Lampp server internal installation problem
Hello,
I’ve followed several tutorials to install a Lampp server on my Manjaro KDE.
But I still have a problem configuring httpd.
I’ve tried to change the port in httpd.conf, but nothing works, I still get the same error:
httpd --status         ✔
(13)Permission denied: AH00072: make_sock: could not bind to address [::]:80
(13)Permission denied: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Can you help me and let me know what I’ve done wrong?
I had no problem with Mariadb, I followed the tutorial for php.ini, but Apache always gives me the same error.
Port 80 is a privileged port. A normal user can’t use it. Change it to a non privileged port like 8080, or even better use the httpd.service to start the Apache Webserver and do not run the Webserver with your normal user.
Thanks for your answer.
I had already tried port 8080 and restarted httpd, but I still get the same status response.
I put 127.0.0.1:8080 in my browser and it’s still the same answer.
That can’t be. Please tell us the error message that you are seeing.
This is:
Connection failed
Firefox cannot establish a connection with the server at address 127.0.0.1:8080.
    The site may be temporarily unavailable or overloaded. Try again later;
 If you can't browse any sites, check your computer's network connection;
 If your computer or network is protected by a firewall or proxy, make sure Firefox is authorized to access the Web.
please give us a complete output of the log or terminal output
Apache logs can be found in /var/log/httpd/
lampp logs /opt/lampp/logs
ss -lnp | grep -e :80 -e :443
httpd -k start
sudo systemctl status httpd.service
i guess the browser output wasn’t meant here
Arch - Wiki: AH00072: make_sock: could not bind to address
For /var/log/httpd/error_log
[Sun Apr 13 21:54:04.438812 2025] [mpm_prefork:notice] [pid 84671:tid 84671] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 21:54:04.438912 2025] [core:notice] [pid 84671:tid 84671] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:04:20.667435 2025] [mpm_prefork:notice] [pid 84671:tid 84671] AH00169: caught SIGTERM, shutting down
[Sun Apr 13 22:07:31.625928 2025] [mpm_prefork:notice] [pid 88103:tid 88103] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:07:31.625996 2025] [core:notice] [pid 88103:tid 88103] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:17:50.523685 2025] [mpm_prefork:notice] [pid 88103:tid 88103] AH00170: caught SIGWINCH, shutting down gracefully
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
[Sun Apr 13 22:17:50.583929 2025] [mpm_prefork:notice] [pid 91079:tid 91079] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:17:50.583986 2025] [core:notice] [pid 91079:tid 91079] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:23:50.590526 2025] [mpm_prefork:notice] [pid 91079:tid 91079] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Apr 13 22:23:50.645766 2025] [mpm_prefork:notice] [pid 92704:tid 92704] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:23:50.645831 2025] [core:notice] [pid 92704:tid 92704] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:31:46.221597 2025] [mpm_prefork:notice] [pid 92704:tid 92704] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Apr 13 22:31:46.283781 2025] [mpm_prefork:notice] [pid 94886:tid 94886] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:31:46.283853 2025] [core:notice] [pid 94886:tid 94886] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:32:19.086961 2025] [mpm_prefork:notice] [pid 94886:tid 94886] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Apr 13 22:32:19.173886 2025] [mpm_prefork:notice] [pid 95027:tid 95027] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:32:19.173955 2025] [core:notice] [pid 95027:tid 95027] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sun Apr 13 22:33:19.009287 2025] [mpm_prefork:notice] [pid 95027:tid 95027] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Apr 13 22:33:19.067702 2025] [mpm_prefork:notice] [pid 95266:tid 95266] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sun Apr 13 22:33:19.067792 2025] [core:notice] [pid 95266:tid 95266] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Mon Apr 14 01:40:21.076351 2025] [mpm_prefork:notice] [pid 95266:tid 95266] AH00170: caught SIGWINCH, shutting down gracefully
[Mon Apr 14 11:50:11.563525 2025] [mpm_prefork:notice] [pid 862:tid 862] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Mon Apr 14 11:50:11.563789 2025] [core:notice] [pid 862:tid 862] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Mon Apr 14 19:09:10.443489 2025] [mpm_prefork:notice] [pid 862:tid 862] AH00170: caught SIGWINCH, shutting down gracefully
[Mon Apr 14 19:09:10.500238 2025] [mpm_prefork:notice] [pid 90790:tid 90790] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Mon Apr 14 19:09:10.500305 2025] [core:notice] [pid 90790:tid 90790] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Mon Apr 14 19:54:32.141448 2025] [mpm_prefork:notice] [pid 90790:tid 90790] AH00170: caught SIGWINCH, shutting down gracefully
[Mon Apr 14 19:54:32.200142 2025] [mpm_prefork:notice] [pid 99819:tid 99819] AH00163: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Mon Apr 14 19:54:32.200208 2025] [core:notice] [pid 99819:tid 99819] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
For /var/log/httpd/access_log: it’s empty.
