I am running into this problem for almost a year now and also created posts but no response on them. So, I will try to keep this pretty verbose. Bear with me
Whenever I put my system on sleep and resume it later after “few hours”, it lags periodically and the time difference between previous lag and current lag can vary between 30 secs to ~5 mins.
At first, I thought only input devices may be lagged. But complete system lags for some time, video, rendering of the project (unity games), even during gameplay this happens.
At first, I solved it by downgrading to 5.4 kernel, but it still was coming on that version, so I have upgraded to latest 5.10 version
$ free -h
total used free shared buff/cache available
Mem: 15Gi 2.6Gi 7.7Gi 819Mi 5.2Gi 11Gi
Swap: 3.0Gi 6.0Mi 3.0Gi
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=38845911-dabf-40cf-a0fe-8abe080d3bfe rw udev.log_priority=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505GT.310 date: 11/26/2020
ID-1: BAT0 charge: 38.3 Wh (97.7%) condition: 39.2/48.1 Wh (81.5%)
volts: 12.8 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: Charging cycles: 41
RAM: total: 15.48 GiB used: 3.63 GiB (23.4%)
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 852 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 852 2: 900 3: 901
4: 866 5: 900 6: 900 7: 896 8: 901 9: 900 10: 899 11: 901 12: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Local Storage: total: 931.51 GiB used: 332.8 GiB (35.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-11Z10T0
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 268.55 GiB size: 263.28 GiB (98.04%)
used: 106.67 GiB (40.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 38845911-dabf-40cf-a0fe-8abe080d3bfe
used: 79.9 MiB (15.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 6BB0-A5B3
ID-3: /home raw-size: 662.46 GiB size: 650.99 GiB (98.27%)
used: 226.05 GiB (34.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 599d6bb8-a70e-4e8f-9e25-d0bd29595d48
ID-1: swap-1 type: file size: 3 GiB used: 6.4 MiB (0.2%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-11:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 319 Uptime: 13h 28m wakeups: 24 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
pacman: 1499 lib: 364 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.05
$ sudo dmesg
[ 0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[ 0.000000] Linux version 5.10.49-1-MANJARO (builduser@LEGION) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Jul 11 12:59:43 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=38845911-dabf-40cf-a0fe-8abe080d3bfe rw udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000078b22fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078b23000-0x000000007a399fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a39a000-0x000000007a416fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007a417000-0x000000007a536fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007a537000-0x000000007ab40fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007ab41000-0x000000007ac0dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007ac0e000-0x000000007ac0efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007ac0f000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047dffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0x7a3b3000 ACPI=0x7a3b3000 TPMFinalLog=0x7a4a1000 SMBIOS=0x7a989000 SMBIOS 3.0=0x7a988000 MEMATTR=0x74bd9018 ESRT=0x756f6d98
[ 0.000000] SMBIOS 3.2.1 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. TUF Gaming FX505GT_FX505GT/FX505GT, BIOS FX505GT.310 11/26/2020
[ 0.000000] tsc: Detected 2600.000 MHz processor
[ 0.000000] tsc: Detected 2599.992 MHz TSC
[ 0.000468] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000471] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000477] last_pfn = 0x47e000 max_arch_pfn = 0x400000000
[ 0.000480] MTRR default type: write-back
[ 0.000481] MTRR fixed ranges enabled:
[ 0.000483] 00000-9FFFF write-back
[ 0.000483] A0000-BFFFF uncachable
[ 0.000484] C0000-FFFFF write-protect
[ 0.000485] MTRR variable ranges enabled:
[ 0.000487] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000488] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.000488] 2 base 007B800000 mask 7FFF800000 uncachable
[ 0.000490] 3 base 2000000000 mask 6000000000 uncachable
[ 0.000490] 4 base 1000000000 mask 7000000000 uncachable
[ 0.000491] 5 base 0800000000 mask 7800000000 uncachable
[ 0.000492] 6 base 4000000000 mask 4000000000 uncachable
[ 0.000493] 7 disabled
[ 0.000493] 8 disabled
[ 0.000494] 9 disabled
[ 0.000990] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001364] last_pfn = 0x7ac0f max_arch_pfn = 0x400000000
[ 0.017210] esrt: Reserving ESRT space from 0x00000000756f6d98 to 0x00000000756f6dd0.
[ 0.017214] e820: update [mem 0x756f6000-0x756f6fff] usable ==> reserved
[ 0.017228] check: Scanning 1 areas for low memory corruption
[ 0.017232] Using GB pages for direct mapping
[ 0.017496] Secure boot disabled
[ 0.017497] RAMDISK: [mem 0x36759000-0x373a3fff]
[ 0.017501] ACPI: Early table checksum verification disabled
[ 0.017504] ACPI: RSDP 0x000000007A3B3000 000024 (v02 _ASUS_)
[ 0.017508] ACPI: XSDT 0x000000007A3B30C8 000114 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017514] ACPI: FACP 0x000000007A3FA430 000114 (v06 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017519] ACPI: DSDT 0x000000007A3B3270 0471BE (v02 _ASUS_ Notebook 01072009 INTL 20160527)
[ 0.017522] ACPI: FACS 0x000000007A536080 000040
[ 0.017525] ACPI: APIC 0x000000007A3FA548 0000F4 (v04 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017528] ACPI: FPDT 0x000000007A3FA640 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017531] ACPI: FIDT 0x000000007A3FA688 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017534] ACPI: MCFG 0x000000007A3FA728 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.017537] ACPI: SSDT 0x000000007A3FA768 0071B0 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
[ 0.017540] ACPI: SSDT 0x000000007A401918 001B5F (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.017544] ACPI: MSDM 0x000000007A403478 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
[ 0.017547] ACPI: SSDT 0x000000007A4034D0 0031C6 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.017550] ACPI: SSDT 0x000000007A406698 0023AD (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.017553] ACPI: HPET 0x000000007A408A48 000038 (v01 _ASUS_ Notebook 00000002 01000013)
[ 0.017556] ACPI: SSDT 0x000000007A408A80 002C26 (v02 _ASUS_ CflH_Rvp 00001000 INTL 20160527)
[ 0.017561] ACPI: SSDT 0x000000007A40B6A8 000FAE (v02 _ASUS_ Ther_Rvp 00001000 INTL 20160527)
[ 0.017564] ACPI: SSDT 0x000000007A40C658 002A19 (v02 INTEL xh_cfhd4 00000000 INTL 20160527)
[ 0.017567] ACPI: UEFI 0x000000007A40F078 000042 (v01 _ASUS_ Notebook 00000002 01000013)
[ 0.017570] ACPI: ECDT 0x000000007A40F0C0 0000C1 (v01 OEM OEM 00000001 OEM. 00000003)
[ 0.017573] ACPI: LPIT 0x000000007A40F188 000094 (v01 _ASUS_ Notebook 00000002 01000013)
[ 0.017577] ACPI: SSDT 0x000000007A40F220 0027DE (v02 _ASUS_ PtidDevc 00001000 INTL 20160527)
[ 0.017580] ACPI: DBGP 0x000000007A411A00 000034 (v01 _ASUS_ Notebook 00000002 01000013)
[ 0.017583] ACPI: DBG2 0x000000007A411A38 000061 (v00 _ASUS_ Notebook 00000002 01000013)
[ 0.017586] ACPI: DMAR 0x000000007A411AA0 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.017589] ACPI: SSDT 0x000000007A411B48 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.017592] ACPI: SSDT 0x000000007A411C90 0000B4 (v02 SgRef SgPeg 00001000 INTL 20160527)
[ 0.017595] ACPI: NHLT 0x000000007A411D48 001771 (v00 INTEL EDK2 00000002 01000013)
[ 0.017598] ACPI: BGRT 0x000000007A4134C0 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017601] ACPI: UEFI 0x000000007A4134F8 00063A (v01 INTEL RstSataE 00000000 ?? 00000000)
[ 0.017604] ACPI: UEFI 0x000000007A413B38 00005C (v01 INTEL RstSataV 00000000 ?? 00000000)
[ 0.017607] ACPI: TPM2 0x000000007A413B98 000034 (v04 _ASUS_ Notebook 00000001 AMI 00000000)
[ 0.017610] ACPI: SSDT 0x000000007A413BD0 001EF2 (v01 OptRef OptTabl 00001000 INTL 20160527)
[ 0.017613] ACPI: WSMT 0x000000007A415AC8 000028 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.017616] ACPI: Reserving FACP table memory at [mem 0x7a3fa430-0x7a3fa543]
[ 0.017617] ACPI: Reserving DSDT table memory at [mem 0x7a3b3270-0x7a3fa42d]
[ 0.017618] ACPI: Reserving FACS table memory at [mem 0x7a536080-0x7a5360bf]
[ 0.017619] ACPI: Reserving APIC table memory at [mem 0x7a3fa548-0x7a3fa63b]
[ 0.017620] ACPI: Reserving FPDT table memory at [mem 0x7a3fa640-0x7a3fa683]
[ 0.017621] ACPI: Reserving FIDT table memory at [mem 0x7a3fa688-0x7a3fa723]
[ 0.017622] ACPI: Reserving MCFG table memory at [mem 0x7a3fa728-0x7a3fa763]
[ 0.017623] ACPI: Reserving SSDT table memory at [mem 0x7a3fa768-0x7a401917]
[ 0.017624] ACPI: Reserving SSDT table memory at [mem 0x7a401918-0x7a403476]
[ 0.017624] ACPI: Reserving MSDM table memory at [mem 0x7a403478-0x7a4034cc]
[ 0.017625] ACPI: Reserving SSDT table memory at [mem 0x7a4034d0-0x7a406695]
[ 0.017626] ACPI: Reserving SSDT table memory at [mem 0x7a406698-0x7a408a44]
[ 0.017627] ACPI: Reserving HPET table memory at [mem 0x7a408a48-0x7a408a7f]
[ 0.017628] ACPI: Reserving SSDT table memory at [mem 0x7a408a80-0x7a40b6a5]
[ 0.017629] ACPI: Reserving SSDT table memory at [mem 0x7a40b6a8-0x7a40c655]
[ 0.017630] ACPI: Reserving SSDT table memory at [mem 0x7a40c658-0x7a40f070]
[ 0.017631] ACPI: Reserving UEFI table memory at [mem 0x7a40f078-0x7a40f0b9]
[ 0.017632] ACPI: Reserving ECDT table memory at [mem 0x7a40f0c0-0x7a40f180]
[ 0.017633] ACPI: Reserving LPIT table memory at [mem 0x7a40f188-0x7a40f21b]
[ 0.017634] ACPI: Reserving SSDT table memory at [mem 0x7a40f220-0x7a4119fd]
[ 0.017634] ACPI: Reserving DBGP table memory at [mem 0x7a411a00-0x7a411a33]
[ 0.017635] ACPI: Reserving DBG2 table memory at [mem 0x7a411a38-0x7a411a98]
[ 0.017636] ACPI: Reserving DMAR table memory at [mem 0x7a411aa0-0x7a411b47]
[ 0.017637] ACPI: Reserving SSDT table memory at [mem 0x7a411b48-0x7a411c8b]
[ 0.017638] ACPI: Reserving SSDT table memory at [mem 0x7a411c90-0x7a411d43]
[ 0.017639] ACPI: Reserving NHLT table memory at [mem 0x7a411d48-0x7a4134b8]
[ 0.017640] ACPI: Reserving BGRT table memory at [mem 0x7a4134c0-0x7a4134f7]
[ 0.017641] ACPI: Reserving UEFI table memory at [mem 0x7a4134f8-0x7a413b31]
[ 0.017642] ACPI: Reserving UEFI table memory at [mem 0x7a413b38-0x7a413b93]
[ 0.017643] ACPI: Reserving TPM2 table memory at [mem 0x7a413b98-0x7a413bcb]
[ 0.017644] ACPI: Reserving SSDT table memory at [mem 0x7a413bd0-0x7a415ac1]
[ 0.017645] ACPI: Reserving WSMT table memory at [mem 0x7a415ac8-0x7a415aef]
[ 0.017659] ACPI: Local APIC address 0xfee00000
[ 0.017885] No NUMA configuration found
[ 0.017886] Faking a node at [mem 0x0000000000000000-0x000000047dffffff]
[ 0.017890] NODE_DATA(0) allocated [mem 0x47dffc000-0x47dffffff]
[ 0.047280] Zone ranges:
[ 0.047281] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.047282] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.047284] Normal [mem 0x0000000100000000-0x000000047dffffff]
[ 0.047285] Device empty
[ 0.047286] Movable zone start for each node
[ 0.047287] Early memory node ranges
[ 0.047288] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.047289] node 0: [mem 0x0000000000100000-0x0000000078b22fff]
[ 0.047290] node 0: [mem 0x000000007ac0e000-0x000000007ac0efff]
[ 0.047291] node 0: [mem 0x0000000100000000-0x000000047dffffff]
[ 0.047293] Initmem setup node 0 [mem 0x0000000000001000-0x000000047dffffff]
[ 0.047295] On node 0 totalpages: 4156098
[ 0.047296] DMA zone: 64 pages used for memmap
[ 0.047297] DMA zone: 23 pages reserved
[ 0.047298] DMA zone: 3998 pages, LIFO batch:0
[ 0.047542] DMA zone: 28770 pages in unavailable ranges
[ 0.047544] DMA32 zone: 7661 pages used for memmap
[ 0.047545] DMA32 zone: 490276 pages, LIFO batch:63
[ 0.050843] DMA32 zone: 29916 pages in unavailable ranges
[ 0.050844] Normal zone: 57216 pages used for memmap
[ 0.050845] Normal zone: 3661824 pages, LIFO batch:63
[ 0.077095] Normal zone: 8192 pages in unavailable ranges
[ 0.077098] x86/hpet: Will disable the HPET for this platform because it's not reliable
[ 0.077137] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
[ 0.077537] ACPI: PM-Timer IO Port: 0x1808
[ 0.077539] ACPI: Local APIC address 0xfee00000
[ 0.077545] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.077546] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.077547] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.077548] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.077548] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.077549] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.077550] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.077550] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.077551] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.077552] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.077552] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.077553] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.077615] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.077617] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.077618] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.077620] ACPI: IRQ0 used by override.
