Hello!
Lately I’ve been getting these micro freezes, where the system freezes for some seconds. The log shows;
Kwin_wayland[1091]: kwin_wayland_drm: The main thread was hanging temporarily!
plasmashell 6.3.6
kwin 6.3.6
Edit : since the last freeze, I rebooted, because I noticed that while I had the system up to date, I still had to reboot for the latest kernel to come in use. It is now 6.15.6-1 that is active.
inxi -Faz
Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.15-x86_64
root=UUID=056bd6a9-c464-4351-83f3-fae7ba0af99a rw rootflags=subvol=@
quiet splash resume=UUID=2fb0f355-cde7-4eb9-9259-9822d28c5af2
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.15.0
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
UEFI: American Megatrends v: 5002 date: 01/13/2025
ID-1: hidpp_battery_1 charge: 69% condition: N/A volts: 3.9 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1754 2: 1754 3: 1754
4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121611
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
Pro 5500M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1
code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 0d:00.0 chip-ID: 1002:7340 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5760x3360 display-ID: 0
Monitor-1: DP-1 pos: top-right model: LG (GoldStar) 27GN950
serial: <filter> built: 2021 res: mode: 3840x2160 hz: 144 scale: 155% (1.55)
to: 2477x1394 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 pos: bottom-l model: Idek Iiyama PLE2607WS
serial: <filter> built: 2008 res: mode: 1920x1200 hz: 60 scale: 100% (1)
dpi: 89 gamma: 1.2 size: 550x344mm (21.65x13.54") diag: 649mm (25.5")
ratio: 16:10 modes: max: 1920x1200 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
navi14 LLVM 20.1.7 DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:7340
memory: 7.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 25.1.5-arch1.1
device-ID: 1002:7340 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio vendor: ASRock
bus-ID: 0d:00.1 chip-ID: 1002:ab38 class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:11b1
class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-3.4:9 chip-ID: 045e:0745 class-ID: 0300
Local Storage: total: 8.3 TiB used: 976.19 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 48.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B1Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 247.56 GiB size: 247.56 GiB (100.00%)
used: 165.75 GiB (67.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:6
used: 616 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 3.49 TiB size: 3.44 TiB (98.40%)
used: 810.17 GiB (23.0%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
ID-4: /var/log raw-size: 247.56 GiB size: 247.56 GiB (100.00%)
ID-1: swap-1 type: partition size: 63.5 GiB used: 273.2 MiB (0.4%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:5
System Temperatures: cpu: 44.0 C mobo: 39.0 C gpu: amdgpu temp: 50.0 C
mem: 0.0 C
Fan Speeds (rpm): cpu: 783 gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 4.97 GiB (15.9%)
Processes: 451 Power: uptime: 4d 4h 15m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1436 libs: 373 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 20.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
Mod edit:- Title made more search-friendly; command output placed within preformatted text box. No charge. In future please format code or command output to forum guidelines.
@mod : thank you for your edition. I’ll try to remember that.