tcp   LISTEN 0      511                                                      *:80                     *:*
httpd -k start
httpd.service - Apache Web Server
     Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; preset: disabled)
     Active: active (running) since Mon 2025-04-14 19:54:32 CEST; 2h 13min ago
 Invocation: aacf82432c2048838c28205802bd5514
   Main PID: 99819 (httpd)
      Tasks: 6 (limit: 18809)
     Memory: 3.1M (peak: 3.9M)
        CPU: 274ms
     CGroup: /system.slice/httpd.service
             ├─99819 /usr/bin/httpd -k start -DFOREGROUND
             ├─99826 /usr/bin/httpd -k start -DFOREGROUND
             ├─99827 /usr/bin/httpd -k start -DFOREGROUND
             ├─99828 /usr/bin/httpd -k start -DFOREGROUND
             ├─99829 /usr/bin/httpd -k start -DFOREGROUND
             └─99830 /usr/bin/httpd -k start -DFOREGROUND
avr 14 19:54:32 bruno-hppaviliongamingdesktop69000xx systemd[1]: Started Apache Web Server.
Thank you
how did you install it? tut link?
apache package (sudo pacman -S apache) or lampp/xampp package (pamac build xampp)?
i suspect a user rights issue. only root is allowed to use the low-level ports.
what happens with
sudo systemctl restart httpd.service
or
sudo httpd restart
I install it with the Apache packets.
For sudo systemctl restart httpd.service, it’s always the same:
     Active: active (running) since Mon 2025-04-14 22:30:29 CEST; 13s ago
 Invocation: f73458050d974380b2303e9a47c43ce6
   Main PID: 129021 (httpd)
     Memory: 3M (peak: 3.9M)
        CPU: 38ms
             ├─129021 /usr/bin/httpd -k start -DFOREGROUND
             ├─129027 /usr/bin/httpd -k start -DFOREGROUND
             ├─129028 /usr/bin/httpd -k start -DFOREGROUND
             ├─129029 /usr/bin/httpd -k start -DFOREGROUND
             ├─129030 /usr/bin/httpd -k start -DFOREGROUND
             └─129031 /usr/bin/httpd -k start -DFOREGROUND
And for sudo httpd restart: it’s a bad command.
ok, ty for your output.
what do your configs look like? are there any problems here? duplicate entries? check > Listen 80 < and/or > ServerName 127.0.0.1 <
check folder
ls -al /etc/httpd/
config file?! /etc/httpd/conf/httpd.conf
If you have issues with your configuration you can have Apache check the configuration with: apachectl configtest
These options in /etc/httpd/conf/httpd.conf might be interesting for you:
User http
    For security reasons, as soon as Apache is started by the root user (directly or via startup scripts) it switches to this UID. The default user is http, which is created automatically during installation.
restarted the system completely?
I’ve restarted the system completely, no change.
 ls -al /etc/httpd/         ✔
total 20
drwxr-xr-x   3 root root  4096 13 avr 21:00 .
drwxr-xr-x 131 root root 12288 14 avr 19:00 ..
drwxr-xr-x   3 root root  4096 14 avr 19:08 conf
lrwxrwxrwx   1 root root    22 26 jan 03:14 modules -> /usr/lib/httpd/modules
apachectl configtest         ✔
Syntax OK
ok keep checking
ls -al /etc/httpd/*
ls -al /var/log/httpd/
what does your .config look like?
cat /etc/httpd/conf/httpd.conf
what do the logs say? which ones are there?
network settings changed?
hosts?
cat /etc/hosts
my guesses are slowly coming to an end. i personally use nginx on my systems.
The first command:
ls -al /etc/httpd/*         ✔
lrwxrwxrwx 1 root root   22 26 jan 03:14 /etc/httpd/modules -> /usr/lib/httpd/modules
/etc/httpd/conf:
total 108
drwxr-xr-x 3 root root  4096 14 avr 19:08 .
drwxr-xr-x 3 root root  4096 13 avr 21:00 ..
drwxr-xr-x 2 root root  4096 13 avr 21:00 extra
-rw-r--r-- 1 root root 20302 14 avr 19:54 httpd.conf
-rw-r--r-- 1 root root 13064 26 jan 03:14 magic
-rw-r--r-- 1 root root 60970 26 jan 03:14 mime.types
The second one:
ls -al /var/log/httpd/         ✔
total 16
drwxr-xr-x  2 root root 4096 13 avr 21:54 .
drwxr-xr-x 11 root root 4096 14 avr 11:50 ..