[ 0.077621] ACPI: IRQ9 used by override.
[ 0.077623] Using ACPI (MADT) for SMP configuration information
[ 0.077624] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.077631] e820: update [mem 0x75601000-0x7562ffff] usable ==> reserved
[ 0.077639] TSC deadline timer available
[ 0.077640] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[ 0.077658] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.077660] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.077661] PM: hibernation: Registered nosave memory: [mem 0x75601000-0x7562ffff]
[ 0.077663] PM: hibernation: Registered nosave memory: [mem 0x756f6000-0x756f6fff]
[ 0.077665] PM: hibernation: Registered nosave memory: [mem 0x78b23000-0x7a399fff]
[ 0.077665] PM: hibernation: Registered nosave memory: [mem 0x7a39a000-0x7a416fff]
[ 0.077666] PM: hibernation: Registered nosave memory: [mem 0x7a417000-0x7a536fff]
[ 0.077667] PM: hibernation: Registered nosave memory: [mem 0x7a537000-0x7ab40fff]
[ 0.077667] PM: hibernation: Registered nosave memory: [mem 0x7ab41000-0x7ac0dfff]
[ 0.077669] PM: hibernation: Registered nosave memory: [mem 0x7ac0f000-0x7fffffff]
[ 0.077670] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[ 0.077670] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.077671] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.077672] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.077672] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.077673] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.077674] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.077674] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.077675] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[ 0.077676] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.077676] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.077677] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.077678] [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.077680] Booting paravirtualized kernel on bare hardware
[ 0.077682] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.082928] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:12 nr_node_ids:1
[ 0.083264] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.083271] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.083272] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[ 0.083299] Built 1 zonelists, mobility grouping on. Total pages: 4091134
[ 0.083300] Policy zone: Normal
[ 0.083302] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=38845911-dabf-40cf-a0fe-8abe080d3bfe rw udev.log_priority=3
[ 0.084264] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.084737] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.084844] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.129555] Memory: 16142148K/16624392K available (14344K kernel code, 2061K rwdata, 8884K rodata, 1704K init, 4248K bss, 481984K reserved, 0K cma-reserved)
[ 0.129562] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.129702] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.129716] Kernel/User page tables isolation: enabled
[ 0.129736] ftrace: allocating 41892 entries in 164 pages
[ 0.145120] ftrace: allocated 164 pages with 3 groups
[ 0.145224] rcu: Preemptible hierarchical RCU implementation.
[ 0.145225] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.145226] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=12.
[ 0.145227] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.145228] Trampoline variant of Tasks RCU enabled.
[ 0.145228] Rude variant of Tasks RCU enabled.
[ 0.145229] Tracing variant of Tasks RCU enabled.
[ 0.145229] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.145230] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.149113] NR_IRQS: 20736, nr_irqs: 2152, preallocated irqs: 16
[ 0.149827] Console: colour dummy device 80x25
[ 0.149845] printk: console [tty0] enabled
[ 0.149871] ACPI: Core revision 20200925
[ 0.150284] APIC: Switch to symmetric I/O mode setup
[ 0.150285] DMAR: Host address width 39
[ 0.150287] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.150293] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.150294] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.150297] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.150298] DMAR: RMRR base: 0x0000007933b000 end: 0x0000007935afff
[ 0.150299] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[ 0.150302] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.150303] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.150304] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.153550] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.153552] x2apic enabled
[ 0.153583] Switched APIC routing to cluster x2apic.
[ 0.162671] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[ 0.162676] Calibrating delay loop (skipped), value calculated using timer frequency.. 5202.65 BogoMIPS (lpj=8666640)
[ 0.162678] pid_max: default: 32768 minimum: 301
[ 0.166007] LSM: Security Framework initializing
[ 0.166007] Yama: becoming mindful.
[ 0.166007] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.166007] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.166007] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.166007] process: using mwait in idle threads
[ 0.166007] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.166007] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.166007] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.166007] Spectre V2 : Mitigation: Full generic retpoline
[ 0.166007] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.166007] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.166007] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.166007] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.166007] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.166007] SRBDS: Mitigation: Microcode
[ 0.166007] MDS: Mitigation: Clear CPU buffers
[ 0.166007] Freeing SMP alternatives memory: 36K
[ 0.166007] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.166007] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.166007] ... version: 4
[ 0.166007] ... bit width: 48
[ 0.166007] ... generic registers: 4
[ 0.166007] ... value mask: 0000ffffffffffff
[ 0.166007] ... max period: 00007fffffffffff
[ 0.166007] ... fixed-purpose events: 3
[ 0.166007] ... event mask: 000000070000000f
[ 0.166007] rcu: Hierarchical SRCU implementation.
[ 0.166007] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.166007] smp: Bringing up secondary CPUs ...
[ 0.166007] x86: Booting SMP configuration:
[ 0.166007] .... node #0, CPUs: #1 #2 #3 #4 #5 #6
[ 0.179447] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.179487] #7 #8 #9 #10 #11
[ 0.183188] smp: Brought up 1 node, 12 CPUs
[ 0.183188] smpboot: Max logical packages: 1
[ 0.183188] smpboot: Total of 12 processors activated (62424.80 BogoMIPS)
[ 0.186513] devtmpfs: initialized
[ 0.186513] x86/mm: Memory block size: 128MB
[ 0.186904] PM: Registering ACPI NVS region [mem 0x7a417000-0x7a536fff] (1179648 bytes)
[ 0.186904] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.186904] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.186904] pinctrl core: initialized pinctrl subsystem
[ 0.186904] PM: RTC time: 04:53:47, date: 2021-07-15
[ 0.186904] NET: Registered protocol family 16
[ 0.186904] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.186945] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.187070] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.187076] audit: initializing netlink subsys (disabled)
[ 0.187082] audit: type=2000 audit(1626324826.023:1): state=initialized audit_enabled=0 res=1
[ 0.187082] thermal_sys: Registered thermal governor 'fair_share'
[ 0.187082] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.187082] thermal_sys: Registered thermal governor 'step_wise'
[ 0.187082] thermal_sys: Registered thermal governor 'user_space'
[ 0.187082] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.187082] cpuidle: using governor ladder
[ 0.187082] cpuidle: using governor menu
[ 0.187082] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.187082] ACPI: bus type PCI registered
[ 0.187082] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.187082] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.187082] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.187082] PCI: Using configuration type 1 for base access
[ 0.187082] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.190280] Kprobes globally optimized
[ 0.190283] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.190283] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.190283] ACPI: Added _OSI(Module Device)
[ 0.190283] ACPI: Added _OSI(Processor Device)
[ 0.190283] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.190283] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.190283] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.190283] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.190283] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.292336] ACPI: 12 ACPI AML tables successfully acquired and loaded
[ 0.295020] ACPI: EC: EC started
[ 0.295021] ACPI: EC: interrupt blocked
[ 0.297682] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.297682] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.338911] ACPI: Dynamic OEM Table Load:
[ 0.338918] ACPI: SSDT 0xFFFF9AC80181EE00 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.340929] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.343157] ACPI: Dynamic OEM Table Load:
[ 0.343163] ACPI: SSDT 0xFFFF9AC80182D400 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.345326] ACPI: Dynamic OEM Table Load:
[ 0.345332] ACPI: SSDT 0xFFFF9AC80104A800 000581 (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.347609] ACPI: Dynamic OEM Table Load:
[ 0.347614] ACPI: SSDT 0xFFFF9AC801821A00 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.349685] ACPI: Dynamic OEM Table Load:
[ 0.349691] ACPI: SSDT 0xFFFF9AC80104F000 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.352098] ACPI: Dynamic OEM Table Load:
[ 0.352103] ACPI: SSDT 0xFFFF9AC80104D800 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.354358] ACPI: Dynamic OEM Table Load:
[ 0.354363] ACPI: SSDT 0xFFFF9AC80182F400 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.356653] ACPI: Dynamic OEM Table Load:
[ 0.356660] ACPI: SSDT 0xFFFF9AC80109C000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.359628] ACPI: Dynamic OEM Table Load:
[ 0.359634] ACPI: SSDT 0xFFFF9AC801828400 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.368296] ACPI: Interpreter enabled
[ 0.368344] ACPI: (supports S0 S3 S4 S5)
[ 0.368351] ACPI: Using IOAPIC for interrupt routing
[ 0.368393] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.370171] ACPI: Enabled 9 GPEs in block 00 to 7F
[ 0.373479] ACPI: Power Resource [PG00] (on)
[ 0.508043] ACPI: Power Resource [PXP] (off)
[ 0.513017] ACPI: Power Resource [PXP] (off)
[ 0.516950] ACPI: Power Resource [BTPR] (off)
[ 0.518488] ACPI: Power Resource [USBC] (on)
[ 0.518696] ACPI: Power Resource [PAUD] (on)
[ 0.522839] ACPI: Power Resource [V0PR] (on)
[ 0.523374] ACPI: Power Resource [V1PR] (on)
[ 0.523899] ACPI: Power Resource [V2PR] (on)
[ 0.528046] ACPI: Power Resource [PXTC] (on)
[ 0.530419] ACPI: Power Resource [PXTC] (off)
[ 0.532786] ACPI: Power Resource [WRST] (on)
[ 0.540785] ACPI: Power Resource [FN00] (off)
[ 0.540899] ACPI: Power Resource [FN01] (off)
[ 0.541007] ACPI: Power Resource [FN02] (off)
[ 0.541116] ACPI: Power Resource [FN03] (off)
[ 0.541223] ACPI: Power Resource [FN04] (off)
[ 0.542026] ACPI: Power Resource [PIN] (off)
[ 0.542684] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.542691] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.542949] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.543192] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ 0.543193] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.544288] PCI host bridge to bus 0000:00
[ 0.544290] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.544291] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.544292] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.544293] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.544294] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.544295] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.544296] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.544297] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.544298] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.544299] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.544300] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.544321] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[ 0.544870] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.544916] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.545388] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[ 0.545397] pci 0000:00:02.0: reg 0x10: [mem 0xa2000000-0xa2ffffff 64bit]
[ 0.545402] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.545406] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.545424] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.545626] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.545635] pci 0000:00:04.0: reg 0x10: [mem 0xa4398000-0xa439ffff 64bit]
[ 0.545915] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.545924] pci 0000:00:08.0: reg 0x10: [mem 0xa43b1000-0xa43b1fff 64bit]
[ 0.546194] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.546230] pci 0000:00:12.0: reg 0x10: [mem 0xa43b0000-0xa43b0fff 64bit]
[ 0.546611] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.546646] pci 0000:00:14.0: reg 0x10: [mem 0xa4380000-0xa438ffff 64bit]
