Hi there everyone, recently ever since I started using the Cinnamon spin of Manjaro on my main desktop, immediately one problem I’ve instantly noticed is resizing windows can be extremely laggy especially on applications such as Firefox while tabbed onto a Youtube video page. Other sites such as Twitter can make the system freeze up for a split second as I scroll through my feed as well. Everything else however like games seem to have no issues, it’s specifically window resizing that causes this lag
I’ve tried other various Cinnamon spins like Garuda’s take on the DE that doesn’t have this laggy window resizing problem, albeit it has a couple of its own little quirks. I’ve tried various kernels, refresh rates, etc and I seemingly haven’t found what’s causing this problem. There is also a couple of smaller faults like highlighting a category in my menu can cause the highlight graphic to jitter and stutter, specifically when watching a Twitch stream, as well as my bluetooth and pamac notifications have their dialogue boxes go beneath the screen when hovering over them.
Definitely a little stumped here and not quite sure what else I can do on my own.
Kernel: 5.19.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Cinnamon v: 5.4.12 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Tactus product: Custom v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX X570-E GAMING WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4101
date: 09/10/2021
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse charge: 100% (should be ignored) status: discharging
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
rev: 2 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Speed (MHz): avg: 2624 high: 3900 min/max: 2200/5218 boost: disabled
cores: 1: 3900 2: 3900 3: 2200 4: 2200 5: 2200 6: 2200 7: 3900 8: 3900
9: 2200 10: 3898 11: 2200 12: 2200 13: 2200 14: 2200 15: 2200 16: 2200
17: 2200 18: 3900 19: 2200 20: 2200 21: 2200 22: 2200 23: 2200 24: 2200
bogomips: 187263
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 bus-ID: 0c:00.0
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 2560x1440
OpenGL: renderer: AMD Radeon RX 6800 XT (sienna_cichlid LLVM 14.0.6 DRM
3.47 5.19.16-2-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-4:2
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4
Device-3: RODE Microphones NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Creative Pebble V3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2
Sound API: ALSA v: k5.19.16-2-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel
bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-6:4
Local Storage: total: 8.2 TiB used: 3.43 TiB (41.9%)
ID-1: /dev/nvme0n1 vendor: Seagate model: FireCuda 530 ZP1000GM30013
size: 931.51 GiB temp: 42.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 870 QVO 2TB size: 1.82 TiB
ID-3: /dev/sdb vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-4: /dev/sdc vendor: Seagate model: ST4000NE001-2MA101 size: 3.64 TiB
ID-5: /dev/sdd type: USB vendor: SanDisk model: USB 3.2Gen1
ID-1: / size: 915.53 GiB used: 57.29 GiB (6.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 39.0 C mobo: 33.0 C gpu: amdgpu temp: 68.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 447 Uptime: 11m Memory: 62.71 GiB used: 4.9 GiB (7.8%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1351
Shell: Bash v: 5.1.16 inxi: 3.3.22
