After update, videos start lagging (losing frames) and any keyboard input (in terminal, browser, etc.) starts having delay (I write some bunch of symbols, and they show up after a while)
I looked with btop on my system and found nothing suspicious. CPU and memory usage are within a norm (like CPU — 5%, Memory — 10-20%)
I use kernel 6.11.10-2, GNOME/Wayland.
CPU: Ryzen 7 8845 HS
RAM: 16 GB
If any else information about my system is needed to solve my problem — write me please
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Please provide system information according to forum requirements in the links listed (above). Output of the following command may be useful for those wishing to help:
I tried Linux 6.6.63-1-MANJARO. Installed through “Manjaro Settings Manager” and run with advanced options for Manjaro when GRUB had started (Tried both options for kernel that there was)
