Ever since I’ve updated the Nvidia drivers to 460.32.03, I’ve had frequent flicker at light desktop use, that disappears when running something GPU accelerated, like video playback through mpv, or playing games.
Something less frequent has been KWin crashing. In them, everything on-screen freezes for 10 seconds or so, while audio can keep playing normally in the background.
The current drivers seem to have issues with my 1080 Ti, according to Nvidia’s Linux forums, but I thought more eyes on my logs wouldn’t hurt.
inxi -Fxza
System: Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c28c9ba1-1ab9-48ed-a6c3-a5cf6794acea ro apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 2.80 date: 06/10/2020
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118417
Speed: 2748 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2748 2: 2113 3: 2132 4: 2056 5: 4069
6: 2631 7: 2087 8: 2388 9: 2988 10: 2058 11: 4135 12: 2155 13: 2127 14: 3088 15: 2938 16: 2171
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 26:00.0 chip ID: 10de:1b06
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5") s-diag: 692mm (27.3")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 26:00.1
chip ID: 10de:10ef
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 28:00.3 chip ID: 1022:1457
Device-3: GYROCOM C&C UAC1 DAC type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-10:2 chip ID: 1852:5110
Sound Server: ALSA v: k5.10.7-3-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: e000 bus ID: 22:00.0 chip ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth708516b state: up speed: 10000 Mbps duplex: full mac: <filter>
RAID: System supports mdraid: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active size: 744.74 GiB
Info: report: N/A blocks: 780914688 chunk size: 512k super blocks: 1.2
Components: Online:
0: sdb maj-min: 8:16 size: 186.31 GiB
1: sde maj-min: 8:64 size: 186.31 GiB
2: sdc maj-min: 8:32 size: 186.31 GiB
3: sdd maj-min: 8:48 size: 186.31 GiB
Drives: Local Storage: total: raw: 1.18 TiB usable: 1.18 TiB used: 430.11 GiB (35.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 4B6Q
ID-2: /dev/sdb maj-min: 8:16 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
serial: N/A rev: a424
ID-3: /dev/sdc maj-min: 8:32 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
ID-4: /dev/sdd maj-min: 8:48 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
ID-5: /dev/sde maj-min: 8:64 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
Partition: ID-1: / raw size: 465.26 GiB size: 456.96 GiB (98.22%) used: 189.48 GiB (41.5%) fs: ext4 dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 59.8 C mobo: 44.0 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1313 fan-3: 1037 fan-4: 702 fan-5: 900 gpu: nvidia fan: 44%
Info: Processes: 337 Uptime: 1h 13m wakeups: 0 Memory: 31.37 GiB used: 3.64 GiB (11.6%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1365 lib: 418 Shell: Zsh v: 5.8 running in: yakuake inxi: 3.2.02
Here are some logs from my previous session, where I had a KWin crash:
cat /var/log/Xorg.0.log.old
[ 83039.354] (--) Log file renamed from "/var/log/Xorg.pid-501287.log" to "/var/log/Xorg.0.log"
[ 83039.354]
X.Org X Server 1.20.10
[ 83039.354] Build Operating System: Linux Manjaro Linux
[ 83039.354] Current Operating System: Linux jp-gentoo 5.10.7-3-MANJARO #1 SMP PREEMPT Fri Jan 15 21:11:34 UTC 2021 x86_64
[ 83039.354] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=c28c9ba1-1ab9-48ed-a6c3-a5cf6794acea ro apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
[ 83039.354] Build Date: 16 December 2020 10:33:32PM
[ 83039.354]
[ 83039.354] Current version of pixman: 0.40.0
[ 83039.354] Before reporting problems, check http://wiki.x.org
[ 83039.354] Markers: (--) probed, (**) from config file, (==) default setting,
[ 83039.354] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 23 23:51:59 2021
[ 83039.355] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 83039.355] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 83039.355] (==) ServerLayout "layout"
[ 83039.355] (**) |-->Screen "Screen0" (0)
[ 83039.355] (**) | |-->Monitor "Monitor0"
[ 83039.356] (**) | |-->Device "Device0"
[ 83039.356] (==) Automatically adding devices
[ 83039.356] (==) Automatically enabling devices
[ 83039.356] (==) Automatically adding GPU devices
[ 83039.356] (==) Automatically binding GPU devices
[ 83039.356] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 83039.356] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 83039.356] Entry deleted from font path.
[ 83039.356] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 83039.356] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 83039.356] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 83039.356] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 83039.356] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 83039.356] (**) Extension "COMPOSITE" is enabled
[ 83039.356] (II) The server relies on udev to provide the list of input devices.
