cyril
17 July 2024 00:11
1
Hi there,
First of all, I would like to start of by saying that I love the KDE desktop and Manjaro OS. It was one of the first Linux operating systems and I found myself coming back to it after trying Mint with Cinnamon for an extended period of time.
Unfortunately, I have found that my desktop experience is extremely laggy. My specs are as follows:
CPU: Ryzen 5 3800x
GPU: RTX 3080
RAM: 48GB
Kernel: 6.6 (problem existed with 6.1 too)
The issue I find is that no matter what application, there seem to be an intermittent âfpsâ drop when dragging windows, loading windows, typing and watching videos on YouTube (there are more cases where this happens, but these are the main problems I face). I have not timed it accurately, however, it seems that this fps drop occurs about every 3 seconds when moving a window in a circle. It also seems as though the lag becomes more pronounced when there are more windows open.
I have auto-installed proprietary drivers through the Manjaro Settings Manager. The output of nvidia-smi
| NVIDIA-SMI 550.100 Driver Version: 550.100 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3080 Off | 00000000:09:00.0 On | N/A |
| 0% 48C P3 107W / 340W | 2517MiB / 10240MiB | 3% Default |
| | | N/A |
The command lsmod | grep nouveau
yields nothing.
My friend using Kubuntu with KDE is experiencing similar issues, using an intel processor with 3080.
Thank you in advance for any help,
Cheers
BG405
17 July 2024 00:23
2
Hello and welcome to the Manjaro community!
First I would suggest posting the output of inxi -zv8
to reveal more detailed information about your system, in order for people to help.
By the initial details youâve provided, your system looks to have enough resources and then some (compared to mine) and I experience no such lag. Your inxi report will let us know, for example, if youâre on x11 or Wayland, etc. plus other important stuff.
Cheers!
cyril
17 July 2024 01:12
3
Thanks for responding so quickly. One thing that may be different to a lot of other users is that I have 3x 1440p displays connected.
Here is the output of inxi -zv8
Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f860e074-580d-4d54-a981-b6294261ab25 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASRock model: X570M Pro4 serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P2.60
date: 04/06/2020
System RAM: total: 48 GiB available: 46.98 GiB used: 8.41 GiB (17.9%)
Array-1: capacity: 128 GiB slots: 4 modules: 3 EC: None
(unregistered) size: 16 GiB speed: 2667 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: A-DATA Technology part-no: DDR4 3600 serial: <filter>
manufacturer: A-DATA Technology part-no: AX4U320016G16A-BWHD3
serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
serial: <filter>
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2496 high: 4542 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2022
3: 2057 4: 2200 5: 2200 6: 2200 7: 4542 8: 2057 9: 3693 10: 2200 11: 2048
12: 2022 13: 2200 14: 2200 15: 3900 16: 2200 bogomips: 124851
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Micro-Star MSI
driver: nvidia v: 550.100 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:2206 class-ID: 0300
Device-2: USB FHD Camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 27c2:0530
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 4000x2880 s-dpi: 110 s-size: 925x666mm (36.42x26.22")
s-diag: 1140mm (44.87")
Monitor-1: DP-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: middle-l res: 1440x2560 hz: 60 dpi: 109
size: 336x597mm (13.23x23.5") diag: 685mm (26.97") modes: N/A
Monitor-3: DP-4 pos: bottom-r res: 2560x1440 dpi: 109
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.100
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 550.100 device-ID: 10de:2206
surfaces: xcb,xlib
-- omitted --
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 953.87 GiB used: 330.42 GiB (34.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 32B3T8EA temp: 40.9 C
scheme: MBR
ID-1: / raw-size: 684.88 GiB size: 673.06 GiB (98.27%)
used: 330.42 GiB (49.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: f860e074-580d-4d54-a981-b6294261ab25
ID-1: swap-1 type: file size: 512 MiB used: 511.8 MiB (100.0%)
priority: -2 file: /swapfile
-- omitted --
System Temperatures: cpu: 49.9 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1656 pm: pacman pkgs: 1646 libs: 420 tools: pamac,yay pm: flatpak
pkgs: 10
1: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 392
1: cpu: 81.4% command: rust-analyzer pid: 3045 mem: 2124.4 MiB (4.4%)
2: cpu: 54.8% command: firefox pid: 4919 mem: 761.7 MiB (1.5%)
3: cpu: 26.8% command: code pid: 2792 mem: 497.6 MiB (1.0%)
4: cpu: 20.2% command: firefox pid: 5167 mem: 361.6 MiB (0.7%)
5: cpu: 20.1% command: rust-analyzer-proc-macro-srv pid: 3349
mem: 119.3 MiB (0.2%)
Memory top: 5 of 392
1: mem: 2124.4 MiB (4.4%) command: rust-analyzer pid: 3045 cpu: 81.4%
2: mem: 761.7 MiB (1.5%) command: firefox pid: 4919 cpu: 54.8%
3: mem: 650.1 MiB (1.3%) command: plasmashell pid: 906 cpu: 2.8%
4: mem: 497.6 MiB (1.0%) command: code pid: 2792 cpu: 26.8%
5: mem: 434.5 MiB (0.9%) command: firefox pid: 3486 cpu: 14.4%
Processes: 392 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.78 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.35
BG405
17 July 2024 01:22
4
Thanks! Iâd give a Wayland session a try (you can always change it back via the sddm login screen). Nvidia support has (apparently) improved somewhat recently, so hopefully this will help.
cyril
17 July 2024 02:12
5
You just made my day. Thank you!
