When did someone touched cups? My Kyocera colour laser doesn´t print colour anymore. It used to work. Switched to manjaro because ubuntu messed up printing. It still does print but only B&W even when the settings are still color…
You most likely need to rebuild the Kyocera AUR package you installed at some point to get it working. Most AUR packages need a rebuild after a system update.
I haven’t installed kyocera from AUR, I can only find a PPD file on my system.
But throwing the printer away in the printer settings and add a new one updated it.
Driver version is now drvless.ppd version 1.28.15 and in color it was on the monochrome test page from two days ago EM6026CE.PPD version 8.1309.
