Hello.
When I unsuccessfully tried to install the last big update, I completely broke the system, and I finally broke it in chroot on a live drive. I reinstalled fresh sys with old home part (it deletes all hidden and configs from home part and replaced the root partition completely).
So In the new system with kde6, I faced the problem of intermittent graphics freezes it looks like this in journalcrl:
Jun 25 18:18:17 username xembedsniproxy[1178]: Container window visible, stack below
Jun 25 18:18:18 username kwin_x11[1110]: OpenGL vendor string: NVIDIA Corporation
Jun 25 18:18:18 username kwin_x11[1110]: OpenGL renderer string: NVIDIA GeForce GTX 680/PCIe/SSE2
Jun 25 18:18:18 username kwin_x11[1110]: OpenGL version string: 3.1.0 NVIDIA 470.256.02
Jun 25 18:18:18 username kwin_x11[1110]: OpenGL shading language version string: 1.40 NVIDIA via Cg compiler
Jun 25 18:18:18 username kwin_x11[1110]: Driver: NVIDIA
Jun 25 18:18:18 username kwin_x11[1110]: Driver version: 470.256.2
Jun 25 18:18:18 username kwin_x11[1110]: GPU class: Unknown
Jun 25 18:18:18 username kwin_x11[1110]: OpenGL version: 3.1
Jun 25 18:18:18 username kwin_x11[1110]: GLSL version: 1.40
Jun 25 18:18:18 username kwin_x11[1110]: Requires strict binding: no
Jun 25 18:18:18 username kwin_x11[1110]: Virtual Machine: no
Jun 25 18:18:18 username kwin_x11[1110]: Timer query support: yes
Jun 25 18:18:18 username kwin_x11[1110]: BlurConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: GlideConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: KscreenConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: OverviewConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: SlideConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: SlidingPopupsConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: WindowViewConfig::instance called after the first use - ignoring
Jun 25 18:18:18 username kwin_x11[1110]: ZoomConfig::instance called after the first use - ignoring
The picture itself freezes, while the sound goes on (this can be seen from the running videos). As a rule, I encounter this problem in browsers (GChrome and FireFox), but it seems to have been somewhere else…
Part of my inxi -F:
Host: username Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: N/A
Mobo: ASUSTeK model: H87-PLUS v: Rev X.0x serial: 130410807103833
UEFI: American Megatrends v: 0310 date: 04/07/2013
Info: quad core model: Intel Core i7-4770K bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 2449 min/max: 800/3900 cores: 1: 2669 2: 3449 3: 800
4: 3577 5: 3493 6: 2326 7: 1600 8: 1680
Device-1: NVIDIA GK104 [GeForce GTX 680] driver: nvidia v: 470.256.02
Display: server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: nvidia gpu: nvidia s-res: 3640x1920
API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
renderer: NVIDIA GeForce GTX 680/PCIe/SSE2
API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib
So It seems to me that this happens at those moments when the application tries to use OpenGL. Perhaps after reinstalling the system, I have some kind of misconfiguration and missing some drivers or something else…
I changed the latest 6.9 kernel to 6.6, but unfortunately it didn’t help so.
Btw when I’m typing this text catch freeze again.
So maybe I don’t see something obvious. I will be extremely grateful for your help. Using such a freezing system is a pain.
