Hello there,
I’m running KDE Plasma on Manjaro (stable) on my Surface Laptop 3. Out of the box drivers, (I would think it should be fine considering the hardware is Intel).
Here is the INXI command, if it helps.
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=da2f461e-7834-4a0c-92cc-23a815fb50bf rw quiet
resume=UUID=579177a4-b51d-4600-961f-b35d60f671c1 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Microsoft product: Surface Laptop 3
v: 124I:00036T:000M:0300000D:0B:07F:1C:05P:48S:01E:0Y:0K:0U:02
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Microsoft model: Surface Laptop 3 serial: <superuser required>
UEFI: Microsoft v: 15.11.140 date: 07/08/2022
ID-1: BAT1 charge: 36.0 Wh (100.0%) condition: 36.0/45.8 Wh (78.6%)
volts: 8.4 min: 7.6 model: SMP M1087273 type: Li-ion serial: <filter>
status: full cycles: 664
RAM: total: 15.22 GiB used: 4.3 GiB (28.2%)
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 3183 high: 3412 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3177 2: 3258 3: 3196
4: 3412 5: 3284 6: 3120 7: 2978 8: 3040 bogomips: 23968
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Iris Plus Graphics G7 vendor: Microsoft driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: DP-1,eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:8a52 class-ID: 0300
Device-2: Microsoft Surface Camera Front type: USB driver: uvcvideo
bus-ID: 3-6:5 chip-ID: 045e:0990 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 4176x1504 s-dpi: 96 s-size: 1104x397mm (43.46x15.63")
s-diag: 1173mm (46.19")
Monitor-1: DP-1 pos: primary,left model: Samsung S24E450 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: right model: Sharp LQ135P1JX51 serial: <filter>
built: 2019 res: 2256x1504 hz: 60 dpi: 201 gamma: 1.2
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2256x1504
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Iris Plus Graphics
(ICL GT2) direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_icl bus-ID: 3-2.3:6 bus-ID: 00:1f.3
chip-ID: 1532:0529 class-ID: 0300 chip-ID: 8086:34c8 class-ID: 0403
serial: <filter>
Device-2: Razer USA USB Sound Card type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:7
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 238.47 GiB used: 48.84 GiB (20.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS256G MEMORY size: 238.47 GiB block-size: physical: 512 B
rev: AEMS0102 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 221.43 GiB size: 216.89 GiB (97.95%)
used: 48.84 GiB (22.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: da2f461e-7834-4a0c-92cc-23a815fb50bf
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: B2A0-F90E
ID-1: swap-1 type: partition size: 16.75 GiB used: 1.2 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 579177a4-b51d-4600-961f-b35d60f671c1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: ALOGIC USB Hub - UAFUUA ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 32e8:2406 class-ID: 0900
Device-1: 3-2.1:4 info: Razer USA RC30-0315 Gaming Mouse [Basilisk X
HyperSpeed] type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:0083 class-ID: 0300
Device-2: 3-2.3:6 info: Razer USA USB Sound Card type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0529 class-ID: 0300
serial: <filter>
Device-3: 3-2.4:8 info: Razer USA Huntsman Tournament Edition
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0243 class-ID: 0300
serial: <filter>
Device-4: 3-4:3 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 2109:0103 class-ID: 1100 serial: <filter>
Device-5: 3-6:5 info: Microsoft Surface Camera Front type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-6: 3-10:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-2:2 info: ALOGIC USB Hub - UAFUUA ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 32e8:2405 class-ID: 0900
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 248 Uptime: 5h 1m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1493 libs: 464 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
When I try to run graphics-heavy applications, such as steam games (and even discord calls at times), I experience massive lag spikes for a minute or two at a time. During this time, music stutters and the entire desktop hangs and becomes unresponsive, as well as abysmal FPS on games (5-10).
At first I thought it was a memory issue, but I have 16GB of memory which is being around 50% utilized during the lag spikes, as well a a swap partition which too is being utilized, but barely. During the lag, CPU usage shoots up to 99.5%, but apart from that the other ‘vitals’ seem fine.
I have reinstalled Manjaro and used different desktop environments too, but to no avail. I’m sure my hardware is capable of running such applications, and it doesn’t seem to be a heavy load based issue (considering discord calls break too), so I think it may be something to do with drivers.
Does anyone have an idea of what’s up? I’ve looked at other forum posts, but everyone points to memory issues (which I doubt are the problem here). I’m new to the forum so I don’t know if I’ve provided enough info, but any and all help is appreciated.
Thanks.
