2443] dhcp4 (enp6s0f4u1u1): option domain_name_servers => '192.168.1.1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2443] dhcp4 (enp6s0f4u1u1): option expiry => '1612197190'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2443] dhcp4 (enp6s0f4u1u1): option host_name => 'vld'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2444] dhcp4 (enp6s0f4u1u1): option ip_address => '192.168.1.38'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2444] dhcp4 (enp6s0f4u1u1): option next_server => '192.168.1.1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2444] dhcp4 (enp6s0f4u1u1): option requested_broadcast_address => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2444] dhcp4 (enp6s0f4u1u1): option requested_domain_name => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2445] dhcp4 (enp6s0f4u1u1): option requested_domain_name_servers => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2445] dhcp4 (enp6s0f4u1u1): option requested_domain_search => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2445] dhcp4 (enp6s0f4u1u1): option requested_host_name => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2445] dhcp4 (enp6s0f4u1u1): option requested_interface_mtu => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2445] dhcp4 (enp6s0f4u1u1): option requested_ms_classless_static_routes => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2446] dhcp4 (enp6s0f4u1u1): option requested_nis_domain => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2446] dhcp4 (enp6s0f4u1u1): option requested_nis_servers => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2446] dhcp4 (enp6s0f4u1u1): option requested_ntp_servers => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2446] dhcp4 (enp6s0f4u1u1): option requested_rfc3442_classless_static_routes => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2446] dhcp4 (enp6s0f4u1u1): option requested_root_path => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2447] dhcp4 (enp6s0f4u1u1): option requested_routers => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2447] dhcp4 (enp6s0f4u1u1): option requested_static_routes => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2447] dhcp4 (enp6s0f4u1u1): option requested_subnet_mask => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2447] dhcp4 (enp6s0f4u1u1): option requested_time_offset => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2448] dhcp4 (enp6s0f4u1u1): option requested_wpad => '1'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2448] dhcp4 (enp6s0f4u1u1): option routers => '192.168.1.1'
1/31/21 6:33 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:33 PM NetworkManager <info> [1612110790.2448] dhcp4 (enp6s0f4u1u1): option subnet_mask => '255.255.255.0'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2448] dhcp4 (enp6s0f4u1u1): option wpad => '
1/31/21 6:33 PM NetworkManager <info> [1612110790.2448] dhcp4 (enp6s0f4u1u1): state changed unknown -> bound
1/31/21 6:33 PM NetworkManager <info> [1612110790.2474] device (enp6s0f4u1u1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:33 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:33 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:33 PM kernel audit: type=1130 audit(1612110790.257:393): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:33 PM NetworkManager <info> [1612110790.2629] device (enp6s0f4u1u1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110790.2634] device (enp6s0f4u1u1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
1/31/21 6:33 PM NetworkManager <info> [1612110790.2651] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:33 PM NetworkManager <info> [1612110790.2780] device (enp6s0f4u1u1): Activation: successful, device activated.
1/31/21 6:33 PM NetworkManager <info> [1612110790.3812] policy: set 'New 802-3-ethernet connection' (enp6s0f4u1u1) as default for IPv4 routing and DNS
1/31/21 6:33 PM kernel audit: type=1131 audit(1612110800.107:394): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM NetworkManager <info> [1612111343.0685] device (enp6s0f4u1u1): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
1/31/21 6:42 PM NetworkManager <info> [1612111343.1122] dhcp4 (enp6s0f4u1u1): canceled DHCP transaction
1/31/21 6:42 PM NetworkManager <info> [1612111343.1123] dhcp4 (enp6s0f4u1u1): state changed bound -> done
1/31/21 6:42 PM NetworkManager <warn> [1612111343.1127] device (enp6s0f4u1u1): set-link: failure to reset link negotiation
1/31/21 6:42 PM NetworkManager <info> [1612111343.1134] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:42 PM NetworkManager <info> [1612111343.1384] policy: set 'debeselis' (wlp3s0) as default for IPv4 routing and DNS
1/31/21 6:42 PM dbus-daemon [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
1/31/21 6:42 PM systemd Starting Network Manager Script Dispatcher Service...