[ 83039.356] (II) Module ABI versions:
[ 83039.356] X.Org ANSI C Emulation: 0.4
[ 83039.356] X.Org Video Driver: 24.1
[ 83039.356] X.Org XInput driver : 24.1
[ 83039.356] X.Org Server Extension : 10.0
[ 83039.356] (++) using VT number 1
[ 83039.356] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 83039.357] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 83039.358] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 83039.358] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 83039.360] (--) PCI:*(38@0:0:0) 10de:1b06:1043:85e5 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/131072
[ 83039.360] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 83039.360] (II) LoadModule: "glx"
[ 83039.360] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 83039.361] (II) Module glx: vendor="X.Org Foundation"
[ 83039.361] compiled for 1.20.10, module version = 1.0.0
[ 83039.361] ABI class: X.Org Server Extension, version 10.0
[ 83039.361] (II) LoadModule: "nvidia"
[ 83039.361] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 83039.362] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 83039.362] compiled for 1.6.99.901, module version = 1.0.0
[ 83039.362] Module class: X.Org Video Driver
[ 83039.362] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 83039.362] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 83039.362] (II) Loading sub module "fb"
[ 83039.362] (II) LoadModule: "fb"
[ 83039.362] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 83039.362] (II) Module fb: vendor="X.Org Foundation"
[ 83039.362] compiled for 1.20.10, module version = 1.0.0
[ 83039.362] ABI class: X.Org ANSI C Emulation, version 0.4
[ 83039.362] (II) Loading sub module "wfb"
[ 83039.362] (II) LoadModule: "wfb"
[ 83039.362] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 83039.362] (II) Module wfb: vendor="X.Org Foundation"
[ 83039.362] (II) Loading sub module "ramdac"
[ 83039.362] (II) LoadModule: "ramdac"
[ 83039.362] (II) Module "ramdac" already built-in
[ 83039.363] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 83039.363] (==) NVIDIA(0): RGB weight 888
[ 83039.363] (==) NVIDIA(0): Default visual is TrueColor
[ 83039.363] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 83039.363] (**) Option "AllowNVIDIAGpuScreens"
[ 83039.363] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 83039.363] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 83039.363] (**) NVIDIA(0): Option "Coolbits" "28"
[ 83039.363] (**) NVIDIA(0): Enabling 2D acceleration
[ 83039.363] (II) Loading sub module "glxserver_nvidia"
[ 83039.363] (II) LoadModule: "glxserver_nvidia"
[ 83039.363] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 83039.368] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 83039.368] compiled for 1.6.99.901, module version = 1.0.0
[ 83039.368] Module class: X.Org Server Extension
[ 83039.368] (II) NVIDIA GLX Module 460.32.03 Sun Dec 27 18:53:34 UTC 2020
[ 83039.368] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 83039.642] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:38:0:0
[ 83039.642] (--) NVIDIA(0): DFP-0
[ 83039.642] (--) NVIDIA(0): DFP-1
[ 83039.642] (--) NVIDIA(0): DFP-2 (boot)
[ 83039.642] (--) NVIDIA(0): DFP-3
[ 83039.642] (--) NVIDIA(0): DFP-4
[ 83039.642] (--) NVIDIA(0): DFP-5
[ 83039.643] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:38:0:0
[ 83039.643] (II) NVIDIA(0): (GPU-0)
[ 83039.643] (--) NVIDIA(0): Memory: 11534336 kBytes
[ 83039.643] (--) NVIDIA(0): VideoBIOS: 86.02.39.00.22
[ 83039.643] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 83039.643] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 83039.643] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 83039.643] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 83039.643] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 83039.643] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 83039.643] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 83039.643] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): connected
[ 83039.643] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): Internal DisplayPort
[ 83039.643] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): 1440.0 MHz maximum pixel clock
[ 83039.644] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 83039.644] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 83039.644] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 83039.644] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 83039.644] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 83039.644] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 83039.645] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 83039.645] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 83039.645] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 83039.650] (==) NVIDIA(0):
[ 83039.650] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 83039.650] (==) NVIDIA(0): will be used as the requested mode.
[ 83039.650] (II) NVIDIA(0): Validated MetaModes:
[ 83039.650] (II) NVIDIA(0): "DFP-2:nvidia-auto-select"
[ 83039.650] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[ 83039.656] (--) NVIDIA(0): DPI set to (108, 107); computed from "UseEdidDpi" X config
[ 83039.656] (--) NVIDIA(0): option
[ 83039.657] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 83039.657] (II) NVIDIA: access.
[ 83039.660] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 83039.660] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 83039.660] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 83039.660] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 83039.660] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 83039.660] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 83039.660] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 83039.660] (II) NVIDIA(0): Config Options in the README.
[ 83039.686] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[ 83039.733] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 83039.733] (==) NVIDIA(0): Backing store enabled
[ 83039.733] (==) NVIDIA(0): Silken mouse disabled
[ 83039.733] (**) NVIDIA(0): DPMS enabled
[ 83039.733] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 83039.733] (II) Loading sub module "dri2"
[ 83039.733] (II) LoadModule: "dri2"
[ 83039.733] (II) Module "dri2" already built-in
[ 83039.733] (II) NVIDIA(0): [DRI2] Setup complete
[ 83039.733] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 83039.733] (II) Initializing extension Generic Event Extension
[ 83039.733] (II) Initializing extension SHAPE
[ 83039.733] (II) Initializing extension MIT-SHM
[ 83039.733] (II) Initializing extension XInputExtension
[ 83039.733] (II) Initializing extension XTEST
[ 83039.733] (II) Initializing extension BIG-REQUESTS
[ 83039.733] (II) Initializing extension SYNC
[ 83039.733] (II) Initializing extension XKEYBOARD
[ 83039.733] (II) Initializing extension XC-MISC
[ 83039.733] (II) Initializing extension SECURITY
[ 83039.733] (II) Initializing extension XFIXES
[ 83039.734] (II) Initializing extension RENDER
[ 83039.734] (II) Initializing extension RANDR
[ 83039.734] (II) Initializing extension COMPOSITE
[ 83039.734] (II) Initializing extension DAMAGE
[ 83039.734] (II) Initializing extension MIT-SCREEN-SAVER
[ 83039.734] (II) Initializing extension DOUBLE-BUFFER
[ 83039.734] (II) Initializing extension RECORD
[ 83039.734] (II) Initializing extension DPMS
[ 83039.734] (II) Initializing extension Present
[ 83039.734] (II) Initializing extension DRI3
[ 83039.734] (II) Initializing extension X-Resource
[ 83039.734] (II) Initializing extension XVideo
[ 83039.734] (II) Initializing extension XVideo-MotionCompensation
[ 83039.734] (II) Initializing extension GLX
[ 83039.734] (II) Indirect GLX disabled.