[ 0.546792] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.547713] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.547743] pci 0000:00:14.2: reg 0x10: [mem 0xa43a8000-0xa43a9fff 64bit]
[ 0.547763] pci 0000:00:14.2: reg 0x18: [mem 0xa43af000-0xa43affff 64bit]
[ 0.548115] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[ 0.548229] pci 0000:00:14.3: reg 0x10: [mem 0xa43a4000-0xa43a7fff 64bit]
[ 0.548869] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.549335] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[ 0.549370] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.549809] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.549842] pci 0000:00:16.0: reg 0x10: [mem 0xa43ad000-0xa43adfff 64bit]
[ 0.549967] pci 0000:00:16.0: PME# supported from D3hot
[ 0.550638] pci 0000:00:17.0: [8086:282a] type 00 class 0x010400
[ 0.550950] pci 0000:00:17.0: reg 0x10: [mem 0xa4390000-0xa4397fff]
[ 0.551088] pci 0000:00:17.0: reg 0x14: [mem 0xa43ac000-0xa43ac0ff]
[ 0.551227] pci 0000:00:17.0: reg 0x18: [io 0x5090-0x5097]
[ 0.551366] pci 0000:00:17.0: reg 0x1c: [io 0x5080-0x5083]
[ 0.551503] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.551519] pci 0000:00:17.0: reg 0x24: [mem 0xa4300000-0xa437ffff]
[ 0.552217] pci 0000:00:17.0: PME# supported from D3hot
[ 0.552850] pci 0000:00:1d.0: [8086:a334] type 01 class 0x060400
[ 0.553072] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.553140] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.553711] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[ 0.553743] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.554176] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[ 0.554701] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040380
[ 0.554768] pci 0000:00:1f.3: reg 0x10: [mem 0xa43a0000-0xa43a3fff 64bit]
[ 0.554864] pci 0000:00:1f.3: reg 0x20: [mem 0xa4100000-0xa41fffff 64bit]
[ 0.555025] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.556750] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.556917] pci 0000:00:1f.4: reg 0x10: [mem 0xa43aa000-0xa43aa0ff 64bit]
[ 0.557127] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.557611] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.557637] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.557938] pci 0000:01:00.0: [10de:1f91] type 00 class 0x030000
[ 0.557957] pci 0000:01:00.0: reg 0x10: [mem 0xa3000000-0xa3ffffff]
[ 0.557973] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.557988] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.557997] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.558006] pci 0000:01:00.0: reg 0x30: [mem 0xa4000000-0xa407ffff pref]
[ 0.558096] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.558333] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.558355] pci 0000:01:00.1: reg 0x10: [mem 0xa4080000-0xa4083fff]
[ 0.558584] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.558586] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.558588] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.558591] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.558749] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.558777] pci 0000:02:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.558815] pci 0000:02:00.0: reg 0x18: [mem 0xa4204000-0xa4204fff 64bit]
[ 0.558838] pci 0000:02:00.0: reg 0x20: [mem 0xa4200000-0xa4203fff 64bit]
[ 0.558998] pci 0000:02:00.0: supports D1 D2
[ 0.558999] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.559227] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.559232] pci 0000:00:1d.0: bridge window [io 0x3000-0x3fff]
[ 0.559237] pci 0000:00:1d.0: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.579820] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.579929] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 0.580037] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.580143] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.580250] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.580356] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.580463] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.580569] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.581923] ACPI: EC: interrupt unblocked
[ 0.581924] ACPI: EC: event unblocked
[ 0.581946] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.581947] ACPI: EC: GPE=0xb
[ 0.581948] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot ECDT EC initialization complete
[ 0.581949] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.582016] iommu: Default domain type: Translated
[ 0.582038] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.582038] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.582038] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.582038] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.582038] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.582038] vgaarb: loaded
[ 0.582038] SCSI subsystem initialized
[ 0.582038] libata version 3.00 loaded.
[ 0.582038] ACPI: bus type USB registered
[ 0.582038] usbcore: registered new interface driver usbfs
[ 0.582038] usbcore: registered new interface driver hub
[ 0.582038] usbcore: registered new device driver usb
[ 0.582038] pps_core: LinuxPPS API ver. 1 registered
[ 0.582038] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.582038] PTP clock support registered
[ 0.582038] EDAC MC: Ver: 3.0.0
[ 0.582038] Registered efivars operations
[ 0.582764] NetLabel: Initializing
[ 0.582765] NetLabel: domain hash size = 128
[ 0.582766] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.582779] NetLabel: unlabeled traffic allowed by default
[ 0.582783] PCI: Using ACPI for IRQ routing
[ 0.672030] PCI: pci_cache_line_size set to 64 bytes
[ 0.672153] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.672154] e820: reserve RAM buffer [mem 0x75601000-0x77ffffff]
[ 0.672155] e820: reserve RAM buffer [mem 0x756f6000-0x77ffffff]
[ 0.672156] e820: reserve RAM buffer [mem 0x78b23000-0x7bffffff]
[ 0.672157] e820: reserve RAM buffer [mem 0x7ac0f000-0x7bffffff]
[ 0.672158] e820: reserve RAM buffer [mem 0x47e000000-0x47fffffff]
[ 0.673333] clocksource: Switched to clocksource tsc-early
[ 0.683391] VFS: Disk quotas dquot_6.6.0
[ 0.683404] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.683462] pnp: PnP ACPI init
[ 0.683573] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[ 0.683578] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.683800] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.683802] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.683805] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.683952] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.683955] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.684225] system 00:03: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.684226] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.684227] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.684228] system 00:03: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.684230] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.684231] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.684232] system 00:03: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.684233] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.684237] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.684527] system 00:04: [io 0x1800-0x18fe] could not be reserved
[ 0.684528] system 00:04: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.684530] system 00:04: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.684531] system 00:04: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.684532] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.684533] system 00:04: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.684535] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.684538] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.684921] system 00:05: [io 0x2000-0x20fe] has been reserved
[ 0.684924] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.686369] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[ 0.686371] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[ 0.686374] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.687284] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.706802] pnp: PnP ACPI: found 8 devices
[ 0.712419] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.712474] NET: Registered protocol family 2
[ 0.712621] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.714471] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.714548] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.714720] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.714789] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.714858] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.714913] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.714958] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.715115] NET: Registered protocol family 1
[ 0.715119] NET: Registered protocol family 44
[ 0.715134] pci 0000:00:15.0: BAR 0: assigned [mem 0xa43ab000-0xa43abfff 64bit]
[ 0.715158] pci 0000:00:1e.0: BAR 0: assigned [mem 0xa43ae000-0xa43aefff 64bit]
[ 0.715175] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.715177] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.715179] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.715181] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.715185] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.715191] pci 0000:00:1d.0: bridge window [io 0x3000-0x3fff]
[ 0.715198] pci 0000:00:1d.0: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.715212] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.715213] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.715214] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.715215] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
[ 0.715216] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
[ 0.715216] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
[ 0.715217] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
[ 0.715218] pci_bus 0000:00: resource 11 [mem 0x000f0000-0x000fffff window]
[ 0.715219] pci_bus 0000:00: resource 12 [mem 0x80000000-0xdfffffff window]
[ 0.715220] pci_bus 0000:00: resource 13 [mem 0xfc800000-0xfe7fffff window]
[ 0.715222] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.715223] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa40fffff]
[ 0.715223] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.715225] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.715226] pci_bus 0000:02: resource 1 [mem 0xa4200000-0xa42fffff]
[ 0.715434] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.715848] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.715912] PCI: CLS 64 bytes, default 64
[ 0.715941] Trying to unpack rootfs image as initramfs...
[ 0.852130] Freeing initrd memory: 12588K
[ 0.852165] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.852166] software IO TLB: mapped [mem 0x000000006d76c000-0x000000007176c000] (64MB)
[ 0.852235] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.853086] check: Scanning for low memory corruption every 60 seconds
[ 0.853386] Initialise system trusted keyrings
[ 0.853404] Key type blacklist registered
[ 0.853444] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.854407] zbud: loaded
[ 0.863492] Key type asymmetric registered
[ 0.863493] Asymmetric key parser 'x509' registered
[ 0.863498] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.863525] io scheduler mq-deadline registered
[ 0.863526] io scheduler kyber registered
[ 0.863544] io scheduler bfq registered
[ 0.863648] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.868180] pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[ 0.868219] pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
[ 0.868221] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.868379] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.868411] efifb: probing for efifb
[ 0.868423] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 0.868424] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.868425] efifb: scrolling: redraw
[ 0.868426] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.868463] fbcon: Deferring console take-over
[ 0.868465] fb0: EFI VGA frame buffer device
[ 0.868471] intel_idle: MWAIT substates: 0x11142120
[ 0.868472] intel_idle: v0.5.1 model 0x9E
[ 0.869059] intel_idle: Local APIC timer is reliable in all C-states
[ 0.869286] ACPI: AC Adapter [AC0] (off-line)
[ 0.869364] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.869379] ACPI: Sleep Button [SLPB]
[ 0.869402] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.869414] ACPI: Power Button [PWRB]
[ 0.869434] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:01/input/input2
[ 0.869446] ACPI: Lid Switch [LID]
[ 0.869470] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.872700] ACPI: Power Button [PWRF]
[ 0.877022] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.877023] ACPI: Thermal Zone [THRM] (38 C)
[ 0.877226] [Firmware Bug]: Invalid critical threshold (0)
[ 0.877321] ACPI: Invalid passive threshold
[ 0.877672] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.877673] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.877850] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.879231] hpet_acpi_add: no address or irqs in _CRS
[ 0.879287] Non-volatile memory driver v1.3
[ 0.879288] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.879288] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.880486] ahci 0000:00:17.0: version 3.0
[ 0.880645] ahci 0000:00:17.0: Found 1 remapped NVMe devices.