-rw-r--r--  1 root root    0 13 avr 21:54 access_log
-rw-r--r--  1 root root 4421 14 avr 22:30 error_log
The third:
cat /etc/httpd/conf/httpd.conf         ✔
# This is the main Apache HTTP server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/etc/httpd"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:/run/httpd
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
#LoadModule mpm_event_module modules/mod_mpm_event.so
LoadModule mpm_prefork_module modules/mod_mpm_prefork.so
#LoadModule mpm_worker_module modules/mod_mpm_worker.so
LoadModule authn_file_module modules/mod_authn_file.so
#LoadModule authn_dbm_module modules/mod_authn_dbm.so
#LoadModule authn_anon_module modules/mod_authn_anon.so
#LoadModule authn_dbd_module modules/mod_authn_dbd.so
#LoadModule authn_socache_module modules/mod_authn_socache.so
LoadModule authn_core_module modules/mod_authn_core.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_user_module modules/mod_authz_user.so
#LoadModule authz_dbm_module modules/mod_authz_dbm.so
#LoadModule authz_owner_module modules/mod_authz_owner.so
#LoadModule authz_dbd_module modules/mod_authz_dbd.so
LoadModule authz_core_module modules/mod_authz_core.so
#LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
#LoadModule authnz_fcgi_module modules/mod_authnz_fcgi.so
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule auth_basic_module modules/mod_auth_basic.so
#LoadModule auth_form_module modules/mod_auth_form.so
#LoadModule auth_digest_module modules/mod_auth_digest.so
#LoadModule allowmethods_module modules/mod_allowmethods.so
#LoadModule file_cache_module modules/mod_file_cache.so
#LoadModule cache_module modules/mod_cache.so
#LoadModule cache_disk_module modules/mod_cache_disk.so
#LoadModule cache_socache_module modules/mod_cache_socache.so
#LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
#LoadModule socache_dbm_module modules/mod_socache_dbm.so
#LoadModule socache_memcache_module modules/mod_socache_memcache.so
#LoadModule socache_redis_module modules/mod_socache_redis.so
#LoadModule watchdog_module modules/mod_watchdog.so
#LoadModule macro_module modules/mod_macro.so
#LoadModule dbd_module modules/mod_dbd.so
#LoadModule dumpio_module modules/mod_dumpio.so
#LoadModule echo_module modules/mod_echo.so
#LoadModule buffer_module modules/mod_buffer.so
#LoadModule data_module modules/mod_data.so
#LoadModule ratelimit_module modules/mod_ratelimit.so
LoadModule reqtimeout_module modules/mod_reqtimeout.so
#LoadModule ext_filter_module modules/mod_ext_filter.so
#LoadModule request_module modules/mod_request.so
LoadModule include_module modules/mod_include.so
LoadModule filter_module modules/mod_filter.so
#LoadModule reflector_module modules/mod_reflector.so
#LoadModule substitute_module modules/mod_substitute.so
#LoadModule sed_module modules/mod_sed.so
#LoadModule charset_lite_module modules/mod_charset_lite.so
#LoadModule deflate_module modules/mod_deflate.so
#LoadModule xml2enc_module modules/mod_xml2enc.so
#LoadModule proxy_html_module modules/mod_proxy_html.so
#LoadModule brotli_module modules/mod_brotli.so
LoadModule mime_module modules/mod_mime.so
#LoadModule ldap_module modules/mod_ldap.so
LoadModule log_config_module modules/mod_log_config.so
#LoadModule log_debug_module modules/mod_log_debug.so
#LoadModule log_forensic_module modules/mod_log_forensic.so
#LoadModule logio_module modules/mod_logio.so
#LoadModule lua_module modules/mod_lua.so
LoadModule env_module modules/mod_env.so
#LoadModule mime_magic_module modules/mod_mime_magic.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
#LoadModule expires_module modules/mod_expires.so
LoadModule headers_module modules/mod_headers.so
#LoadModule ident_module modules/mod_ident.so
#LoadModule usertrack_module modules/mod_usertrack.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule version_module modules/mod_version.so
#LoadModule remoteip_module modules/mod_remoteip.so
#LoadModule proxy_module modules/mod_proxy.so
#LoadModule proxy_connect_module modules/mod_proxy_connect.so
#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
#LoadModule proxy_http_module modules/mod_proxy_http.so
#LoadModule proxy_fcgi_module modules/mod_proxy_fcgi.so
#LoadModule proxy_scgi_module modules/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module modules/mod_proxy_uwsgi.so
#LoadModule proxy_fdpass_module modules/mod_proxy_fdpass.so
#LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
#LoadModule proxy_express_module modules/mod_proxy_express.so
#LoadModule proxy_hcheck_module modules/mod_proxy_hcheck.so
#LoadModule session_module modules/mod_session.so
#LoadModule session_cookie_module modules/mod_session_cookie.so
#LoadModule session_crypto_module modules/mod_session_crypto.so
#LoadModule session_dbd_module modules/mod_session_dbd.so
LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
#LoadModule slotmem_plain_module modules/mod_slotmem_plain.so
#LoadModule ssl_module modules/mod_ssl.so
#LoadModule dialup_module modules/mod_dialup.so
#LoadModule http2_module modules/mod_http2.so
#LoadModule proxy_http2_module modules/mod_proxy_http2.so
#LoadModule md_module modules/mod_md.so
#LoadModule lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
#LoadModule lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
LoadModule unixd_module modules/mod_unixd.so
#LoadModule systemd_module modules/mod_systemd.so
#LoadModule heartbeat_module modules/mod_heartbeat.so
