I found this, but it seems to be left unanswered:
Since a few days im using a 2xKVM-Switch to switch between my working and private PC
My problem is, that when i switch back to my Linux-Desktop-PC (PC1) after a longer time working on (PC2), the display stays black with no signal.
Even if i re-plugin the HDMI cable again, nothing happens.
Does anyone know if i can try to solve this?
Are there Settings for my NVIDIA-Card i can check?
Only thing that helps is a “blind-reboot” by using the reset-button, which can lead to loss of unsaved changes.
My system:
Kernel: 5.19.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: awesome v: 4.3-1538-g4a140ea5e vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3805
date: 05/16/2018
Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP
smt: enabled arch: Skylake-S level: v3 rev: 3 cache: L1: 256 KiB
L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 998 high: 1200 min/max: 800/4200 cores: 1: 837 2: 933
3: 1116 4: 933 5: 965 6: 1200 7: 800 8: 1200 bogomips: 64026
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 515.76 arch: Pascal pcie: speed: 8 GT/s lanes: 16 ports:
active: none off: HDMI-A-1 empty: DP-1,DVI-D-1,DVI-D-2 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: nvidia unloaded: vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.57x13.46")
s-diag: 872mm (34.33")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar)
ULTRAWIDE serial: <filter> res: 3440x1440 hz: 50 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