[ 0.880646] ahci 0000:00:17.0: Switch your BIOS from RAID to AHCI mode to use them.
[ 0.880721] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl RAID mode
[ 0.880722] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds apst
[ 0.881444] scsi host0: ahci
[ 0.881712] scsi host1: ahci
[ 0.881883] scsi host2: ahci
[ 0.882013] scsi host3: ahci
[ 0.882084] scsi host4: ahci
[ 0.882109] ata1: DUMMY
[ 0.882109] ata2: DUMMY
[ 0.882110] ata3: DUMMY
[ 0.882111] ata4: DUMMY
[ 0.882117] ata5: SATA max UDMA/133 abar m524288@0xa4300000 port 0xa4300300 irq 16
[ 0.882141] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.882150] ehci-pci: EHCI PCI platform driver
[ 0.882161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.882163] ohci-pci: OHCI PCI platform driver
[ 0.882169] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.882195] usbcore: registered new interface driver usbserial_generic
[ 0.882198] usbserial: USB Serial support registered for generic
[ 0.882217] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.882217] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.882866] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.883222] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.884318] rtc_cmos rtc_cmos: registered as rtc0
[ 0.884591] rtc_cmos rtc_cmos: setting system clock to 2021-07-15T04:53:47 UTC (1626324827)
[ 0.884601] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.884631] intel_pstate: Intel P-state driver initializing
[ 0.885557] intel_pstate: Disabling energy efficiency optimization
[ 0.885558] intel_pstate: HWP enabled
[ 0.885785] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.886031] hid: raw HID events driver (C) Jiri Kosina
[ 0.886140] ashmem: initialized
[ 0.886214] intel_pmc_core INT33A1:00: initialized
[ 0.886279] drop_monitor: Initializing network drop monitor service
[ 0.886343] Initializing XFRM netlink socket
[ 0.886419] NET: Registered protocol family 10
[ 0.890398] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.891745] Segment Routing with IPv6
[ 0.891746] RPL Segment Routing with IPv6
[ 0.891764] NET: Registered protocol family 17
[ 0.892541] microcode: sig=0x906ea, pf=0x20, revision=0xea
[ 0.892654] microcode: Microcode Update Driver: v2.2.
[ 0.892657] IPI shorthand broadcast: enabled
[ 0.892665] sched_clock: Marking stable (879407567, 13055640)->(905914990, -13451783)
[ 0.892841] registered taskstats version 1
[ 0.892847] Loading compiled-in X.509 certificates
[ 0.895885] Loaded X.509 cert 'Build time autogenerated kernel key: 5e649498937fba3fd452e8e68fc816deb54d4711'
[ 0.897777] zswap: loaded using pool zstd/z3fold
[ 0.898283] Key type ._fscrypt registered
[ 0.898284] Key type .fscrypt registered
[ 0.898285] Key type fscrypt-provisioning registered
[ 0.900530] PM: Magic number: 13:892:868
[ 0.900579] acpi INT346F:02: hash matches
[ 0.900795] RAS: Correctable Errors collector initialized.
[ 0.916861] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 1.196184] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.197037] ata5.00: ATA-10: WDC WD10SPZX-11Z10T0, 01.01A01, max UDMA/133
[ 1.197043] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.198199] ata5.00: configured for UDMA/133
[ 1.198478] scsi 4:0:0:0: Direct-Access ATA WDC WD10SPZX-11Z 1A01 PQ: 0 ANSI: 5
[ 1.198872] sd 4:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.198877] sd 4:0:0:0: [sda] 4096-byte physical blocks
[ 1.198897] sd 4:0:0:0: [sda] Write Protect is off
[ 1.198901] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.198923] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.312449] sda: sda1 sda2 sda3
[ 1.313610] sd 4:0:0:0: [sda] Attached SCSI disk
[ 1.316419] Freeing unused decrypted memory: 2036K
[ 1.317084] Freeing unused kernel image (initmem) memory: 1704K
[ 1.329555] Write protecting the kernel read-only data: 26624k
[ 1.330923] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.331731] Freeing unused kernel image (rodata/data gap) memory: 1356K
[ 1.389625] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.389628] rodata_test: all tests were successful
[ 1.389629] x86/mm: Checking user space page tables
[ 1.443751] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.443755] Run /init as init process
[ 1.443756] with arguments:
[ 1.443756] /init
[ 1.443757] with environment:
[ 1.443758] HOME=/
[ 1.443758] TERM=linux
[ 1.443759] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 1.528530] fbcon: Taking over console
[ 1.528642] Console: switching to colour frame buffer device 240x67
[ 1.622202] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.622209] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.623358] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.623368] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.623680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.623681] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.623683] usb usb1: Product: xHCI Host Controller
[ 1.623683] usb usb1: Manufacturer: Linux 5.10.49-1-MANJARO xhci-hcd
[ 1.623684] usb usb1: SerialNumber: 0000:00:14.0
[ 1.623811] hub 1-0:1.0: USB hub found
[ 1.623857] hub 1-0:1.0: 16 ports detected
[ 1.627058] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.627061] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.627064] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.627105] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.627106] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.627107] usb usb2: Product: xHCI Host Controller
[ 1.627108] usb usb2: Manufacturer: Linux 5.10.49-1-MANJARO xhci-hcd
[ 1.627109] usb usb2: SerialNumber: 0000:00:14.0
[ 1.627203] hub 2-0:1.0: USB hub found
[ 1.627226] hub 2-0:1.0: 8 ports detected
[ 1.869458] tsc: Refined TSC clocksource calibration: 2592.005 MHz
[ 1.869476] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cbb91cef, max_idle_ns: 440795297256 ns
[ 1.869572] clocksource: Switched to clocksource tsc
[ 1.879426] usb 1-11: new high-speed USB device number 2 using xhci_hcd
[ 2.041497] usb 1-11: New USB device found, idVendor=13d3, idProduct=56a2, bcdDevice=19.02
[ 2.041503] usb 1-11: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.041506] usb 1-11: Product: USB2.0 HD UVC WebCam
[ 2.041509] usb 1-11: Manufacturer: Azurewave
[ 2.041511] usb 1-11: SerialNumber: 0x0001
[ 2.166124] usb 1-14: new full-speed USB device number 3 using xhci_hcd
[ 2.307488] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 2.307494] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.329252] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.701985] random: fast init done
[ 4.207437] random: crng init done
[ 4.571874] systemd[1]: systemd 248.3-3-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 4.586391] systemd[1]: Detected architecture x86-64.
[ 4.641438] systemd[1]: Hostname set to <h3ll>.
[ 7.587997] systemd[1]: tmp.HeHQJvWeDz.service: Failed to open /etc/systemd/system/tmp.HeHQJvWeDz.service: No such file or directory
[ 7.619602] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.622544] systemd[1]: Created slice system-getty.slice.
[ 7.623447] systemd[1]: Created slice system-modprobe.slice.
[ 7.624346] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 7.625030] systemd[1]: Created slice User and Session Slice.
[ 7.625362] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.625671] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.626272] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.626560] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.626746] systemd[1]: Reached target Login Prompts.
[ 7.626941] systemd[1]: Reached target Paths.
[ 7.627107] systemd[1]: Reached target Remote File Systems.
[ 7.627268] systemd[1]: Reached target Slices.
[ 7.627464] systemd[1]: Reached target System Time Set.
[ 7.627664] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 7.628028] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.644851] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.648194] systemd[1]: Listening on Process Core Dump Socket.
[ 7.648836] systemd[1]: Listening on Journal Audit Socket.
[ 7.649285] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.649800] systemd[1]: Listening on Journal Socket.
[ 7.650631] systemd[1]: Listening on udev Control Socket.
[ 7.651097] systemd[1]: Listening on udev Kernel Socket.
[ 7.653398] systemd[1]: Mounting Huge Pages File System...
[ 7.655798] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.658250] systemd[1]: Mounting Kernel Debug File System...
[ 7.660729] systemd[1]: Mounting Kernel Trace File System...
[ 7.663568] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 7.665821] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.668373] systemd[1]: Starting Load Kernel Module configfs...
[ 7.670852] systemd[1]: Starting Load Kernel Module drm...
[ 7.672080] systemd[1]: Starting Load Kernel Module fuse...
[ 7.734988] systemd[1]: Starting Set Up Additional Binary Formats...
[ 7.735327] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.825977] fuse: init (API version 7.32)
[ 7.834970] systemd[1]: Starting Load Kernel Modules...
[ 7.835879] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.836031] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 7.836932] systemd[1]: Starting Coldplug All udev Devices...
[ 7.839080] systemd[1]: Mounted Huge Pages File System.
[ 7.839279] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.839471] systemd[1]: Mounted Kernel Debug File System.
[ 7.839653] systemd[1]: Mounted Kernel Trace File System.
[ 7.840059] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 7.840491] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 7.840731] systemd[1]: Finished Load Kernel Module configfs.
[ 7.841104] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 7.841340] systemd[1]: Finished Load Kernel Module fuse.
[ 7.841555] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 277 (systemd-binfmt)
[ 7.842740] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 7.844167] systemd[1]: Mounting FUSE Control File System...
[ 7.845602] systemd[1]: Mounting Kernel Configuration File System...
[ 7.847373] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 7.847668] systemd[1]: Mounted FUSE Control File System.
[ 7.854774] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 7.855103] systemd[1]: Finished Load Kernel Module drm.
[ 7.855480] systemd[1]: Mounted Kernel Configuration File System.
[ 7.883167] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 7.885548] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.887798] systemd[1]: Activating swap /swapfile...
[ 7.888183] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 7.985329] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 7.987544] systemd[1]: Starting Load/Save Random Seed...
[ 7.989980] systemd[1]: Starting Create System Users...
[ 7.991461] systemd[1]: Finished Set Up Additional Binary Formats.
[ 8.254549] vboxdrv: loading out-of-tree module taints kernel.
[ 8.254950] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 8.261555] vboxdrv: Found 12 processor cores
[ 8.283260] vboxdrv: TSC mode is Invariant, tentative frequency 2592004650 Hz
[ 8.283261] vboxdrv: Successfully loaded version 6.1.22 (interface 0x00300000)
[ 8.309477] Adding 3145724k swap on /swapfile. Priority:-2 extents:3 across:3432444k FS
[ 8.309541] systemd[1]: Activated swap /swapfile.