#LoadModule heartmonitor_module modules/mod_heartmonitor.so
#LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
#LoadModule asis_module modules/mod_asis.so
#LoadModule info_module modules/mod_info.so
#LoadModule suexec_module modules/mod_suexec.so
<IfModule !mpm_prefork_module>
        #LoadModule cgid_module modules/mod_cgid.so
</IfModule>
<IfModule mpm_prefork_module>
        #LoadModule cgi_module modules/mod_cgi.so
</IfModule>
#LoadModule dav_fs_module modules/mod_dav_fs.so
#LoadModule dav_lock_module modules/mod_dav_lock.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
#LoadModule imagemap_module modules/mod_imagemap.so
#LoadModule actions_module modules/mod_actions.so
#LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule rewrite_module modules/mod_rewrite.so
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User http
Group http
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin you@example.com
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
ServerName 127.0.0.1:8080
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride none
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "/srv/http"
<Directory "/srv/http">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    Options Indexes FollowSymLinks
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   AllowOverride FileInfo AuthConfig Limit
    AllowOverride None
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "/var/log/httpd/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    CustomLog "/var/log/httpd/access_log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    #CustomLog "/var/log/httpd/access_log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/srv/http/cgi-bin/"
</IfModule>
<IfModule cgid_module>
    # ScriptSock: On threaded servers, designate the path to the UNIX
    # socket used to communicate with the CGI daemon of mod_cgid.
    #Scriptsock cgisock
</IfModule>
# "/srv/http/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/srv/http/cgi-bin">
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule headers_module>
    # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
    # backend servers which have lingering "httpoxy" defects.
    # 'Proxy' request header is undefined by the IETF, not listed by IANA
    RequestHeader unset Proxy early
</IfModule>
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig conf/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    #AddHandler cgi-script .cgi
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    #AddType text/html .shtml
    #AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
#MIMEMagicFile conf/magic
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile on
# Supplemental configuration
# The configuration files in the conf/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
Include conf/extra/httpd-mpm.conf
# Multi-language error messages
Include conf/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
Include conf/extra/httpd-autoindex.conf
# Language settings
Include conf/extra/httpd-languages.conf
# User home directories
Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include conf/extra/httpd-info.conf
# Virtual hosts
#Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include conf/extra/httpd-dav.conf
# Various default settings
Include conf/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include conf/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include conf/extra/httpd-ssl.conf
# Note: The following must must be present to support
#       starting without SSL on platforms with no /dev/random equivalent
#       but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
# Load PHP
<IfModule php_module>
    AddHandler php-script .php
    Include conf/extra/php_module.conf
</IfModule>
And the last one:
cat /etc/hosts         ✔
# Standard host addresses
127.0.0.1  localhost
::1        localhost ip6-localhost ip6-loopback
ff02::1    ip6-allnodes
ff02::2    ip6-allrouters
# This host address
127.0.1.1  bruno-hppaviliongamingdesktop69000xx
did you change it like this? was it localhost before?
change to
ServerName localhost
and here you can change the port for the server:
currently on port 80, you now have the choice:
change 80 to 8080
or add a new port
Listen 8080
for both.
but I suspect the ServerName was the problem. After changing it and restart, port 80 (or/and 8080)should be available?
if nothing else helps, look in /var/log/httpd/error_log
I changed port 80 to 8080.
I restarted httpd, and put 101.0.0.1:8080 in the browser, but it runs and no result.
This site is inaccessible
101.0.0.1 took too long to respond.
Here are some tips:
Check connection
Check proxy and firewall
ERR_CONNECTION_TIMED_OUT
always check what your network / ports are doing.
sudo netstat -tulpen
before you ask…(sudo pacman -S net-tools)
where does this IP address come from?
it should 127.0.0.1:8080 or localhost:8080 ?!
are you checking locally with your browser or over the network? First, test locally where the Apache service is running.
did the service start without errors? the output of browser content is not useful.
Installing Apache using
pamac install apache
or using the pamac GUI will install Apache.
start the service with
systemctl start httpd.service
access the default web page in you browser with
localhost
in the address box
That’s it.
If you later drop html files into /srv/http you can access those web pages via your webbrowser by using the same address
localhost