[ 83039.734] (II) GLX: Another vendor is already registered for screen 0
[ 83039.734] (II) Initializing extension XFree86-VidModeExtension
[ 83039.734] (II) Initializing extension XFree86-DGA
[ 83039.734] (II) Initializing extension XFree86-DRI
[ 83039.734] (II) Initializing extension DRI2
[ 83039.734] (II) Initializing extension NV-GLX
[ 83039.735] (II) Initializing extension NV-CONTROL
[ 83039.735] (II) Initializing extension XINERAMA
[ 83039.774] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 83039.774] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 83039.774] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 83039.774] (**) Power Button: Applying InputClass "system-keyboard"
[ 83039.774] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 83039.774] (II) LoadModule: "libinput"
[ 83039.774] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 83039.775] (II) Module libinput: vendor="X.Org Foundation"
[ 83039.775] compiled for 1.20.8, module version = 0.30.0
[ 83039.775] Module class: X.Org XInput Driver
[ 83039.775] ABI class: X.Org XInput driver, version 24.1
[ 83039.775] (II) Using input driver 'libinput' for 'Power Button'
[ 83039.775] (**) Power Button: always reports core events
[ 83039.775] (**) Option "Device" "/dev/input/event1"
[ 83039.775] (**) Option "_source" "server/udev"
[ 83039.776] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 83039.776] (II) event1 - Power Button: device is a keyboard
[ 83039.776] (II) event1 - Power Button: device removed
[ 83039.801] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 83039.801] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 83039.801] (**) Option "xkb_model" "pc105"
[ 83039.801] (**) Option "xkb_layout" "fi"
[ 83039.801] (**) Option "xkb_variant" "classic"
[ 83039.801] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83039.819] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 83039.819] (II) event1 - Power Button: device is a keyboard
[ 83039.820] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 83039.820] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 83039.820] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 83039.820] (**) Power Button: Applying InputClass "system-keyboard"
[ 83039.820] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 83039.820] (II) Using input driver 'libinput' for 'Power Button'
[ 83039.820] (**) Power Button: always reports core events
[ 83039.820] (**) Option "Device" "/dev/input/event0"
[ 83039.820] (**) Option "_source" "server/udev"
[ 83039.821] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 83039.821] (II) event0 - Power Button: device is a keyboard
[ 83039.821] (II) event0 - Power Button: device removed
[ 83039.855] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 83039.855] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 83039.855] (**) Option "xkb_model" "pc105"
[ 83039.855] (**) Option "xkb_layout" "fi"
[ 83039.855] (**) Option "xkb_variant" "classic"
[ 83039.855] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83039.856] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 83039.856] (II) event0 - Power Button: device is a keyboard
[ 83039.857] (II) config/udev: Adding input device Yoyodyne Consulting UAC1 DAC (/dev/input/event10)
[ 83039.857] (**) Yoyodyne Consulting UAC1 DAC: Applying InputClass "evdev keyboard catchall"
[ 83039.857] (**) Yoyodyne Consulting UAC1 DAC: Applying InputClass "libinput keyboard catchall"
[ 83039.857] (**) Yoyodyne Consulting UAC1 DAC: Applying InputClass "system-keyboard"
[ 83039.857] (**) Yoyodyne Consulting UAC1 DAC: Applying InputClass "Keyboard Defaults"
[ 83039.857] (II) Using input driver 'libinput' for 'Yoyodyne Consulting UAC1 DAC'
[ 83039.857] (**) Yoyodyne Consulting UAC1 DAC: always reports core events
[ 83039.857] (**) Option "Device" "/dev/input/event10"
[ 83039.857] (**) Option "_source" "server/udev"
[ 83039.858] (II) event10 - Yoyodyne Consulting UAC1 DAC: is tagged by udev as: Keyboard
[ 83039.858] (II) event10 - Yoyodyne Consulting UAC1 DAC: device is a keyboard
[ 83039.858] (II) event10 - Yoyodyne Consulting UAC1 DAC: device removed
[ 83039.935] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/0003:1852:5110.000F/input/input12/event10"
[ 83039.935] (II) XINPUT: Adding extended input device "Yoyodyne Consulting UAC1 DAC" (type: KEYBOARD, id 8)
[ 83039.935] (**) Option "xkb_model" "pc105"
[ 83039.935] (**) Option "xkb_layout" "fi"
[ 83039.935] (**) Option "xkb_variant" "classic"
[ 83039.935] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83039.936] (II) event10 - Yoyodyne Consulting UAC1 DAC: is tagged by udev as: Keyboard
[ 83039.936] (II) event10 - Yoyodyne Consulting UAC1 DAC: device is a keyboard
[ 83039.937] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 83039.937] (II) No input driver specified, ignoring this device.
[ 83039.937] (II) This device may have been added with another device file.
[ 83039.937] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[ 83039.938] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 83039.938] (II) No input driver specified, ignoring this device.
[ 83039.938] (II) This device may have been added with another device file.
[ 83039.938] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 83039.939] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event16)
[ 83039.939] (II) No input driver specified, ignoring this device.
[ 83039.939] (II) This device may have been added with another device file.
[ 83039.939] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event17)
[ 83039.939] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event18)
[ 83039.940] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/event2)
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "evdev pointer catchall"
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "evdev keyboard catchall"
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[ 83039.940] (**) Valve Software Steam Controller: Applying InputClass "Keyboard Defaults"
[ 83039.940] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[ 83039.940] (**) Valve Software Steam Controller: always reports core events
[ 83039.940] (**) Option "Device" "/dev/input/event2"
[ 83039.940] (**) Option "_source" "server/udev"
[ 83039.942] (II) event2 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[ 83039.942] (II) event2 - Valve Software Steam Controller: device is a pointer
[ 83039.942] (II) event2 - Valve Software Steam Controller: device is a keyboard
[ 83039.942] (II) event2 - Valve Software Steam Controller: device removed
[ 83040.015] (II) libinput: Valve Software Steam Controller: needs a virtual subdevice
[ 83040.015] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-2/3-2:1.0/0003:28DE:1142.0001/input/input4/event2"
[ 83040.015] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: MOUSE, id 9)
[ 83040.015] (**) Option "AccelerationScheme" "none"
[ 83040.015] (**) Valve Software Steam Controller: (accel) selected scheme none/0
[ 83040.015] (**) Valve Software Steam Controller: (accel) acceleration factor: 2.000
[ 83040.015] (**) Valve Software Steam Controller: (accel) acceleration threshold: 4
[ 83040.016] (II) event2 - Valve Software Steam Controller: is tagged by udev as: Keyboard Mouse
[ 83040.017] (II) event2 - Valve Software Steam Controller: device is a pointer
[ 83040.017] (II) event2 - Valve Software Steam Controller: device is a keyboard
[ 83040.018] (II) config/udev: Adding input device Valve Software Steam Controller (/dev/input/mouse0)
[ 83040.018] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[ 83040.018] (**) Valve Software Steam Controller: Applying InputClass "Keyboard Defaults"
[ 83040.018] (II) No input driver specified, ignoring this device.
[ 83040.018] (II) This device may have been added with another device file.
