I’m on the Unstable branch and did a big update yesterday, and now KTorrent isn’t starting. If I try starting it from the terminal it gives me several errors:
qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "stateChanged" : Type not registered with QDBus in parameter list: QNetworkManagerInterface::NMState
qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "connectivityChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMConnectivityState
qt.dbus.integratton: Could not connect "org.freedesktop.NetwortManager" to "deviceTypeChanged" : Type not relstered with QtDBus in paraneter list: QNetworkManagerIntertace::NMDeviceType
qt.dbus.integratton: Could not connect "org.freedesktop.NetwortManager" to "MeteredChanged" : Type not relstered with QtDBus in paraneter list: QNetworkManagerIntertace::NMMetered
QLayout: Attempting to add QLayout ""to kt::FileView "", which already has a layout
KCrash: Application 'ktorrent' crashing... crashRecursionCounter = 2
Segmentation fault (core dumped)
I’m on Unstable as that is what was recommended for the Raspberry Pi 5. Is that still the case?
I tried changing channel via this guide , but coming from unstable is a downgrade, and the upgrade command doesn’t do anything. Is there a way to force all the packages to switch to the other branch?