[ 8.309667] systemd[1]: Reached target Swap.
[ 8.310390] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 8.312450] systemd[1]: Mounted Temporary Directory (/tmp).
[ 8.323354] VBoxNetAdp: Successfully started.
[ 8.380038] VBoxNetFlt: Successfully started.
[ 8.403640] systemd[1]: Finished Coldplug All udev Devices.
[ 8.428334] systemd[1]: Finished Load/Save Random Seed.
[ 8.429130] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 8.548106] Linux agpgart interface v0.103
[ 10.939237] systemd[1]: Finished Create System Users.
[ 10.941867] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.702170] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 11.704567] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 11.706931] systemd[1]: Starting Journal Service...
[ 11.709075] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 11.885959] nvidia: module license 'NVIDIA' taints kernel.
[ 11.885961] Disabling lock debugging due to kernel taint
[ 11.916586] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[ 11.917026] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 11.917788] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 11.962418] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.42.01 Tue Jun 15 21:26:37 UTC 2021
[ 11.964207] systemd[1]: Started Journal Service.
[ 11.964959] audit: type=1130 audit(1626324838.575:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.074143] systemd-journald[294]: Received client request to flush runtime journal.
[ 12.838703] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.42.01 Tue Jun 15 21:22:38 UTC 2021
[ 13.051197] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 13.051200] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 13.316880] audit: type=1130 audit(1626324839.928:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.681801] audit: type=1130 audit(1626324840.291:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.391676] audit: type=1130 audit(1626324841.001:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.852347] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input5
[ 14.852970] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 14.853044] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 14.853185] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 15.109474] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 15.161229] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ 15.162411] intel_rapl_common: Found RAPL domain package
[ 15.162412] intel_rapl_common: Found RAPL domain dram
[ 15.162571] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 15.510347] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 15.529064] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 15.531798] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 15.790166] intel-spi 0000:00:1f.5: mx25l12805d (16384 Kbytes)
[ 15.790561] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 15.790618] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 15.793271] Creating 1 MTD partitions on "0000:00:1f.5":
[ 15.793274] 0x000000000000-0x000001000000 : "BIOS"
[ 15.796768] i2c i2c-0: 1/4 memory slots populated (from DMI)
[ 15.797261] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 15.872797] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 15.873062] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 15.898226] i2c_hid i2c-ELAN1200:00: supply vdd not found, using dummy regulator
[ 15.898251] i2c_hid i2c-ELAN1200:00: supply vddl not found, using dummy regulator
[ 15.900263] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[ 15.900567] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 16.058798] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 16.059759] checking generic (80000000 7f0000) vs hw (a2000000 1000000)
[ 16.059761] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[ 16.059762] fb0: switching to inteldrmfb from EFI VGA
[ 16.059824] Console: switching to colour dummy device 80x25
[ 16.059853] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 16.062610] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 16.064000] Intel(R) Wireless WiFi driver for Linux
[ 16.064040] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 16.074611] libphy: r8169: probed
[ 16.074802] r8169 0000:02:00.0 eth0: RTL8168h/8111h, 04:d4:c4:e4:71:fd, XID 541, IRQ 133
[ 16.074804] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 16.166563] input: ELAN1200:00 04F3:30BA Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN1200:00/0018:04F3:30BA.0001/input/input7
[ 16.166672] input: ELAN1200:00 04F3:30BA Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN1200:00/0018:04F3:30BA.0001/input/input8
[ 16.166730] hid-generic 0018:04F3:30BA.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN1200:00 04F3:30BA] on i2c-ELAN1200:00
[ 16.352333] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 16.352339] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 16.352342] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 16.352345] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 16.352347] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 16.352350] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 16.352352] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 16.352355] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 16.352357] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 16.352360] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 16.352362] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 16.352365] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 16.352368] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 16.352370] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 16.352373] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 16.352375] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 16.352378] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 16.353252] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 16.442222] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 16.453979] asus_wmi: ASUS WMI generic driver loaded
[ 16.457290] intel_rapl_common: Found RAPL domain package
[ 16.457292] intel_rapl_common: Found RAPL domain core
[ 16.457293] intel_rapl_common: Found RAPL domain uncore
[ 16.457294] intel_rapl_common: Found RAPL domain dram
[ 16.458218] asus_wmi: Initialization: 0x1
[ 16.458408] asus_wmi: BIOS WMI version: 8.1
[ 16.458585] asus_wmi: SFUN value: 0x4a0061
[ 16.458587] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 16.458588] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 16.477225] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 16.494806] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 16.501205] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input9
[ 16.503018] ACPI Error: Divide by zero (20200925/utmath-478)
[ 16.503043] ACPI Error: Aborting method \_SB.ATKD.WMNB due to previous error (AE_AML_DIVIDE_BY_ZERO) (20200925/psparse-529)
[ 16.566264] battery: new extension: ASUS Battery Extension
[ 16.567786] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 16.629527] iTCO_vendor_support: vendor-support=0
[ 16.631297] dw-apb-uart.1: ttyS4 at MMIO 0xa43ae000 (irq = 20, base_baud = 115200) is a 16550A
[ 16.696279] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 16.696420] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 16.696759] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 16.710292] input: ELAN1200:00 04F3:30BA Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN1200:00/0018:04F3:30BA.0001/input/input10
[ 16.710552] input: ELAN1200:00 04F3:30BA Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN1200:00/0018:04F3:30BA.0001/input/input11
[ 16.710742] hid-multitouch 0018:04F3:30BA.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN1200:00 04F3:30BA] on i2c-ELAN1200:00
[ 16.723421] mousedev: PS/2 mouse device common for all mice
[ 17.126196] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 17.126202] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 17.126205] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 17.126207] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 17.126210] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 17.187130] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 1
[ 17.194814] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 17.195497] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[ 17.195720] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 17.195780] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input13
[ 17.197658] fbcon: i915drmfb (fb0) is primary device
[ 17.201505] Console: switching to colour frame buffer device 240x67
[ 17.216654] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 17.302372] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x318
[ 17.358477] iwlwifi 0000:00:14.3: base HW address: 0c:dd:24:41:19:9b
[ 17.426129] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 17.427256] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 17.431714] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 17.587236] audit: type=1130 audit(1626324844.198:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:asus::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.618955] cryptd: max_cpu_qlen set to 1000
[ 17.757717] AVX2 version of gcm_enc/dec engaged.
[ 17.757719] AES CTR mode by8 optimization enabled
[ 17.796655] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 17.796679] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 17.905984] audit: type=1130 audit(1626324844.515:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.141529] audit: type=1130 audit(1626324844.751:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.142558] audit: type=1130 audit(1626324844.751:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.168737] loop: module loaded
[ 18.536634] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 18.536653] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 18.541506] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 18.992553] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 18.992599] sof-audio-pci 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 18.993084] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 18.993397] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 18.999583] sof-audio-pci 0000:00:1f.3: use msi interrupt mode
[ 19.312641] sof-audio-pci 0000:00:1f.3: hda codecs found, mask 5
[ 19.312646] sof-audio-pci 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 19.312656] sof-audio-pci 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 19.887039] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 6 size 0x20
[ 19.887046] sof-audio-pci 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 19.887051] sof-audio-pci 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:17:0
[ 19.887053] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 19.887069] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 3 size 0x30
[ 19.887072] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 5 size 0x20
[ 20.020165] sof-audio-pci 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 20.020172] sof-audio-pci 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:17:0
[ 20.020174] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 20.421027] sof-audio-pci 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:17:0
[ 20.421032] sof-audio-pci 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 20.445268] sof-audio-pci 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 20.467150] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC233: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 20.467156] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 20.467160] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 20.467162] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 20.467165] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 20.467168] snd_hda_codec_realtek ehdaudio0D0: Mic=0x12
[ 20.501670] audit: type=1130 audit(1626324847.111:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-6BB0\x2dA5B3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.519103] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 20.519118] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[ 20.519541] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[ 20.519555] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[ 20.519568] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[ 20.519583] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[ 20.519592] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[ 20.519609] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[ 20.519625] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[ 20.519640] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[ 20.519659] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[ 20.519675] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[ 20.519690] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[ 20.535195] input: sof-hda-dsp Front Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input14
[ 20.535345] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input15
[ 20.535472] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input16
[ 20.535638] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input17
[ 22.794203] audit: type=1130 audit(1626324849.405:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-599d6bb8\x2da70e\x2d4e8f\x2d9e25\x2dd0bd29595d48 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.920734] audit: type=1131 audit(1626324849.531:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.488628] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 26.266891] Bluetooth: Core ver 2.22
[ 26.266918] NET: Registered protocol family 31
[ 26.266919] Bluetooth: HCI device and connection manager initialized
