New to Manjaro KDE here. In the terminal, Konsole, and Yakuake, is there a way to change the tab completion options? For example, when one wants to change directory and the folder is in uppercase and one types in lowercase but changes to uppercase when the Tab key is pressed.
in ~/inputrc (create if you dont have) , put “set completion-ignore-case on”.
For example mine is :
# do not bell on tab-completion
#set bell-style none
set meta-flag on
set input-meta on
set convert-meta off
set output-meta on
$if mode=emacs
"\e[A": history-search-backward
"\e[B": history-search-forward
# Colorize Completions
# Color files by types
set colored-stats On
# Append char to indicate type
set visible-stats On
# Mark directories
set mark-directories On
# Mark symlinked directories
set mark-symlinked-directories On
# Color the common prefix
set colored-completion-prefix On
# Color the common prefix in menu-complete
set menu-complete-display-prefix On
$endif
$if Bash
TAB:menu-complete
Space: magic-space
#history like zsh
set match-hidden-files off
set completion-map-case on
set history-preserve-point on
#set mark-modified-lines on
set visible-stats on
set print-completions-horizontally on
set show-all-if-ambiguous on
set completion-query-items 0
set page-completions off
$endif
