Hi all,
I’ve recently been assigned a new laptop for work. While it has hybrid graphics, I’m sticking with the vanilla open source drivers because I don’t want to deal with the headache. Using the built-in display works just fine. However, when I connect my external display, some funkiness starts to occur.
- KDE recognizes the display and prompts me to extend it
- I do, and the new display turns black
- I can move my cursor to the display, and see it on the display
- If I drag a window fully onto the display, it “disappears”
- the window is not painted on the new display
- the window is present in the task manager
- my cursor reacts to where the window should be (i.e., it changes to resize, etc).
- Using the meta + drag gesture lets me bring the window back to my primary, working display
I can “force” the external display to update by changing its position from the Display Configuration settings panel. When I do this, I can see my wallpaper, as well as the window. However, any attempts to interact with the window don’t paint any changes.
I tried a Wayland session and it worked, but for other reasons (e.g., screen sharing, general stability) I can’t use Wayland.
Kernel: 5.18.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=88a34fd2-59b7-46f5-9296-0e6433eeb9dd rw quiet
cryptdevice=UUID=31d11fca-9aa8-4b52-bc13-1c2abdf0cb35:luks-31d11fca-9aa8-4b52-bc13-1c2abdf0cb35
root=/dev/mapper/luks-31d11fca-9aa8-4b52-bc13-1c2abdf0cb35 apparmor=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20Y6S1U200
v: ThinkPad X1 Extreme Gen 4i serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 20Y6S1U200 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: N40ET34W (1.16 )
date: 04/08/2022
ID-1: BAT0 charge: 85.5 Wh (95.7%) condition: 89.3/90.1 Wh (99.2%)
volts: 16.6 min: 15.5 model: SMP 5B11B79217 type: Li-poly serial: <filter>
status: not charging cycles: 3
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
RAM: total: 31.08 GiB used: 7.77 GiB (25.0%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x3E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1039 high: 1287 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1128 2: 1194 3: 1010
4: 998 5: 1287 6: 1112 7: 801 8: 1026 9: 1224 10: 1105 11: 801 12: 917
13: 986 14: 1206 15: 800 16: 1031 bogomips: 73744
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-06)
arch: Ampere process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-5 empty: DP-6,HDMI-A-2,eDP-2
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4.2.2.2:13 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Device-4: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 3-8:4 chip-ID: 13d3:5271 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915,nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2400 s-dpi: 96 s-size: 2032x635mm (80.00x25.00")
s-diag: 2129mm (83.82")
Monitor-1: DP-5 mapped: DP-1-5 pos: right model: Dell U3818DW
serial: <filter> built: 2021 res: 3840x1600 hz: 60 dpi: 111 gamma: 1.2
size: 880x367mm (34.65x14.45") diag: 953mm (37.5") modes: max: 3840x1600
min: 720x400
Monitor-2: eDP-1 pos: primary,left model: LG Display 0x06aa built: 2020
res: 3840x2400 hz: 60 dpi: 284 gamma: 1.2 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 3-4.2.2.2:13
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 046d:082d chip-ID: 8086:43c8 class-ID: 0102 serial: <filter>
class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-4: C-Media Henge Audio type: USB
driver: cm6533_jd,snd-usb-audio,usbhid bus-ID: 3-4.4:8 chip-ID: 0d8c:0022
class-ID: 0300
Sound Server-1: ALSA v: k5.18.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-2.1:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u2u1 state: down mac: <filter>
IF-ID-1: br-43b20090e4d5 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: global
IP v6: <filter> scope: link
Message: Output throttled. IPs: 4; Limit: 10; Override: --limit [1-x;-1 all]
IF-ID-2: br-62a6b8721e31 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1 all]
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth6f7b629 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-14:11 chip-ID: 8087:0032 class-ID: e001
Device-1: luks-31d11fca-9aa8-4b52-bc13-1c2abdf0cb35 maj-min: 254:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
Local Storage: total: 476.94 GiB used: 61.68 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512TDV