[ 26.266922] Bluetooth: HCI socket layer initialized
[ 26.266923] Bluetooth: L2CAP socket layer initialized
[ 26.266926] Bluetooth: SCO socket layer initialized
[ 26.570095] usbcore: registered new interface driver btusb
[ 26.571565] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[ 26.572531] Bluetooth: hci0: Device revision is 2
[ 26.572535] Bluetooth: hci0: Secure boot is enabled
[ 26.572538] Bluetooth: hci0: OTP lock is enabled
[ 26.572542] Bluetooth: hci0: API lock is enabled
[ 26.572545] Bluetooth: hci0: Debug lock is disabled
[ 26.572549] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 26.778138] audit: type=1130 audit(1626324853.388:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.812634] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 26.938706] mc: Linux media interface: v0.10
[ 27.289208] videodev: Linux video capture interface: v2.00
[ 27.477509] uvcvideo: Found UVC 1.00 device USB2.0 HD UVC WebCam (13d3:56a2)
[ 27.481789] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input18
[ 27.482070] usbcore: registered new interface driver uvcvideo
[ 27.482074] USB Video Class driver (1.1.1)
[ 28.326002] Bluetooth: hci0: Waiting for firmware download to complete
[ 28.326547] Bluetooth: hci0: Firmware loaded in 1715319 usecs
[ 28.326565] Bluetooth: hci0: Waiting for device to boot
[ 28.340586] Bluetooth: hci0: Device booted in 13701 usecs
[ 28.399231] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[ 28.401639] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 28.404692] Bluetooth: hci0: Firmware revision 0.1 build 6 week 12 2021
[ 31.769116] audit: type=1131 audit(1626324858.381:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.796225] audit: type=1130 audit(1626324859.408:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.409022] audit: type=1130 audit(1626324862.018:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.044141] audit: type=1130 audit(1626324862.655:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.047529] audit: type=1334 audit(1626324862.658:18): prog-id=10 op=LOAD
[ 36.265650] audit: type=1127 audit(1626324862.875:19): pid=593 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 36.350582] audit: type=1130 audit(1626324862.961:20): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.489868] audit: type=1130 audit(1626324863.101:21): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.529409] audit: type=1130 audit(1626324863.138:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.558801] audit: type=1130 audit(1626324863.168:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.228845] kauditd_printk_skb: 6 callbacks suppressed
[ 38.228848] audit: type=1101 audit(1626324864.838:30): pid=621 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_time acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 38.297419] audit: type=1103 audit(1626324864.908:31): pid=621 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_unix,pam_env acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 38.297648] audit: type=1006 audit(1626324864.908:32): pid=621 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 38.349900] audit: type=1105 audit(1626324864.961:33): pid=621 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_limits,pam_unix acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 38.350280] audit: type=1110 audit(1626324864.961:34): pid=621 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_unix,pam_env acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 38.682634] audit: type=1104 audit(1626324865.295:35): pid=621 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_unix,pam_env acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 38.682832] audit: type=1106 audit(1626324865.295:36): pid=621 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_limits,pam_unix acct="terabyte" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
[ 40.551930] audit: type=1130 audit(1626324867.161:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.556056] audit: type=1130 audit(1626324867.165:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.561745] audit: type=1130 audit(1626324867.171:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.974935] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 40.974937] Bluetooth: BNEP filters: protocol multicast
[ 40.974940] Bluetooth: BNEP socket layer initialized
[ 41.097066] NET: Registered protocol family 38
[ 43.363776] kauditd_printk_skb: 9 callbacks suppressed
[ 43.363779] audit: type=1130 audit(1626324869.975:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.629475] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 43.829623] r8169 0000:02:00.0 enp2s0: Link is Down
[ 44.227179] audit: type=1130 audit(1626324870.838:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.061608] audit: type=1130 audit(1626324871.671:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.951404] audit: type=1130 audit(1626324872.561:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.233041] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 54.048560] audit: type=1131 audit(1626324880.658:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 56.925379] audit: type=1100 audit(1626324883.535:54): pid=859 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 56.925479] audit: type=1101 audit(1626324883.535:55): pid=859 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 56.926203] audit: type=1103 audit(1626324883.538:56): pid=859 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 56.996639] audit: type=1130 audit(1626324883.608:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.082532] audit: type=1101 audit(1626324883.691:58): pid=861 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.082583] audit: type=1103 audit(1626324883.691:59): pid=861 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 57.082845] audit: type=1006 audit(1626324883.695:60): pid=861 uid=0 old-auid=4294967295 auid=967 tty=(none) old-ses=4294967295 ses=2 res=1
[ 57.108069] audit: type=1105 audit(1626324883.718:61): pid=861 uid=0 auid=967 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.139208] audit: type=1334 audit(1626324883.748:62): prog-id=17 op=LOAD
[ 67.936003] kauditd_printk_skb: 3 callbacks suppressed
[ 67.936007] audit: type=1130 audit(1626324894.548:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 67.969109] audit: type=1334 audit(1626324894.578:67): prog-id=18 op=LOAD
[ 67.969281] audit: type=1334 audit(1626324894.581:68): prog-id=19 op=LOAD
[ 68.568827] audit: type=1130 audit(1626324895.178:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 71.473799] audit: type=1131 audit(1626324898.085:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 71.642809] audit: type=1334 audit(1626324898.255:71): prog-id=16 op=UNLOAD
[ 71.642818] audit: type=1334 audit(1626324898.255:72): prog-id=15 op=UNLOAD
[ 71.642823] audit: type=1334 audit(1626324898.255:73): prog-id=14 op=UNLOAD
[ 77.324993] audit: type=1100 audit(1626324903.935:74): pid=905 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 77.326301] audit: type=1101 audit(1626324903.938:75): pid=905 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 77.326718] audit: type=1103 audit(1626324903.938:76): pid=905 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 77.326813] audit: type=1006 audit(1626324903.938:77): pid=905 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 77.344151] audit: type=1130 audit(1626324903.955:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.352236] audit: type=1101 audit(1626324903.961:79): pid=907 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.352240] audit: type=1103 audit(1626324903.961:80): pid=907 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="terabyte" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 77.352346] audit: type=1006 audit(1626324903.961:81): pid=907 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 77.354147] audit: type=1105 audit(1626324903.965:82): pid=907 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="terabyte" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.501567] audit: type=1334 audit(1626324904.111:83): prog-id=20 op=LOAD
[ 89.773421] kauditd_printk_skb: 5 callbacks suppressed
[ 89.773422] audit: type=1131 audit(1626324916.385:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 89.778943] audit: type=1131 audit(1626324916.388:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.577253] audit: type=1130 audit(1626324930.188:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 109.598252] Bluetooth: RFCOMM TTY layer initialized
[ 109.598263] Bluetooth: RFCOMM socket layer initialized
[ 109.598274] Bluetooth: RFCOMM ver 1.11
[ 134.722490] r8169 0000:02:00.0 enp2s0: Link is Down
[ 141.146090] Generic FE-GE Realtek PHY r8169-200:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[ 141.146122] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 141.146335] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[ 141.452396] audit: type=1130 audit(1626324968.065:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 152.026350] audit: type=1131 audit(1626324978.638:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 263.836234] r8169 0000:02:00.0 enp2s0: Link is Down
[ 270.072059] audit: type=1130 audit(1626325097.036:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 271.494823] Generic FE-GE Realtek PHY r8169-200:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[ 271.494892] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[ 280.677512] audit: type=1131 audit(1626325107.637:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 953.296708] audit: type=1130 audit(1626325780.289:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 953.296717] audit: type=1131 audit(1626325780.289:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4643.144777] audit: type=1334 audit(1626329470.099:98): prog-id=21 op=LOAD
[ 4643.145019] audit: type=1334 audit(1626329470.099:99): prog-id=22 op=LOAD
[ 4643.145118] audit: type=1334 audit(1626329470.099:100): prog-id=23 op=LOAD
[ 4643.257468] audit: type=1130 audit(1626329470.212:101): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4691.782535] audit: type=1131 audit(1626329518.735:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4691.920160] audit: type=1334 audit(1626329518.872:103): prog-id=23 op=UNLOAD
[ 4691.920186] audit: type=1334 audit(1626329518.872:104): prog-id=22 op=UNLOAD
[ 4691.920201] audit: type=1334 audit(1626329518.872:105): prog-id=21 op=UNLOAD
[ 8894.763320] audit: type=1130 audit(1626333721.727:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8895.511249] r8169 0000:02:00.0 enp2s0: Link is Down
[ 8896.343230] PM: suspend entry (deep)
[ 8896.802819] Filesystems sync: 0.459 seconds
[ 8897.574724] Freezing user space processes ... (elapsed 0.003 seconds) done.
[ 8897.578280] OOM killer disabled.
[ 8897.578308] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 8897.579962] printk: Suspending console(s) (use no_console_suspend to debug)
[ 8897.621678] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 8897.648458] sd 4:0:0:0: [sda] Stopping disk
[ 8898.145870] ACPI: EC: interrupt blocked
[ 8898.357420] ACPI: Preparing to enter system sleep state S3
[ 8898.360632] ACPI: EC: event blocked
[ 8898.360633] ACPI: EC: EC stopped
[ 8898.360635] PM: Saving platform NVS memory
[ 8898.360655] Disabling non-boot CPUs ...
[ 8898.361667] IRQ 129: no longer affine to CPU1
[ 8898.362722] smpboot: CPU 1 is now offline
[ 8898.364931] IRQ 130: no longer affine to CPU2
[ 8898.365998] smpboot: CPU 2 is now offline
[ 8898.368123] IRQ 131: no longer affine to CPU3
[ 8898.369188] smpboot: CPU 3 is now offline
[ 8898.372191] smpboot: CPU 4 is now offline
[ 8898.375366] smpboot: CPU 5 is now offline
[ 8898.378311] smpboot: CPU 6 is now offline
[ 8898.380072] smpboot: CPU 7 is now offline
[ 8898.381752] smpboot: CPU 8 is now offline
[ 8898.383487] smpboot: CPU 9 is now offline
[ 8898.385254] smpboot: CPU 10 is now offline
[ 8898.386993] smpboot: CPU 11 is now offline
[ 8898.391290] ACPI: Low-level resume complete
[ 8898.391401] ACPI: EC: EC started
[ 8898.391401] PM: Restoring platform NVS memory
[ 8898.394097] smpboot: Scheduler frequency invariance went wobbly, disabling!
[ 8898.394312] Enabling non-boot CPUs ...
[ 8898.394491] x86: Booting SMP configuration:
[ 8898.394492] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 8898.397234] CPU1 is up
[ 8898.397392] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 8898.399265] CPU2 is up
[ 8898.399415] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 8898.401269] CPU3 is up
[ 8898.401410] smpboot: Booting Node 0 Processor 4 APIC 0x8
[ 8898.403261] CPU4 is up
[ 8898.403391] smpboot: Booting Node 0 Processor 5 APIC 0xa
[ 8898.405254] CPU5 is up
[ 8898.405381] smpboot: Booting Node 0 Processor 6 APIC 0x1
[ 8898.406171] CPU6 is up
[ 8898.406303] smpboot: Booting Node 0 Processor 7 APIC 0x3
[ 8898.406982] CPU7 is up
[ 8898.407108] smpboot: Booting Node 0 Processor 8 APIC 0x5
[ 8898.407792] CPU8 is up
[ 8898.407918] smpboot: Booting Node 0 Processor 9 APIC 0x7
[ 8898.408616] CPU9 is up
[ 8898.408744] smpboot: Booting Node 0 Processor 10 APIC 0x9
[ 8898.409502] CPU10 is up
[ 8898.409624] smpboot: Booting Node 0 Processor 11 APIC 0xb
[ 8898.410342] CPU11 is up
[ 8898.413496] ACPI: Waking up from system sleep state S3
[ 8898.560610] acpi LNXPOWER:03: Turning ON
[ 8898.562683] ACPI: EC: interrupt unblocked
[ 8899.814665] ACPI: EC: event unblocked
[ 8899.818460] sd 4:0:0:0: [sda] Starting disk
[ 8900.126381] usb 1-11: reset high-speed USB device number 2 using xhci_hcd
[ 8900.288767] acpi LNXPOWER:0b: Turning OFF
[ 8900.289854] acpi LNXPOWER:04: Turning OFF
[ 8900.290989] OOM killer enabled.
[ 8900.290991] Restarting tasks ... done.
