Hello.
After some of last updates there is one process named kworker/4:1+events and it always hits one cpu core for 100% and it won’t go down. Slows my laptop.
101 root 20 0 0 0 0 I 100,0 0,0 14:10.86 kworker/4:1-events
No idea what to do. Rebooted to older kernel (from 6.6.10-1 to 6.1.7-1) but it didn’t helped.
Let me know what you need and I’ll provide.
Edit:
So I found out it was because of eth driver module r8168 so I disabled it. But now I don’t have eth. Any ideas?
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=75b4a339-3527-4ddf-a52a-6c47b44e6130 rw
cryptdevice=UUID=aa016456-ecb8-4596-89b8-1ca0be5e009e:luks-aa016456-ecb8-4596-89b8-1ca0be5e009e
root=/dev/mapper/luks-aa016456-ecb8-4596-89b8-1ca0be5e009e
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81B0 v: Lenovo V330-14IKB
serial: <filter> Chassis: type: 10 v: Lenovo V330-14IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: 6UCN54WW(V4.09) date: 11/23/2018
ID-1: BAT1 charge: 22.4 Wh (94.1%) condition: 23.8/30.0 Wh (79.2%)
power: 3.7 W volts: 8.6 min: 7.5 model: 0x53 0x4D 0x50 0x00 0x31 0x42 0x4C
0x31 0x37 0x4D 0x32 0x50 0x42 type: Li-ion serial: <filter>
status: charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
System RAM: total: 20 GiB available: 19.28 GiB used: 2.46 GiB (12.7%)
igpu: 64 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.5
max: 1.5 width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMA851S6AFR6N-UH serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
curr: 1.2 min: 1.5 max: 1.5 width (bits): data: 64 total: 64
manufacturer: Crucial part-no: CT16G4SFD8266.C16FJ serial: <filter>
Info: model: Intel Core i5-8250U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 435 high: 681 min/max: 400/3400 base/boost: 2800/8300
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 681 6: 400 7: 400
8: 400 bogomips: 28808
sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left
model: Idek Iiyama PL2730H serial: <filter> built: 2019 res: 1920x1080
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: right model: BOE Display 0x06bb built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: n/a (root, process) tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl,pavucontrol
vendor: Lenovo driver: r8169 v: kernel modules: r8168 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:3166 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0a2a
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c010c
Device-1: luks-aa016456-ecb8-4596-89b8-1ca0be5e009e maj-min: 254:0
type: LUKS dm: dm-0 size: 229.37 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 229.37 GiB
Device-2: luks-081b91bd-da78-4557-a556-59013f440aa1 maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Local Storage: total: 238.47 GiB used: 173.96 GiB (72.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS256GD9TNG-62A0A size: 238.47 GiB block-size: physical: 512 B
fw-rev: 80001E00 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 46d 9h cycles: 2,192
read-units: 17,814,714 [9.12 TB] written-units: 18,848,707 [9.65 TB]
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 173.96 GiB (77.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-aa016456-ecb8-4596-89b8-1ca0be5e009e label: N/A
uuid: 75b4a339-3527-4ddf-a52a-6c47b44e6130
used: 408 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 7F71-C007
ID-1: /dev/dm-1 maj-min: 254:1
mapped: luks-081b91bd-da78-4557-a556-59013f440aa1 size: 8.8 GiB fs: swap
label: N/A uuid: 3dbf3f42-61fb-4fca-b8ba-bf0003df75c8
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Chicony Integrated Camera (1280x720@30) type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-2: 1-6:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Device-3: 1-8:4 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:0081 class-ID: ff00 serial: <filter>
Device-4: 1-9:5 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 40.0 C pch: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 270 Uptime: 4m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 2229 libs: 570 tools: pacaur,pamac,yay pm: flatpak
pkgs: 0 Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