[ 83040.018] (II) config/udev: Adding input device Logitech Gaming Mouse G600 (/dev/input/event3)
[ 83040.018] (**) Logitech Gaming Mouse G600: Applying InputClass "evdev pointer catchall"
[ 83040.018] (**) Logitech Gaming Mouse G600: Applying InputClass "libinput pointer catchall"
[ 83040.018] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G600'
[ 83040.018] (**) Logitech Gaming Mouse G600: always reports core events
[ 83040.018] (**) Option "Device" "/dev/input/event3"
[ 83040.018] (**) Option "_source" "server/udev"
[ 83040.076] (II) event3 - Logitech Gaming Mouse G600: is tagged by udev as: Mouse
[ 83040.076] (II) event3 - Logitech Gaming Mouse G600: device is a pointer
[ 83040.076] (II) event3 - Logitech Gaming Mouse G600: device removed
[ 83040.148] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-3/3-3:1.0/0003:046D:C24A.0007/input/input5/event3"
[ 83040.148] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G600" (type: MOUSE, id 10)
[ 83040.148] (**) Option "AccelerationScheme" "none"
[ 83040.148] (**) Logitech Gaming Mouse G600: (accel) selected scheme none/0
[ 83040.148] (**) Logitech Gaming Mouse G600: (accel) acceleration factor: 2.000
[ 83040.148] (**) Logitech Gaming Mouse G600: (accel) acceleration threshold: 4
[ 83040.206] (II) event3 - Logitech Gaming Mouse G600: is tagged by udev as: Mouse
[ 83040.206] (II) event3 - Logitech Gaming Mouse G600: device is a pointer
[ 83040.207] (II) config/udev: Adding input device Logitech Gaming Mouse G600 (/dev/input/mouse1)
[ 83040.207] (II) No input driver specified, ignoring this device.
[ 83040.207] (II) This device may have been added with another device file.
[ 83040.208] (II) config/udev: Adding input device Logitech Gaming Mouse G600 Keyboard (/dev/input/event4)
[ 83040.208] (**) Logitech Gaming Mouse G600 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 83040.208] (**) Logitech Gaming Mouse G600 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 83040.208] (**) Logitech Gaming Mouse G600 Keyboard: Applying InputClass "system-keyboard"
[ 83040.208] (**) Logitech Gaming Mouse G600 Keyboard: Applying InputClass "Keyboard Defaults"
[ 83040.208] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G600 Keyboard'
[ 83040.208] (**) Logitech Gaming Mouse G600 Keyboard: always reports core events
[ 83040.208] (**) Option "Device" "/dev/input/event4"
[ 83040.208] (**) Option "_source" "server/udev"
[ 83040.209] (II) event4 - Logitech Gaming Mouse G600 Keyboard: is tagged by udev as: Keyboard
[ 83040.209] (II) event4 - Logitech Gaming Mouse G600 Keyboard: device is a keyboard
[ 83040.210] (II) event4 - Logitech Gaming Mouse G600 Keyboard: device removed
[ 83040.255] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-3/3-3:1.1/0003:046D:C24A.0008/input/input6/event4"
[ 83040.255] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G600 Keyboard" (type: KEYBOARD, id 11)
[ 83040.255] (**) Option "xkb_model" "pc105"
[ 83040.255] (**) Option "xkb_layout" "fi"
[ 83040.255] (**) Option "xkb_variant" "classic"
[ 83040.255] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.256] (II) event4 - Logitech Gaming Mouse G600 Keyboard: is tagged by udev as: Keyboard
[ 83040.256] (II) event4 - Logitech Gaming Mouse G600 Keyboard: device is a keyboard
[ 83040.257] (II) config/udev: Adding input device Logitech Gaming Mouse G600 (/dev/input/event5)
[ 83040.257] (II) No input driver specified, ignoring this device.
[ 83040.257] (II) This device may have been added with another device file.
[ 83040.258] (II) config/udev: Adding input device Cooler Master Technology Inc. MasterKeys Pro M Single (/dev/input/event6)
[ 83040.258] (**) Cooler Master Technology Inc. MasterKeys Pro M Single: Applying InputClass "evdev keyboard catchall"
[ 83040.258] (**) Cooler Master Technology Inc. MasterKeys Pro M Single: Applying InputClass "libinput keyboard catchall"
[ 83040.258] (**) Cooler Master Technology Inc. MasterKeys Pro M Single: Applying InputClass "system-keyboard"
[ 83040.258] (**) Cooler Master Technology Inc. MasterKeys Pro M Single: Applying InputClass "Keyboard Defaults"
[ 83040.258] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. MasterKeys Pro M Single'
[ 83040.258] (**) Cooler Master Technology Inc. MasterKeys Pro M Single: always reports core events
[ 83040.258] (**) Option "Device" "/dev/input/event6"
[ 83040.258] (**) Option "_source" "server/udev"
[ 83040.260] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: is tagged by udev as: Keyboard
[ 83040.260] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: device is a keyboard
[ 83040.260] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: device removed
[ 83040.295] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-4/3-4:1.0/0003:2516:0048.000C/input/input8/event6"
[ 83040.295] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. MasterKeys Pro M Single" (type: KEYBOARD, id 12)
[ 83040.295] (**) Option "xkb_model" "pc105"
[ 83040.295] (**) Option "xkb_layout" "fi"
[ 83040.295] (**) Option "xkb_variant" "classic"
[ 83040.295] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.297] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: is tagged by udev as: Keyboard
[ 83040.297] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: device is a keyboard
[ 83040.298] (II) config/udev: Adding input device Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control (/dev/input/event8)
[ 83040.298] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 83040.298] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 83040.298] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: Applying InputClass "system-keyboard"
[ 83040.298] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: Applying InputClass "Keyboard Defaults"
[ 83040.298] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control'
[ 83040.298] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: always reports core events
[ 83040.298] (**) Option "Device" "/dev/input/event8"
[ 83040.298] (**) Option "_source" "server/udev"
[ 83040.299] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: is tagged by udev as: Keyboard
[ 83040.300] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: device is a keyboard
[ 83040.300] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: device removed
[ 83040.361] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-4/3-4:1.2/0003:2516:0048.000E/input/input10/event8"
[ 83040.361] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control" (type: KEYBOARD, id 13)
[ 83040.361] (**) Option "xkb_model" "pc105"
[ 83040.361] (**) Option "xkb_layout" "fi"
[ 83040.361] (**) Option "xkb_variant" "classic"
[ 83040.361] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.363] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: is tagged by udev as: Keyboard
[ 83040.363] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: device is a keyboard
[ 83040.364] (II) config/udev: Adding input device Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard (/dev/input/event9)
[ 83040.364] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: Applying InputClass "evdev keyboard catchall"
