Hi there,
after using manjaro and Windows 8 in dual-boot without problems since one week I have problems with my ethernet on manjaro. LAN is not recognized nor working and strangely some WiFi spots, too. Other WiFi spots are working. On Windows everything works.
Here my
$ inxi -nazy
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
inxi
$ inxi --full --admin --verbosity=7 --filter --no-host
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=20a1f776-2d43-47ad-afaf-5f810fb6ec0d rw quiet
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 4290W1A v: ThinkPad X220
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 4290W1A serial: <filter> UEFI-[Legacy]: LENOVO
v: 8DET76WW (1.46 ) date: 06/21/2018
ID-1: BAT0 charge: 35.3 Wh (73.7%) condition: 47.9/57.7 Wh (83.1%)
volts: 11.7 min: 11.1 model: SANYO 42T4861 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 7.65 GiB used: 3 GiB (39.2%)
RAM Report:
Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 3 MiB bogomips: 16755
Speed: 918 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 918 2: 939
3: 830 4: 928
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge
pln pni popcnt pse pse36 pti pts rdtscp sep ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Chicony Lenovo Integrated Camera (0.3MP) type: USB
driver: uvcvideo bus-ID: 1-1.6:5 chip-ID: 04f2:b217 class-ID: 0e02
Display: x11 server: X.org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.1.4 compat-v: 3.0 direct render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
class-ID: 0200
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 545.3 GiB used: 331.44 GiB (60.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS543232A7A384
size: 298.09 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: B70B scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung
model: SSD 850 EVO mSATA 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: SSD
serial: <filter> rev: 1B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block-size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 91.13 GiB size: 89.19 GiB (97.88%)
used: 73.61 GiB (82.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb3
maj-min: 8:19 label: N/A uuid: 20a1f776-2d43-47ad-afaf-5f810fb6ec0d
ID-2: /run/media/lb/6AA418C9A41899A1 raw-size: 297.99 GiB
size: 297.99 GiB (100.00%) used: 257.83 GiB (86.5%) fs: fuseblk
block-size: 4096 B dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 6AA418C9A41899A1
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: <superuser required>
label: N/A uuid: C21A23191A2309CD
ID-2: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb1 maj-min: 8:17 size: 350 MiB fs: <superuser required>
label: N/A uuid: B4FC7F32FC7EEE4C
ID-4: /dev/sdb2 maj-min: 8:18 size: 141.41 GiB fs: <superuser required>
label: N/A uuid: 5CC0DE95C0DE74AC
ID-5: /dev/sdc1 maj-min: 8:33 size: 14.32 GiB fs: <superuser required>
label: N/A uuid: E3B6-5F1A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:3
info: Upek Biometric Touchchip/Touchstrip Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.0 speed: 12 Mb/s
power: 100mA chip-ID: 147e:2016 class-ID: 0000
Device-2: 1-1.6:5 info: Chicony Lenovo Integrated Camera (0.3MP)
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 200mA chip-ID: 04f2:b217 class-ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.2:3 info: SanDisk Ultra Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5583 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3494
Processes: 221 Uptime: 1h 9m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1597 lib: 445
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.05
rfkill
$ rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Does anybody have an idea what I can do?
Help appreciated.
Best.
