I ran into a networking issue after a simple router config change while being connected to a local network device over SSH. I guess the router had to restart some things, causing the connection to drop for a few seconds. The connection never properly returned to my Manjaro machine however.
Behavior:
- The machine is connected over ethernet to the router
- The network interface correctly gets a leased IP over DHCP
- I can ping both localhost and the leased IP of the network interface
- I cannot ping any local network device, including the router (gateway)
- I cannot ping anything outside the local network (like 8.8.8.8)
- The router cannot ping the Manjaro machine
- A Windows installation on the same machine (dual boot) works perfectly fine
> ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether d0:50:99:ad:7b:41 brd ff:ff:ff:ff:ff:ff
3: br-49c3a9bcfc91: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:24:c0:af:5a brd ff:ff:ff:ff:ff:ff
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:90:b4:78:4f brd ff:ff:ff:ff:ff:ff
5: br-abf7b7410a5d: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:57:25:5d:c9 brd ff:ff:ff:ff:ff:ff
6: br-d37005efd653: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:04:59:c3:cf brd ff:ff:ff:ff:ff:ff
7: br-0ae9995b562e: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:33:1a:60:34 brd ff:ff:ff:ff:ff:ff
8: br-47117eb5582f: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:16:fa:1f:10 brd ff:ff:ff:ff:ff:ff
> ip address
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
inet 192.168.1.20/24 brd 192.168.1.255 scope global dynamic noprefixroute enp0s25
valid_lft 81367sec preferred_lft 81367sec
inet6 fe80::e835:189f:ad89:c3e3/64 scope link noprefixroute
3: br-49c3a9bcfc91: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.19.0.1/16 brd 172.19.255.255 scope global br-49c3a9bcfc91
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
5: br-abf7b7410a5d: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.30.0.1/16 brd 172.30.255.255 scope global br-abf7b7410a5d
6: br-d37005efd653: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.21.0.1/16 brd 172.21.255.255 scope global br-d37005efd653
7: br-0ae9995b562e: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.20.0.1/16 brd 172.20.255.255 scope global br-0ae9995b562e
8: br-47117eb5582f: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.22.0.1/16 brd 172.22.255.255 scope global br-47117eb5582f
> ip route
default via 192.168.1.1 dev enp0s25 proto dhcp metric 20100
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.19.0.0/16 dev br-49c3a9bcfc91 proto kernel scope link src 172.19.0.1 linkdown
172.20.0.0/16 dev br-0ae9995b562e proto kernel scope link src 172.20.0.1 linkdown
172.21.0.0/16 dev br-d37005efd653 proto kernel scope link src 172.21.0.1 linkdown
172.22.0.0/16 dev br-47117eb5582f proto kernel scope link src 172.22.0.1 linkdown
172.30.0.0/16 dev br-abf7b7410a5d proto kernel scope link src 172.30.0.1 linkdown
192.168.1.0/24 dev enp0s25 proto kernel scope link src 192.168.1.20 metric 100
> ixni -N
Network: Device-1: Intel Ethernet I218-V driver: e1000e
> ping -c 3 192.168.1.20
PING 192.168.1.20 (192.168.1.20) 56(84) bytes of data.
64 bytes from 192.168.1.20: icmp_seq=1 ttl=64 time=0.059 ms
64 bytes from 192.168.1.20: icmp_seq=2 ttl=64 time=0.050 ms
64 bytes from 192.168.1.20: icmp_seq=3 ttl=64 time=0.050 ms
--- 192.168.1.20 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2006ms
rtt min/avg/max/mdev = 0.050/0.053/0.059/0.004 ms
> ping -c 3 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
From 192.168.1.20 icmp_seq=1 Destination Host Unreachable
From 192.168.1.20 icmp_seq=2 Destination Host Unreachable
From 192.168.1.20 icmp_seq=3 Destination Host Unreachable
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 2024ms
pipe 2
> tracepath 192.168.1.1
1?: [LOCALHOST] pmtu 1500
1: pc-linux 1851.286ms !H
Resume: pmtu 1500
So far I’ve tried rebooting, unplugging and reconnecting the network cable, removing and recreating the connection profile through the Manjaro setting GUI, and adding a temporary routing entry to the gateway using ip route add.
Does anyone know anything else I can try?