[ 83040.364] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: Applying InputClass "libinput keyboard catchall"
[ 83040.364] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: Applying InputClass "system-keyboard"
[ 83040.364] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: Applying InputClass "Keyboard Defaults"
[ 83040.364] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard'
[ 83040.364] (**) Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: always reports core events
[ 83040.364] (**) Option "Device" "/dev/input/event9"
[ 83040.364] (**) Option "_source" "server/udev"
[ 83040.366] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: is tagged by udev as: Keyboard
[ 83040.366] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: device is a keyboard
[ 83040.366] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: device removed
[ 83040.401] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-4/3-4:1.2/0003:2516:0048.000E/input/input11/event9"
[ 83040.401] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard" (type: KEYBOARD, id 14)
[ 83040.401] (**) Option "xkb_model" "pc105"
[ 83040.401] (**) Option "xkb_layout" "fi"
[ 83040.401] (**) Option "xkb_variant" "classic"
[ 83040.401] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.403] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: is tagged by udev as: Keyboard
[ 83040.403] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: device is a keyboard
[ 83040.404] (II) config/udev: Adding input device Cooler Master Technology Inc. MasterKeys Pro M Single System Control (/dev/input/event7)
[ 83040.404] (**) Cooler Master Technology Inc. MasterKeys Pro M Single System Control: Applying InputClass "evdev keyboard catchall"
[ 83040.404] (**) Cooler Master Technology Inc. MasterKeys Pro M Single System Control: Applying InputClass "libinput keyboard catchall"
[ 83040.404] (**) Cooler Master Technology Inc. MasterKeys Pro M Single System Control: Applying InputClass "system-keyboard"
[ 83040.404] (**) Cooler Master Technology Inc. MasterKeys Pro M Single System Control: Applying InputClass "Keyboard Defaults"
[ 83040.404] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. MasterKeys Pro M Single System Control'
[ 83040.404] (**) Cooler Master Technology Inc. MasterKeys Pro M Single System Control: always reports core events
[ 83040.404] (**) Option "Device" "/dev/input/event7"
[ 83040.404] (**) Option "_source" "server/udev"
[ 83040.406] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: is tagged by udev as: Keyboard
[ 83040.406] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: device is a keyboard
[ 83040.406] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: device removed
[ 83040.441] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-4/3-4:1.2/0003:2516:0048.000E/input/input9/event7"
[ 83040.441] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. MasterKeys Pro M Single System Control" (type: KEYBOARD, id 15)
[ 83040.441] (**) Option "xkb_model" "pc105"
[ 83040.441] (**) Option "xkb_layout" "fi"
[ 83040.441] (**) Option "xkb_variant" "classic"
[ 83040.441] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.443] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: is tagged by udev as: Keyboard
[ 83040.443] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: device is a keyboard
[ 83040.444] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event19)
[ 83040.444] (II) No input driver specified, ignoring this device.
[ 83040.444] (II) This device may have been added with another device file.
[ 83040.444] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event20)
[ 83040.445] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event21)
[ 83040.445] (II) No input driver specified, ignoring this device.
[ 83040.445] (II) This device may have been added with another device file.
[ 83040.445] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event22)
[ 83040.446] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event23)
[ 83040.446] (II) No input driver specified, ignoring this device.
[ 83040.446] (II) This device may have been added with another device file.
[ 83040.446] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event24)
[ 83040.446] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event25)
[ 83040.447] (II) config/udev: Adding input device PC Speaker (/dev/input/event11)
[ 83040.447] (II) No input driver specified, ignoring this device.
[ 83040.447] (II) This device may have been added with another device file.
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "evdev pointer catchall"
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "evdev keyboard catchall"
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "libinput pointer catchall"
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "libinput keyboard catchall"
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "system-keyboard"
[ 83040.453] (**) Valve Software Steam Controller: Applying InputClass "Keyboard Defaults"
[ 83040.453] (II) Using input driver 'libinput' for 'Valve Software Steam Controller'
[ 83040.453] (**) Valve Software Steam Controller: always reports core events
[ 83040.453] (**) Option "Device" "/dev/input/event2"
[ 83040.453] (**) Option "_source" "_driver/libinput"
[ 83040.453] (II) libinput: Valve Software Steam Controller: is a virtual subdevice
[ 83040.453] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:27:00.3/usb3/3-2/3-2:1.0/0003:28DE:1142.0001/input/input4/event2"
[ 83040.453] (II) XINPUT: Adding extended input device "Valve Software Steam Controller" (type: KEYBOARD, id 16)
[ 83040.453] (**) Option "xkb_model" "pc105"
[ 83040.453] (**) Option "xkb_layout" "fi"
[ 83040.453] (**) Option "xkb_variant" "classic"
[ 83040.453] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 83040.454] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): connected
[ 83040.454] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): Internal DisplayPort
[ 83040.454] (--) NVIDIA(GPU-0): LG Electronics 27GL850 (DFP-2): 1440.0 MHz maximum pixel clock
[ 83040.458] (II) event1 - Power Button: device removed
[ 83040.508] (II) event0 - Power Button: device removed
[ 83040.535] (II) event10 - Yoyodyne Consulting UAC1 DAC: device removed
[ 83040.588] (II) event3 - Logitech Gaming Mouse G600: device removed
[ 83040.641] (II) event4 - Logitech Gaming Mouse G600 Keyboard: device removed
[ 83040.668] (II) event6 - Cooler Master Technology Inc. MasterKeys Pro M Single: device removed
[ 83040.695] (II) event8 - Cooler Master Technology Inc. MasterKeys Pro M Single Consumer Control: device removed
[ 83040.748] (II) event9 - Cooler Master Technology Inc. MasterKeys Pro M Single Keyboard: device removed
[ 83040.775] (II) event7 - Cooler Master Technology Inc. MasterKeys Pro M Single System Control: device removed
[ 83040.801] (II) event2 - Valve Software Steam Controller: device removed
[ 83040.856] (II) UnloadModule: "libinput"
[ 83040.857] (II) UnloadModule: "libinput"
[ 83040.946] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 83040.947] (II) Server terminated successfully (0). Closing log file.