[ 8900.294974] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 8900.322092] PM: suspend exit
[ 8901.552926] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 8901.555460] ata5.00: configured for UDMA/133
[ 8901.804556] audit: type=1130 audit(1626337948.410:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8901.804564] audit: type=1131 audit(1626337948.410:108): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8901.836231] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 8901.999585] r8169 0000:02:00.0 enp2s0: Link is Down
[ 8904.668931] audit: type=1131 audit(1626337951.273:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8905.696154] audit: type=1100 audit(1626337952.300:110): pid=22886 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="terabyte" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 8911.608340] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 8911.608365] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 8913.337227] audit: type=1130 audit(1626337959.943:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8923.674144] audit: type=1131 audit(1626337970.280:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13539.690697] input: Rockerz 550 (AVRCP) as /devices/virtual/input/input19
[21046.704847] audit: type=1130 audit(1626350093.565:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21068.746126] audit: type=1130 audit(1626350115.605:114): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21068.746130] audit: type=1131 audit(1626350115.605:115): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22692.004182] audit: type=1130 audit(1626351738.866:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[22702.356623] audit: type=1100 audit(1626351749.219:117): pid=51264 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[22702.420407] audit: type=1101 audit(1626351749.282:118): pid=51264 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[22754.933490] audit: type=1334 audit(1626351801.796:119): prog-id=19 op=UNLOAD
[22754.933494] audit: type=1334 audit(1626351801.796:120): prog-id=18 op=UNLOAD
[22754.933784] audit: type=1334 audit(1626351801.796:121): prog-id=6 op=UNLOAD
[22754.933786] audit: type=1334 audit(1626351801.796:122): prog-id=5 op=UNLOAD
[22754.933793] audit: type=1334 audit(1626351801.796:123): prog-id=4 op=UNLOAD
[22754.950032] audit: type=1334 audit(1626351801.813:124): prog-id=10 op=UNLOAD
[22754.950366] audit: type=1334 audit(1626351801.813:125): prog-id=9 op=UNLOAD
[22754.950369] audit: type=1334 audit(1626351801.813:126): prog-id=8 op=UNLOAD
[22754.950375] audit: type=1334 audit(1626351801.813:127): prog-id=7 op=UNLOAD
[22754.950520] audit: type=1334 audit(1626351801.813:128): prog-id=13 op=UNLOAD
[24378.713831] kauditd_printk_skb: 16 callbacks suppressed
[24378.713835] audit: type=1130 audit(1626353425.582:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24384.755392] audit: type=1130 audit(1626353431.622:146): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24385.229245] r8169 0000:02:00.0 enp2s0: Link is Down
[24385.847858] audit: type=1131 audit(1626353432.716:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24389.299932] PM: suspend entry (deep)
[24389.916725] Filesystems sync: 0.616 seconds
[24390.648043] Freezing user space processes ... (elapsed 0.004 seconds) done.
[24390.652437] OOM killer disabled.
[24390.652439] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[24390.654350] printk: Suspending console(s) (use no_console_suspend to debug)
[24390.672347] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[24390.730118] sd 4:0:0:0: [sda] Stopping disk
[24391.236407] ACPI: EC: interrupt blocked
[24391.448049] ACPI: Preparing to enter system sleep state S3
[24391.451216] ACPI: EC: event blocked
[24391.451218] ACPI: EC: EC stopped
[24391.451219] PM: Saving platform NVS memory
[24391.451239] Disabling non-boot CPUs ...
[24391.453345] smpboot: CPU 1 is now offline
[24391.456763] smpboot: CPU 2 is now offline
[24391.460026] smpboot: CPU 3 is now offline
[24391.463599] smpboot: CPU 4 is now offline
[24391.466942] smpboot: CPU 5 is now offline
[24391.471308] smpboot: CPU 6 is now offline
[24391.472951] smpboot: CPU 7 is now offline
[24391.474659] smpboot: CPU 8 is now offline
[24391.476353] smpboot: CPU 9 is now offline
[24391.478045] smpboot: CPU 10 is now offline
[24391.479668] smpboot: CPU 11 is now offline
[24391.483742] ACPI: Low-level resume complete
[24391.483854] ACPI: EC: EC started
[24391.483854] PM: Restoring platform NVS memory
[24391.486777] Enabling non-boot CPUs ...
[24391.486969] x86: Booting SMP configuration:
[24391.486970] smpboot: Booting Node 0 Processor 1 APIC 0x2
[24391.489704] CPU1 is up
[24391.489857] smpboot: Booting Node 0 Processor 2 APIC 0x4
[24391.491704] CPU2 is up
[24391.491857] smpboot: Booting Node 0 Processor 3 APIC 0x6
[24391.493705] CPU3 is up
[24391.493853] smpboot: Booting Node 0 Processor 4 APIC 0x8
[24391.495717] CPU4 is up
[24391.495866] smpboot: Booting Node 0 Processor 5 APIC 0xa
[24391.497740] CPU5 is up
[24391.497869] smpboot: Booting Node 0 Processor 6 APIC 0x1
[24391.498659] CPU6 is up
[24391.498793] smpboot: Booting Node 0 Processor 7 APIC 0x3
[24391.499476] CPU7 is up
[24391.499607] smpboot: Booting Node 0 Processor 8 APIC 0x5
[24391.500316] CPU8 is up
[24391.500445] smpboot: Booting Node 0 Processor 9 APIC 0x7
[24391.501154] CPU9 is up
[24391.501284] smpboot: Booting Node 0 Processor 10 APIC 0x9
[24391.502002] CPU10 is up
[24391.502132] smpboot: Booting Node 0 Processor 11 APIC 0xb
[24391.502858] CPU11 is up
[24391.506055] ACPI: Waking up from system sleep state S3
[24391.651059] acpi LNXPOWER:03: Turning ON
[24391.653119] ACPI: EC: interrupt unblocked
[24392.905149] ACPI: EC: event unblocked
[24392.906429] sd 4:0:0:0: [sda] Starting disk
[24393.213478] usb 1-11: reset high-speed USB device number 2 using xhci_hcd
[24393.374486] restoring control 00000000-0000-0000-0000-000000000101/10/5
[24393.374489] restoring control 00000000-0000-0000-0000-000000000101/12/11
[24393.376772] acpi LNXPOWER:0b: Turning OFF
[24393.377168] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[24393.378067] acpi LNXPOWER:04: Turning OFF
[24393.379204] OOM killer enabled.
[24393.379205] Restarting tasks ... done.
[24393.408847] PM: suspend exit
[24394.596689] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[24394.600189] ata5.00: configured for UDMA/133
[24394.615241] audit: type=1131 audit(1626355361.126:148): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24395.195761] audit: type=1130 audit(1626355361.706:149): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24395.195764] audit: type=1131 audit(1626355361.706:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24395.226812] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[24395.416704] r8169 0000:02:00.0 enp2s0: Link is Down
[24401.862740] Generic FE-GE Realtek PHY r8169-200:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[24401.862762] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[24401.862785] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[24402.200008] audit: type=1130 audit(1626355368.713:151): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24412.619547] audit: type=1131 audit(1626355379.130:152): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24415.377872] audit: type=1100 audit(1626355381.890:153): pid=54705 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="terabyte" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[24642.902439] r8169 0000:02:00.0 enp2s0: Link is Down
[24649.807406] audit: type=1130 audit(1626355616.320:154): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[24654.553139] Generic FE-GE Realtek PHY r8169-200:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[24654.553146] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[24659.615870] audit: type=1131 audit(1626355626.130:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25670.105517] audit: type=1100 audit(1626356636.624:156): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[25670.137509] audit: type=1101 audit(1626356636.654:157): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[25670.138082] audit: type=1110 audit(1626356636.654:158): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[25670.144445] audit: type=1105 audit(1626356636.661:159): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[25670.249533] audit: type=1106 audit(1626356636.767:160): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[25670.249743] audit: type=1104 audit(1626356636.767:161): pid=56960 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[28440.319691] input: Rockerz 550 (AVRCP) as /devices/virtual/input/input20
[29727.351993] audit: type=1130 audit(1626360693.927:162): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29728.040321] r8169 0000:02:00.0 enp2s0: Link is Down
[29729.923207] PM: suspend entry (deep)
[29730.495117] Filesystems sync: 0.571 seconds
[29733.721533] Bluetooth: hci0: Timed out waiting for suspend events
[29733.721610] Bluetooth: hci0: Suspend timeout bit: 6
[29733.721681] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[29733.721744] Freezing user space processes ... (elapsed 0.004 seconds) done.
[29733.726076] OOM killer disabled.
[29733.726077] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[29733.728015] printk: Suspending console(s) (use no_console_suspend to debug)
[29733.744534] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[29733.779434] sd 4:0:0:0: [sda] Stopping disk
[29734.415680] ACPI: EC: interrupt blocked
[29734.624020] ACPI: Preparing to enter system sleep state S3
[29734.627225] ACPI: EC: event blocked
[29734.627227] ACPI: EC: EC stopped
[29734.627228] PM: Saving platform NVS memory
[29734.627247] Disabling non-boot CPUs ...
[29734.629396] smpboot: CPU 1 is now offline
[29734.632809] smpboot: CPU 2 is now offline
[29734.636328] smpboot: CPU 3 is now offline
[29734.639697] smpboot: CPU 4 is now offline
[29734.643010] smpboot: CPU 5 is now offline
[29734.646446] smpboot: CPU 6 is now offline
[29734.648957] smpboot: CPU 7 is now offline
[29734.650636] smpboot: CPU 8 is now offline
[29734.652297] smpboot: CPU 9 is now offline
[29734.653882] smpboot: CPU 10 is now offline
[29734.655495] smpboot: CPU 11 is now offline
[29734.659602] ACPI: Low-level resume complete
[29734.659713] ACPI: EC: EC started
[29734.659714] PM: Restoring platform NVS memory
[29734.662446] Enabling non-boot CPUs ...
[29734.662773] x86: Booting SMP configuration:
[29734.662774] smpboot: Booting Node 0 Processor 1 APIC 0x2
[29734.665507] CPU1 is up
[29734.665663] smpboot: Booting Node 0 Processor 2 APIC 0x4
[29734.667499] CPU2 is up
[29734.667649] smpboot: Booting Node 0 Processor 3 APIC 0x6
[29734.669500] CPU3 is up
[29734.669650] smpboot: Booting Node 0 Processor 4 APIC 0x8
[29734.671507] CPU4 is up
[29734.671655] smpboot: Booting Node 0 Processor 5 APIC 0xa
[29734.673520] CPU5 is up
[29734.673669] smpboot: Booting Node 0 Processor 6 APIC 0x1
[29734.674470] CPU6 is up
[29734.674604] smpboot: Booting Node 0 Processor 7 APIC 0x3
[29734.675284] CPU7 is up
[29734.675414] smpboot: Booting Node 0 Processor 8 APIC 0x5
[29734.676122] CPU8 is up
[29734.676251] smpboot: Booting Node 0 Processor 9 APIC 0x7
[29734.676957] CPU9 is up
[29734.677087] smpboot: Booting Node 0 Processor 10 APIC 0x9
[29734.677799] CPU10 is up
[29734.677928] smpboot: Booting Node 0 Processor 11 APIC 0xb
[29734.678663] CPU11 is up
[29734.681869] ACPI: Waking up from system sleep state S3
[29734.830326] acpi LNXPOWER:03: Turning ON
[29734.832476] ACPI: EC: interrupt unblocked
[29736.101138] ACPI: EC: event unblocked
[29736.103123] sd 4:0:0:0: [sda] Starting disk
[29736.409575] usb 1-11: reset high-speed USB device number 2 using xhci_hcd
[29736.570478] restoring control 00000000-0000-0000-0000-000000000101/10/5
[29736.570482] restoring control 00000000-0000-0000-0000-000000000101/12/11
[29736.572750] acpi LNXPOWER:0b: Turning OFF
[29736.573222] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[29736.574041] acpi LNXPOWER:04: Turning OFF
[29736.575180] OOM killer enabled.
[29736.575182] Restarting tasks ... done.
