I’m having issues with the update. In pamac I get this message when trying to update:
conflicting files:
- konsole: /etc/xdg/konsolerc already exists in filesystem (owned by manjaro-kde-settings)
I use kde-unstable repo for context, it worked fine so far.
Please post:
pacman -Qi konsole manjaro-kde-settings
pacman -Ql konsole | grep etc
pacman -Ql manjaro-kde-settings | grep etc
(Konsole in regular repo doesn’t include that file.)
Is a change from upstream, not Arch tho … but KDE … This was added in the file
remove manjaro-kde-settings
for now, I’ll try to fix it soon
I hope i’m doing this good with block quotes
Version : 22.08.3.r8740.g7c568234-1
Description : KDE terminal emulator
Architecture : x86_64
URL : https://apps.kde.org/konsole/
Licenses : GPL LGPL FDL
Groups : kde-applications kde-utilities
Provides : None
Depends On : knotifyconfig kpty kparts kinit knewstuff
Optional Deps : keditbookmarks: to manage bookmarks [installed]
Required By : yakuake
Optional For : dolphin kate krusader
Conflicts With : None
Replaces : konsole-git
Installed Size : 7,81 MiB
Packager : Manjaro Build Server <build@manjaro.org>
Build Date : Sat 12 Nov 2022 21:42:39 CET
Install Date : Mon 14 Nov 2022 13:22:20 CET
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Version : 20220130-1
Description : Manjaro Linux KDE settings
Architecture : any
URL : https://gitlab.manjaro.org/profiles-and-settings/manjaro-kde-settings
Licenses : GPL
Groups : None
Provides : None
Depends On : zsh manjaro-base-skel manjaro-icons noto-fonts-compat plasma5-themes-breath
sddm-breath-theme xdg-desktop-portal-kde
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : manjaro-desktop-settings-19.0 manjaro-kde-settings-dev
Replaces : manjaro-desktop-settings-19.0 manjaro-kde-settings-dev
Installed Size : 40,59 KiB
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Sun 30 Jan 2022 02:50:13 CET
Install Date : Tue 16 Aug 2022 14:20:01 CEST
Install Script : Yes
nothing
manjaro-kde-settings /etc/
manjaro-kde-settings /etc/profile.d/
manjaro-kde-settings /etc/profile.d/qt5-accessibility.sh
manjaro-kde-settings /etc/sddm.conf.d/
manjaro-kde-settings /etc/sddm.conf.d/00_manjaro_settings.conf
manjaro-kde-settings /etc/sddm.conf.d/virtualkeyboard.conf
manjaro-kde-settings /etc/skel/
manjaro-kde-settings /etc/skel/.config/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/colors.css
manjaro-kde-settings /etc/skel/.config/gtk-3.0/gtk.css
manjaro-kde-settings /etc/skel/.config/gtk-3.0/settings.ini
manjaro-kde-settings /etc/skel/.config/gtk-3.0/window_decorations.css
manjaro-kde-settings /etc/skel/.config/kdeglobals
manjaro-kde-settings /etc/skel/.xinitrc
manjaro-kde-settings /etc/xdg/
manjaro-kde-settings /etc/xdg/kdeglobals
manjaro-kde-settings /etc/xdg/konsolerc
manjaro-kde-settings /etc/xdg/ksmserverrc
manjaro-kde-settings /etc/xdg/kwinrc
manjaro-kde-settings /etc/xdg/yakuakerc
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Check previous comment by @LordTermor.
You should use preformatted text </> for code.
Now getting this error
EDIT: I guess removing manjaro-kde-settings actually did fix it, i just had to persuade it a little bit. I did refresh mirrors, refresh databases and had to relaunch pamac for it to finally start upgrading.
conflicting files:
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/00008160000006810000408080010102 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/028006030e0e7ebffc7f7070c0600140 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/03b6e0fcb3499374a867c041f52298f0 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/08e8e1c95fe2fc01f976f1e063a24ccd already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/1081e37283d90000800003c07f3ef6bf already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/14fef782d02440884392942c11205230 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/2870a09082c103050810ffdffffe0204 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/3085a0e285430894940527032f8b26df already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/3ecb610c1bf2410f44200f48c40d3599 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/4498f0e0c1937ffe01fd06f973665830 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/5c6cd98b3f3ebcb1f9c7f1c204630408 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/6407b0e94181790501fd1e167b474872 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/640fb0e74195791501fd1ed57b41487f already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/9081237383d90e509aa00f00170e968f already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/9d800788f1b08800ae810202380a0822 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/X_cursor already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/alias already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/all-scroll already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/bd_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/bottom_left_corner already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/bottom_right_corner already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/bottom_side already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/bottom_tee already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/c7088f0f3e6c8088236ef8e1e3e70000 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/cell already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/circle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/col-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/context-menu already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/copy already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/cross already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/cross_reverse already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/crossed_circle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/crosshair already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/d9ce0ab605698f320427677b458ad60b already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/default already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/diamond_cross already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-ask already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-copy already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-link already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-move already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-no-drop already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dnd-none already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dot_box_mask already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/dotbox already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/draft_large already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/draft_small already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/draped_box already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/e-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/e29285e634086352946a0e7090d73106 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ew-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/fcf1c3c7cd4491d801f1e1c78f100000 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/fd_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/fleur already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/grab already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/grabbing already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/h_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/hand already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/hand1 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/hand2 already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/help already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/icon already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/left_ptr already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/left_ptr_help already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/left_ptr_watch already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/left_side already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/left_tee already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/link already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ll_angle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/lr_angle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/move already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/n-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ne-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/nesw-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/no-drop already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/not-allowed already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ns-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/nw-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/nwse-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/openhand already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/pencil already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/pirate already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/plus already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/pointer already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/pointer-move already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/progress already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/question_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/right_ptr already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/right_side already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/right_tee already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/row-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/s-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_down_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_h_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_left_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_right_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_up_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sb_v_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/se-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/size_all already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/size_bdiag already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/size_fdiag already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/size_hor already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/size_ver already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/sw-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/target already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/tcross already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/text already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/top_left_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/top_left_corner already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/top_right_corner already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/top_side already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/top_tee already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ul_angle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/ur_angle already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/v_double_arrow already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/vertical-text already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/w-resize already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/wait already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/watch already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/xterm already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/zoom-in already exists in filesystem (owned by adwaita-icon-theme)
- adwaita-cursors: /usr/share/icons/Adwaita/cursors/zoom-out already exists in filesystem (owned by adwaita-icon-theme)
This has nothing to do with previous error and kde unstable, so you should open a new topic. (or @Yochanan should move it, since there really is a problem with package
) …or maybe not, I don’t know what I’m looking at in terminal anymore.