journalctl -b-1 -x | grep -i kwin
tammi 23 00:48:19 jp-gentoo dbus-daemon[1184]: [session uid=1000 pid=1184] Activating service name='org.kde.ActivityManager' requested by ':1.11' (uid=1000 pid=1250 comm="/usr/bin/kwin_x11 ")
tammi 23 00:48:20 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 771, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:48:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2478, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:48:25 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5328, resource id: 31457363, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:48:25 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5333, resource id: 31457364, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:48:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6035, resource id: 14680343, major code: 3 (GetWindowAttributes), minor code: 0
tammi 23 00:48:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6036, resource id: 14680343, major code: 14 (GetGeometry), minor code: 0
tammi 23 00:49:15 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19356, resource id: 62914615, major code: 15 (QueryTree), minor code: 0
tammi 23 00:49:34 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29063, resource id: 75497514, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:53:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2345, resource id: 31457392, major code: 73 (GetImage), minor code: 0
tammi 23 00:53:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2346, resource id: 31457392, major code: 73 (GetImage), minor code: 0
tammi 23 00:53:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2347, resource id: 31457392, major code: 73 (GetImage), minor code: 0
tammi 23 00:53:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2348, resource id: 31457392, major code: 73 (GetImage), minor code: 0
tammi 23 00:53:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2349, resource id: 31457392, major code: 73 (GetImage), minor code: 0
tammi 23 00:53:34 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9178, resource id: 71303175, major code: 15 (QueryTree), minor code: 0
tammi 23 00:55:34 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28691, resource id: 77594747, major code: 18 (ChangeProperty), minor code: 0
tammi 23 00:55:35 jp-gentoo systemd[1174]: app-kwincompositing-77f1ed0e509a4064b21e271359f4526f.scope: Succeeded.
tammi 23 01:00:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63420, resource id: 79691796, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:09:52 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53022, resource id: 31457413, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:09:52 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53029, resource id: 31457414, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:10:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64513, resource id: 88080392, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:10:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64517, resource id: 85983260, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:10:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64538, resource id: 31457415, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:15:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19567, resource id: 69206023, major code: 15 (QueryTree), minor code: 0
tammi 23 01:17:42 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18461, resource id: 31457416, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:17:42 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18475, resource id: 31457417, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:17:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40717, resource id: 85983240, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:17:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40721, resource id: 69206040, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:17:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40749, resource id: 31457418, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:20:48 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31049, resource id: 73400394, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:20:53 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51202, resource id: 31457419, major code: 15 (QueryTree), minor code: 0
tammi 23 01:20:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57220, resource id: 31457421, major code: 20 (GetProperty), minor code: 0
tammi 23 01:20:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57221, resource id: 31457421, major code: 15 (QueryTree), minor code: 0
tammi 23 01:21:18 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6210, resource id: 94371856, major code: 15 (QueryTree), minor code: 0
tammi 23 01:21:18 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6348, resource id: 73400395, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:21:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17468, resource id: 92274695, major code: 15 (QueryTree), minor code: 0
tammi 23 01:30:19 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27758, resource id: 14740990, major code: 3 (GetWindowAttributes), minor code: 0
tammi 23 01:30:19 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 27759, resource id: 14740990, major code: 14 (GetGeometry), minor code: 0
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
tammi 23 01:32:24 jp-gentoo kwin_x11[1250]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
tammi 23 01:37:38 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21741, resource id: 14749131, major code: 3 (GetWindowAttributes), minor code: 0
tammi 23 01:37:38 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 21742, resource id: 14749131, major code: 14 (GetGeometry), minor code: 0
tammi 23 01:37:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22847, resource id: 62914785, major code: 15 (QueryTree), minor code: 0
tammi 23 01:46:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9917, resource id: 83886082, major code: 15 (QueryTree), minor code: 0
tammi 23 01:50:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54592, resource id: 83886082, major code: 15 (QueryTree), minor code: 0
tammi 23 01:50:23 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55356, resource id: 62914748, major code: 15 (QueryTree), minor code: 0
tammi 23 01:50:25 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58301, resource id: 69206018, major code: 15 (QueryTree), minor code: 0
tammi 23 01:50:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59599, resource id: 31457449, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3824, resource id: 69206064, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3828, resource id: 83886088, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3832, resource id: 31457450, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:42 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5305, resource id: 31457452, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:56 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18387, resource id: 79691784, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:56 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18391, resource id: 69206064, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:56 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18408, resource id: 31457453, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19408, resource id: 31457455, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:50:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19854, resource id: 92274690, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32840, resource id: 69206226, major code: 19 (DeleteProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32853, resource id: 69206226, major code: 19 (DeleteProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32854, resource id: 69206226, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32855, resource id: 69206226, major code: 19 (DeleteProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32856, resource id: 69206226, major code: 19 (DeleteProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32857, resource id: 69206226, major code: 19 (DeleteProperty), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32858, resource id: 69206226, major code: 7 (ReparentWindow), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32859, resource id: 69206226, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32860, resource id: 69206226, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 01:51:35 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32861, resource id: 69206226, major code: 10 (UnmapWindow), minor code: 0
tammi 23 01:51:42 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33876, resource id: 69206018, major code: 15 (QueryTree), minor code: 0
tammi 23 01:51:43 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34118, resource id: 92274690, major code: 18 (ChangeProperty), minor code: 0
tammi 23 01:52:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50247, resource id: 31457462, major code: 18 (ChangeProperty), minor code: 0
tammi 23 02:01:04 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43724, resource id: 83886082, major code: 15 (QueryTree), minor code: 0
tammi 23 17:51:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16888, resource id: 83886110, major code: 18 (ChangeProperty), minor code: 0
tammi 23 17:51:18 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21844, resource id: 73400411, major code: 18 (ChangeProperty), minor code: 0
tammi 23 17:52:04 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65221, resource id: 85983248, major code: 15 (QueryTree), minor code: 0
tammi 23 17:52:04 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65379, resource id: 73400412, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:15:28 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53027, resource id: 83886097, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:15:28 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53032, resource id: 83886098, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:18:29 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9495, resource id: 94371848, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:18:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10980, resource id: 92274917, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:18:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11029, resource id: 83886099, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:19:01 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13507, resource id: 14932055, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 18:19:01 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13667, resource id: 83886100, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:19:01 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13671, resource id: 85983240, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:19:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25262, resource id: 12582919, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:22:37 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12543, resource id: 92274690, major code: 15 (QueryTree), minor code: 0
tammi 23 18:40:48 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41954, resource id: 31457466, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:43:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44772, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 18:44:43 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62728, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 18:47:05 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9167, resource id: 31457486, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:47:41 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42708, resource id: 79691820, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:47:41 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42723, resource id: 79691821, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:47:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47978, resource id: 115343368, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:47:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47982, resource id: 113246322, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:47:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48046, resource id: 79691822, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:48:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64841, resource id: 79691828, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:48:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64846, resource id: 79691829, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:50:05 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29030, resource id: 115343368, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:50:05 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29036, resource id: 113246349, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:50:05 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29065, resource id: 79691830, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:51:36 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24124, resource id: 85983240, major code: 18 (ChangeProperty), minor code: 0
tammi 23 18:56:23 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10859, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 19:01:32 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27201, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 19:03:37 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6627, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 19:38:36 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48978, resource id: 111149058, major code: 15 (QueryTree), minor code: 0
