Every system search I use (application launcher, the new overview and krunner itself) seems to be sufering from the same problem: whenever I start typing in the search bar it takes a rather long time (about 5 seconds) to initalize, after that adding more characters to the search runs smoothly, however such “smoothness” resets every time I re-open the application, so every time I try to search in plasma overview it gets stuck for a few seconds.
I’ve tried running krunner -d
to run it as a daemon, wich seems to work but only for about 5 minutes, until it goes back to status quo
Has anyone experienced this and/or knows of a way to fix it?
Kernel: 5.19.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=45c4647f-cf0d-4650-8365-24ed42d1dcae rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: AB350M-DS3H V2 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350M-DS3H V2-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F52f date: 04/28/2022
RAM: total: 13.57 GiB used: 4.03 GiB (29.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 3 PRO 2200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen level: v3 built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2374 high: 3208 min/max: 1600/3825 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 3208
3: 1600 4: 3091 bogomips: 30553
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,
DP-2, DP-3, DVI-D-1, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: HDMI-A-2 empty: DVI-D-2 bus-ID: 08:00.0 chip-ID: 1002:15dd
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: LG (GoldStar) 2D FHD TV
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
5.19.13-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel bus-ID: 3-2:2 v: kernel pcie:
chip-ID: 8086:0808 gen: 1 class-ID: 0300 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
chip-ID: 1002:15de class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Intel USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.19.13-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.58 running: yes
vendor: Gigabyte driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
Local Storage: total: 1.16 TiB used: 549.55 GiB (46.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 500GB SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: T0709E0L temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD6400BPVT-60HXZT1 size: 596.17 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: B1E1 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 212.66 GiB
(46.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: ManjaroNVME
uuid: 45c4647f-cf0d-4650-8365-24ed42d1dcae
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 6B35-87A8
ID-3: /mnt/Linux600Gb raw-size: 596.17 GiB size: 585.74 GiB (98.25%)
used: 336.89 GiB (57.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Linux600Gb uuid: 5fa1f7a0-0935-486a-838d-0823f022a3e3
ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 0E50-D7EC
ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb3 maj-min: 8:19 size: 111.18 GiB fs: ntfs label: N/A
uuid: D8A651B9A6519938
ID-4: /dev/sdb4 maj-min: 8:20 size: 508 MiB fs: ntfs label: N/A
uuid: C610687E106876F9
ID-5: /dev/sdc1 maj-min: 8:33 size: 14.29 GiB fs: exfat label: Ventoy
uuid: 42A3-96E4
ID-6: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 5A89-BA75
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c092 class-ID: 0300
serial: <filter>
Device-2: 1-6:3 info: BY Tech Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 258a:0049 class-ID: 0300
Device-3: 1-7:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-4: 1-9:5 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Intel USB PnP Sound Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 8086:0808 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.8 C mobo: N/A
GPU: device: amdgpu temp: 35.0 C fan: 122 watts: 5.22 device: amdgpu
temp: 38.0 C
Processes: 288 Uptime: 38m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
clang: 14.0.6 Packages: 2244 pm: dpkg pkgs: 0 pm: pacman pkgs: 2225
libs: 503 tools: pamac,yay pm: flatpak pkgs: 7 pm: snap pkgs: 12 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.21
