Hi
, i think i broke the terminal. I configured my konsole to start from /bin/fish , by adding /bin/fish in profile settings of the konsole. It worked well. After some time I added /bin/fish | lolcat to make it colorfull
. Now the konsole is not opening
. Idk
what to do.
Does it totally just not open? Or did you get an error or something?
Bruh you use a cancerous amount of emojis LMAO
No its not giving me any error one something like that . Its not opening.
What happens when you press Ctrl + Alt + T
The terminal window opened and it closed within 0.5 second
Go to ~/.local/konsole/, idenfify your default profile file (you can find name in ~/.config/konsolerc) and remove lolcat part from Command= line
You can try removing the config files of Konsole?
I tried this didnt work
. After that i removed both the file mentioned in this and it worked
. Thanks guys you guys are amazing
It worked
After deleting the config files and all terminal revert back to deafult settings after restarting terminal even if i change the profiles bruh
Iβm confused, can you rephrase? Do you mean that your settings donβt save?
If i goto konsole settings > Edit current profile > appearance and change breeze ( deafult konsole color scheme ) to something else , the konsole theme changes at that time. But is i close and reopen the konsole the colour scheme changes to breeze
Oh it fixed. Default [ Read Only ] was selected as default profile . I created a new profile and changed the colour scheme in that new profile , then i made the new profile default
