Konsole profiles are recovering
Hi all.
Currently I have 2 Konsole profiles:
Build-in [Read-only] [Default]
Breath
The problem is that any changes are lost after the window is closed. If I make Breath the default or add a new profile, that change will persist until I close the window. After closing everything is restored.
Also, these changes are not seen by other Konsole applications (eg Yakuake).
I have a freshly installed system with KDE theme + Kvantum theme, I didn’t make any special settings.
> cat ~/.config/konsolerc
[Desktop Entry]
DefaultProfile=baroness-profile.profile (that`s profile i created!)
[General]
ConfigVersion=1
[MainWindow]
HDMI-A-0 Height 2560x1080=554
HDMI-A-0 Width 2560x1080=911
HDMI-A-0 XPosition 2560x1080=824
HDMI-A-0 YPosition 2560x1080=253
RestorePositionForNextInstance=false
State=AAAA/wAAAAD9AAAAAQAAAAAAAAEUAAACD/wCAAAAAvsAAAAiAFEAdQBpAGMAawBDAG8AbQBtAGEAbgBkAHMARABvAGMAawAAAAAbAAACDwAAAS4A////+wAAABwAUwBTAEgATQBhAG4AYQBnAGUAcgBEAG8AYwBrAAAAABsAAAIPAAAAvgD///8AAAOPAAACDwAAAAQAAAAEAAAACAAAAAj8AAAAAQAAAAIAAAACAAAAFgBtAGEAaQBuAFQAbwBvAGwAQgBhAHIAAAAAAP////8AAAAAAAAAAAAAABwAcwBlAHMAcwBpAG8AbgBUAG8AbwBsAGIAYQByAAAAAAD/////AAAAAAAAAAA=
ToolBarsMovable=Disabled
[UiSettings]
ColorScheme=Sweet
According to this config, Konsole just ignores my settings. What can I do to fix that?
And you should see that in ~/.local/share/konsole/
Is it there or disappears when you restart Konsole?
AFAIK that should be
[UiSettings]
ColorScheme=
because you define that in the profile you just created, top line
[Appearance]
ColorScheme=Sweet
> ls ~/.local/share/konsole/
Sweet-Ambar-Blue.colorscheme  Sweet.colorscheme  Sweet-Mars.colorscheme
I didn’t write that profile, I used Konsole UI to create that. Problem is Konsole does not want to read profiles I created, instead it loads default profiles.
What you show there are .coloscheme files. I see no .profile in there.
The two highlighted are also in that folder on my end
Look at that, please
I don’t know how to explain this with words
Your video shows exactly what i asked, but only partially
Meaning, that with Dolphin opened inside your ~/.local/share/konsole/ see if when you create the profile, the file is written there, and if disappears by itself when closing Konsole.
On my end, each time i create a new_profile i get in that folder a file called new_profile.profile and remains there after i close Konsole, then i can tweak it later too.
Edit:
Found this that seems to be exactly what your issue is 458835 – Configuration files created with the create new profile button are not saved
And guess what? I managed to reproduce the issue on a VM install. If i create a New Profile and i click Apply, is in the ~/.local/share/konsole/ but once i Click OK it vanishes by itself.
Edit2:
Managed to reproduce on another install too, but i see no errors … A hacky way to overcome this issue, is to create a fake profile, running this command:
echo '[General]' > ~/.local/share/konsole/Empty.profile && echo 'Name=Empty' >> ~/.local/share/konsole/Empty.profile
Restart Konsole and then Edit/Rename/Tweak and save that profile with your settings, and make it Default.
This solution works perfectly, thanks!
