Hey! This is my first post so sorry if I’m not helping providing the relevant info.
So there’s this problem with my WiFi, it isn’t working nor showing up any connections available, I’ve tried some solutions downloading the driver of Intel and uninstalling the rest, with no luck.
I moved on trying to see if the iwlmvm
module presented any troubles, first with trying to unload it and load it back up with no errors and then seeing if in the dmseg
there’s anything, and it doesn’t seems to be anything wrong besides it tries to init with no error logged despite it besides “api flags index 2 larger than supported by driver”
Now I’ve ran out of ideas, although it seems to load the driver when i do lsmod
and it shows up on inxi
, yet not in ip addr show
, as far as i know the problem is caused because there should be an interface connected with the card but it doesn’t appears.
Here i leave some of the logs that the commands show;
inxi --admin --verbosity=7 --filter --widthPreformatted text
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-2:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f3u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:3
ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
3: enp4s0f3u2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 0c:37:96:15:c6:e4 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.93/24 brd 192.168.1.255 scope global dynamic noprefixroute enp4s0f3u2
valid_lft 27770sec preferred_lft 27770sec
inet6 fe80::2dd6:b243:9302:6520/64 scope link noprefixroute
dmsg | less
[ 3.601972] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 3.604737] cryptd: max_cpu_qlen set to 1000
[ 3.679662] usbcore: registered new interface driver cdc_ether
[ 3.691662] AVX2 version of gcm_enc/dec engaged.
[ 3.691753] AES CTR mode by8 optimization enabled
[ 3.694449] usbcore: registered new interface driver r8153_ecm
[ 3.696440] i8042: PNP: No PS/2 controller found.
[ 3.696608] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 3.696631] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 3.697010] iwlwifi 0000:02:00.0: loaded firmware version 66.f1c864e0.0 cc-a0-66.ucode op_mode iwlmvm
[ 4.072164] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.078278] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[ 4.078345] Bluetooth: hci0: Boot Address: 0x24800
[ 4.078348] Bluetooth: hci0: Firmware Version: 21-22.22
[ 4.078349] Bluetooth: hci0: Firmware already loaded
[ 4.082726] mousedev: PS/2 mouse device common for all mice
[ 4.120178] NET: Registered PF_QIPCRTR protocol family
[ 4.222828] iwlwifi 0000:02:00.0: retry init count 0
[ 4.224370] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.389149] iwlwifi 0000:02:00.0: retry init count 1
[ 4.390668] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.447437] intel_rapl_common: Found RAPL domain package
[ 4.447441] intel_rapl_common: Found RAPL domain core
[ 4.539949] iwlwifi 0000:02:00.0: retry init count 2
Edit: Formated some of the text and improved redaction