tammi 23 19:40:47 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32838, resource id: 111149063, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:24:51 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8257, resource id: 79691831, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:24:51 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8278, resource id: 31457493, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:26:00 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1139, resource id: 79691796, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:27:54 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 40194, resource id: 73400419, major code: 14 (GetGeometry), minor code: 0
tammi 23 20:28:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39586, resource id: 111149072, major code: 15 (QueryTree), minor code: 0
tammi 23 20:28:45 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39796, resource id: 73400429, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:34:22 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14466, resource id: 31457498, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:34:31 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63647, resource id: 79691783, major code: 15 (QueryTree), minor code: 0
tammi 23 20:34:47 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9062, resource id: 79691783, major code: 15 (QueryTree), minor code: 0
tammi 23 20:39:18 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36733, resource id: 31457506, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:39:19 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39738, resource id: 85983240, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:39:19 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39742, resource id: 79691792, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:39:20 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39754, resource id: 31457507, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:39:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41191, resource id: 31457509, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55153, resource id: 79691801, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 495, resource id: 96469000, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 499, resource id: 94371959, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:44 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 539, resource id: 79691802, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:45 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1529, resource id: 85983240, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:45 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1533, resource id: 79691803, major code: 18 (ChangeProperty), minor code: 0
tammi 23 20:40:45 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1539, resource id: 31457510, major code: 18 (ChangeProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8866, resource id: 44046940, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8880, resource id: 44046940, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8881, resource id: 44046940, major code: 18 (ChangeProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8882, resource id: 44046940, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8883, resource id: 44046940, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8884, resource id: 44046940, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8885, resource id: 44046940, major code: 7 (ReparentWindow), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8886, resource id: 44046940, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8887, resource id: 44046940, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 21:14:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8888, resource id: 44046940, major code: 10 (UnmapWindow), minor code: 0
tammi 23 21:22:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48992, resource id: 79691778, major code: 15 (QueryTree), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58914, resource id: 15620668, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58920, resource id: 83886339, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58934, resource id: 83886339, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58935, resource id: 83886339, major code: 18 (ChangeProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58936, resource id: 83886339, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58937, resource id: 83886339, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58938, resource id: 83886339, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58939, resource id: 83886339, major code: 7 (ReparentWindow), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58940, resource id: 83886339, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58941, resource id: 83886339, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 21:22:26 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58942, resource id: 83886339, major code: 10 (UnmapWindow), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62903, resource id: 83886324, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62917, resource id: 83886324, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62918, resource id: 83886324, major code: 18 (ChangeProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62919, resource id: 83886324, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62920, resource id: 83886324, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62921, resource id: 83886324, major code: 19 (DeleteProperty), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62922, resource id: 83886324, major code: 7 (ReparentWindow), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62923, resource id: 83886324, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62924, resource id: 83886324, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 21:23:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62925, resource id: 83886324, major code: 10 (UnmapWindow), minor code: 0
tammi 23 21:29:06 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45916, resource id: 83886478, major code: 15 (QueryTree), minor code: 0
tammi 23 21:52:31 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63939, resource id: 85983239, major code: 15 (QueryTree), minor code: 0
tammi 23 21:57:54 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8024, resource id: 85983239, major code: 15 (QueryTree), minor code: 0
tammi 23 21:58:47 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19680, resource id: 31457555, major code: 18 (ChangeProperty), minor code: 0
tammi 23 21:59:16 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35277, resource id: 85983279, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:58 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55117, resource id: 98566152, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:58 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55121, resource id: 96469206, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:58 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55139, resource id: 85983280, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55726, resource id: 94371848, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55730, resource id: 85983281, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:00:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55742, resource id: 31457556, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:01:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58638, resource id: 31457558, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:01:28 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5871, resource id: 85983275, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:01:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22479, resource id: 98566152, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:01:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22483, resource id: 96469180, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:01:57 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22518, resource id: 85983276, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:04 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28075, resource id: 85983283, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:07 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33837, resource id: 85983289, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:07 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33842, resource id: 85983290, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:15 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38733, resource id: 100663301, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:15 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38742, resource id: 85983291, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:54 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48032, resource id: 100663303, major code: 15 (QueryTree), minor code: 0
tammi 23 22:02:58 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51163, resource id: 85983297, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:02:58 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51168, resource id: 85983298, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52591, resource id: 100663301, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:02 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52597, resource id: 85983299, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54156, resource id: 96469228, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54160, resource id: 98566152, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:11 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54192, resource id: 85983300, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:13 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55593, resource id: 94371848, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:13 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55597, resource id: 85983301, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:03:13 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55601, resource id: 31457561, major code: 18 (ChangeProperty), minor code: 0
tammi 23 22:44:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55166, resource id: 85983234, major code: 15 (QueryTree), minor code: 0
tammi 23 23:16:14 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 317, resource id: 85983239, major code: 15 (QueryTree), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49611, resource id: 85983238, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49625, resource id: 85983238, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49626, resource id: 85983238, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49627, resource id: 85983238, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49628, resource id: 85983238, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49629, resource id: 85983238, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49630, resource id: 85983238, major code: 7 (ReparentWindow), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49631, resource id: 85983238, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49632, resource id: 85983238, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49633, resource id: 85983238, major code: 10 (UnmapWindow), minor code: 0
tammi 23 23:20:21 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49719, resource id: 85983248, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:24:56 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11864, resource id: 31457607, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:25:01 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15461, resource id: 85983253, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:32 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39613, resource id: 96469143, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:32 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39617, resource id: 98566152, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:32 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39646, resource id: 85983254, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:33 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40607, resource id: 94371848, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:33 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40611, resource id: 85983255, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:26:33 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40624, resource id: 31457608, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:15 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36096, resource id: 31457611, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:25 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41950, resource id: 85983252, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:25 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41957, resource id: 85983253, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:39 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52277, resource id: 98566152, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:39 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52281, resource id: 96469223, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:39 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52303, resource id: 85983254, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52571, resource id: 94371848, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52575, resource id: 85983255, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:40 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52594, resource id: 31457612, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54681, resource id: 15833609, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54828, resource id: 15833613, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54865, resource id: 15833617, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54902, resource id: 15833621, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: kwin_scene_opengl: OpenGL 2 compositing setup failed
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: kwin_scene_opengl: OpenGL driver recommends XRender based compositing. Falling back to XRender.