[29736.608462] PM: suspend exit
[29737.558476] audit: type=1131 audit(1626366890.893:163): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29737.799482] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[29737.801381] ata5.00: configured for UDMA/133
[29739.097972] audit: type=1130 audit(1626366892.433:164): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29739.097975] audit: type=1131 audit(1626366892.433:165): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29739.126199] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[29739.322997] r8169 0000:02:00.0 enp2s0: Link is Down
[29743.226009] audit: type=1100 audit(1626366896.559:166): pid=63214 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="terabyte" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
[29744.507677] wlo1: authenticate with 5c:f9:fd:8b:f5:8d
[29744.509576] wlo1: send auth to 5c:f9:fd:8b:f5:8d (try 1/3)
[29744.625318] wlo1: authenticated
[29744.629911] wlo1: associate with 5c:f9:fd:8b:f5:8d (try 1/3)
[29744.631722] wlo1: RX AssocResp from 5c:f9:fd:8b:f5:8d (capab=0x911 status=0 aid=1)
[29744.635006] wlo1: associated
[29744.635087] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:f9:fd:8b:f5:8d
[29744.891267] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[29745.684604] audit: type=1130 audit(1626366899.019:167): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29750.655750] audit: type=1100 audit(1626366903.988:168): pid=63261 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="terabyte" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[29755.565601] audit: type=1131 audit(1626366908.898:169): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30126.638296] input: Rockerz 550 (AVRCP) as /devices/virtual/input/input21
[30869.683991] audit: type=1130 audit(1626368023.558:170): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30869.804819] wlo1: deauthenticating from 5c:f9:fd:8b:f5:8d by local choice (Reason: 3=DEAUTH_LEAVING)
[30872.077874] PM: suspend entry (deep)
[30872.285679] Filesystems sync: 0.207 seconds
[30874.956560] Bluetooth: hci0: Timed out waiting for suspend events
[30874.956638] Bluetooth: hci0: Suspend timeout bit: 6
[30874.956710] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[30874.956772] Freezing user space processes ... (elapsed 0.004 seconds) done.
[30874.961037] OOM killer disabled.
[30874.961039] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[30874.962834] printk: Suspending console(s) (use no_console_suspend to debug)
[30874.989823] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[30875.003026] sd 4:0:0:0: [sda] Stopping disk
[30875.420979] ACPI: EC: interrupt blocked
[30875.628996] ACPI: Preparing to enter system sleep state S3
[30875.632195] ACPI: EC: event blocked
[30875.632196] ACPI: EC: EC stopped
[30875.632198] PM: Saving platform NVS memory
[30875.632217] Disabling non-boot CPUs ...
[30875.634677] smpboot: CPU 1 is now offline
[30875.636713] smpboot: CPU 2 is now offline
[30875.638741] smpboot: CPU 3 is now offline
[30875.640732] smpboot: CPU 4 is now offline
[30875.642810] smpboot: CPU 5 is now offline
[30875.645328] smpboot: CPU 6 is now offline
[30875.647401] smpboot: CPU 7 is now offline
[30875.649378] smpboot: CPU 8 is now offline
[30875.651401] smpboot: CPU 9 is now offline
[30875.653393] smpboot: CPU 10 is now offline
[30875.655395] smpboot: CPU 11 is now offline
[30875.659967] ACPI: Low-level resume complete
[30875.660079] ACPI: EC: EC started
[30875.660080] PM: Restoring platform NVS memory
[30875.662990] Enabling non-boot CPUs ...
[30875.663188] x86: Booting SMP configuration:
[30875.663189] smpboot: Booting Node 0 Processor 1 APIC 0x2
[30875.665928] CPU1 is up
[30875.666134] smpboot: Booting Node 0 Processor 2 APIC 0x4
[30875.668731] CPU2 is up
[30875.668935] smpboot: Booting Node 0 Processor 3 APIC 0x6
[30875.671550] CPU3 is up
[30875.671751] smpboot: Booting Node 0 Processor 4 APIC 0x8
[30875.674380] CPU4 is up
[30875.674598] smpboot: Booting Node 0 Processor 5 APIC 0xa
[30875.677241] CPU5 is up
[30875.677438] smpboot: Booting Node 0 Processor 6 APIC 0x1
[30875.678579] CPU6 is up
[30875.678782] smpboot: Booting Node 0 Processor 7 APIC 0x3
[30875.679693] CPU7 is up
[30875.679875] smpboot: Booting Node 0 Processor 8 APIC 0x5
[30875.680796] CPU8 is up
[30875.680967] smpboot: Booting Node 0 Processor 9 APIC 0x7
[30875.681915] CPU9 is up
[30875.682089] smpboot: Booting Node 0 Processor 10 APIC 0x9
[30875.683075] CPU10 is up
[30875.683249] smpboot: Booting Node 0 Processor 11 APIC 0xb
[30875.684221] CPU11 is up
[30875.688302] ACPI: Waking up from system sleep state S3
[30875.835614] acpi LNXPOWER:03: Turning ON
[30875.837701] ACPI: EC: interrupt unblocked
[30877.096879] ACPI: EC: event unblocked
[30877.098727] sd 4:0:0:0: [sda] Starting disk
[30877.401550] usb 1-11: reset high-speed USB device number 2 using xhci_hcd
[30877.562451] restoring control 00000000-0000-0000-0000-000000000101/10/5
[30877.562455] restoring control 00000000-0000-0000-0000-000000000101/12/11
[30877.564814] acpi LNXPOWER:0b: Turning OFF
[30877.565162] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[30877.566149] acpi LNXPOWER:04: Turning OFF
[30877.567285] OOM killer enabled.
[30877.567287] Restarting tasks ... done.
[30877.596317] PM: suspend exit
[30878.774824] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[30878.781567] ata5.00: configured for UDMA/133
[30879.672418] audit: type=1131 audit(1626371327.009:171): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30879.751777] audit: type=1130 audit(1626371327.089:172): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30879.751780] audit: type=1131 audit(1626371327.089:173): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30879.784876] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[30879.974996] r8169 0000:02:00.0 enp2s0: Link is Down
[30884.470282] wlo1: authenticate with 5c:f9:fd:8b:f5:8d
[30884.472101] wlo1: send auth to 5c:f9:fd:8b:f5:8d (try 1/3)
[30884.623272] wlo1: authenticated
[30884.625325] wlo1: associate with 5c:f9:fd:8b:f5:8d (try 1/3)
[30884.627663] wlo1: RX AssocResp from 5c:f9:fd:8b:f5:8d (capab=0x911 status=0 aid=1)
[30884.631207] wlo1: associated
[30884.631277] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:f9:fd:8b:f5:8d
[30884.749753] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[30885.041242] audit: type=1130 audit(1626371332.375:174): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30893.579392] audit: type=1100 audit(1626371340.915:175): pid=65247 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="terabyte" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[30895.684288] audit: type=1131 audit(1626371343.018:176): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32034.787500] audit: type=1100 audit(1626372482.912:177): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.788757] audit: type=1101 audit(1626372482.912:178): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.788976] audit: type=1110 audit(1626372482.915:179): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.790883] audit: type=1105 audit(1626372482.915:180): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.954740] audit: type=1100 audit(1626372483.079:181): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.954819] audit: type=1101 audit(1626372483.079:182): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.955269] audit: type=1103 audit(1626372483.079:183): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32034.955329] audit: type=1105 audit(1626372483.079:184): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32059.829135] audit: type=1106 audit(1626372507.956:185): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32059.829145] audit: type=1104 audit(1626372507.956:186): pid=66718 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32059.831073] audit: type=1106 audit(1626372507.956:187): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32059.831288] audit: type=1104 audit(1626372507.956:188): pid=66717 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
[32175.968616] audit: type=1100 audit(1626372624.093:189): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32175.971971] audit: type=1101 audit(1626372624.097:190): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32175.972785] audit: type=1110 audit(1626372624.097:191): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32175.979202] audit: type=1105 audit(1626372624.103:192): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32175.982402] audit: type=1106 audit(1626372624.107:193): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32175.982547] audit: type=1104 audit(1626372624.107:194): pid=67172 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32186.026051] audit: type=1101 audit(1626372634.150:195): pid=67185 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32186.026233] audit: type=1110 audit(1626372634.150:196): pid=67185 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32186.028121] audit: type=1105 audit(1626372634.153:197): pid=67185 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32186.029389] audit: type=1106 audit(1626372634.153:198): pid=67185 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32186.029459] audit: type=1104 audit(1626372634.153:199): pid=67185 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32200.139771] audit: type=1101 audit(1626372648.263:200): pid=67204 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32200.140312] audit: type=1110 audit(1626372648.263:201): pid=67204 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32200.146287] audit: type=1105 audit(1626372648.270:202): pid=67204 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32200.148826] audit: type=1106 audit(1626372648.273:203): pid=67204 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32200.148968] audit: type=1104 audit(1626372648.273:204): pid=67204 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.658075] audit: type=1100 audit(1626372701.783:205): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.659498] audit: type=1101 audit(1626372701.783:206): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.659697] audit: type=1110 audit(1626372701.783:207): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.661662] audit: type=1105 audit(1626372701.786:208): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.730543] audit: type=1106 audit(1626372701.853:209): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32253.730649] audit: type=1104 audit(1626372701.853:210): pid=67861 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32259.083651] input: Rockerz 550 (AVRCP) as /devices/virtual/input/input22
[32957.589953] audit: type=1100 audit(1626373405.703:211): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32957.591360] audit: type=1101 audit(1626373405.707:212): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32957.591574] audit: type=1110 audit(1626373405.707:213): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32957.593895] audit: type=1105 audit(1626373405.707:214): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32957.731606] audit: type=1106 audit(1626373405.847:215): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32957.731707] audit: type=1104 audit(1626373405.847:216): pid=69119 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32961.563877] audit: type=1101 audit(1626373409.677:217): pid=69128 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32961.564072] audit: type=1110 audit(1626373409.680:218): pid=69128 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32961.566005] audit: type=1105 audit(1626373409.680:219): pid=69128 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32961.567925] audit: type=1106 audit(1626373409.683:220): pid=69128 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32969.394380] kauditd_printk_skb: 1 callbacks suppressed
[32969.394382] audit: type=1101 audit(1626373417.510:222): pid=69147 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32969.394576] audit: type=1110 audit(1626373417.510:223): pid=69147 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32969.396417] audit: type=1105 audit(1626373417.510:224): pid=69147 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32969.397990] audit: type=1106 audit(1626373417.513:225): pid=69147 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32969.398059] audit: type=1104 audit(1626373417.513:226): pid=69147 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32983.197042] audit: type=1101 audit(1626373431.314:227): pid=69158 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32983.197235] audit: type=1110 audit(1626373431.314:228): pid=69158 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32983.199112] audit: type=1105 audit(1626373431.314:229): pid=69158 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32998.567460] audit: type=1106 audit(1626373446.684:230): pid=69158 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[32998.567669] audit: type=1104 audit(1626373446.684:231): pid=69158 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33001.097059] audit: type=1101 audit(1626373449.214:232): pid=69180 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33001.097609] audit: type=1110 audit(1626373449.214:233): pid=69180 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33001.103749] audit: type=1105 audit(1626373449.221:234): pid=69180 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33001.123465] audit: type=1106 audit(1626373449.241:235): pid=69180 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33001.123529] audit: type=1104 audit(1626373449.241:236): pid=69180 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33011.978487] audit: type=1101 audit(1626373460.094:237): pid=69190 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="terabyte" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33011.978668] audit: type=1110 audit(1626373460.094:238): pid=69190 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[33011.980580] audit: type=1105 audit(1626373460.098:239): pid=69190 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