lanes: 4 type: SSD serial: <filter> rev: 3011P4LN temp: 45.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 61.68 GiB (13.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-31d11fca-9aa8-4b52-bc13-1c2abdf0cb35 label: N/A
uuid: 88a34fd2-59b7-46f5-9296-0e6433eeb9dd
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 88E0-E3DA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-2:2 info: VIA Labs USB 3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-2.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-4: 2-2.2:4 info: VIA Labs USB 3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-5: 2-2.2.2:5 info: VIA Labs USB 3.1 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 2109:0817 class-ID: 0900
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-7: 3-4:2 info: VIA Labs USB 2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-8: 3-4.2:5 info: VIA Labs USB 2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 2109:2817 class-ID: 0900
Hub-9: 3-4.2.2:10 info: VIA Labs USB 2.0 Hub ports: 4 rev: 2.1
Device-1: 3-4.2.2.2:13 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-2: 3-4.2.2.3:14 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 3-4.2.2.4:15 info: Holtek USB Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 04d9:0230 class-ID: 0301
Device-4: 3-4.2.4:12 info: Henge Docks LLC Docks Stone type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.0 speed: 12 Mb/s
power: 100mA chip-ID: 2a4e:2001 class-ID: 0300 serial: <filter>
Device-5: 3-4.4:8 info: C-Media Henge Audio type: Audio,HID
driver: cm6533_jd,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0d8c:0022 class-ID: 0300
Hub-10: 3-5:16 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0451:8442 class-ID: 0900
Device-1: 3-5.5:17 info: Texas Instruments type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0451:82ff class-ID: 0300 serial: <filter>
Device-2: 3-8:4 info: IMC Networks Integrated RGB Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-9:7 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00f9
class-ID: ff00 serial: <filter>
Device-4: 3-10:9 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 056a:52a3 class-ID: 0300
Device-5: 3-14:11 info: Intel AX210 Bluetooth type: Bluetooth
Hub-11: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3036 fan-2: 2783
Processes: 480 Uptime: 33m wakeups: 5977 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1359 pacman: 1354 lib: 344 flatpak: 5 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.19
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
KWin Support Information:
The following information should be used when requesting support on e.g. https://forum.kde.org.
It provides information about the currently running instance, which options are used,
what OpenGL driver and which effects are running.
Please post the information provided underneath this introductory text to a paste bin service
like https://paste.kde.org instead of pasting into support threads.
Version
KWin version: 5.24.6
Qt Version: 5.15.5
Qt compile version: 5.15.5
XCB compile version: 1.15
Operation Mode: X11 only
Build Options
KWIN_BUILD_DECORATIONS: yes
KWIN_BUILD_TABBOX: yes
KWIN_BUILD_ACTIVITIES: yes
HAVE_X11_XCB: yes
HAVE_EPOXY_GLX: yes
HAVE_WAYLAND_EGL: yes
X11
Vendor: The X.Org Foundation
Vendor Release: 12101003
Protocol Version/Revision: 11/0
SHAPE: yes; Version: 0x11
RANDR: yes; Version: 0x14
DAMAGE: yes; Version: 0x11
Composite: yes; Version: 0x4
RENDER: yes; Version: 0xb
XFIXES: yes; Version: 0x50
SYNC: yes; Version: 0x31
GLX: yes; Version: 0x0
Decoration
Plugin: org.kde.breeze
Theme:
Plugin recommends border size: None
Blur: 0
onAllDesktopsAvailable: true
alphaChannelSupported: true
closeOnDoubleClickOnMenu: false
decorationButtonsLeft: 0, 2
decorationButtonsRight: 6, 3, 4, 5
borderSize: 0
gridUnit: 18
font: Noto Sans,10,-1,0,50,0,0,0,0,0
smallSpacing: 4
largeSpacing: 18
Platform
Cursor
themeName: breeze_cursors
themeSize: 24
Options
focusPolicy: 0
xwaylandCrashPolicy:
xwaylandMaxCrashCount: 3
nextFocusPrefersMouse: false
clickRaise: true
autoRaise: false
autoRaiseInterval: 0
delayFocusInterval: 0
shadeHover: false
shadeHoverInterval: 250
separateScreenFocus: false
activeMouseScreen: true
placement: 6
focusPolicyIsReasonable: true
borderSnapZone: 10
windowSnapZone: 10
centerSnapZone: 0
