KWrite does not write to txt file
My system
[hikmateustad@hikmateustad-dell]$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=fd162b4b-2899-428d-9233-5f208d174b0b ro quiet mitigations=off
  kvm.nx_huge_pages=off udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Desktop System: Dell product: Inspiron One 2320 v: 00 serial: <filter>
  Chassis: type: 13 v: PRFirestone_CKMY6_A00.SDR serial: <filter>
  Mobo: Dell model: 0XW3KG v: A02 serial: <filter> BIOS: Dell v: A10
  date: 09/17/2012
  RAM: total: 7.68 GiB used: 3.99 GiB (52.0%)
  Info: Quad Core model: Intel Core i5-2400S bits: 64 type: MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 6 MiB bogomips: 19960
  Speed: 1596 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 1596 2: 1596
  3: 1596 4: 1596
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pebs pge pln pni popcnt pse pse36 pts rdtscp rep_good sep smx ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
  vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable, SMT disabled
  Type: mds status: Vulnerable; SMT disabled
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
  usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0102
  class-ID: 0300
  Device-2: NVIDIA GF108M [GeForce GT 525M] vendor: Dell driver: nvidia
  v: 390.141 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:0df5
  class-ID: 0300
  Device-3: Chicony Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-1.4:6 chip-ID: 04f2:b2a8 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
  display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
  s-diag: 583mm (23")
  Monitor-1: HDMI-1-2 res: 1920x1080 hz: 60 dpi: 96
  size: 510x287mm (20.1x11.3") diag: 585mm (23")
  OpenGL: renderer: GeForce GT 525M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.141
  direct render: Yes
  vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
  Device-1: Intel Centrino Advanced-N 6230 [Rainbow Peak] driver: iwlwifi
  v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 8086:0091 class-ID: 0280
  vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 05:00.0
  IF: enp5s0 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
  driver: btusb v: 0.8 bus-ID: 1-1.3:5 chip-ID: 8086:0189 class-ID: e001
  Message: No LVM data was found.
  Local Storage: total: 931.51 GiB used: 112.77 GiB (12.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST31000524AS
  size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: JC4A scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRWBD CT30N rev: A201
  dev-links: cdrom
  ID-1: / raw-size: 120 GiB size: 117.62 GiB (98.01%) used: 39.22 GiB (33.3%)
  fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
  uuid: fd162b4b-2899-428d-9233-5f208d174b0b
  ID-2: /run/media/hikmateustad/32D659A6D6596ADD raw-size: 120 GiB
  size: 120 GiB (100.00%) used: 10.8 GiB (9.0%) fs: ntfs dev: /dev/sda8
  maj-min: 8:8 label: N/A uuid: 32D659A6D6596ADD
  ID-3: /run/media/hikmateustad/D85EAEC75EAE9E2E raw-size: 120 GiB
  size: 120 GiB (100.00%) used: 62.74 GiB (52.3%) fs: ntfs dev: /dev/sda11
  maj-min: 8:11 label: N/A uuid: D85EAEC75EAE9E2E
  ID-1: /dev/sda1 maj-min: 8:1 size: 39.2 MiB fs: vfat label: N/A
  uuid: 5450-4444
  ID-2: /dev/sda10 maj-min: 8:10 size: 120 GiB fs: ntfs label: N/A
  uuid: F8DA997DDA9938B8
  ID-3: /dev/sda12 maj-min: 8:12 size: 118.22 GiB fs: ntfs label: N/A
  uuid: 3056CD4456CD0C12
  ID-4: /dev/sda2 maj-min: 8:2 size: 13.25 GiB fs: ntfs label: RECOVERY
  uuid: E6CEDE74CEDE3D0D
  ID-5: /dev/sda3 maj-min: 8:3 size: 80 GiB fs: ntfs label: N/A
  uuid: 7C0A92070A91BF18
  ID-6: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
  uuid: N/A
  ID-7: /dev/sda5 maj-min: 8:5 size: 116 GiB fs: ext4 label: N/A
  uuid: fa10d535-c59a-4558-a41e-b9420d1b41cb
  ID-8: /dev/sda6 maj-min: 8:6 size: 4 GiB fs: swap label: N/A
  uuid: 90960401-17ac-4c37-bd25-0de6808d2939
  ID-9: /dev/sda9 maj-min: 8:9 size: 120 GiB fs: ntfs label: N/A
  uuid: A81A73E61A73B044
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Quanta Optical Touch Screen type: HID
  driver: hid-multitouch,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 96mA chip-ID: 0408:3008 class-ID: 0300 serial: <filter>
  Device-2: 1-1.2:4 info: Realtek RTS5139 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0139
  class-ID: ff00 serial: <filter>
  Device-3: 1-1.3:5 info: Intel Centrino Advanced-N 6230 Bluetooth adapter
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Device-4: 1-1.4:6 info: Chicony Laptop_Integrated_Webcam_HD type: Video
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.5:5 info: SiGma Micro Keyboard TRACER Gamma Ivory
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0002 class-ID: 0300
  Device-2: 2-1.6:4 info: Holtek Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 04d9:0499 class-ID: 0301
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 75 C
  Fan Speeds (RPM): cpu: 1534 gpu: nvidia fan: 100%
  Processes: 236 Uptime: 8h 46m wakeups: 0 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1336 lib: 415
  Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
Kwrite does not save a text (.txt file extension) on a Windows partition
Using dolphin file manager if I right click on the volume then I cannot create anything.
Definitely a permission issue.
What can I do to fix this?
Thank you in advance for your time.
You probably don’t have access to write to this partition – see:
@Tomek You are probably correct about the assertition that @maycne.sonahoz put forward.
I’m pretty sure I have disabled Windows Fast Boot in BIOS. However, I frequently triple boot between Windows, Pop!_OS and Manjaro and on probably one such occasion my Windows filesystem must have been left in an open state which might have caused this error.
Worked on Windows for couple of days and then switched back to Manjaro; the error has disappeared.
If ever I face this error again I will take steps as @Tomek detailed.
I’ll mark that as the answer for the time being.
Thanks @Tomek