For those with the same issue, I made sure plasma-workspace
was installed (this replaced plasma-wayland-session
After logging in with wayland, I got a black screen with cursor . Creating the file /etc/modprobe.d/nvidia.conf
with contents:
options nvidia_drm modeset=1
options nvidia_drm fbdev=1
and rebooting fixed the issue.
BG405
17 July 2024 02:18
6
Thanks for adding the extra details re. nvidia.conf! That likely will help others.
Cheers!
cscs
17 July 2024 02:37
7
is not in the repos at all.
This indicates you were somehow not up to date and/or performed a partial-upgrade, etc.
Make sure to be fully in sync and up to date. Iâll throw in a mirror rank as well;
sudo pacman-mirrors --continent && sudo pacman -Syu
PS.
Why legacy?
In any case I might mention your BIOS has updates that address performance, compatibility, and security.
BG405
17 July 2024 02:42
8
Indeed re. the mirrors. I changed mine for yesterdayâs update because I couldnât be bothered to wait all day for the UK ones to sync (with the major Plasma6 update, they were only up for an hour all day! Just long enough for some of us to grab the packages!). Nice to be one of the âearly birdsâ for a change.
cscs:
Why legacy?
Why not Legacy? There is nothing wrong with legacy. UEFI is a downgrade in relation to Security.
BG405
17 July 2024 03:38
10
Iâm running this system on legacy. I considered switching to EFI boot but have decided not to bother for the time being (disk is already GPT with the needed partitions).
cscs
17 July 2024 03:40
11
Disagree a few ways.
Not least of which is that legacy generally should be on MBR whereas UEFI should be on GPT.
If anything legacy invites possible hardware hiccups that would not otherwise exist as well as complicates the boot process unnecessarily.
EFI will also generally bequeath marginally quicker boot times.
I wont get into the largely misunderstood discussion on âsecure bootâ.
But suffice it so say that a self-managed mechanism of keys would certainly be more secure than ⊠nothing. Which is what legacy would provide.
Oh lets also not forget issues of size. Anyone with a 2TB+ drive will need to be on EFI. and so on.
I think the biggest reason to switch to UEFI is that some newer GPU Models wonât give you a Post-Screen (Bootscreen), because the GPU Vendors want to force us in UEFI⊠for a shady reason (i assume).
My 4TB HDD (GPT) (non-boot) has no problem. So that 2TB+ handicap is only in relation to boot, same with Nvme Boot, wonât work under legacy⊠but im a gamer and i use Nvme for gaming.
Legacy gives great security, because OS and Bios are complettly separated.
No OS Tool, can do shady things on my Bios per mistake (as AMD did in the past with their Driverâs) or a Virus that can change Voltage settings (just for fun of the attacker, to destroy someone otherâs PCâs).
No Virus can hide in EFI, some with Rootkits from shady gaming companys.
BG405
17 July 2024 03:46
13
Surely you mean GPT?
This reminds me of partitioning 10GB hard drives on a separate (newer) system with an 8.4GB (?) primary partition, so the BIOS could boot from the thing. Or similar with that 33GB limit on the new 40GB hard drives.
cscs
17 July 2024 03:51
14
Kobold:
So rootkits didnt exist before EFI?
And they cant do things to, ex, the MBR?
We must be talking about different ârootkitsâ.
A kernel-mode rootkit variant called a bootkit can infect startup code like the Master Boot Record (MBR), Volume Boot Record (VBR), or boot sector, and in this way can be used to attack full disk encryption systems.
An example of such an attack on disk encryption is the "evil maid attack", in which an attacker installs a bootkit on an unattended computer. The envisioned scenario is a maid sneaking into the hotel room where the victims left their hardware. The bootkit replaces the legitima
(Fun fact, me and all my friendâs had the CiH Virus around 1998 which deleted all our Bioses)
So no thatâs not what i meant, they can just hide better in EFI.
And Low Level Anti-Cheat for gaming are often requires UEFI, who doensât want a hidden rootkit on his PC which collects all possible data with Ring0 system access and have full control of the consumerâs PC?
Some people would see Legacy as old/bad only because it doesnât support the newest shady features⊠not everything around UEFI is a upgrade.
BG405
17 July 2024 03:55
16
That sort of thing was the only virus Iâve ever had, and I got it from an internet cafĂ© in Nairobi. Guessing that was a âbootkitâ?
When I got home, I got the stuff I needed off said disk, then forgot to eject the thing. Next time I rebooted, ahem ⊠gotcha.
Easily fixed, though; in my case fixboot, fixmbr was all that was needed, thankfully.
I wouldnât want to think about the much more advanced nasties out there, however. Better to be safe than sorry.
Dang, thatâs the power of Legacy⊠with EFI you had a bigger problem.
system
Closed
20 July 2024 04:02
18