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: kwin_scene_opengl: To overwrite the detection use the environment variable KWIN_COMPOSE
tammi 23 23:36:59 jp-gentoo kwin_x11[1250]: kwin_scene_opengl: For more information see https://community.kde.org/KWin/Environment_Variables#KWIN_COMPOSE
tammi 23 23:37:00 jp-gentoo audit[1250]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1250 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=11 res=1
tammi 23 23:37:00 jp-gentoo kernel: audit: type=1701 audit(1611437820.959:487): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1250 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=11 res=1
tammi 23 23:37:01 jp-gentoo dbus-daemon[1184]: [session uid=1000 pid=1184] Activating service name='org.kde.KSplash' requested by ':1.215' (uid=1000 pid=495113 comm="/usr/bin/kwin_x11 --crashes 1 ")
tammi 23 23:37:01 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1755, resource id: 85983264, major code: 3 (GetWindowAttributes), minor code: 0
tammi 23 23:37:01 jp-gentoo kwin_x11[495113]: kwin_core: Compositing is not possible
tammi 23 23:37:03 jp-gentoo systemd-coredump[495118]: Process 1250 (kwin_x11) of user 1000 dumped core.
░░ Subject: Process 1250 (kwin_x11) dumped core
░░ Process 1250 (kwin_x11) crashed and dumped core.
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: DesktopGridConfig::instance called after the first use - ignoring
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: KscreenConfig::instance called after the first use - ignoring
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: PresentWindowsConfig::instance called after the first use - ignoring
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: SlideConfig::instance called after the first use - ignoring
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: SlidingPopupsConfig::instance called after the first use - ignoring
tammi 23 23:38:54 jp-gentoo kwin_x11[495113]: ZoomConfig::instance called after the first use - ignoring
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63469, resource id: 14680073, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63483, resource id: 14680073, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63484, resource id: 14680073, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63485, resource id: 14680073, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63486, resource id: 14680073, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63487, resource id: 14680073, major code: 19 (DeleteProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63488, resource id: 14680073, major code: 7 (ReparentWindow), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63489, resource id: 14680073, major code: 6 (ChangeSaveSet), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63490, resource id: 14680073, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63491, resource id: 14680073, major code: 10 (UnmapWindow), minor code: 0
tammi 23 23:38:55 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63583, resource id: 14680209, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:38:55 jp-gentoo systemd[1174]: app-kwincompositing-2bf8bcf663854ff68b9d853bcec10562.scope: Succeeded.
tammi 23 23:47:05 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60469, resource id: 85998232, major code: 2 (ChangeWindowAttributes), minor code: 0
tammi 23 23:47:09 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61743, resource id: 62914563, major code: 15 (QueryTree), minor code: 0
tammi 23 23:47:09 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61942, resource id: 31457667, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:50:33 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57473, resource id: 83886560, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:50:33 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57486, resource id: 12582920, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:50:38 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63554, resource id: 14680081, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:10 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7958, resource id: 65011720, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:10 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7962, resource id: 62914765, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:10 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7977, resource id: 14680082, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:10 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8303, resource id: 60817416, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:10 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8309, resource id: 14680083, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:31 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17155, resource id: 14680071, major code: 15 (QueryTree), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19686, resource id: 25165830, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19690, resource id: 50331654, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19694, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19698, resource id: 35651589, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19702, resource id: 4194309, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19706, resource id: 75497477, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19710, resource id: 37748741, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19714, resource id: 27262997, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19718, resource id: 33554437, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19722, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19793, resource id: 44048107, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19799, resource id: 73400482, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19863, resource id: 23068689, major code: 18 (ChangeProperty), minor code: 0
tammi 23 23:51:58 jp-gentoo kwin_x11[495113]: The X11 connection broke: I/O error (code 1)
tammi 23 23:51:59 jp-gentoo audit[495113]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=495113 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=6 res=1
journalctl -b-1 -p3 -x
-- Journal begins at Mon 2020-08-24 20:07:55 EEST, ends at Sun 2021-01-24 01:17:01 EET. --
tammi 23 00:48:09 jp-gentoo kernel: mpt2sas_cm0: overriding NVDATA EEDPTagMode setting
tammi 23 00:48:22 jp-gentoo pipewire[1532]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
tammi 23 00:48:45 jp-gentoo pulseaudio[1353]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Stack trace of thread 1250:
#0 0x00007f5deb4b2615 n/a (n/a + 0x0)
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
tammi 23 23:51:59 jp-gentoo systemd-coredump[501206]: Failed to send coredump datagram: Connection reset by peer
tammi 23 23:52:02 jp-gentoo kernel: watchdog: watchdog0: watchdog did not stop!
This is from my current boot, where KWin hasn’t crashed (yet…), so I don’t know if it’s of any use:
sudo dmesg -l emerg,alert,crit,err,warn
[ 0.186206] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.291896] PPR NX GT IA GA PC GA_vAPIC
[ 1.714026] ata6.00: supports DRM functions and may not be fully accessible
[ 1.716141] ata6.00: supports DRM functions and may not be fully accessible
[ 2.007406] mpt2sas_cm0: overriding NVDATA EEDPTagMode setting
[ 2.514895] usb 1-10: config 1 has an invalid interface number: 3 but max is 2
[ 2.514897] usb 1-10: config 1 has an invalid interface number: 3 but max is 2
[ 2.514898] usb 1-10: config 1 has an invalid interface number: 3 but max is 2
[ 2.514899] usb 1-10: config 1 has no interface number 2
[ 9.238528] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 9.242958] nvidia: loading out-of-tree module taints kernel.
[ 9.242968] nvidia: module license 'NVIDIA' taints kernel.
[ 9.242969] Disabling lock debugging due to kernel taint
[ 9.423760] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.32.03 Sun Dec 27 19:00:34 UTC 2020
[ 10.159610] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff window]
[ 10.159729] caller _nv000706rm+0x1af/0x200 [nvidia] mapping multiple BARs
[ 15.822237] kauditd_printk_skb: 52 callbacks suppressed
[ 29.025229] kauditd_printk_skb: 8 callbacks suppressed
[ 81.266245] kauditd_printk_skb: 57 callbacks suppressed
[ 97.301309] kauditd_printk_skb: 34 callbacks suppressed