1/31/21 6:42 PM systemd Started Network Manager Script Dispatcher Service.
1/31/21 6:42 PM audit SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM kernel audit: type=1130 audit(1612111343.153:395): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM NetworkManager <info> [1612111345.7274] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/59)
1/31/21 6:42 PM NetworkManager <info> [1612111346.3932] device (eth0): interface index 57 renamed iface from 'eth0' to 'enp6s0f4u1u1'
1/31/21 6:42 PM NetworkManager <info> [1612111346.4031] device (enp6s0f4u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1/31/21 6:42 PM NetworkManager <info> [1612111349.2200] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:42 PM NetworkManager <info> [1612111349.2219] device (enp6s0f4u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111349.2236] policy: auto-activating connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:42 PM NetworkManager <info> [1612111349.2247] device (enp6s0f4u1u1): Activation: starting connection 'New 802-3-ethernet connection' (32c83907-3469-430f-8d6b-629b799fbc8e)
1/31/21 6:42 PM NetworkManager <info> [1612111349.2250] device (enp6s0f4u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111349.2279] device (enp6s0f4u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111349.2290] device (enp6s0f4u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111349.2296] dhcp4 (enp6s0f4u1u1): activation: beginning transaction (timeout in 45 seconds)
1/31/21 6:42 PM NetworkManager <info> [1612111352.8363] device (enp6s0f4u1u1): carrier: link connected
1/31/21 6:42 PM systemd NetworkManager-dispatcher.service: Succeeded.
1/31/21 6:42 PM audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM kernel audit: type=1131 audit(1612111353.107:396): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2007] dhcp4 (enp6s0f4u1u1): option dhcp_lease_time => '86400'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2007] dhcp4 (enp6s0f4u1u1): option domain_name_servers => '192.168.1.1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2008] dhcp4 (enp6s0f4u1u1): option expiry => '1612197754'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2008] dhcp4 (enp6s0f4u1u1): option host_name => 'vld'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2008] dhcp4 (enp6s0f4u1u1): option ip_address => '192.168.1.38'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2009] dhcp4 (enp6s0f4u1u1): option next_server => '192.168.1.1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2009] dhcp4 (enp6s0f4u1u1): option requested_broadcast_address => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2009] dhcp4 (enp6s0f4u1u1): option requested_domain_name => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2009] dhcp4 (enp6s0f4u1u1): option requested_domain_name_servers => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_domain_search => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_host_name => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_interface_mtu => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_ms_classless_static_routes => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_nis_domain => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2010] dhcp4 (enp6s0f4u1u1): option requested_nis_servers => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_ntp_servers => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_rfc3442_classless_static_routes => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_root_path => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_routers => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_static_routes => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_subnet_mask => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2011] dhcp4 (enp6s0f4u1u1): option requested_time_offset => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2012] dhcp4 (enp6s0f4u1u1): option requested_wpad => '1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2012] dhcp4 (enp6s0f4u1u1): option routers => '192.168.1.1'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2012] dhcp4 (enp6s0f4u1u1): option subnet_mask => '255.255.255.0'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2012] dhcp4 (enp6s0f4u1u1): option wpad => '
1/31/21 6:42 PM NetworkManager <info> [1612111354.2012] dhcp4 (enp6s0f4u1u1): state changed unknown -> bound
1/31/21 6:42 PM NetworkManager <info> [1612111354.2056] device (enp6s0f4u1u1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM kernel audit: type=1130 audit(1612111354.217:397): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1/31/21 6:42 PM NetworkManager <info> [1612111354.2221] device (enp6s0f4u1u1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111354.2226] device (enp6s0f4u1u1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
1/31/21 6:42 PM NetworkManager <info> [1612111354.2248] dns-mgr: Writing DNS information to /usr/bin/resolvconf
1/31/21 6:42 PM NetworkManager <info> [1612111354.2401] device (enp6s0f4u1u1): Activation: successful, device activated.
1/31/21 6:42 PM NetworkManager <info> [1612111354.3440] policy: set 'New 802-3-ethernet connection' (enp6s0f4u1u1) as default for IPv4 routing and DNS
1/31/21 6:42 PM kernel audit: type=1131 audit(1612111364.107:398): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
