- I am using the H61H-G11 motherboard. The motherboard has a Controlador Fast Ethernet Realtek 8111E Wake-On-LAN. There is no connection, the LAN controller is not in the system. What is the problem?
Depending on your specific ethernet controller you may need to either install or remove the $kernel-r8168 package were $kernel refers to your current running kernel e.g. linux515.
Hi @Netifer, and welcome!
It would seem that you do not have the drivers for said adapter. But luckily I see it in the repositories as well ass the AUR:
$ pamac search r8168
linux54-r8168 8.049.02-49 extra
A kernel module for Realtek 8168 network cards
linux516-rt-r8168 8.049.02-3 community
linux516-r8168 8.049.02-8 extra
linux515-rt-r8168 8.049.02-14 community
linux515-r8168 8.049.02-28 extra
linux510-r8168 8.049.02-51 extra
linux49-r8168 8.049.02-25 extra
linux44-r8168 8.049.02-28 extra
linux419-r8168 8.049.02-31 extra
linux414-r8168 8.049.02-26 extra
r8168-pf 8.045.08-1 AUR
A kernel module for Realtek 8168 network cards(pf kernel)
r8168-dkms 8.049.02-1 AUR
A kernel module for Realtek 8168 network cards (DKMS version)
r8168-ck 8.048.03-1 AUR
A kernel module for Realtek 8168 network cards (linux-ck)
╭─mir8168
There are for many kernels. You’d have to know for which kernel, to install the driver for your kernel.
Alternatively, AFAIK anyway, you can install the *-dkms version, which might actually be better, because it survives kernel upgrades. The driver is in the AUR, so can be installed with:
pamac build r8168-dkms
Hope this helps!
I’m using kernel 5.15.
When I trying “pamac build r8168-dkms”:
==> ERROR: Missing opt kernel headers for module r8168/8.049.02.
==> ERROR: Missing lib kernel headers for module r8168/8.049.02.
==> ERROR: Missing sbin kernel headers for module r8168/8.049.02.
==> ERROR: Missing mnt kernel headers for module r8168/8.049.02.
==> ERROR: Missing var kernel headers for module r8168/8.049.02.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module r8168/8.049.02.
==> ERROR: Missing bin kernel headers for module r8168/8.049.02.
==> ERROR: Missing boot kernel headers for module r8168/8.049.02.
==> ERROR: Missing run kernel headers for module r8168/8.049.02.
==> ERROR: Missing usr kernel headers for module r8168/8.049.02.
==> ERROR: Missing proc kernel headers for module r8168/8.049.02.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module r8168/8.049.02.
==> ERROR: Missing root kernel headers for module r8168/8.049.02.
==> ERROR: Missing lost+found kernel headers for module r8168/8.049.02.
==> ERROR: Missing etc kernel headers for module r8168/8.049.02.
==> ERROR: Missing srv kernel headers for module r8168/8.049.02.
==> ERROR: Missing tmp kernel headers for module r8168/8.049.02.
==> ERROR: Missing lib64 kernel headers for module r8168/8.049.02.
==> ERROR: Missing home kernel headers for module r8168/8.049.02.
==> ERROR: Missing sys kernel headers for module r8168/8.049.02.
==> ERROR: Missing dev kernel headers for module r8168/8.049.02.
The kernel headers aren’t installed. Install them first, using:
pamac install linux515-headers
If NIC driver is installed in mhwd or Manjaro Settings Manager it will install the additional headers files and blacklist the r8169 driver