snapOnlyWhenOverlapping: false
rollOverDesktops: true
focusStealingPreventionLevel: 1
operationTitlebarDblClick: 5000
operationMaxButtonLeftClick: 5000
operationMaxButtonMiddleClick: 5015
operationMaxButtonRightClick: 5014
commandActiveTitlebar1: 0
commandActiveTitlebar2: 1
commandActiveTitlebar3: 2
commandInactiveTitlebar1: 4
commandInactiveTitlebar2: 1
commandInactiveTitlebar3: 2
commandWindow1: 7
commandWindow2: 8
commandWindow3: 8
commandWindowWheel: 28
commandAll1: 10
commandAll2: 3
commandAll3: 14
keyCmdAllModKey: 16777251
condensedTitle: false
electricBorderMaximize: true
electricBorderTiling: true
electricBorderCornerRatio: 0.25
borderlessMaximizedWindows: false
killPingTimeout: 5000
hideUtilityWindowsForInactive: true
compositingMode: 1
useCompositing: true
hiddenPreviews: 1
glSmoothScale: 2
glStrictBinding: true
glStrictBindingFollowsDriver: true
glPreferBufferSwap: 101
glPlatformInterface: 1
windowsBlockCompositing: true
latencyPolicy:
renderTimeEstimator:
Screen Edges
desktopSwitching: false
desktopSwitchingMovingClients: false
cursorPushBackDistance: 1x1
timeThreshold: 150
reActivateThreshold: 350
actionTopLeft: 0
actionTop: 0
actionTopRight: 0
actionRight: 0
actionBottomRight: 0
actionBottom: 0
actionBottomLeft: 0
actionLeft: 0
Screens
Multi-Head: no
Active screen follows mouse: yes
Number of Screens: 2
Screen 0:
Geometry: 0,0,3840x2400
Scale: 1
Refresh Rate: 60000
Screen 1:
Geometry: 3840,0,3840x1600
Scale: 1
Refresh Rate: 59993
Compositing
Compositing is active
Compositing Type: OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics (TGL GT1)
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.1.3
OpenGL platform interface: GLX
OpenGL shading language version string: 4.60
Driver: Intel
GPU class: Tiger Lake
OpenGL version: 4.6
GLSL version: 4.60
Mesa version: 22.1.3
X server version: 1.21.1
Linux kernel version: 5.18.10
Direct rendering: Requires strict binding: yes
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
OpenGL 2 Shaders are used
Loaded Effects:
zoom
kwin4_effect_logout
kwin4_effect_sessionquit
kwin4_effect_login
slidingpopups
kwin4_effect_windowaperture
colorpicker
desktopgrid
slide
glide
screenshot
kwin4_effect_maximize
kwin4_effect_morphingpopups
kwin4_effect_frozenapp
kwin4_effect_scale
kwin4_effect_fullscreen
kwin4_effect_squash
kwin4_effect_fadingpopups
kwin4_effect_dialogparent
highlightwindow
presentwindows
blur
screenedge
startupfeedback
kscreen
Currently Active Effects:
blur
Effect Settings:
zoom:
zoomFactor: 1.2
mousePointer: 0
mouseTracking: 0
focusTrackingEnabled: false
textCaretTrackingEnabled: false
focusDelay: 350
moveFactor: 20
targetZoom: 1
kwin4_effect_logout:
pluginId: kwin4_effect_logout
isActiveFullScreenEffect: false
kwin4_effect_sessionquit:
pluginId: kwin4_effect_sessionquit
kwin4_effect_login:
pluginId: kwin4_effect_login
slidingpopups:
slideInDuration: 150
slideOutDuration: 250
kwin4_effect_windowaperture:
pluginId: kwin4_effect_windowaperture
colorpicker:
desktopgrid:
zoomDuration: 300
border: 10
desktopNameAlignment: 0
layoutMode: 0
customLayoutRows: 2
usePresentWindows: true
slide:
duration: 500
horizontalGap: 45
verticalGap: 20
slideDocks: false
slideBackground: true
glide:
duration: 160
inRotationEdge: 0
inRotationAngle: 3
inDistance: 30
inOpacity: 0.4
outRotationEdge: 2
outRotationAngle: 3
outDistance: 30
outOpacity: 0
screenshot:
kwin4_effect_maximize:
pluginId: kwin4_effect_maximize
kwin4_effect_morphingpopups:
pluginId: kwin4_effect_morphingpopups
kwin4_effect_frozenapp:
pluginId: kwin4_effect_frozenapp
kwin4_effect_scale:
pluginId: kwin4_effect_scale
kwin4_effect_fullscreen:
pluginId: kwin4_effect_fullscreen
kwin4_effect_squash:
pluginId: kwin4_effect_squash
kwin4_effect_fadingpopups:
pluginId: kwin4_effect_fadingpopups
kwin4_effect_dialogparent:
pluginId: kwin4_effect_dialogparent
highlightwindow:
presentwindows:
layoutMode: 0
showCaptions: true
showIcons: true
doNotCloseWindows: false
ignoreMinimized: false
accuracy: 20
fillGaps: true
fadeDuration: 150
showPanel: true
leftButtonWindow: 1
rightButtonWindow: 2
middleButtonWindow: 0
leftButtonDesktop: 2
middleButtonDesktop: 0
rightButtonDesktop: 0
blur:
screenedge:
startupfeedback:
type: 1
kscreen:
Loaded Plugins:
kwin5_plugin_krunner
kwin5_plugin_nightcolor
Available Plugins:
kwin5_plugin_colord
Thanks for taking the time to read this!
